wHat does when light on modem shows int go greem mean
Well done I knew you could do it.
I think you need a rest.
You can leave it on.
I donβt know if your monitor is set to turn off
It should go off after about 10 mins
Donβt forget in the morning that the comp is on
Just move the mouse to wake it up.
When you want to shut down to move it to itβs new place
[ol]
[li]Open the Start menu.[/li][li]Click the Power icon.[/li][li]Click Shutdown[/li][/ol]
I have work in the morning but will be on line before I go.Comment
thanks, and i can reward you if needed.Originally posted by PeterOzWell done I knew you could do it.
[ol]
