Go here Click On Me change os to win 64
scroll down and pick chipset drivers - the top 2 download and install
Ok, I installed those 2. So I know it sounds strange, but my benchmark to see if it'll crash atm is Webkinz classic. It's a game my gf plays regularly. As soon as I started it up, logged in, the screen froze and I got a BSOD soon after of MACHINE_CHECK_EXCEPTION. I included the minidump file this time. I'm not sure if it'll help.Go here Click On Me change os to win 64
I don't mean to be that person, but I'm not sure what else I could possibly do more with my ram... I've replaced it twice now, it's gone through 3 different types. The motherboard is brand new too so I don't think it's that either.Minidump says memory = ram
Me eitherI don't mean to be that person, but I'm not sure what else I could possibly do more with my ram..
Ok, so I tried to publish the Speccy report, but their servers are down. It seems like it's an ongoing issue. I did attach the .speccy report that can be loaded in Speccy. I also attached the hwmonitor report as well.can you go here https://www.cpuid.com/softwares/hwmonitor.html
and run
As far as I can tell, the PC runs flawlessly in safe mode. I was able to play the game perfectly without any hitches, freezes, really any issue.boot to safe mode and try GF game
Wrong answerAs far as I can tell, the PC runs flawlessly in safe mode. I was able to play the game perfectly without any hitches, freezes, really any issue.
Include in your next reply a Get System Info log.Ok, so I tried to publish the Speccy report, but their servers are down.
There is no Display option in the classic control panel.in normal mode
- Search for Control Panel in your search bar, then open the app. This will take you to the classic Control Panel from previous Windows releases.
- Change the view mode to Large icons.
- Click on Display.
- Click Change Display Settings. You can find this on the left side of the window.
- Scroll down and click on Advanced display settings. A new dialogue box will appear.
- Select the Troubleshoot tab, then click on the Change settings button.
- In the Hardware acceleration section, move the pointer fully towards none.
- Click OK to apply your settings, and restart your computer.
in normal mode
- Click on Display.
So I am not sure what happened now. Since the safe mode, the PC has been acting even worse in normal mode. I open firefox, microsoft edge, opera gx, any web browser and I try to go to the link Malnutrition added, when I try to go to pchelpforum all browsers loss connection and ask me to refresh. Is there any way someone can remote access the pc? I'm not sure if that is allowed or easier.Include in your next reply a Get System Info log.
Save it to your desktop when complete.
Once you have the file on your desktop, then upload it here.
Copy the URL after your report is loaded.
Then send us the link.![]()
I don't see a display option with small or large icons. It's not there at all. Could it be because of Nvidia control panel?Change classic mode to large or small icons
Change MHZ to 60MHZ
Test
That brings up the new display settings. There's no option for troubleshooting nor anything mentioning hardware acceleration in advanced display settingsright click on desktop
