Program opening problem - previous help given
no idea.
faulty adapter, incompatible driver version - not sure.
give the wireless a few days to prove itself.
if no issues, than let's blame the NIC, then I would reconnect the ethernet, uninstall its current driver, let Windows Updates install what it thinks is correct.
if the issue returns, uninstall that Windows driver and this time get it manually from the motherboards website.
if still no luck, stop using the NIC adapter and get a PCIe network card.
Strange how everything else was fine except a few specific things that would give me connection issues.
This is the reason I asked about how they are connected.
Dothis with and without the cable.
You can be on two different networks - Yes off the one modem/router
Open the cmd prompt and either type or copy and paste
Either type or copy and paste what is in Blue. What is in Red is what you do e.g Enter (Press the Enter key)
ipconfig /all >"%userprofile%\desktop\ipconfig.txt" Enter
This should put a text file on your desktop. Please attach the file in your reply.
The information this gives cannot be used to hack your computer.
It is only the internal network address
Here the attachments.
Without cable file name "Wifi"
With cable file name "Cable"
PS - I can't get Cable.txt to attached haha
Second attachment.
OMG! No matter what I do I can't get another attachment added. These fun and games never stop.
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-85V8UAT
DNS Suffix Search List. . . . . . : Home
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : Home
Description . . . . . . . . . . . : Killer E2500 Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 30-9C-23-13-28-A6
IPv6 Address. . . . . . . . . . . : 2a02:c7f:32bd:8700:3d9b:9f54:3d2c:1f0c(Preferred)
IPv6 Address. . . . . . . . . . . : fd19:1eed:ca6a:0:9c9c:4486:1e0d:f24a(Preferred)
Temporary IPv6 Address. . . . . . : 2a02:c7f:32bd:8700:ed4d:9f42:5e48:668e(Preferred)
Temporary IPv6 Address. . . . . . : fd19:1eed:ca6a:0:ed4d:9f42:5e48:668e(Preferred)
Link-local IPv6 Address . . . . . : fe80::8040:1b78:3463:1749%15(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.3(Preferred)
Lease Obtained. . . . . . . . . . : 24 February 2023 19:31:14
Lease Expires . . . . . . . . . . : 25 February 2023 19:36:06
Default Gateway . . . . . . . . . : fe80::9e31:c3ff:feed:3df9%15
192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 254843939
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2B-80-90-FB-30-9C-23-13-28-A6
DNS Servers . . . . . . . . . . . : fd19:1eed:ca6a:0:9e31:c3ff:feed:3df8
208.67.222.222
208.67.220.220
Wireless LAN adapter Local Area Connection* 1:
Physical Address. . . . . . . . . : 90-61-AE-9A-6A-CE
Wireless LAN adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 92-61-AE-9A-6A-CD
Wireless LAN adapter WiFi:
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3168
Physical Address. . . . . . . . . : 90-61-AE-9A-6A-CD
IPv6 Address. . . . . . . . . . . : 2a02:c7f:32bd:8700:c557:fcf3:fb09:c9af(Preferred)
IPv6 Address. . . . . . . . . . . : fd19:1eed:ca6a:0:77ee:60ab:7e47:8921(Preferred)
Temporary IPv6 Address. . . . . . : 2a02:c7f:32bd:8700:f11f:8333:d79d:b60e(Preferred)
Temporary IPv6 Address. . . . . . : fd19:1eed:ca6a:0:f11f:8333:d79d:b60e(Preferred)
Link-local IPv6 Address . . . . . : fe80::c34c:c2cb:7f17:fa35%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.5(Preferred)
Lease Obtained. . . . . . . . . . : 24 February 2023 19:27:12
Lease Expires . . . . . . . . . . : 25 February 2023 19:32:53
Default Gateway . . . . . . . . . : fe80::9e31:c3ff:feed:3df9%7
192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 126902702
192.168.0.1
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 90-61-AE-9A-6A-D1
Settings look correct.
As Bruce mentioned it could be a faulty nic
It could also be a faulty cable.
Or the port on the modem/router it is connected to.
