Originally posted by PeterOz
Is 14 years old for a computer? I will just be happy when i will no longer be getting βcant connect because your browser is not updatedβ messages. And the problems with logging in, and the constant messages saying a script is slowing things down, and on and on, lol -
A couple more questions before i try and get this running tonight. The keyboard doesnt have any lights like mine does. No green light for the num, caps or scroll key. How do i even know if the keyboard is working? My keyboard now has a round connection and this one is square so it wont fit. I bought one at walamrt and the woman said it will fit my comp. It has lights. Can i use the walmart one instead. Also, there isnt a light for the monitor. How do i know if it is working? Also, there is no diagram provided. Which button turns it on or off? It has to be on when i start the comp., And, i might have forgotten but does it ask me to set up the anti-virus when i turn it on and it loads, and i should say no?Comment
It could have lights you just might see them until the power is on.Originally posted by jxdamaThe keyboard doesnt have any lights like mine does.
Keep the packaging for the walmart one - you may be able to return it.
You really should have asked first.-Save money.
If the one that came with the computer does not have lights we could have got an adapter for your old one for about $2.00
It depends on how it was setup by HPOriginally posted by jxdamai might have forgotten but does it ask me to set up the anti-virus when i turn it on and it loads, and i should say no?
Do not stress about it.
If it pops up and ask you to run it say no.
Do you have your log in details - username and password written down for PCHelp forum ( Do NOT Post them here) so you can log in on the new computerComment
I just received a computer - Not as much ram as yours and windows 10Originally posted by jxdamaAbout how long does it take for the new comp to completely load?
so yours should be faster.
Unbox - connect network monitor keyboard mouse and power on
Loads windows 10
18minsComment
So i should use the keyboard that came with the comp? I guess im worried because what if the comp starts to load but the keyboard isnt working and i have no idea because of no lights. Also, will i need the speakers to be working. Finally, all i need to be plugged in is the monitor and comp, ? right? The speakers and modem are already plugged in. Anything else i need to know? all thats left is to plug the comp in the surge pro and transfer the ethernet cable. im going to go ahead and plug that in when i turn the new comp on and use my phone if i need you.Originally posted by PeterOzIt could have lights you just might see them until the power is on.
You are causing yourself more worry then needed.Originally posted by jxdamaI guess im worried because what if the comp starts to load but the keyboard isnt working and i have no idea because of no lights
If it makes you more secure, to start with you can plug both keyboards into any of the front usb ports.
YES you can have 2 keyboards connected at once.
When all is being moved to final place then connect the keyboard you want.
Speakers can wait until new comp is in itβs final place.
Not needed for setup.
If you like the feel of your old keyboard you can look local for on of these.
Click On MeComment
