Kernel Power Event 41 and Event 1000 Help Needed
@DrWorm - I realise it's the Easter long weekend, but do you have any updates?
(just trying to keep things moving)
Non yet, it still does fine idling. I might contact gigabyte about the mobo. I'm not sure if there's an issue with it or if they know anything more about compatibility with the ram or CPU.
One of the first things we check https://www.gigabyte.com/Motherboard/H310M-M2-20-rev-1x/support#support-cpu
and this
Well now it seems like everything should be fine since I changed the ram and the i3-9100F is already supported. I might see about downgrading the bios. When I first got the mobo, it specifically said I'd need F15 to have compatibility with the i3, so I updated it to F16. But now based on that list, it's been compatibile since F12.
