Wired mouse turning on and off randomly when moving it
Syntectic
20
Mouse : Razer Viper rz01-0255
Pc Specs if needed:
OS: Windows 10
Cpu: AMD Ryzen 9 7900X
Ram: Flare X5 DDR5-6000 CL36-36-36-96 1.35V 32GB (2x16GB) AMD EXPO
Gpu: NVIDIA GeForce RTX 3060 Ti
Motherboard: ROG STRIX B650E-F GAMING WIFI (AM5)
Psu: CORSAIR RM850e
This issue just started happening out of nowhere in like march with my mouse. When I move it around it will just disconnect and reconnect after a second. It doesn't happen for any reason, it will happened at random times as long as I'm moving it. What I notice is that one, the more I move it when like I'm playing a game where I need to flick it, it happens more often, two, when it "disconnects" I hear the windows usb disconnect noise and not the reconnect when it turns back on, three, I see the light for the dpi and razer logo turn off when it happens.
I ended up buying the same version of the mouse but newer off amazon https://www.amazon.com/dp/B07TT8G59J?psc=1&ref=ppx_yo2ov_dt_b_product_details after I couldn't find the issue and it stopped happing thinking it was a mouse issue. After 2-3 months I decide to add a new ssd to my pc so I disconnect everything and reconnect it. A couple hours into gaming the same day It starts happening again where it disconnects and reconnects.
I have tried switching usb ports and that hasn't helped, I tried updating firmware and downloading razer synapse to no avail, I tried to uninstall drivers for it and it still hasn't helped. It doesn't happen to any other devices other than the mouse. I tried to see if maybe it was tugging at the end of the cord so I put a book on the wire and gave it slack but it still happens.
I will be gladly happy to provide screenshots if needed of device manager or something if needed. Its the most little but infuriating issue that has happened to me since it happens way too often and I want to know if its a pc or mouse issue. Thank you for reading this and please if you have any ideas of things to try I will do it. Have a great day
