  • jxdama
    • Dec 2022
    • 660
    #121
    @My comp is almost 14 years old
    • jxdama
      • Dec 2022
      • 660
      #122
      Lets see if the K Meleon browser will work. I was reading about the upgrade to windows10 and that seems complicated.
        #123
        as Peter has said, I’d be going to Windows 10.
        you’ll get a current, supported OS, with all current browsers supported as well.
        I’d be backing up my data, and if you like, upgrading my hard drive to a solid state drive if it hasn’t already got one.
        since you’d be reloading Windows, may as well do that to a new, fast drive. that give the old gal a new lease on life.
        • PeterOz
          PCHF Technical Response Team
          • Mar 2021
          • 4181
          #124
          First things first.
          Let’s see if you can get your bookmarks saved from firefox.
          If this works we will do the same for passwords and history.
          [ATTACH type=β€œfull”]12019[/ATTACH][ATTACH type=β€œfull”]12020[/ATTACH][ATTACH type=β€œfull”]12021[/ATTACH][ATTACH type=β€œfull”]12022[/ATTACH]
          • jxdama
            • Dec 2022
            • 660
            #125
            Originally posted by PeterOz
            First things first.
            [ATTACH type=β€œfull” alt=β€œFF Bookmarks 1.png”]12019[/ATTACH][ATTACH type=β€œfull” alt=β€œFF Bookmarks 2.png”]12020[/ATTACH][ATTACH type=β€œfull” alt=β€œFF Bookmarks 3.png”]12021[/ATTACH][ATTACH type=β€œfull” alt=β€œFF Bookmarks 4.png”]12022[/ATTACH]
            I think the bookmarks are saved. I now have an icon with a firefox logo on my start up page.
            • jxdama
              • Dec 2022
              • 660
              #126
              Will be headed to bed, and thanks
              • PeterOz
                • Mar 2021
                • 4181
                #127
                good
                Passwords and history to follow later
                • PeterOz
                  • Mar 2021
                  • 4181
                  #128
                  Not a prob.
                  I will post
                  1. how to download and install 7Zip
                  2. how to extract the K-melon and run.
                    If you are successful try your bank with k-melon
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #129
                    Go to this site and download 7-Zip Click on me
                    [ATTACH type=β€œfull”]12025[/ATTACH][ATTACH type=β€œfull”]12026[/ATTACH][ATTACH type=β€œfull”]12027[/ATTACH]
                    This should now give 7-Zip as an option with the mouse right click menu
                    • jxdama
                      • Dec 2022
                      • 660
                      #130
                      2 problems. When i click on the windowsx64 thing it wont work and says i need windows x86. I go down 1 line to windowsx86 and it downloads. I downloaded the 7zip thing but then when i go to your next step all i get is a website with instructions, this:
                      How to open 7Z files
                      [ol]
                      [li]Save the .7z file to the desktop. If your compressed file was downloaded from a website, it may be saved in the…[/li][li]Launch WinZip from your start menu or Desktop shortcut. Open the compressed file by clicking File > Open. If your system…[/li][li]Select all the files and folders inside the compressed file. Or multi-select only the files or folders you want to open…[/li][li]Click 1-click Unzip and choose Unzip to PC or Cloud in the WinZip toolbar under the Unzip/Share tab.[/li][li]Choose the destination folder to place t…[/li][/ol]
                      would it be easier just to get a new computer?
                      • jxdama
                        • Dec 2022
                        • 660
                        #131
                        I cant see step num 2 even come up, open with 7-zip
                        • jxdama
                          • Dec 2022
                          • 660
                          #132
                          [ATTACH type=β€œfull”]12034[/ATTACH]
                          That is what i have. what do i click next? and remember i clicked on wondowsx86, not windowsx64
                          • jxdama
                            • Dec 2022
                            • 660
                            #133
                            Is this where i go?
                            [ATTACH type=β€œfull”]12036[/ATTACH]
                            • jxdama
                              • Dec 2022
                              • 660
                              #134
                              this is it?
                              • jxdama
                                • Dec 2022
                                • 660
                                #135
                                I got it downloaded and put in the problem sites and its doing the same things chrome and firefox is doing. Thanks so much for taking the time to help with the k-meleon. Im proud of myself for getting it to work. Is the best option now to just get a new comp?
