  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #406
    Originally posted by jxdama
    ok, now it says type here to search. it has some icons and in the upper right it saysrecyle bin and under that microsoft edge
    That is the new windows 11 desktop
    I guess now i put in the ehternet?
    Yes
    Let’s see what happens
    • jxdama
      • Dec 2022
      • 660
      #407
      I meant upper left, lol
      • jxdama
        • Dec 2022
        • 660
        #408
        Yes
        If it works hit edge and see if i can bring up your site?
        • PeterOz
          • Mar 2021
          • 4181
          #409
          Yes
          • jxdama
            • Dec 2022
            • 660
            #410
            sorry, servers ip address can not be found. i typed in several sites and nothing
            • PeterOz
              • Mar 2021
              • 4181
              #411
              Did you disconnect the cable from the old computer and plug into the new?
              Because this site was showing you were still online.
              • jxdama
                • Dec 2022
                • 660
                #412
                Yes, but i can try again if you want. The first time i unplugged th modem and stuck that in by mistake then i plugged it in right, but i can retry
                • jxdama
                  • Dec 2022
                  • 660
                  #413
                  I dont understand why my old comp connects but this one wont. It cant be the cable since it works in the old comp, . It plugs in right next to the mouse and keyboard plug in right?
                  • jxdama
                    • Dec 2022
                    • 660
                    #414
                    I tried again and nothing
                    • PeterOz
                      • Mar 2021
                      • 4181
                      #415
                      Yes only one place it can go
                      You may have to
                      Unplug from old computer
                      plug into new computer
                      reboot new computer
                      Test internet.
                      If no good
                      Shutdown computer
                      Unplug power to modem
                      Wait 30 sec
                      Turn modem back on
                      When light on modem shows internet - go green
                      Can take 5 mins
                      Start pc after it is connected
                      Test
                      [ATTACH type=β€œfull” alt=β€œcm8200 internet connected.JPG”]12101[/ATTACH]
                      • jxdama
                        • Dec 2022
                        • 660
                        #416
                        put the ethernet cable back in the new comp and do the steps?
                        • jxdama
                          • Dec 2022
                          • 660
                          #417
                          reboot, just turn it off and back on with the button or do alt/cntrl,del?
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #418
                            [ol]
                            [li]Open the Start menu.[/li][li]Click the Power icon.[/li][li]Click Restart.[/li][/ol]
                            • PeterOz
                              • Mar 2021
                              • 4181
                              #419
                              Yes
                              Make sure it is from modem to computer
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #420
                                Just take the cable out fro the back of old computer
