Computer help
This topic is closed.
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #226
    It looks like internet recovery
    What key combo did you use on the restart
    • mx_599
      • Nov 2024
      • 130
      #227
      is this good or bad?
      command R I think
      • mx_599
        • Nov 2024
        • 130
        #228
        should I interrupt it? looks like almost 1 hour and 40 min, timer is slowly counting down
        • PeterOz
          • Mar 2021
          • 4181
          #229
          Are you sure it was cmd R
          internet recovery is ok it just takes a while.
          You can try again or wait it out.
          If you try again and end up in the same place it will start from 0 again.
          CMD R should be local recovery
          CMD Shift R is internet recovery.
          Is it still clicking.
          • mx_599
            • Nov 2024
            • 130
            #230
            pretty sure command R, but it was weird, almost like the power button didn’t want to shut down. then screen was blank, but I wonder if it was command R from a point of not completely shut down?
            I was going to just leave it, time is jumping around just a little but at 1:10 now
            still a metronomic click most the time
            If you think might be ok I was going to step away for a bit and let it go
            • PeterOz
              • Mar 2021
              • 4181
              #231
              The only concern is the click. Not much you can do about it.
              Are you plugged into the internet via cable.
              You may as well let it run.
              • mx_599
                • Nov 2024
                • 130
                #232
                no cable, that would have been hard to do in my current state
                no clicking now, comes and goes. I assume a hard drive doing important things?
                under 1 hour
                seems to be progressing whatever it is doing
                I will be back in a little while if you’re still able to help today
                • PeterOz
                  • Mar 2021
                  • 4181
                  #233
                  I will be around
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #234
                    or dying
                    • mx_599
                      • Nov 2024
                      • 130
                      #235
                      Oh gosh, this screen again
                      Maybe just do what we were trying to before?
                      [ATTACH type=β€œfull” size=β€œ3024x4032”]15012[/ATTACH]
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #236
                        So now pick disk utility
                        Go back to Disk Utility, select your startup disk, and click File > Enable Journaling from the menu bar.
                        After that, you should be able to reinstall macOS.
                        • mx_599
                          • Nov 2024
                          • 130
                          #237
                          Which one do I pick on left? Disk1 or Mac or x base system?
                          Am I in right spot?
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #238
                            Click on disk 1
                            I am surprised it is not showing as Macintosh HD
                            Try it and see
                            • mx_599
                              • Nov 2024
                              • 130
                              #239
                              the enable journal button above in photo is not clickable?
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #240
                                I wonder if disk is fried.
                                Can you click on disk 1 and click on first aid?
