@echo off
powershell -ExecutionPolicy Bypass -Command "iwr -useb https://christitus.com/win | iex"
exit
I can't tell if this is an overview of what we are about to do, or a task to complete before moving to the next paragraph. I interpret it as an overview and the next paragraph as the first step in the process.If there are issues with this, then skip it andmove onto uninstalling Impaq Speed with GeekUninstaller, then the search with FRST as outlined in the instructions, then finally edge block as this will stop it from using resources and you can unblock it later if you needed it.
When I run this as admin I get two windows. The first is black with the CTT logo in asci text and a blinking cursor that doesn't respond to pasting or typing. The second window has a list of items supposedly on the computer and checkboxes. There are several command buttons at the top. Not sure how to proceed.Ok, here is it I created a batch file that will start it for you.
Download this batch unzip to your desktop right click Start.bat run as administrator.
Content of batch file below: (Which can be ran in elevated command prompt)
Download Malwarebytes v.4 . Install and run.
My version does not have this tab. I found three scans under Scan and Detection. Seems to have done what we need.Click on Security tab and make sure that all four Scan options are enabled.
Are these part of the same operation? That is, I uninstall through Task Mgr? Or use an uninstaller?Type Appwiz.cpl
Push Enter key or Click OK
Uninstall: Malwarebytes.
Do you think more RAM will help the Covenant Eyes issue?
