it seems to be working fine on my friends laptop, although he owns no games to test, music seems to be playing fine for him like it was for me.
PLEASE HELP MY AUDIO IS MESSING UP
Did you use the same speaker cable/s.
Have you tried headphones?
Have you tried both the front and rear audio ports on the computer.
Are you using a HDMI cable from the video card to your screen.
Some helpful tips here for you to check.
Last but not least, use your last system restore point that your created before you uninstalled the previous drivers.Comment
yes i used the same speaker cable/s.
yes headphones made no difference
yes both front and rear ports used
yes i have two monitors one has HDMI to the pc and the other is connected via DVI
I HAVE JUST HAD AN UPDATE i connected my Bluetooth earphones to the PC Bluetooth and the sound is working perfectly fine, I played a game and no static at all, however itβs annoying i cant use my speakers still ):Comment
Which confirms that the audio chip is still working and the drivers are good.
Do you get any audio from the HDMI monitor.
Can you upload a screenshot of the Volume mixer, you right click on the speaker icon on the taskbar and then select Open Volume mixer.Comment
no the monitor doesnβt have sound coming from it, only the speakers, Iβve put the speakers back to my PC and it worked for a few mins then it started going static, on the left side and then silent, then the right side followed. THIS picture is what you requested whilst a video is playing, thereβs no sound coming from the speakers just small fuzz/static now. [ATTACH type=βfullβ]5758[/ATTACH]Comment
i`m stumped tbh, I can only think that there is a problem with the internal speaker connection/s or something interfering with the audio chip
Long shot but when you next watch a video can you go into the Device Manager then Sound, Video and Game Controllers, what audio setting is shown to be the default, if it is HDMI audio it would explain the no audio coming through the speakers.
Did you happen to look at the information at the link in my reply #47, I don`t use any apps so have none to try allocating sound to for testing purposes.
There is a way around this if we are unable to find and correct the problem, a USB audio deviceComment
Also not sure if this is relevant but on dell support assist it has this: [ATTACH type=βfullβ]5762[/ATTACH]
also: this is what i see when i click on properties on AMD High Definition Audio Device and Realtek Audio [ATTACH type=βfullβ alt=βSVGC REALTEJ.pngβ]5760[/ATTACH] [ATTACH type=βfullβ alt=βNUMBA 2.pngβ]5761[/ATTACH]Comment
The HDMI is not interfering with things then so back to a loose connection or possibly the audio chip being affected by something.
Did you notice the installation dates for those drivers in your screenshots, almost three weeks ago, the unknown device could be your webcam.Comment
Did you try the speaker port on the front of the case to see if it sounds the same as the port your using for the speakers??
there is a speaker port on front and backComment
if itβs same both ports and PC has been reloaded not looking good, I guess you could hookup a USB sound cardOriginally posted by Madmatt2006Did you try the speaker port on the front of the case to see if it sounds the same as the port your using for the speakers??
there is a speaker port on front and backDone in reply #47 but no change and likewise made the suggestion in reply #51 Matt (y)Originally posted by Madmatt2006if itβs same both ports and PC has been reloaded not looking good, I guess you could hookup a USB sound cardComment
No worries, glad you now have audio and thank you for letting us know that you no longer required assistance (y)Comment
