  • jxdama
    • Dec 2022
    • 660
    #361
    Originally posted by PeterOz
    So you have the black cmd screen
    yes with a flashing cursor
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      #362
      LEAVE NETWORK CABLE OUT FOR NOW
      If you have the cmd screen
      Type in
      OOBE\BYPASSNRO
      then press enter. In this cmd they are the letter O not the number zero
      The computer will reboot
      It will ask you for the country region
      and keyboard again
      It should then give you the option below
      [ATTACH type=β€œfull” alt=β€œWin 11 No internet.JPG”]12099[/ATTACH]
      [ATTACH type=β€œfull” alt=β€œWin 11 Continue with limited setup.JPG”]12100[/ATTACH]
      • jxdama
        • Dec 2022
        • 660
        #363
        Type in
        OOBE\BYPASSNRO
        and keyboard again
        ok and thanks
        • jxdama
          • Dec 2022
          • 660
          #364
          Before i do it should it be in caps like you have?
          • PeterOz
            • Mar 2021
            • 4181
            #365
            No matter
            • jxdama
              • Dec 2022
              • 660
              #366
              I cant find a slash that goes in that direction
              • PeterOz
                • Mar 2021
                • 4181
                #367
                Caps just makes it look more like the letter O
                Easy to read on internet
                • PeterOz
                  • Mar 2021
                  • 4181
                  #368
                  Maybe above the enter key
                  can you see it on other kb
                  If it is till plugged in you can mix between both
                  • jxdama
                    • Dec 2022
                    • 660
                    #369
                    the letters wont work. nothing happens when i type thme
                    • jxdama
                      • Dec 2022
                      • 660
                      #370
                      the letters dont work on either keyboard
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #371
                        Click in the black screen
                        • jxdama
                          • Dec 2022
                          • 660
                          #372
                          i got it, i had to put the cursor there
                          • jxdama
                            • Dec 2022
                            • 660
                            #373
                            I think its rebooting
                            • jxdama
                              • Dec 2022
                              • 660
                              #374
                              Type in
                              OOBE\BYPASSNRO
                              and keyboard again
                              The first half of the screen comes up, not the 2nd part. β€œi dont have internet” is clickable. should i put the network cable back in?
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #375
                                No
                                just click on I do not have internet
                                I will say when to connect back in
