Router came on as normal. Ipconfig doesn't seem to have changed?yes
Sorry slack on my behalf
Lights unchanged on both ends. Rebooting now.Still lights?
reboot computer
check ipconfig / all agin
The results from ipconfig and a ping. Pinging has gone back to how it was before.Lights unchanged on both ends. Rebooting now.
I appreciate all your time and help!I am sorry I have not been able to solve this with you.
I have asked some others to have a look and have given a brief description
of what was tried.
I was thinking cat 7 may be the issue as I have seen older computers
Struggle when using higher rated cables.
Yep! And yes, I truly do not understand what has gone wrong (apart from maybe hardware failure) because it literally has been fine as is for a couple years and hasn't been fiddled with. I changed nothing from one day to the next!Sorry I missed that this had be working with that cable for a while.
Anyway we have a least proved both cables are good.
Ping works! What is 127?if you open cmd
ping 127.0.0.1
what happens
Okay, makes sense!127.0.0.1 is local
So you are pinging yourself
which seems to say network card should be ok
