  • xrobwx71
    • Mar 2023
    • 1066
    #226
    Originally posted by PeterOz
    Also the computer will come with 6mths anti virus protection from McAfee or Nortons
    DO NOT set this up we will delete them.
    Windows comes with its own protection which is now better than the bought ones.
    :love:
    • jxdama
      • Dec 2022
      • 660
      #227
      Yes
      No I set one up tooooooooo long ago to remember.
      It will be a basic sign in with a current email - from anyone. Or setup a new microsoft email
      Mobile Phone number - for account recovery incase you lose your password.
      However, we can set it to a local account once you have logged in for the first time.
      Will aol work? Its the only email i have. I just have this bad feeling something will go wrong. Why cant it just be turn it on and it works, like a tv. You said dont set up the anti-virus. Will it ask me to when i turn it on?
      • jxdama
        • Dec 2022
        • 660
        #228
        Will my modem work with the new comp?
        • jxdama
          • Dec 2022
          • 660
          #229
          I think i put the stand on right but this monitor isnt adjustable like mine now. Can i go and buy a monitor from walmart that adjusts and will fit the comp? It must be able to adjust.
          • jxdama
            • Dec 2022
            • 660
            #230
            I want it to slant up some but it wont budge and im afraid if i put too much pressure on it, it will break.
            • jxdama
              • Dec 2022
              • 660
              #231
              I put it together wrong or something and now i cant get it back apart.
              • PeterOz
                PCHF Technical Response Team
                • Mar 2021
                • 4181
                #232
                Yes
                if you must you can return the monitor to best buy and ask for a different model.
                From what I can see the monitor will tilt back and forth but not up and down.
                I have only seen 1 monitor that will slide up and down - Dell and it does not tilt.
                You can use your current monitor and return the new one to best buy for a refund.
                Your old monitor plugs into the blue port above the current monitor.
                I doubt it they basically can only go one way
                have a look at the pic in post#207 Click on me
                • PeterOz
                  • Mar 2021
                  • 4181
                  #233
                  Take a deep breath and do not panic.
                  All will be fine.
                  [ATTACH type=β€œfull”]12051[/ATTACH]
                  [ATTACH type=β€œfull”]12052[/ATTACH]
                  • jxdama
                    • Dec 2022
                    • 660
                    #234
                    Thanks, I got the monitor to work, It seems i had the connection pushed in too far and it wouldnt move. I think ive figured out how to hook things up
                    • jxdama
                      • Dec 2022
                      • 660
                      #235
                      2 more Q’s. Will AOL email work for an account and is it going to ask me to set up the anti-virus and should i say no?
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #236
                        Should do yes
                        Should not ask until you log in - If it does not ask do not worry for now.
                        Windows built in protection will be working.
                        Did you get the new monitor to tilt?
                        • jxdama
                          • Dec 2022
                          • 660
                          #237
                          Should do yes
                          Yes i did
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #238
                            Just saw this.
                            Time to go for it
                            • jxdama
                              • Dec 2022
                              • 660
                              #239
                              The thing is about that Gmail thing is i have a gmail account it seems, ( email deleted for privacy reasons ) but when i sent an email to that address it doesnt go anywhere. The email is sent, AOL doesnt say there was an error, but i cant find anyplace that has a log of emails like AOL does. You click on AOL mail and you can see new emails, old emails, spam emails and deleted. If i have to put in a gmail and it says they are sending me an activation code i wont be able to get the code.
                              • jxdama
                                • Dec 2022
                                • 660
                                #240
                                Just saw this.
                                Time to go for it
                                Im still debating if i should try and find someone to be here with me. Im terrified
