  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #391
    hit next
    • PeterOz
      • Mar 2021
      • 4181
      #392
      will probably fail
      no X in top right hand corner?
      • PeterOz
        • Mar 2021
        • 4181
        #393
        Don’t post it here
        Do you have your username and password for this site
        written down
        or do you know them
        • jxdama
          • Dec 2022
          • 660
          #394
          Originally posted by PeterOz
          will probably fail
          no, fail doesnt sound good, but hit next?
          • jxdama
            • Dec 2022
            • 660
            #395
            Don’t post it here
            written down
            or do you know them
            pchelpforum? Yes, i have all my passwords written down though i probaly missed a few. but the previous thing, fill it out and hit next
            • PeterOz
              • Mar 2021
              • 4181
              #396
              You can’t close the form?
              no X
              Of fill out and next
              Not a problem
              • jxdama
                • Dec 2022
                • 660
                #397
                there is a back arrow in the upper left, but no x in the upper right
                • PeterOz
                  • Mar 2021
                  • 4181
                  #398
                  Just fill out and see what happens
                  • jxdama
                    • Dec 2022
                    • 660
                    #399
                    It says register is optional, but no X
                    • jxdama
                      • Dec 2022
                      • 660
                      #400
                      now it comes up with 3 things about HP using my info for various reasons. the 3 boxes are check marked but i can click away the check mark and make the boxes empty
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #401
                        Do that
                        There should be some kind of escape
                        Keep going and see what happens
                        • jxdama
                          • Dec 2022
                          • 660
                          #402
                          now it says hi, getting things ready for you. might take a few minutes
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #403
                            you should see windows desktop soon
                            • jxdama
                              • Dec 2022
                              • 660
                              #404
                              ok, now it says type here to search. it has some icons and in the upper right it saysrecyle bin and under that microsoft edge
                              • jxdama
                                • Dec 2022
                                • 660
                                #405
                                I guess now i put in the ehternet? Is the type here to search where i put in the pchelpforum address or do i need to hit edge
