Computer help
This topic is closed.
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #256
    Originally posted by mx_599
    I can click it but I can’t type in box that says untitled
    Not good
    As I have said before I think your disk has failed. Hence the clicking.
    If you look at it it says only 1.39GB
    Where as pic in post # 148 shows 2 Drives
    Top drive is Macintosh HDD
    • PeterOz
      • Mar 2021
      • 4181
      #257
      To confirm if the drive has gone south.
      Have you still got the Linux bootable usb stick?
      Do you have a spare usb stick?
      • mx_599
        • Nov 2024
        • 130
        #258
        yes i have linux stick
        • PeterOz
          • Mar 2021
          • 4181
          #259
          Do you remember how to boot off linux and see mac HDD
          We did it before
          • PeterOz
            • Mar 2021
            • 4181
            #260
            And this
            • PeterOz
              • Mar 2021
              • 4181
              #261
              Try this
              Stick your current ubuntu usb into the usb port on the mac
              hold down the option key and power on
              you should get 2 drives showing.
              use tab button to pick the usb - should be labelled as efi with a usb logo
              press return key
              it will then start to load.
              It might stop - just wait a couple of mins and see if it loads
              Click on the Ubuntu home icon
              click on other locations
              can you access the drive. - If not what is the error - take a pic
              • PeterOz
                • Mar 2021
                • 4181
                #262
                Any luck?
                • mx_599
                  • Nov 2024
                  • 130
                  #263
                  Did the same thing as before. I thought computer was off then just magically turned on. See photo. Do I still need to try to turn off? This is with the Ubuntu stick. Yes, I have bank USB too[ATTACH type=β€œfull” size=β€œ3024x4032”]15019[/ATTACH]
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #264
                    You need to see if you can access the mac drive like you did when we recovered the files.
                    You need to boot from ubuntu.
                    See above post # 261
                    That is why you need to hold the on button in for at least 20 secs
                    • mx_599
                      • Nov 2024
                      • 130
                      #265
                      I might have to sleep and pick this up tomorrow
                      so if bad HD, can I take apart and replace it with SSD?
                      also, I find this hard to believe? nothing bad ever happened. this all started because I accidentally hit update button. why would that ruin everything?
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #266
                        The fail could be because the HDD was failing and it could not finish.
                        • PeterOz
                          • Mar 2021
                          • 4181
                          #267
                          Catch you tomorrow.
                          YES
                          • mx_599
                            • Nov 2024
                            • 130
                            #268
                            I am getting so bummed out and frustrated. I was trying to get photo of all black screen with about 4 choices then disappeared before I could get pictures
                            Here is where it sits
                            [ATTACH type=β€œfull” size=β€œ3024x4032”]15033[/ATTACH]
                            • PeterOz
                              • Mar 2021
                              • 4181
                              #269
                              click cancel and see if it continues
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #270
                                Take a pic and post please.
