  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #331
    Have you pushed Next?
    • jxdama
      • Dec 2022
      • 660
      #332
      I will have to put in the network cable one more time. If i keep messing withthis cable its going to break or something
      • PeterOz
        • Mar 2021
        • 4181
        #333
        NO
        • PeterOz
          • Mar 2021
          • 4181
          #334
          On the new computer
          Press the Shift and F10 key
          You should get a cmd screen similar to this
          [ATTACH type=β€œfull”]12098[/ATTACH]
          • jxdama
            • Dec 2022
            • 660
            #335
            More good news. the next key is grayed out so i cant click it. Nothing ever works right for me
            • PeterOz
              • Mar 2021
              • 4181
              #336
              Read my post 335 above
              • jxdama
                • Dec 2022
                • 660
                #337
                On the new computer
                [ATTACH type=β€œfull” alt=β€œCmd screen.JPG”]12098[/ATTACH]
                Do i have to put the cable bck in again?
                • PeterOz
                  • Mar 2021
                  • 4181
                  #338
                  NO
                  I will tell you when
                  Please read Post 335 above
                  • jxdama
                    • Dec 2022
                    • 660
                    #339
                    put the cable back in because it isnt doing anything now. maybe the keyboard isnt working. there is no light
                    • jxdama
                      • Dec 2022
                      • 660
                      #340
                      absolutely nothing happens when i hit shift and f10
                      • jxdama
                        • Dec 2022
                        • 660
                        #341
                        the keyboard works because the up and down works
                        • jxdama
                          • Dec 2022
                          • 660
                          #342
                          On the very top it says ethernet not connected
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #343
                            Hold the shift key in and press f10
                            It is not press one then the other
                            it is press both together
                            • jxdama
                              • Dec 2022
                              • 660
                              #344
                              ZIP. i guess the keyboard works because i hit f8 and the brightness thing comes up im hitting shift any key and so far only f8 seems to work
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #345
                                Ok
                                Can you manage to connect the cable
                                if yes
                                see if it let’s you continue
