On the desktop the bookmarks when you open that is shows the bookmarks correct.
Yes, and they all pop up in Chrome for some reason. Also, i have now completed putting them into emails to myself but i have to write down the passwords and usernames though luckily i use the same for every site unless i have to change itOriginally posted by RustysOn the desktop the bookmarks when you open that is shows the bookmarks correct.Comment
I think this is the one though there is one for 399 but the guy said its very slow. I sort of want to get what i have now. Im worried i wont be able to figure out how to hook up an all in one.Originally posted by RustysWhat you really need to do is get off this system and get a newer one before your identity get stolen.
What are all in ones that you were looking at.
I was going to go and get one today but i wanted to see if the K meleon would work. They had a regular comp for 369 but then i have to buy the monitor separate. What speed comp do i need to get? 4g, 6g, 8g? I dont think ican get there till monday now.Originally posted by RustysWhat you really need to do is get off this system and get a newer one before your identity get stolen.
What are all in ones that you were looking at.Comment
Im just so worried. I have to have one with an ethernet connection. Right now the cable from the ground goes directly into my modem and then a separte cable goees from the modem to the computer. Will the cable i have now going from the modem to the comp fit the new comp? If not does that mean i cant get a new comp? The woman at walmart told me the comp doesnt come with a cable from the modem to the comp.Comment
WHYOriginally posted by jxdamaIm just so worried.
You need to slow down. You are posting question after question without giving anyone time to reply.
I personally do not like all in one computers. I find they are always slow. I have never seen one that performs well.
The person selling it even said that model is slow.
Do you mean like yours is, not an all in one just a box.Originally posted by jxdamaThey had a regular comp
No, you should be able to use your current monitor. You must have missed before when I asked for the make and model of your monitor.Originally posted by jxdamabut then i have to buy the monitor separate.
This has nothing to do with computer speeds - more like wifi speeds - not needed in your case.Originally posted by jxdamaWhat speed comp do i need to get? 4g, 6g, 8g
As above I think normal computer is better than an all in one. Just my opinion.Originally posted by jxdamaIs a regular comp as good as an all in one? Can even a person like me get it going
Yes, the size of the connection plug has not changed.Originally posted by jxdamaWill the cable i have now going from the modem to the comp fit the new comp
it might only take 10 mins. HoweverOriginally posted by jxdamaIf someone could help me it would probably take 10 minutes.
We all try and help as soon as we can. This is a site where we all volunteer our time and most of us have work and family commitments.
So you can get a hand picking a new computer the big question is what is your budgetComment
They said the 699 one was fast and the 399 one is slow. They told me i couldnt use my monitor because its not a flat screen but i am sure you are right. Thanks about the plug. I meant it would take 10 minute to hook it up if someone were here at my house to help. Yall do an awesome job and if i can i will happy to donate. i agree, i think something like i have might be best.Originally posted by PeterOzWHY
And this
And thisOriginally posted by PeterOzSo you can get a hand picking a new computer the big question is what is your budget
Originally posted by PeterOzYou must have missed before when I asked for the make and model of your monitor.Comment
