  • jxdama
    • Dec 2022
    • 660
    #91
    Also, walmart told me the all in one’s dont have a direct cable connection, you have to have wifi. Best buy says they do have a cable connection.
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      #92
      Originally posted by jxdama
      The only way i know how to do it is take a picture of it on my phone then send it to your email
      How are you going to email it
      You said your phone will not email.
      What is the make and model of your current computer
      • jxdama
        • Dec 2022
        • 660
        #93
        I assumed all i had to do was enter an emial address like you enter a phone num but for some reason they make sending an email complicated. Compaq presario PC.
        • PeterOz
          • Mar 2021
          • 4181
          #94
          Compaq presario PC.
          They make a lot of different models
          • jxdama
            • Dec 2022
            • 660
            #95
            It says windows vista home premium and intel premium dual core
            • PeterOz
              • Mar 2021
              • 4181
              #96
              If you cannot find a model number
              can you find any of these numbers serial numbers, service tags or asset tags
              • jxdama
                • Dec 2022
                • 660
                #97
                I will need a magnifying glass. Let me see if i can find it.
                • jxdama
                  • Dec 2022
                  • 660
                  #98
                  SR5350F is on the front
                  • jxdama
                    • Dec 2022
                    • 660
                    #99
                    CNH7470RS1
                    • PeterOz
                      • Mar 2021
                      • 4181
                      #100
                      No pics on hp website
                      1. Is this an all in one computer or a separate box and Monitor.
                      2. When you replace it do you want to replace it with an all in one or a separate box and monitor
                      • jxdama
                        • Dec 2022
                        • 660
                        #101
                        Its a separate box and monitor. I dont care one way or the other as long as i can still connect the cord from the modem to the computer and not have wifi. The all in one sounds easy to install since i assume i just leave the cable coming from the ground hooked into the modem and then unplug the ethernet cable from my comp now and put it in the other computer and i dont have to connect the mouse, keyboard or speakers because they are already in the comp.
                        • PeterOz
                          • Mar 2021
                          • 4181
                          #102
                          No all in one means the computer box and monitor are in one box.
                          You still need to connect all the other stuff.
                          You could get an all in one that has speakers and use a wireless keyboard and mouse
                          • jxdama
                            • Dec 2022
                            • 660
                            #103
                            [IMG alt="images" width="140px" height="140px"]https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcSXUTW-JbLC0V0DsC_nAcIUhI69qqmaLsarryB2EKE_OZlnnWbfb16xJO pl6w&s[/IMG]
                            That looks very similar to what i have
                            • jxdama
                              • Dec 2022
                              • 660
                              #104
                              I think all the ones at best buy had a wireless mouse and keyboard. Which is better and easier to install? All in one or like i have now?
                              • jxdama
                                • Dec 2022
                                • 660
                                #105
                                That might be the exact one i have.
