Problem with my Ethernet Connection
  • LuciferLilac
    • Feb 2024
    • 39
    #31
    Okay, I turned off all three options available.
    And I went back and set the manual again to .175, so I should ping that instead, right?
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      #32
      yes
      • LuciferLilac
        • Feb 2024
        • 39
        #33
        I pinged both, just in case.
        • PeterOz
          • Mar 2021
          • 4181
          #34
          This is odd
          On the desktop
          go back to the network settings and make sure it is still 175
          If it is
          In the bottom section
          make the first dns server
          192.168.10.1
          the alternate 8.8.8.8
          save and ping again
          • PeterOz
            • Mar 2021
            • 4181
            #35
            do not run network diagnostic
            • LuciferLilac
              • Feb 2024
              • 39
              #36
              Originally posted by PeterOz
              This is odd
              On the desktop
              If it is
              192.168.10.1
              save and ping again
              Still 175.
              Thats β€œPreferred DNS Server” I’m changing, yes?
              • PeterOz
                • Mar 2021
                • 4181
                #37
                sorry
                yes
                • LuciferLilac
                  • Feb 2024
                  • 39
                  #38
                  sorry
                  yes
                  I wasn’t sure if the ping was meant to go to 192.168.10.175 or 192.168.10.1 so I did both.
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #39
                    from the desktop if you ping
                    192.168.10.1
                    Fail ?
                    if yes
                    can you reboot the modem/router?
                    • LuciferLilac
                      • Feb 2024
                      • 39
                      #40
                      192.168.10.1
                      Fail ?
                      if yes
                      Assuming that’s a fail. I’ll just, turn the router off and turn it on after giving it a minute, yes?
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #41
                        that is a fail
                        Reboot router - off
                        wait a min
                        back on
                        Ping 192.168.10.1 from desktop
                        • LuciferLilac
                          • Feb 2024
                          • 39
                          #42
                          This is what the router end looks like. Ping came back a failure again.
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #43
                            What is the black Ethernet cable not plugged in?
                            • LuciferLilac
                              • Feb 2024
                              • 39
                              #44
                              From a roommate who moved out
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #45
                                So which cable is your desktop?
