Originally posted by PeterOz
Problem with my Ethernet Connection
ok looked like a flat telephone cable not a netwok cable.
Last thing I can think of to try
Go back to adapter settings and set both back to obtain ip address and obtain dns.
then go to device manager
Right click on Realtek pcie 2.5gbe family controller
left click on uninstall device
Reboot
It should reinstall automattically
If not it then starts to look like hardware or malware.
Do yo need step by step instructions?Comment
It did reinstall automatically, but I donβt have Internet.
Is it possible Iβve got out of date drivers somewhere?Comment
I know you said you plugged the white cable into the laptop and it worked.
Is there any writing on the cable saying that it is Cat 5 or 5e Or 6 etc?
Is the black cable from room mate able to be used for a test?
I doubt driver as the device manager shows driver ok.Comment
Cat 5E. And it doesnβt seem to have helped, still nothing on the Internet endOriginally posted by PeterOznot easy to move a desktop I know but if we can plug black cable in for testing.
What is black cable 5, 6 or 7Comment
Green light on the router, same solid orange, flickering green as before on the computer.Originally posted by PeterOzgreen light both ends
and i assume ping 192.168.10.1 still fails
Ping this time gives βtransmit failed. general failure.β probably the cableβs faultComment
Normally bad driver will show in device managerOriginally posted by LuciferLilacIs it possible Iβve got out of date drivers somewhere?
You could try this
Will need usb to transfer from laptop to desktop
Realtek RTL8125 LAN driver V1125.9.614.2022 For Windows 11 64-bit.
Realtek RTL8125 LAN driver V10.60.615.2022 For Windows 10 64-bit.
From here Click On MeComment
I went back to the white cable but now Iβm getting transmit failed for that one too. Also,
Looks up to date.Originally posted by PeterOzTo see what driver you have
back to device manager
Left click on properties
Click on driver tabComment
(Went back to the white cable) It claimed a success on flushing the DNS, but the ping has been coming back as transmit failed since I first swapped to the black cable. No change after flush dns.Comment
