yes, that is what I want to do. Itβs just not something I can plug in quick to check. I donβt mean to drag this out. Just heavy computer and no space so every time I try something new I have to lift it to temporary space and try stuff then stow it back away. I am not trying to be a pain, I am steadfastly pushing forward. You guys would have had this all squared away in 15 minutes!!
I got the computer hooked up again and trying to do the command and R button but not doing anything. However, I am not convinced it is not me doing something wrong? I donβt understand if I and pressing at the right moment. I feel like I am playing a video game and I was never good at those either. Its going to the same screen as before?
Do you only have a precise moment in time to get command and R pressed? Is there a sequence to them?
Thanks again guys, I will leave all hooked up and check back through day. I might not have more time until tonightβ¦but like I said, I will leave stuff hooked up so maybe I can get forward progress in next day or two
thanks
Brian
[ATTACH type=βfullβ alt=β1734909717605.webpβ]14880[/ATTACH]
Do you get to this place?
If yes Click on Utilities
Click on Disk utilities
Follow this from SELECT you disc in disc utilities
Disk Utility can find and repair errors related to the formatting and directory structure of a Mac storage device. Errors can lead to unexpected behaviour when using your Mac, and significant errors might even prevent your Mac from starting up completely.
Hi Peter. I get these. But i donβt know if I am doing command functions correct? Do I have to hold them down before hitting power button? Press them over and over? A certain sequence? Then it makes me wonder if key board transmitted?? So I donβt know
Try hold both buttons down with one hand and power on with the other hand
Keep holding until you see the
[ATTACH type=βfullβ width=β218pxβ size=β960x884β]14883[/ATTACH]
screen or you see the
[ATTACH type=βfullβ size=β100x134β]14884[/ATTACH]
Are you using a wireless or wired keyboard?
none of those screens come up. I held the buttons for a couple minutes while it was loading but it did not do anything. same screen I posted above
Wireless
Hi Peter
I tried these again. I even put fresh batteries in keyboard. It is wireless. Not sure if you saw that yesterday. I wonder if mine is not communicating fast enough. Maybe need USB keyboard?
I just get the following screen like always and it takes about 2min of this white loading screen
Even a windows keyboard wired could work.
Did you try unplugging the power cable from the computer?
With the wireless keyboard push the on button and get a green light then try.
With a wired windows keyboard replace the option with the windows key.
Press Windows key +R key
Are you holding both keys in at the same time?
Try
Windows key + Alt + Shift + R
You have to press and hold the keys before the chime
