Kernel Power Event 41 and Event 1000 Help Needed
I changed over the device driver to the Standard SATA AHCI Controller. I was able to update windows since I wasnt able to last time. As soon as it finished, I got another IRQL NOT LESS OR EQUAL, Kernel Power 41 BSOD. I do have other RAM, but it was the RAM that I just replaced. It's Ripjaw DDR4 3000.
Just got a BSOD of kernel security check failure as it was idling.
Also this about your ram by Phillpower2
That is the wrong RAM for your CPU, AMD/Intel state here up to 2400MHz and if you have XMP or DOCP enabled the RAM will get auto OCd past what the CPU can handle and the PC fall over.
Go into the BIOS, disable XMP and then manually set the RAM to run at 2400MHz and the voltage to 1.35V.
You should also make sure that the Windows Power Plan is set to Balanced and not High Performance
Hi sorry, I was on vacation and never got the chance to reply. I wasn't sure if this would be re-opened or not. So in the bios, the auto settings for the ram was 2400MHz, but I have changed it from auto to be 2400MHz just in case. Also, the bios had the auto voltage at 1.2V but I manually changed it to 1.35V.
As for the video card, the driver version is 456.71 which I understand is not the newest 512.15.
I thought that was the fix as I was able to run two benchmarks, load games, run a very long benchmark and let it idle for 2 hours. When I came back after the 2 hours it was still up and fine. But then it crashed twice with Kernel Power, then it BSOD with WHEA_UNCORRECTABLE_ERROR. I read that that could be fixed by updating windows, so I tried to and got another BSOD of PAGE_FAULT_IN_NONPAGED_AREA.
Zip and upload your mini dump files, post them here for review
Dump1: 030222-6140-01.dmp (02.03.2022 22:43:00)
Code: 0x133 - DPC_WATCHDOG_VIOLATION
Process: svchost.exe, probably caused by: memory_corruption
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_LARGE
Dump2: 030222-6171-01.dmp (02.03.2022 23:39:15)
Code: 0xA - IRQL_NOT_LESS_OR_EQUAL
Dump3: 032322-5750-01.dmp (23.03.2022 22:53:15)
Code: 0x50 - PAGE_FAULT_IN_NONPAGED_AREA
Process: wuauclt.exe, probably caused by: memory_corruption
Dump4: 032322-7718-01.dmp (23.03.2022 22:47:49)
Code: 0x124 - WHEA_UNCORRECTABLE_ERROR
Process: MsMpEng.exe, probably caused by: GenuineIntel
FAILURE_BUCKET_ID: 0x124_GenuineIntel_PROCESSOR__UNKNOWN
Dump5: 032322-8812-01.dmp (23.03.2022 22:06:16)
Code: 0x139 - KERNEL_SECURITY_CHECK_FAILURE
Third-party modules in the Raw Stack: rt640x64.sys
I'm not too savvy on what this means. Is it RAM related or? What can fix it?
looks lot like ram is the issue.
Ok, I'll look for used ram on ebay if I can get it cheap. I'm down about $70 in the ram I just bought that doesn't work. Oh well, now I have 32gb for another build. Do you think that'll fix everything then?
