  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #241
    You do not need gmail
    use aol
    Originally posted by jxdama
    Im still debating if i should try and find someone to be here with me. Im terrified
    Do you have room and powerpoints to connect new and old computer and have on at the same time?
    • jxdama
      • Dec 2022
      • 660
      #242
      use aol
      no i can use flip phone but it is slow and tiny. This is from flip phone
      • jxdama
        • Dec 2022
        • 660
        #243
        The last 2 days i called and left a message for this mobile computer repair place to see if they would come and help but they never returned my calls.
        • PeterOz
          • Mar 2021
          • 4181
          #244
          Do you have a neighbour or friend who can come in
          or your daughter
          • PeterOz
            • Mar 2021
            • 4181
            #245
            You should not need this.
            Have you connected the parts as my pic?
            • jxdama
              • Dec 2022
              • 660
              #246
              or your daughter
              Sadly, my daughter is in TX, the friend i had that set up my comp 13 years ago is dead, and my neighbors wont be of any help. I have some things connected except the the things i will need to first disconnect the old comp. Another Q, is that little button on the top right the thing i push to turn it on? Will a light come on to say its on?
              • PeterOz
                • Mar 2021
                • 4181
                #247
                yes
                Cant tell from the pic
                Is there any spare spot on the power board
                • jxdama
                  • Dec 2022
                  • 660
                  #248
                  yes
                  Power board? The front of the comp? Another Q, the cable that goes from the monitor to the comp looks exactly the same on both ends. Does it matter which end goes where?
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #249
                    Power board?
                    I thought you were connected to a powerboard
                    cable is the same just plug in
                    • jxdama
                      • Dec 2022
                      • 660
                      #250
                      Do you mean the surge protector? There are 2 spots available on that.
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #251
                        Can you plug the new compter into one and the monitor into the other?
                        If possible connect the new computer into the surge protector
                        Plug the monitor into the surge protector
                        Turn on
                        When it gets to the setup network part
                        Just disconnect the network cable from the old and connect to the new.
                        NO NEED TO POWER EITHER OF THEM OFF
                        would this be possible for a temp solution?
                        • jxdama
                          • Dec 2022
                          • 660
                          #252
                          Turn on
                          Are you saying leave my old comp on until the internet connection is needed on the new one? Its possible to do. One thing is its hard for me to move around quickly and get down on the floor alot to make all these connections. Would you be mad if we wait 1 more day so i can try and find someone to asist? If not i will rest up tomorrow as much as possible and 1 way or another i will get this done tomorrow. I can temporarily put the new comp on the floor and let it run and leave the old comp monitor on the desk until everything is done.
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #253
                            Not at all
                            Take your time I am in no hurry
                            If you can find an able body to help that is fine.
                            Take as long as you need.
                            If you have someone to help then have them connect power and network to new computer and switch on.
                            If something is not looking right they can connect the network cable back to the old one for you.
                            And you are back online.
                            Correct
                            Once windows is loaded to the desktop screen shut it down and move old out new in
                            Take your time.
                            Just remember when it gets to the Let’s connect to the network stage just swap the network cable over from the back of the old
                            to the new. No need to power off the old or the new.
                            Network cables can be switched when computers are powered on
                            • jxdama
                              • Dec 2022
                              • 660
                              #254
                              Not at all
                              Correct
                              Take your time.
                              Thanks so much for your help. About how long does it take for the new comp to completely load?
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #255
                                Do not know
                                I have not bought a new comp in the past 18 odd years
                                My guess is 1/2 to 1 hour.
                                I know one person who says he can reload in 10mins but it all depends on the computer itself.
