I did find this in History in the top left toolbar. When i click on import and back up it brings it all up
Lets see if this work
Press the following keys at the same time and see if that gets us to the screen shot I posted.
Ctrl + Shift + O
What version of Firefox are you using.
Across the top of Firefox is there File, Edit, β¦ is there one called Bookmark there?
How do you access your bookmarks in Firefox?
This will give me a better idea it the above action do not work.Comment
I found the screens you are talking about in History in the top left toolbarOriginally posted by RustysLets see if this work
Ctrl + Shift + O
the history is just a list of sites that you have been to and will not accomplish what you are wonting to accomplish.
can you post a screen shot of this so we can be on the same page.Originally posted by jxdamawhen i click on desktop on the top left it still says bookmarks in file name and HTML files in save as on the bottomComment
Im going to have to leave in a few minutes till i return this evening. Thanks for your help so far. I still have another question. If I get that all in one comp do i still take the cable from under the house and plug it in the modem like it is now, then take the other cable from the modem and plug it into the comp? Where do i plug the new comp into a power supply? I didnt see where the power cord goes to.Comment
Due to the policy cannot communicate via email.
On your keyboard there is a key that may look similar to.
[ATTACH type=βfullβ]12004[/ATTACH] [ATTACH type=βfullβ]12005[/ATTACH]
With the screen that is open that you which to post press that key one then in the text box for this tread press the Ctrl + V to paste the image.Comment
