Originally posted by PeterOz
A couple of issues I am hoping for some help with
This topic is closed.
Also when you set the BIOS you set it as
[ol]
[li]Depending on your board, do one of the following: Go to the Configuration > SATA Drives menu, set Configure SATA to IDE. Go to the Advanced > Drive Configuration menu, set ATA/IDE Mode to Native.[/li][/ol]Comment
I had someone send me another copy of Win Xp that they say they know is good. I am uninstalling the one I have and going to try this one and see if the luck is any better. If not, then I am at a loss. I can’t find my thumbdrive, so I will need to get another. But I may just try what you have here with another blank cd. I hate to keep using them, but my primary objective at this point is just to get this PC working.Comment
I don’t think I have done this. So I will try it too.Originally posted by PeterOzAlso when you set the BIOS you set it as
[ol]
I didn’t have any options like this under configuration.Originally posted by TheMUBM
PeterOz:
[ol]
[li]Depending on your board, do one of the following: Go to the Configuration > SATA Drives menu, set Configure SATA to IDE. Go to the Advanced > Drive Configuration menu, set ATA/IDE Mode to Native[/li][/ol]Comment
Between graduate school and work I just didn’t have the time to keep working on it. I took it to the PC shop and he was able to get it going. It is working now. I appreciate all your time and help. I made a small donation (not near worth what you put into my issue) as a token of gratitude.Originally posted by PeterOzInstead of him looking at it Can he download the files to a usb and loan it to you
Thanks for all your effort.Comment
I don’t suppose he said what it was ?
I am thinking corrupt download Would be nice to know in-case some one else needs help, but if he did not say
I am sure they will be happy.
I am sorry I could not get you going,
Cheers
PeterOzComment
Thought you were part of the site so the donation would help. Sorry if I misunderstood. But nah all he said was he had to find very specific drivers and he was able to find them. Not sure where because I tried anything and everything.Originally posted by PeterOzI don’t suppose he said what it was ?
Cheers
PeterOzComment
You did the right thing with your donation - It helps the site to keep running - The helpers do it for free. So your Donation is very much appreciated.Originally posted by TheMUBMThought you were part of the site so the donation would help.
That’s why I am convinced it was a download/burn to disc issue.
The main thing is you are going.Comment
