X-86 based system family model 58 stepping 9 genuine intel ~2893 MHZ
A couple of issues I am hoping for some help with
This topic is closed.
When you installed the 32 bit did you reformat the drive or just load over top of the 64
Did you try the 64 drivers when you had 64 loaded.
Sorry this is taking so long. Just something not right somewhere I can’t put my finger on it yet.Comment
A couple of more things- are you using a usb now or still dvd. If dvd copy the 32 bit network driver to your desktop - will it run?
- If no click on start >Right click my computer >Left click Properties>Left Click Hardware Tab>Left click device manager
Left Click + sign next to IDE ATA/ATAPI controllers Right click Primary IDE channel>Left click Properties> Left Click Advanced settings
Make sure Transfer mode is set to DMA or DMA if available
Try the exe file again.
Pic attached
If the above does not work and you have a usb stick (to save dvd’s) Try this it is a zip file
Intel driver
Sorry for so many different post - Just try to give as much info as I can because of the time difference
Say if it is overwhelming.
Cheers
PeterOzComment
No biggie. I haven’t reached my wits end just yet. I will answer your other questions this evening when I get home and have time. I know a guy who runs a PC shop, he said he will look at it for if I can’t get it to work. I am going to try some more stuff before I break down and take it to him.Originally posted by PeterOzWhen you installed the 32 bit did you reformat the drive or just load over top of the 64
Well I used Darik’s boot and nuke to completely remove everything. Then started over from scratch with a fresh install, so I assume it reformatted. It does let me install some games, they just won’t play, which I assume has something to do with the lack of video drivers.Originally posted by PeterOzWhen you installed the 32 bit did you reformat the drive or just load over top of the 64
It all says DMA if available.Originally posted by PeterOzA couple of more things- are you using a usb now or still dvd. If dvd copy the 32 bit network driver to your desktop - will it run?
Pic attached
I will see if I can locate my thumbdrive at work today and try this, this evening.Originally posted by PeterOzIf the above does not work and you have a usb stick (to save dvd’s) Try this it is a zip file
Intel driver
Cheers
PeterOzComment
Correct
Do you know how to set the Bios ? Normally press F2 then set to defaults should be an option. Then F10 to save and exitOriginally posted by TheMUBMmedia not connected, check cable.Comment
