Computer help
This topic is closed.
  • mx_599
    • Nov 2024
    • 130
    #241
    yes it is in photo above
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      #242
      I mean do it.
      Click on disk 1 and run first aid
      • PeterOz
        • Mar 2021
        • 4181
        #243
        After first aid can you do the journal?
        • mx_599
          • Nov 2024
          • 130
          #244
          what do I click in photo to run first aid?
          • PeterOz
            • Mar 2021
            • 4181
            #245
            This
            • mx_599
              • Nov 2024
              • 130
              #246
              still not sure
              • PeterOz
                • Mar 2021
                • 4181
                #247
                About what?
                • mx_599
                  • Nov 2024
                  • 130
                  #248
                  see photo, don’t know how to run it. what do I click?
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #249
                    with disk 1 selected and first aid
                    Can you click on repair disk
                    Repair permissions
                    • mx_599
                      • Nov 2024
                      • 130
                      #250
                      they dont seem to be clickable
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #251
                        [ol]
                        [li]Are you able to do this?[/li][li]Click View > Show All Devices.[/li][li]Select the physical disk located at the top (named similarly to Apple SSD AP1234F Media) and click Erase. -Not the super drive[/li][IMG alt=β€œHow to reformat Mac startup disk”]https://iboysoft.com/images/en-news/...artup-disk.jpg
                        [li]Name the drive Macintosh HD.[/li][li]Choose OS Extended (Journaled).[/li][li]Keep the scheme GUID Parition Map.[/li][li]Click Erase.[/li][li]Close Disk Utility and return to the macOS Utilities window.[/li][li]Click β€œReinstall macOS” and follow the instructions on the screen to finish the installation.[/li][/ol]
                        *** NB DO NOT SELECT THE ORANGE DISK THAT IS THE RECOVERY***
                        https://iboysoft.com/tips/disk-is-locked-mac.html#:~:text=Solution%201%3A%20Unlock%20the%20 disk&text=If%20the%20message%20doesn’t,login%20pas sword%20to%20unlock%20it.
                        • mx_599
                          • Nov 2024
                          • 130
                          #252
                          You mean up in left corner?[ATTACH type=β€œfull” size=β€œ3024x4032”]15017[/ATTACH]
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #253
                            I am starting to think your drive may have collapsed.
                            See pic in post # 237 can you click on Disk 1 and click on erase?
                            • PeterOz
                              • Mar 2021
                              • 4181
                              #254
                              If you can click on erase
                              [ol]
                              [li]Name the drive Macintosh HD.[/li][li]Choose OS Extended (Journaled). for format[/li][li]Keep the scheme GUID Parition Map.[/li][li]Click Erase.[/li][li]Close Disk Utility and return to the macOS Utilities window.[/li][li]Click β€œReinstall macOS” and follow the instructions on the screen to finish the installation.[/li][/ol]
                              • mx_599
                                • Nov 2024
                                • 130
                                #255
                                I can click it but I can’t type in box that says untitled
