Program opening problem - previous help given
So steam on C drive, seems fine.
All games are on secondary and so far seem okay.
Boot time seems fine.
How much of my previous problem do you think was down to space issues on C drive or was it definately AVG which has been removed?
Combo of both
I have not read your previous post but this one is a space issue.
Have a look at what @Bruce advised. On win10 it is easier to route docs,pics ,downloads etc to E drive so it goes automatically.
Lol this is something else. So yeah it seems everything is working fine and this particular app worked fine ....
Until today.
All thats changed is I installed R2games on my E drive - reluctantly may I add.
This browser game I believe is powered by GT Arcade.
I love a good conspiracy but I genuinely feel like anything related to either of these gaming platforms has given me issues.
Twitch will also not load via chrome.
Yeah but I've just gotten rid of it all together and it hasnt helped unless I need to do something else to completely get rid of it.
I suggest you look at this and move Docs,Pics, Downloads etc so the go to E: Drive
Something to think about.
  1. Right-click My Documents (on the desktop), and then click Properties.
  2. In the Target box, type the new path to the My Documents folder, or click Move to browse to the folder and if needed, create a new My Documents folder. If the path you type does not exist, you are prompted to confirm that you want to create a new folder.
  3. Click Yes to move files from the old My Documents location to the new location, or click No if you do not want to move these files. Note that if you click No, the files in the old location are not deleted, but they are no longer visible from My Documents after the change.
There is something wrong with this laptop and connectivity. Its practically a fresh install with the exceptions of a few installs, steam + 3 games and chrome. Thats it. My other more basic laptop has no issues despite it not being designed for gaming. Same on either chrome or edge.
In addition to what I showed you last night - this also happens and its a mirror image of really what brought me here in the first place to further discover space problems. I done actually use either of what these pages are for but its now the principle.
As I said my other laptop is fine when I need to get onto that particular site but for whatever reason this laptop gives me constant problems, for a long time it worked fine but then last month this same problem kept on happening.
