  • jxdama
    • Dec 2022
    • 660
    #46
    Originally posted by xrobwx71
    If you get a new computer, The AV that comes with it is the best to use. You won’t need a 3rd party AV.
    Do you know of any computer repair shops that are locally owned? This would be better than Best Buy.
    Also, if you have a High School or local Technical College, they may have a co-op programs that will allow computer students to do the work you need at a fraction of the cost.
    Doesnt the AV that comes with it cost a monthly fee? I went to best buy and they want $200 to set it up and back up my bookmarks. I was looking at an all in 1 comp that is 699. The back is totally different from my tower comp. Do i still take the cable from the ground and hook it into the modem, then take another line from the modem to the back of the all in 1?
    • jxdama
      • Dec 2022
      • 660
      #47
      OH, they are also a month behind so the earliest they could come out is june 18
      • Rustys
        • 7862
        #48
        Originally posted by jxdama
        Is there a link that will actually download it? If i get a new comp will all these issues be solved?
        Yes
        • xrobwx71
          • Mar 2023
          • 1066
          #49
          Not Windows Defender, its integrated into the Operating System, works as good as any 3rd party, take very few resources.
          • jxdama
            • Dec 2022
            • 660
            #50
            The man at best buy said you cant back up bookmarks to a disk and put it in the new firefox because they dont have discs anymore
            • jxdama
              • Dec 2022
              • 660
              #51
              Delete any other AV?
              • Rustys
                • 7862
                #52
                Thumb drive (USB Drives) you can back them up to that.
                Basically yes
                • jxdama
                  • Dec 2022
                  • 660
                  #53
                  Basically yes
                  Im sorry for being stupid, but i dont know what USB drive is or how in the heck i can get my bookmarks and passwords into a USB
                  • Rustys
                    • 7862
                    #54
                    Will have to switch system so can provide proper instructions so there will be a time delay.
                    We all started someplace no worries there.
                    • jxdama
                      • Dec 2022
                      • 660
                      #55
                      I found a place in troubleshooting info and somehow made a profile that says john but it didnt do anything that i know of. There was nothing to click on or save or send anywhere.
                      • Rustys
                        • 7862
                        #56
                        Just to confirm that we are going to be getting the bookmarks form Firefox correct?
                        Do you know what version that you are using?
                        • jxdama
                          • Dec 2022
                          • 660
                          #57
                          This is what it says
                          Profile: john
                          Default Profile no
                          Root Directory C:\Users\John\AppData\Roaming\Mozilla\Firefox\Prof iles\4qmfcrzj.john
                          Local Directory C:\Users\John\AppData\Local\Mozilla\Firefox\Profil es\4qmfcrzj.john
                          under it in 4 separate boxes it has Rename, Remove, Set as default profile, and Launch profile in new driver
                          • jxdama
                            • Dec 2022
                            • 660
                            #58
                            yes, and all the passwords to go with them
                            • Rustys
                              • 7862
                              #59
                              Backup for Bookmarks please feel free to ask if you get confused or any issue arises.
                              With Firefox open in the upper right, you will see 3 horizontal bars select that.
                              Look down the list and select bookmarks.
                              on the very bottom you will see Manage Bookmarks click Manage Bookmarks.
                              You should now be at the following window
                              [HEADING=1][ATTACH type=β€œfull” alt=β€œScreenshot_20230517_103159.png”]11999[/ATTACH][/HEADING]
                              Where it shows Import and Backup top middle click that
                              From that menu select Export Bookmarks to HTML
                              This will bring up the save window.
                              Select Desktop from the far left then select Save in the lower right.
                              Close out everything to the desktop and you should see a file named Bookmarks.
                              • jxdama
                                • Dec 2022
                                • 660
                                #60
                                I clicked on the 3 bars. there is nothing that says bookmarks or favorites
