Computer help
I received the Apple Keyboard. Can we work on it this Friday or weekend? or even tomorrow night? I have a headache.
can you give me some of the prompts to try or should I scroll back and try to repeat a bunch of the prior ones with the key board plugged in?
Firs thing is do you have all the data you needed off the mac.
If yes
with keyboard plugged in and wireless keyboard turned off.
Turn mac on whilst holding - Keep holding until you see something.
  • Command-R: Start up from the built-in macOS Recovery System. Use this key combination to re-install the latest macOS that was installed on your system or to use the other apps in macOS Recovery.
This should give you a recovery screen similar to this. Your one won't say Sonoma.
It will be El Captain or High Sierra
If you get that screen choose the Reinstall mac os and click continue.
If the above does not work.
Power off
Start holding
  • Option-Command-R: Start up from macOS Recovery over the internet. Use this key combination to re-install macOS and upgrade to the latest version of macOS that’s compatible with your Mac.
I am going to try plugging this in here soon and trying this if you are around later. standby...
Omg! I finally got something different!!!
It's going slow as molasses.
Will update. Also I will be bumming around for day, probably tomorrow too
Ok, got this! Completely different than anything we had before
I think you want me to reinstall X, 2nd option down?
I will wait a bit to see what you say
Yes, I am happy with the files you helped me recover. Shouldn't be anything on there that I didn't get on that other drive we got
Try this
If your Mac is formatted with Mac OS Extended, you need to enable journaling on it before installing macOS.
Go back to Disk Utility, select your startup disk, and click File > Enable Journaling from the menu bar.
After that, you should be able to reinstall macOS.
how do I go back to the disk utility or where do I find that?
I forget if I have a password, I think I do
Now it's doing something. Globe is finally spinning
There is an internal clicking noise???
