Sure, Iβm thin on ideasβ¦ Perhaps if the usb works, then use it. Windows 11 is buggy and it maybe just that. Perhaps another member will chime n, sorry we could not come to a resolutionβ¦
no internet on network but there is
the usb adapter is fine. If i wanted to go drastic measures would a fresh windows install likely fix this?Comment
Sorry @Malnutrition
I thought this was maked solved?
Skimming through the thread You are at the point that
USB wifi connects to internet
Onboard wifi does not connect to internet
True or False
[HEADING=3]Can you Download and run and then post. Speccy - Free Download [/HEADING]
[HEADING=3]To publish a Speccy profile to the Web:[/HEADING]
[HEADING=3]In Speccy, click File, and then click Publish Snapshot.[/HEADING]
Speccy publishes the profile and displays a second Publish Snapshot dialog box. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.
The last part of each URL is randomized, so only people you provide with the URL will be able to find your profile.Comment
can you go back to the on board wireless card and put it back to DHCP
Reboot the computer
Either type or copy and paste what is in [COLOR=rgb(41, 105, 176)]Blue. What is in Red is what you do e.g [COLOR=rgb(184, 49, 47)]Enter (Press the Enter key)
[COLOR=rgb(41, 105, 176)]ipconfig /all >β%userprofile%\desktop\ipconfig.txtβ [COLOR=rgb(184, 49, 47)]Enter
This should put a text file on your desktop. Please attach the file in your reply.[/COLOR][/COLOR][/COLOR][/COLOR]Comment
He means to reverse the static ip. Obtain ip address automatically.
[ATTACH type=βfullβ alt=βCapture.PNGβ]9802[/ATTACH]Comment
To reenable DHCP and make sure you are obtaining DNS servers and Ip automatically.
Run the command below in elevated command prompt and reboot the computer.
After that, post the ipconfig all as requested by @PeterOznetsh int ipv4 resetComment
