When I do a dxdiag, it says Optiplex 9010. I assume that is correct. Under device manager I don’t have anything that specifically says network. I have one that says ethernet controller, but when I hit properties it gives me no real information other than “driver not installed.”
A couple of issues I am hoping for some help with
This topic is closed.
Will do. It will take me a minute. I left my thumbdrive at work so I will need to use cd-r or DVD, so i am going to download all the possible drivers.Originally posted by PeterOzOk download both drivers only one will work. Look at my pic for settings that should work for your machineComment
Odd you did choose XP and not XP 64 bit.
That message normally means 64 instead of 32 or corrupt driver. is it an exe file or a zip file.
If zip then it has to unpack first.
I don’t want you to keep wasting dvd’s
Try this
If it has a yellow mark and no name then right click on the adapter>Left click on Properties >Details Tab.
Use the drop down box to show Device Description. If no name change the drop down to Hardware Id’s
What is listed?Comment
I think I may know part of my problem and I apologize for wasting your time. I wasn’t even thinking when I installed this WinXP and it being a 64 bit OS. The PC is a 32 bit system. I am going to uninstall XP and see if I can find a 32 bit version.Comment
