PC won't display 2 monitors at the same time
Are you sure the monitors both work?
I suspect the old monitor is no longer compatible with the new Motherboard especially as another monitor works.
The idea is to make sure by checking the device manager and the control panel to make sure all of Nivida is gone.
The file you downloaded Version 472.84 (post #13) you say shows as version 30.15.1165,
I am wondering if all of the original nvida version 30.15.1165 did not uninstall completely
The driver in post # 66 was a notebook driver - my mistake:eek:
If you are 100% sure you have Nivida unistalled go here
This should be driver Version 442.19 Released in 2020
When installed it should show 26.21.14.4219 and not 30.15.1165
Still the same, I'm thinking about taking the monitor back to the place where they fixed it, didn't want to do it at first cause they take so long to do it, but I guess I have to at this point
ok
I am out of ideas now - sorry
Please let me know how you go.
Might be wise to take both monitors so you can see that they have it working.
If they do get it to work ask them HOW
Ok, so, I went there today to see if they could help me out, they are closed till march, I did some tests at home and found out that my second monitor works fine as a second monitor for my notebook, but not for my pc, idk if this might help you guys but for some reason this monitor just does not want to work as a second monitor for my pc, but it is fine for my notebook
Idk if anyone is still here but, i bought a Y cable adapter, 2 hdmi cables into the adapter is connect to the gpu display port, both monitor wont stay on for long, i think i found what the problem is, power supply cant handle it all, the place will open again Thursday and ill give you lot an update
