Solved Strange process dupe bug crashing many programs
Laro
6
28
Hello there!
Yesterday, my Windows machine began doing something really strange. I was multitasking with several programs open like usual: Whatsapp Desktop, Discord, Spotify, Chrome, Photoshop, etc. Suddenly, many programs (all mentioned above) stopped responding (with the exception of Chrome). After successfully terminating them, reopening them was impossible since they'd all not respond almost immediately after starting.
I tried restarting my PC but the issue persists. While trying to troubleshoot I learned that many other programs crash too: Control Panel's Device Manager, Nvidia GeForce Experience, the latest Nvidia driver wizard installer, etc. I noticed in my Task Manager that the programs that go through this are actually having the processes duped 3-9 times before getting unresponsive or suspended. A few others work normally: Google Chrome, Minecraft, Steam, etc.
The weirdest thing is that this has actually happened twice before and every single time it seems to start after I use a shortcut starting with "Shift + Ctrl". The first two times I was doing "Shift + Ctrl + A" in Discord to collapse all channel categories and this latest time I did "Shift + Ctrl + I" in Photoshop to change my image size. It sounds strange but all 3 occurrences of this started immediately after that. The last couple of times, the issue went away after unplugging my machine to drain it from energy and restarting it after. This doesn't seem to work now.
Booting the machine in Windows Safe Mode seems to get rid of the issue, making me think it might not be a hardware problem. Perhaps something in my OS got messed up? I'd really appreciate not having to do a fresh install of WIndows and instead hopefully locating and fixing the problem.
Please let me know what type of additional information I may be able to provide. Really appreciate any help!
List Installed Programs
List Devices (Only Problems)
Click on Go.
I can't seem to install Speccy since the installation wizard crashes. Is there a way to install this from the command line?
Hey Rustys!
Thank you for your response! Really appreciate the help.
I was under the impression I couldn't install stuff in Safe Mode, but that worked!
Here's the speccy url: http://speccy.piriform.com/results/1zqI13jQKL5gCSKBp5jm7c8
The info listed there correspond to my mahine booted in Safe Mode though.
Here's the Minitool Log:
Ran by ivanr (administrator) on 09-01-2022 at 20:35:33
Running from "C:\Users\ivanr\Desktop"
Model: System Product Name Manufacturer: System manufacturer
Boot Mode: Network
Application errors:
Error: (01/09/2022 08:33:26 PM) (Source: Microsoft-Windows-PerfNet) (User: NT AUTHORITY)
Description: Unable to open the Server service performance object. The first four bytes (DWORD) of the Data section contains the status code.
Error: (01/09/2022 08:30:50 PM) (Source: Microsoft-Windows-PerfNet) (User: NT AUTHORITY)
Error: (01/09/2022 08:28:08 PM) (Source: CAM Service) (User: )
Description: request thread encountered an error: Failed to send result: Io(Os { code: 232, kind: BrokenPipe, message: "The pipe is being closed." })
Error: (01/09/2022 06:17:56 PM) (Source: Application Error) (User: )
Description: Faulting application name: MiniToolBox.exe, version: 17.6.2016.0, time stamp: 0x57634101
Faulting module name: ntdll.dll, version: 10.0.19041.1288, time stamp: 0x027db076
Exception code: 0xc0000005
Fault offset: 0x0005f583
Faulting process id: 0x48cc
Faulting application start time: 0xMiniToolBox.exe0
Faulting application path: MiniToolBox.exe1
Faulting module path: MiniToolBox.exe2
Report Id: MiniToolBox.exe3
Faulting package full name: MiniToolBox.exe4
Faulting package-relative application ID: MiniToolBox.exe5
Error: (01/09/2022 06:17:55 PM) (Source: Application Error) (User: )
Faulting module name: GTII-OSD.dll, version: 2.0.3.0, time stamp: 0x5bb5cddd
Fault offset: 0x00009713
Error: (01/09/2022 06:17:50 PM) (Source: Application Error) (User: )
Faulting process id: 0x29d0
Error: (01/09/2022 06:17:49 PM) (Source: Application Error) (User: )
Error: (01/09/2022 06:17:41 PM) (Source: Application Error) (User: )
Faulting process id: 0x5ec
Error: (01/09/2022 06:17:40 PM) (Source: Application Error) (User: )
System errors:
Error: (01/09/2022 08:35:32 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: 1084mccspsvcUnavailable{8F2BC96B-68C5-40E8-9CE1-368E3ACAC09B}
Microsoft Office Sessions:
Error: (01/09/2022 08:33:26 PM) (Source: Microsoft-Windows-PerfNet)(User: NT AUTHORITY)
Description: 3221225524
Error: (01/09/2022 08:30:50 PM) (Source: Microsoft-Windows-PerfNet)(User: NT AUTHORITY)
Error: (01/09/2022 08:28:08 PM) (Source: CAM Service)(User: )
Error: (01/09/2022 06:17:56 PM) (Source: Application Error)(User: )
Description: MiniToolBox.exe17.6.2016.057634101ntdll.dll10.0.19041.1288027db076c00000050005f58348cc01d805af21454ba0C:\Users\ivanr\Desktop\MiniToolBox.exeC:\WINDOWS\SYSTEM32\ntdll.dllc1e2b713-afb8-4640-991d-91c351c8847a
Error: (01/09/2022 06:17:55 PM) (Source: Application Error)(User: )
Description: MiniToolBox.exe17.6.2016.057634101GTII-OSD.dll2.0.3.05bb5cdddc00000050000971348cc01d805af21454ba0C:\Users\ivanr\Desktop\MiniToolBox.exeC:\Program Files (x86)\ASUS\GPU TweakII\GTII-OSD\x86\GTII-OSD.dll68127967-5582-4e0c-b663-46e6ed920f9e
Error: (01/09/2022 06:17:50 PM) (Source: Application Error)(User: )
Description: MiniToolBox.exe17.6.2016.057634101ntdll.dll10.0.19041.1288027db076c00000050005f58329d001d805af1d24aecdC:\Users\ivanr\Desktop\MiniToolBox.exeC:\WINDOWS\SYSTEM32\ntdll.dll3b5c968e-86cf-49ef-914d-935c6bf1b3ba
Error: (01/09/2022 06:17:49 PM) (Source: Application Error)(User: )
Description: MiniToolBox.exe17.6.2016.057634101GTII-OSD.dll2.0.3.05bb5cdddc00000050000971329d001d805af1d24aecdC:\Users\ivanr\Desktop\MiniToolBox.exeC:\Program Files (x86)\ASUS\GPU TweakII\GTII-OSD\x86\GTII-OSD.dll87e98b79-61d5-4cee-8190-dfa12f9bd2b0
Error: (01/09/2022 06:17:41 PM) (Source: Application Error)(User: )
Description: MiniToolBox.exe17.6.2016.057634101ntdll.dll10.0.19041.1288027db076c00000050005f5835ec01d805af17d2c274C:\Users\ivanr\Desktop\MiniToolBox.exeC:\WINDOWS\SYSTEM32\ntdll.dllc6482156-c724-4a91-9b3b-a9955f961497
Error: (01/09/2022 06:17:40 PM) (Source: Application Error)(User: )
Description: MiniToolBox.exe17.6.2016.057634101GTII-OSD.dll2.0.3.05bb5cdddc0000005000097135ec01d805af17d2c274C:\Users\ivanr\Desktop\MiniToolBox.exeC:\Program Files (x86)\ASUS\GPU TweakII\GTII-OSD\x86\GTII-OSD.dlla696c3e2-9b96-4dd7-9419-a18fb3fd2f92
CodeIntegrity Errors:
Date: 2022-01-09 20:29:23.3550000Z
Description: Code Integrity determined that a process (\Device\HarddiskVolume7\Program Files\Common Files\McAfee\ModuleCore\ProtectedModuleHost.exe) attempted to load \Device\HarddiskVolume7\Program Files\Common Files\McAfee\Platform\Core\vtploader.dll that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2022-01-09 20:29:20.8400000Z
Date: 2022-01-09 20:29:20.8130000Z
Date: 2022-01-09 20:14:45.5380000Z
Description: Code Integrity determined that a process (\Device\HarddiskVolume6\Windows\System32\SIHClient.exe) attempted to load \Device\HarddiskVolume6\Program Files\McAfee\MfeAV\AMSIExt.dll that did not meet the Windows signing level requirements.
Date: 2022-01-09 20:14:45.5330000Z
Date: 2022-01-09 20:14:45.5250000Z
Date: 2022-01-09 20:14:45.5200000Z
Date: 2022-01-09 20:14:45.5080000Z
Date: 2022-01-09 20:14:44.7110000Z
Date: 2022-01-09 20:14:44.7050000Z
1Password (HKCU\...\1Password) (Version: 8.5.0-85.NIGHTLY - AgileBits Inc.)
4K Capture Utility (HKLM\...\{DC2C8F41-BE16-4442-BC11-6A36B995A2B3}) (Version: 1.7.4.4808 - Elgato Systems)
7-Zip 19.00 (x64) (HKLM\...\7-Zip) (Version: 19.00 - Igor Pavlov)
Absolver (HKLM\...\Steam App 473690) (Version: - Sloclap)
ABZÛ (HKLM\...\Steam App 384190) (Version: - Giant Squid)
Acronis True Image (HKLM-x32\...\{8FD2E7B8-F7F2-4121-ACAC-74BD07F4B41D}) (Version: 22.5.12510 - Acronis) Hidden
Acronis True Image (HKLM-x32\...\{8FD2E7B8-F7F2-4121-ACAC-74BD07F4B41D}Visible) (Version: 22.5.12510 - Acronis)
ActivTrak Agent 8.1.2.0 (HKLM-x32\...\{74BBE9F5-65FA-41DB-8D1C-B36E9C00CB1E}) (Version: 8.1.2.0 - Birch Grove Software, Inc.) Hidden
Adobe Acrobat DC (HKLM-x32\...\{AC76BA86-1033-FFFF-7760-0C0F074E4100}) (Version: 21.007.20099 - Adobe Systems Incorporated)
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 21.007.20099 - Adobe Systems Incorporated)
Adobe After Effects CC 2018 (HKLM-x32\...\AEFT_15_1) (Version: 15.1.0 - Adobe Systems Incorporated)
Adobe Audition CC 2018 (HKLM-x32\...\AUDT_11_1) (Version: 11.1.0 - Adobe Systems Incorporated)
Adobe Creative Cloud (HKLM-x32\...\Adobe Creative Cloud) (Version: 5.2.1.441 - Adobe Systems Incorporated)
Adobe Genuine Service (HKLM-x32\...\AdobeGenuineService) (Version: 7.6.0.52 - Adobe Inc.)
Adobe Illustrator CC 2018 (HKLM-x32\...\ILST_22_1) (Version: 22.1 - Adobe Systems Incorporated)
Adobe InDesign CC 2018 (HKLM-x32\...\IDSN_13_1) (Version: 13.1 - Adobe Systems Incorporated)
Adobe Lightroom Classic (HKLM-x32\...\LTRM_8_4_1) (Version: 8.4.1 - Adobe Systems Incorporated)
Adobe Media Encoder CC 2018 (HKLM-x32\...\AME_12_1) (Version: 12.1.0 - Adobe Systems Incorporated)
Adobe Photoshop CC 2018 (HKLM-x32\...\PHSP_19_1_3) (Version: 19.1.3 - Adobe Systems Incorporated)
Adobe Premiere Pro CC 2018 (HKLM-x32\...\PPRO_12_1) (Version: 12.1.0 - Adobe Systems Incorporated)
All MB (HKLM-x32\...\{93795eb8-bd86-4d4d-ab27-ff80f9467b37}) (Version: 1.04.04 - ASUSTek Computer Inc.)
Amazon Games (HKCU\...\{4DD10B06-78A4-4E6F-AA39-25E9C38FA568}) (Version: 1.7.3024.2 - Amazon.com Services, Inc.)
Among Us (HKLM\...\Steam App 945360) (Version: - Innersloth)
Android Studio (HKLM\...\Android Studio) (Version: 4.0 - Google LLC)
Apache NetBeans IDE 11.1 (HKLM\...\nbi-nb-all-11.0.0.0.2207) (Version: 11.1 - Apache NetBeans)
Apex Legends (HKLM\...\Steam App 1172470) (Version: - Respawn Entertainment)
Apple Mobile Device Support (HKLM\...\{74CC99EB-7DC0-4CB0-847A-F8C2FE39690C}) (Version: 14.5.0.7 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{A3985C05-7386-411F-A4BF-32A73F37EB44}) (Version: 2.6.3.1 - Apple Inc.)
Application Verifier x64 External Package (HKLM\...\{10CA1677-8F02-3131-F25C-780BAB52E468}) (Version: 10.1.18362.1 - Microsoft) Hidden
ARMOURY CRATE Lite Service (HKLM\...\{EF3944FF-2501-4568-B15C-5701E726719E}) (Version: 4.2.10 - ASUS)
ASUS AIOFan HAL (HKLM\...\{EAE80DED-1A39-41C5-9F60-87CC947F6454}) (Version: 1.1.11.0 - ASUSTek COMPUTER INC.) Hidden
ASUS AIOFan HAL (HKLM-x32\...\{2c89afc7-34f1-46a8-99a8-ededb99eb20f}) (Version: 1.1.11.0 - ASUSTek COMPUTER INC.) Hidden
ASUS AURA Display Component (HKLM\...\{AFD1CF98-FE97-434C-A095-9F27C5BEA53C}) (Version: 1.1.25 - ASUSTek COMPUTER INC. ) Hidden
ASUS AURA Display Component (HKLM-x32\...\{94267bd0-fa8a-4aa4-925d-ec3e0d130fba}) (Version: 1.1.25 - ASUSTek COMPUTER INC. ) Hidden
ASUS AURA Extension Card HAL (HKLM\...\{2C39FF80-1BB2-42C5-A58D-DC90EFF048F6}) (Version: 1.0.24 - ASUSTeK COMPUTER INC.) Hidden
ASUS AURA Extension Card HAL (HKLM-x32\...\{a75323e1-f1a4-4aff-a7ce-3858cbc1c0d2}) (Version: 1.0.24 - ASUSTeK COMPUTER INC.) Hidden
ASUS AURA Headset Component (HKLM\...\{A3C4120D-8096-4307-91A2-FFE37EBD5A3D}) (Version: 1.02.12 - ASUSTek COMPUTER INC.) Hidden
ASUS AURA Headset Component (HKLM-x32\...\{b96dabae-c7ef-45f2-95ab-1a4d917262a3}) (Version: 1.02.12 - ASUSTek COMPUTER INC.) Hidden
ASUS AURA Motherboard HAL (HKLM\...\{D800D836-DE15-4B00-8273-521F022CD837}) (Version: 1.0.66 - ASUSTeK COMPUTER INC.) Hidden
ASUS AURA Motherboard HAL (HKLM-x32\...\{f96df338-98e2-44e4-ab84-adcf722e48e7}) (Version: 1.0.66 - ASUSTeK COMPUTER INC.) Hidden
ASUS AURA Odd Component (HKLM\...\{B5E322FB-C191-463E-BDDD-4F22290EDFDB}) (Version: 1.0.8 - ASUSTeK COMPUTER INC.) Hidden
ASUS AURA Odd Component (HKLM-x32\...\{277875e0-972c-4705-b09c-ca5acf5b2f7c}) (Version: 1.0.8 - ASUSTeK COMPUTER INC.) Hidden
ASUS Aura SDK (HKLM\...\{CF8E6E00-9C03-4440-81C0-21FACB921A6B}) (Version: 3.04.07 - ASUSTek COMPUTER INC.) Hidden
ASUS AURA VGA Component (HKLM\...\{71BB96A6-EAC4-45AE-A17D-D3ED43FF1D14}) (Version: 0.0.2.6 - ASUSTek COMPUTER INC. ) Hidden
ASUS AURA VGA Component (HKLM-x32\...\{5c465d6f-1288-415a-946e-b6ecf1b1a30c}) (Version: 0.0.2.6 - ASUSTek COMPUTER INC. ) Hidden
ASUS Framework Service (HKLM-x32\...\{4483eb46-7659-4490-8603-2104aa5232ef}) (Version: 1.0.4.4 - ASUSTek COMPUTER INC.)
ASUS Framework Service (HKLM-x32\...\{CB0E3BB6-3F2F-401E-B1D4-E23C582ACB11}) (Version: 1.0.4.4 - ASUSTek COMPUTER INC.) Hidden
ASUS GLCKIO2 Driver (HKLM-x32\...\{3507c756-a80f-4b0e-8475-975d8b432176}) (Version: 1.0.20 - ASUSTeK Computer Inc.) Hidden
ASUS GLCKIO2 Driver (HKLM-x32\...\{5960FD0F-BB3B-49AF-B175-F77DC91E995A}) (Version: 1.0.20 - ASUSTeK Computer Inc.) Hidden
ASUS GPU TweakII (HKLM-x32\...\{2914BAB6-CA16-4B5A-BF41-2466656C7040}) (Version: 1.8.9.0 - ASUSTek COMPUTER INC.) Hidden
ASUS GPU TweakII (HKLM-x32\...\InstallShield_{2914BAB6-CA16-4B5A-BF41-2466656C7040}) (Version: 1.8.9.0 - ASUSTek COMPUTER INC.)
ASUS Keyboard HAL (HKLM\...\{0FA0CDEE-5DC8-421E-A97D-C74FA6E66FC3}) (Version: 1.0.50 - ASUSTek COMPUTER INC.) Hidden
ASUS Keyboard HAL (HKLM-x32\...\{52400cff-4628-4ca3-a922-3767b198c1fd}) (Version: 1.0.50 - ASUSTek COMPUTER INC.) Hidden
ASUS MB Peripheral Products (HKLM\...\{BFED9861-7D96-4528-89F1-B090ABBF11A7}) (Version: 1.0.32 - ASUSTeK Computer Inc.) Hidden
ASUS MB Peripheral Products (HKLM-x32\...\{243ceb39-3b77-43ab-9135-fddab4ac7caf}) (Version: 1.0.32 - ASUSTeK Computer Inc.) Hidden
ASUS Mouse HAL (HKLM\...\{1838F91B-D481-45AA-B92F-071C62D0A19A}) (Version: 1.0.53 - ASUSTek COMPUTER INC.) Hidden
ASUS Mouse HAL (HKLM-x32\...\{3dcded5b-10da-4d98-9c1f-c33d25288ebd}) (Version: 1.0.53 - ASUSTek COMPUTER INC.) Hidden
ASUS MousePad HAL (HKLM\...\{723B40A4-5BF2-4DC6-834A-2ADF75F3CF7E}) (Version: 1.0.1.2 - ASUSTek COMPUTER INC.) Hidden
ASUS MousePad HAL (HKLM-x32\...\{0ebcd5fb-7bf9-45b4-a0b6-0932d728e289}) (Version: 1.0.1.2 - ASUSTek COMPUTER INC.) Hidden
ASUS Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.107.67 - ASUSTeK Computer Inc.) Hidden
AURA DRAM Component (HKLM\...\{3881F403-B6B7-4D2F-BDAC-7901EB677F52}) (Version: 1.0.42 - ASUS) Hidden
AURA DRAM Component (HKLM-x32\...\{8997843b-b004-45ed-92fb-d641a4ea83c5}) (Version: 1.0.42 - ASUS) Hidden
AURA lighting effect add-on (HKLM-x32\...\{1E2EA04B-FCA7-457E-B6F4-F33E1858E859}) (Version: 0.0.18 - ASUS)
AURA lighting effect add-on x64 (HKLM\...\{C5A4A164-4428-4931-B728-96EEF0FA3C44}) (Version: 0.0.18 - ASUS)
AURA Service (HKLM-x32\...\{0E536061-3B55-4D45-BF58-0BDA261C94B0}) (Version: 3.05.18 - ASUSTeK Computer Inc.) Hidden
AURA Service (HKLM-x32\...\{2f406341-f76d-47c9-a781-b6d186b55b00}) (Version: 3.05.18 - ASUSTeK Computer Inc.)
Authy Desktop (HKCU\...\authy) (Version: 1.9.0 - Twilio Inc.)
Autodesk Fusion 360 (HKCU\...\73e72ada57b7480280f7a6f4a289729f) (Version: 2.0.5519 - Autodesk, Inc.)
BattleBlock Theater (HKLM\...\Steam App 238460) (Version: - The Behemoth)
Battlerite (HKLM\...\Steam App 504370) (Version: - Stunlock Studios)
Beat Saber (HKLM\...\Steam App 620980) (Version: - Beat Games)
Besiege (HKLM\...\Steam App 346010) (Version: - Spiderling Studios)
BioShock Remastered (HKLM\...\Steam App 409710) (Version: - 2K Boston)
Brackets (HKLM-x32\...\{9CB3A036-0B7E-49B7-A60B-291E245CA6B2}) (Version: 1.13.17696 - brackets.io)
Castle Crashers (HKLM\...\Steam App 204360) (Version: - The Behemoth)
Cisco EAP-FAST Module (HKLM-x32\...\{64BF0187-F3D2-498B-99EA-163AF9AE6EC9}) (Version: 2.2.14 - Cisco Systems, Inc.)
Cisco LEAP Module (HKLM-x32\...\{AF312B06-5C5C-468E-89B3-BE6DE2645722}) (Version: 1.0.19 - Cisco Systems, Inc.)
Cisco PEAP Module (HKLM-x32\...\{0A4EF0E6-A912-4CDE-A7F3-6E56E7C13A2F}) (Version: 1.1.6 - Cisco Systems, Inc.)
ClickOnce Bootstrapper Package for Microsoft .NET Framework (HKLM-x32\...\{0243F145-076D-423A-8F77-218DC8840261}) (Version: 4.8.04119 - Microsoft Corporation) Hidden
Clustertruck (HKLM\...\Steam App 397950) (Version: - Landfall)
Corsair AURA DRAM Component (HKLM\...\{376E0869-A4F1-4DC7-A1FD-EBF3AFFEB832}) (Version: 1.0.13 - CORSAIR COMPONENTS INC.) Hidden
Corsair AURA DRAM Component (HKLM-x32\...\{8fce5ea9-d56f-4f89-a363-830eceb72c72}) (Version: 1.0.13 - CORSAIR COMPONENTS INC.) Hidden
CORSAIR iCUE Software (HKLM-x32\...\{3D350B22-542B-4FB4-B3AC-EA760941C319}) (Version: 3.38.61 - Corsair)
DARK SOULS™ III (HKLM\...\Steam App 374320) (Version: - FromSoftware, Inc.)
Dead Cells (HKLM\...\Steam App 588650) (Version: - Motion Twin)
Destiny 2 (HKLM-x32\...\Destiny 2) (Version: - Blizzard Entertainment)
DiagnosticsHub_CollectionService (HKLM\...\{1F3C3AAC-9F7A-47DA-A082-0ACE770041BE}) (Version: 16.1.28901 - Microsoft Corporation) Hidden
Discord (HKCU\...\Discord) (Version: 0.0.309 - Discord Inc.)
DmC Devil May Cry (HKLM\...\Steam App 220440) (Version: - Ninja Theory)
Doki Doki Literature Club (HKLM\...\Steam App 698780) (Version: - Team Salvato)
Dust: An Elysian Tail (HKLM\...\Steam App 236090) (Version: - Humble Hearts LLC)
Dustforce (HKLM\...\Steam App 65300) (Version: - Hitbox Team)
Dynamo Core 1.3.3 (HKLM\...\{F1AA809A-3D47-4FB9-8854-93E070C66A20}) (Version: 1.3.3.4111 - Dynamo)
EA app (HKLM\...\{C2622085-ABD2-49E5-8AB9-D3D6A642C091}) (Version: 12.0.173.5074 - Electronic Arts) Hidden
EA app (HKLM-x32\...\{5f5bf5ca-72b9-4a11-8c0a-0d8bef9d58f4}) (Version: 12.0.173.5074 - Electronic Arts)
Elgato Stream Deck (HKLM\...\{45F36F94-3832-49C2-81FE-FED086AE974D}) (Version: 5.1.2.14743 - Elgato Systems GmbH)
ENE IO Driver (HKLM-x32\...\{D0512FFD-6194-4D2E-967E-25B82A3322FF}) (Version: 3.0.0 - ENE TECHNOLOGY INC.) Hidden
ENE RGB HAL (HKLM\...\{E050E98C-5524-4AFB-9E53-97700BEF2C02}) (Version: 1.0.17.0 - Ene Tech.) Hidden
ENE RGB HAL (HKLM-x32\...\{5fb603e7-5eff-4f18-a020-fe41c74b2858}) (Version: 1.0.17.0 - Ene Tech.) Hidden
ENE_DRAM_RGB_AURA42 (HKLM\...\{BC5E0A82-C638-44CB-8129-20C8ED70DE7A}) (Version: 1.00.02 - Ene Tech.) Hidden
ENE_DRAM_RGB_AURA42 (HKLM-x32\...\{f3d7fb09-b93f-4c01-a765-0b0adc5bc746}) (Version: 1.00.02 - Ene Tech.) Hidden
ENE_EHD_ASM_HAL (HKLM\...\{CB19FBA3-7A4F-4D2A-A231-F580B5DCD203}) (Version: 1.00.05 - ENE TECHNOLOGY INC.) Hidden
ENE_EHD_ASM_HAL (HKLM-x32\...\{3532d794-73d7-42bd-af02-9f00623dd567}) (Version: 1.00.05 - ENE TECHNOLOGY INC.) Hidden
ENE_EHD_M2_HAL (HKLM\...\{455E34DD-5F26-431E-B542-72F73A8FEED8}) (Version: 1.00.02 - ENE TECHNOLOGY INC.) Hidden
ENE_EHD_M2_HAL (HKLM-x32\...\{24a265a5-9f90-4090-904f-5ed9fa4414b8}) (Version: 1.00.02 - ENE TECHNOLOGY INC.) Hidden
Enter the Gungeon (HKLM\...\Steam App 311690) (Version: - Dodge Roll)
Entity Framework 6.2.0 Tools for Visual Studio 2017 (HKLM-x32\...\{B843915F-00A1-44B1-994C-1AE0A6400AE3}) (Version: 6.2.61807.0 - Microsoft Corporation) Hidden
Entity Framework 6.2.0 Tools for Visual Studio 2019 (HKLM-x32\...\{7C2070BF-8E07-4B5F-A182-FADB0B95AB39}) (Version: 6.2.0.0 - Microsoft Corporation) Hidden
Epic Games Launcher (HKLM-x32\...\{D442B219-3EBE-4EE2-88F9-5A31DF331CB1}) (Version: 1.1.144.0 - Epic Games, Inc.)
eTransmit for Autodesk Revit 2019 (HKLM\...\{4477F08B-1901-0010-0000-9A09D834DFF5}) (Version: 19.0.1.1 - Autodesk) Hidden
eTransmit for Autodesk Revit 2019 (HKLM\...\eTransmit for Autodesk Revit 2019) (Version: 19.0.1.1 - Autodesk)
Fall Guys (HKLM\...\Steam App 1097150) (Version: - Mediatonic)
FARO LS 1.1.600.6 (64bit) (HKLM-x32\...\{510A08AF-1649-4844-94E5-EAC43A023685}) (Version: 6.0.6.5 - FARO Scanner Production)
FlashBack Express 5 (HKLM-x32\...\FlashBack Express 5) (Version: 5.29.0.4318 - Blueberry Software (UK) Ltd.)
FormIt Converter For Revit 2019 (HKLM\...\{5E47699C-B0DE-443F-92AE-1D1334499D5E}) (Version: 1.9.6.0 - Autodesk)
GALAX GAMER RGB (HKLM\...\{06A16AA8-BBA7-4362-962E-16651962D87C}) (Version: 1.00.02 - Galaxy Microsystems Ltd.) Hidden
GALAX GAMER RGB (HKLM-x32\...\{1257fdeb-ffa3-4e17-9d4b-189075ea3656}) (Version: 1.00.02 - Galaxy Microsystems Ltd.)
GameFirst IV (HKLM-x32\...\{CF8E6767-AF00-47A9-9F68-C583556BE3D9}) (Version: 1.7.2.0 - ASUSTeK COMPUTER INC.) Hidden
GameFirst IV (HKLM-x32\...\GameFirst IV 1.7.2.0) (Version: 1.7.2.0 - ASUSTeK COMPUTER INC.)
GameInput Redistributable (HKLM-x32\...\{7E52156F-18FE-B953-BEA9-6BE6A77AFDFF}) (Version: 10.1.19041.3906 - Microsoft Corporation)
Gang Beasts (HKLM\...\Steam App 285900) (Version: - Boneloaf)
Genshin Impact (HKLM\...\Genshin Impact) (Version: 2.14.1.0 - miHoYo Co.,Ltd)
Genshin Impact Beta (HKLM\...\Genshin Impact Beta) (Version: 2.11.2.0 - miHoYo Co.,Ltd)
Git version 2.22.0.windows.1 (HKLM\...\Git_is1) (Version: 2.22.0.windows.1 - The Git Development Community)
GitHub Desktop (HKCU\...\GitHubDesktop) (Version: 2.1.0 - GitHub, Inc.)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 97.0.4692.71 - Google LLC)
GPX Common OSS (POCO, OpenSSL) and libprotobuf binaries (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GpxCommon.Oss) (Version: 7.1 - NVIDIA Corporation) Hidden
Grand Theft Auto V (HKLM\...\Steam App 271590) (Version: - Rockstar North)
HITMAN™ (HKLM\...\Steam App 236870) (Version: - IO Interactive A/S)
Hollow Knight (HKLM\...\Steam App 367520) (Version: - Team Cherry)
Hue Sync (HKLM\...\Hue Sync) (Version: 1.2.1.5 - Philips Lighting B.V.)
Hyper (HKCU\...\hyper) (Version: 3.0.2 - ZEIT, Inc.)
Hyper Light Drifter (HKLM\...\Steam App 257850) (Version: - Heart Machine)
Hyper Scape (HKLM-x32\...\Uplay Install 11957) (Version: - Ubisoft)
icecap_collection_neutral (HKLM-x32\...\{7C703135-98AC-4EB9-86C0-0C3169C99649}) (Version: 16.8.30509 - Microsoft Corporation) Hidden
icecap_collection_neutral (HKLM-x32\...\{A3B4D258-74E1-49D6-9A86-2DFEFEE48DEC}) (Version: 15.8.27906 - Microsoft Corporation) Hidden
icecap_collection_x64 (HKLM\...\{7C914878-C64B-4CA6-8E41-91308877A586}) (Version: 16.8.30509 - Microsoft Corporation) Hidden
icecap_collection_x64 (HKLM\...\{E524832A-C567-499A-8872-0D79596E4DEE}) (Version: 15.8.27906 - Microsoft Corporation) Hidden
icecap_collectionresources (HKLM-x32\...\{469961DF-482F-4213-ACD4-4AFD443F2A88}) (Version: 15.8.27924 - Microsoft Corporation) Hidden
icecap_collectionresources (HKLM-x32\...\{CDD0EC5B-EBEE-4822-B994-78AD30D90874}) (Version: 16.8.30607 - Microsoft Corporation) Hidden
icecap_collectionresourcesx64 (HKLM-x32\...\{12246E9A-D1A6-4D96-8CEA-CCFD064B16E2}) (Version: 15.8.27924 - Microsoft Corporation) Hidden
icecap_collectionresourcesx64 (HKLM-x32\...\{8A64881A-8735-4C75-91BE-BCE0A45BCDB0}) (Version: 16.8.30530 - Microsoft Corporation) Hidden
IIS 10.0 Express (HKLM\...\{ACE1F06E-DB73-449B-ADEF-C94F4C8685A9}) (Version: 10.0.03017 - Microsoft Corporation)
IIS Express Application Compatibility Database for x64 (HKLM\...\{08274920-8908-45c2-9258-8ad67ff77b09}.sdb) (Version: - ) Hidden
IIS Express Application Compatibility Database for x86 (HKLM\...\{ad846bae-d44b-4722-abad-f7420e08bcd9}.sdb) (Version: - ) Hidden
Incredibox (HKLM\...\Steam App 1545450) (Version: - So Far So Good)
Intel(R) C++ Redistributables on Intel(R) 64 (HKLM-x32\...\{F70BCE36-25F2-4475-A918-6209B3D85BF3}) (Version: 15.0.179 - Intel Corporation)
Intel(R) Network Connections 23.5.2.0 (HKLM\...\PROSetDX) (Version: 23.5.2.0 - Intel)
Intel® Hardware Accelerated Execution Manager (HKLM\...\{7563302D-BD6B-4153-BA7D-3E3432E7C22D}) (Version: 7.5.6 - Intel Corporation)
IntelliTraceProfilerProxy (HKLM-x32\...\{7D94CF67-6666-4111-B027-D7AB7F189F70}) (Version: 15.0.18198.01 - Microsoft Corporation) Hidden
iTunes (HKLM\...\{E6FF3475-A35E-481F-8A8E-3D73CF3A30A1}) (Version: 12.10.11.2 - Apple Inc.)
Java(TM) SE Development Kit 12.0.2 (64-bit) (HKLM\...\{3FA68A00-9C88-5E69-870A-B40CB89DC2EF}) (Version: 12.0.2.0 - Oracle Corporation)
Java(TM) SE Development Kit 14.0.1 (64-bit) (HKLM\...\{AF1122ED-203C-5CC1-8249-F85131C61AC4}) (Version: 14.0.1.0 - Oracle Corporation)
Kingston AURA DRAM Component (HKLM\...\{6D2D2DAF-BFE4-45A6-BF40-8A9F7FF54F42}) (Version: 1.0.28 - KINGSTON COMPONENTS INC.) Hidden
Kingston AURA DRAM Component (HKLM-x32\...\{511a62a9-1ff0-4cc5-adfe-4a5bd044a3c0}) (Version: 1.0.28 - KINGSTON COMPONENTS INC.) Hidden
Kits Configuration Installer (HKLM-x32\...\{63AAA877-5536-9481-2385-28A082100D78}) (Version: 10.1.18362.1 - Microsoft) Hidden
Launcher Prerequisites (x64) (HKLM-x32\...\{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
League of Legends (HKLM-x32\...\League of Legends 1.0) (Version: 1.0 - Riot Games, Inc)
Life is Strange™ (HKLM\...\Steam App 319630) (Version: - DONTNOD Entertainment)
Lightshot-5.4.0.35 (HKLM-x32\...\{30A5B3C9-2084-4063-A32A-628A98DE512B}_is1) (Version: 5.4.0.35 - Skillbrains)
Logitech Gaming Software 8.98 (HKLM\...\Logitech Gaming Software) (Version: 8.98.234 - Logitech Inc.)
Lovers in a Dangerous Spacetime (HKLM\...\Steam App 252110) (Version: - Asteroid Base)
Mark of the Ninja (HKLM\...\Steam App 214560) (Version: - Klei Entertainment)
MATLAB R2018a (HKLM\...\Matlab R2018a) (Version: 9.4 - MathWorks)
McAfee LiveSafe (HKLM-x32\...\MSC) (Version: 16.0 R42 - McAfee, LLC)
Microsoft .NET Core SDK 2.1.521 (x64) (HKLM-x32\...\{ec274d4f-a373-4766-bb0e-e20bf20dc910}) (Version: 2.1.521 - Microsoft Corporation)
Microsoft .NET Core SDK 2.1.700 (x64) (HKLM-x32\...\{2335da6c-07b8-4479-b89c-f52986f760f6}) (Version: 2.1.700 - Microsoft Corporation)
Microsoft .NET SDK 5.0.103 (x64) from Visual Studio (HKLM\...\{58BDEF15-554A-4AF7-969F-C34918026641}) (Version: 5.1.321.7308 - Microsoft Corporation)
Microsoft 365 Apps for enterprise - en-us (HKLM\...\O365ProPlusRetail - en-us) (Version: 16.0.13801.21092 - Microsoft Corporation)
Microsoft Edge (HKLM-x32\...\Microsoft Edge) (Version: 97.0.1072.55 - Microsoft Corporation)
Microsoft Edge Update (HKLM-x32\...\Microsoft Edge Update) (Version: 1.3.153.55 - )
Microsoft Edge WebView2 Runtime (HKLM-x32\...\Microsoft EdgeWebView) (Version: 97.0.1072.55 - Microsoft Corporation)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 21.245.1128.0002 - Microsoft Corporation)
Microsoft OneNote Home and Student 2016 - en-us (HKLM\...\OneNoteFreeRetail - en-us) (Version: 16.0.13801.21092 - Microsoft Corporation)
Microsoft Project - en-us (HKLM\...\ProjectProRetail - en-us) (Version: 16.0.13801.21092 - Microsoft Corporation)
Microsoft SQL Server 2014 Express LocalDB (HKLM\...\{52EBC484-44A1-4DC5-824A-0A503735ABD8}) (Version: 12.1.4100.1 - Microsoft Corporation)
Microsoft SQL Server 2016 LocalDB (HKLM\...\{9097BF1A-13A0-4A4A-A1F8-473E2A669863}) (Version: 13.1.4001.0 - Microsoft Corporation)
Microsoft SQL Server Compact 4.0 SP1 x64 ENU (HKLM\...\{78909610-D229-459C-A936-25D92283D3FD}) (Version: 4.0.8876.1 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2019 CTP2.2 (HKLM\...\{8D7CE3B0-5379-46FE-9F4B-A65D9F4CC1F1}) (Version: 15.0.1200.24 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2019 CTP2.2 (HKLM-x32\...\{725CC962-98BD-42C7-87D8-51C680FB1779}) (Version: 15.0.1200.24 - Microsoft Corporation)
Microsoft Update Health Tools (HKLM\...\{E876418F-BE59-4D8C-B9A5-74B056B676FA}) (Version: 2.93.0.0 - Microsoft Corporation)
Microsoft Visual Basic PowerPacks 10.0 (HKLM-x32\...\{2D9F8079-7D50-3EFD-B3BD-ED642E4EE756}) (Version: 10.0.20911 - Microsoft)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{071c9b48-7c32-4621-a0ac-3f809523288f}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32\...\{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.40660 (HKLM-x32\...\{ef6b00ec-13e1-4c25-9064-b2f383cb8412}) (Version: 12.0.40660.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.40660 (HKLM-x32\...\{61087a79-ac85-455c-934d-1fa22cc64f36}) (Version: 12.0.40660.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.28.29334 (HKLM-x32\...\{a9cfe9c7-e54f-46cd-9c5c-542ff8e3e8c4}) (Version: 14.28.29334.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.28.29334 (HKLM-x32\...\{b2d0f752-adc5-496e-8f70-8669de01f746}) (Version: 14.28.29334.0 - Microsoft Corporation)
Microsoft Visual Studio Code (User) (HKCU\...\{771FD6B0-FA20-440A-A002-3B3BAC16DC50}_is1) (Version: 1.63.2 - Microsoft Corporation)
Microsoft Visual Studio Installer (HKLM\...\{6F320B93-EE3C-4826-85E0-ADF79F8D4C61}) (Version: 2.11.47.9733 - Microsoft Corporation)
Microsoft Web Deploy 4.0 (HKLM\...\{B9DCF505-5A79-4CB4-8440-28B89798ABAB}) (Version: 10.0.2228 - Microsoft Corporation)
Microsoft XNA Framework Redistributable 4.0 Refresh (HKLM-x32\...\{D69C8EDE-BBC5-436B-8E0E-C5A6D311CF4F}) (Version: 4.0.30901.0 - Microsoft Corporation)
Minecraft Launcher (HKLM-x32\...\{810F1419-7760-402E-8772-B4054FAA2B72}) (Version: 1.0.0.0 - Mojang)
Mirror's Edge™ Catalyst (HKLM-x32\...\{12228a0d-f6ad-4691-82af-d2c643424468}) (Version: 1.0.3.47248 - Electronic Arts)
ModelSim - Intel FPGA Starter Edition 18.1.0.625 (HKLM\...\ModelSim - Intel FPGA Starter Edition 18.1.0.625) (Version: 18.1 - Intel Corporation)
MongoDB 4.2.7 2008R2Plus SSL (64 bit) (HKLM\...\{296C5C91-6070-4447-9A94-F6F4722B9583}) (Version: 4.2.7 - MongoDB Inc.)
MongoDB Compass Community (HKCU\...\MongoDBCompassCommunity) (Version: 1.21.2 - MongoDB Inc)
Mozilla Firefox 70.0.1 (x64 en-US) (HKLM\...\Mozilla Firefox 70.0.1 (x64 en-US)) (Version: 70.0.1 - Mozilla)
Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 70.0.1 - Mozilla)
MSI Development Tools (HKLM-x32\...\{DB4DB790-64DD-1902-4BF2-833B3B6DBCA1}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Navigation Updater (HKLM-x32\...\{090ACE55-8A91-4E80-AAE5-A44E8E363E72}) (Version: 1.0.67.5 - HYUNDAI MOTOR GROUP)
Nexon Launcher (HKLM-x32\...\Nexon Nexon Launcher) (Version: 2.0.0 - Nexon)
No Man's Sky (HKLM\...\Steam App 275850) (Version: - Hello Games)
Node.js (HKLM\...\{1B300111-9213-4F0B-9BE4-AEDEB1F203C1}) (Version: 12.18.0 - Node.js Foundation)
NVAPI Monitor plugin for NvContainer (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer.NvapiMonitor) (Version: 1.33 - NVIDIA Corporation) Hidden
NVIDIA FrameView SDK 1.1.4923.29968894 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_FrameViewSdk) (Version: 1.1.4923.29968894 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.23.0.74 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.23.0.74 - NVIDIA Corporation)
NVIDIA Graphics Driver 471.11 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 471.11 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.38.60 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.38.60 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.19.0218 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.19.0218 - NVIDIA Corporation)
NvModuleTracker (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvModuleTracker.Driver) (Version: 6.14.24370.22713 - NVIDIA Corporation) Hidden
NZXT CAM 4.30.2 (HKLM\...\ac0666ae-ee66-5310-ac01-9d6348133b2d) (Version: 4.30.2 - NZXT, Inc.)
Oculus (HKLM\...\Oculus) (Version: <3 - Facebook Technologies, LLC)
Office 16 Click-to-Run Extensibility Component (HKLM\...\{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.13801.20638 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.13801.21092 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (HKLM\...\{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.13801.20638 - Microsoft Corporation) Hidden
ONE PIECE PIRATE WARRIORS 3 (HKLM\...\Steam App 331600) (Version: - KOEI TECMO GAMES CO., LTD.)
OpenAL (HKLM-x32\...\OpenAL) (Version: - )
Ori and the Blind Forest: Definitive Edition (HKLM\...\Steam App 387290) (Version: - Moon Studios GmbH)
Overcooked (HKLM\...\Steam App 448510) (Version: - Ghost Town Games Ltd.)
Overwatch (HKLM-x32\...\Overwatch) (Version: - Blizzard Entertainment)
Patriot Viper M2 SSD RGB (HKLM\...\{0886A906-0625-4A43-930D-AA92F6665AF4}) (Version: 1.00.04 - Patriot Memory) Hidden
Patriot Viper M2 SSD RGB (HKLM-x32\...\{ebb7013c-0b03-497c-bed1-1e48e806a593}) (Version: 1.00.04 - Patriot Memory)
Patriot Viper RGB (HKLM\...\{E42E13B0-071E-49C1-B1CC-58198E82F302}) (Version: 1.00.08 - Patriot Memory) Hidden
Patriot Viper RGB (HKLM-x32\...\{4b7bfeff-ac47-46c1-aea6-4556f5f0e6bb}) (Version: 1.00.08 - Patriot Memory)
PDF Report Writer (novaPDF 6.4 printer) (HKLM\...\PDF Report Writer_is1) (Version: - Softland)
Personal Accelerator for Revit (HKLM\...\{7C317DB0-F399-4024-A289-92CF4B6FB256}) (Version: 16.0.1205.0 - Autodesk) Hidden
Personal Accelerator for Revit (HKLM\...\Personal Accelerator for Revit) (Version: 16.0.1205.0 - Autodesk)
PHISON HAL (HKLM\...\{966E33F0-6786-4B38-AA29-C1B3F6C1955D}) (Version: 1.0.3.0 - PHISON Electronics Corp.) Hidden
PHISON HAL (HKLM-x32\...\{05b28ddf-a973-483c-a6ad-95d0897a3ef7}) (Version: 1.0.3.0 - PHISON Electronics Corp.) Hidden
PLAYERUNKNOWN'S BATTLEGROUNDS (HKLM\...\Steam App 578080) (Version: - PUBG Corporation)
Poly Bridge (HKLM\...\Steam App 367450) (Version: - Dry Cactus)
Portal 2 (HKLM\...\Steam App 620) (Version: - Valve)
Portal Knights (HKLM\...\Steam App 374040) (Version: - Keen Games)
PostgreSQL 14 (HKLM\...\PostgreSQL 14) (Version: 14 - PostgreSQL Global Development Group)
Postman-win64-7.34.0 (HKCU\...\Postman) (Version: 7.34.0 - Postman)
Project Winter (HKLM\...\Steam App 774861) (Version: - Other Ocean Interactive)
Python 3.6.5 (Anaconda3 5.2.0 64-bit) (HKCU\...\Python 3.6.5 (Anaconda3 5.2.0 64-bit)) (Version: 5.2.0 - Anaconda, Inc.)
Python Launcher (HKLM-x32\...\{A28C27E4-A725-482A-9C65-61EDC0E4D583}) (Version: 3.7.6657.0 - Python Software Foundation)
Quartus Prime Lite Edition (Free) 18.1.0.625 (HKLM\...\Quartus Prime Lite Edition (Free) 18.1.0.625) (Version: 18.1 - Intel Corporation)
REALTEK Bluetooth Filter Driver (HKLM-x32\...\{9D3D8C60-A5EF-4123-B2B9-172095903AD}) (Version: 1.4.887.170518 - REALTEK Semiconductor Corp.)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8339 - Realtek Semiconductor Corp.)
Realtek PCI-E Wireless LAN Driver (HKLM-x32\...\InstallShield_{70714FB7-4084-4202-A599-2D5935DECB67}) (Version: Drv_3.00.0030 - REALTEK Semiconductor Corp.)
Respondus LockDown Browser 2 (HKLM-x32\...\{BBC7F69B-7A94-41E9-8A4B-B55A8D06431F}) (Version: 2.00.0000 - Respondus)
Riot Vanguard (HKLM\...\Riot Vanguard) (Version: - Riot Games, Inc.)
Risk of Rain (HKLM\...\Steam App 248820) (Version: - Hopoo Games, LLC)
Rivals of Aether (HKLM\...\Steam App 383980) (Version: - Dan Fornace)
Rocket League (HKLM\...\Steam App 252950) (Version: - Psyonix, Inc.)
Rockstar Games Launcher (HKLM-x32\...\Rockstar Games Launcher) (Version: 1.0.17.199 - Rockstar Games)
Rockstar Games Social Club (HKLM-x32\...\Rockstar Games Social Club) (Version: 2.0.4.3 - Rockstar Games)
ROG Live Service (HKLM-x32\...\{2D87BFB6-C184-4A59-9BBE-3E20CE797631}) (Version: 1.2.18.5 - ASUSTek COMPUTER INC.)
SDK ARM Additions (HKLM-x32\...\{73681F86-CD86-4208-572F-959B45430B04}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
SDK ARM Redistributables (HKLM-x32\...\{67EE3804-9642-62BA-EBF1-B1561FB4ECBE}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
SeaTools for Windows 1.4.0.6 (HKLM-x32\...\SeaTools for Windows) (Version: 1.4.0.6 - Seagate Technology)
Shovel Knight: Treasure Trove (HKLM\...\Steam App 250760) (Version: - Yacht Club Games)
Skype™ 7.40 (HKLM-x32\...\{3B7E914A-93D5-4A29-92BB-AF8C3F66C431}) (Version: 7.40.151 - Skype Technologies S.A.)
Slime Rancher (HKLM\...\Steam App 433340) (Version: - Monomi Park)
Speccy (HKLM\...\Speccy) (Version: 1.32 - Piriform)
Splasher (HKLM\...\Steam App 446840) (Version: - Splashteam)
Starbound (HKLM\...\Steam App 211820) (Version: - Chucklefish)
Stardew Valley (HKLM\...\Steam App 413150) (Version: - ConcernedApe)
SteamVR (HKLM\...\Steam App 250820) (Version: - Valve)
SteamWorld Heist (HKLM-x32\...\{2D7B207C-0E17-4444-8555-47EAECABAE57}) (Version: - Image & Form)
Stick Fight: The Game (HKLM\...\Steam App 674940) (Version: - Landfall West)
Streamlabs OBS 0.11.6 (HKLM\...\029c4619-0385-5543-9426-46f9987161d9) (Version: 0.11.6 - General Workings, Inc.)
Sublime Text Build 3176 (HKLM\...\Sublime Text 3_is1) (Version: - Sublime HQ Pty Ltd)
SUPERHOT (HKLM-x32\...\{62F505D5-9210-4784-9094-17CDC868F6DA}) (Version: - SUPERHOT Sp. z o.o.)
SUPERHOT VR (HKLM\...\Steam App 617830) (Version: - SUPERHOT Team)
Terraria (HKLM\...\Steam App 105600) (Version: - Re-Logic)
The Awesome Adventures of Captain Spirit (HKLM\...\Steam App 845070) (Version: - DONTNOD Entertainment)
The Jackbox Party Pack 6 (HKLM\...\Steam App 1005300) (Version: - Jackbox Games, Inc.)
The Witcher 3: Wild Hunt (HKLM\...\Steam App 292030) (Version: - CD PROJEKT RED)
Totally Accurate Battlegrounds (HKLM\...\Steam App 823130) (Version: - Landfall)
Twitch (HKCU\...\{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 8.0.0 - Twitch Interactive, Inc.)
UE4 Prerequisites (x64) (HKLM\...\{36EAD5CF-44EF-4FCF-8BE1-D96C4835D7A4}) (Version: 1.0.11.0 - Epic Games, Inc.) Hidden
UE4 Prerequisites (x64) (HKLM-x32\...\{2890ae6b-90e9-448d-b3e6-97e43c21e2fd}) (Version: 1.0.13.0 - Epic Games, Inc.) Hidden
Undertale (HKLM\...\Steam App 391540) (Version: - tobyfox)
Unity 2020.3.22f1 (HKLM-x32\...\Unity 2020.3.22f1) (Version: 2020.3.22f1 - Unity Technologies ApS)
Unity Hub 2.4.5 (HKLM\...\{Unity Technologies - Hub}) (Version: 2.4.5 - Unity Technologies Inc.)
Universal CRT Extension SDK (HKLM-x32\...\{13952D7A-B7B3-F4F8-5F29-5CD18E8168B7}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Universal CRT Headers Libraries and Sources (HKLM-x32\...\{74CBC330-ED16-31B9-E8BE-0C6A8E67DE32}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Universal CRT Redistributable (HKLM-x32\...\{847D4DAF-0182-265B-324F-406462E8A90D}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Universal CRT Tools x64 (HKLM\...\{54FE4D23-11A2-F1C4-76E9-79C8FB40A4A1}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Universal CRT Tools x86 (HKLM-x32\...\{9F7B0D96-881D-8850-C303-43F3A08E6902}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Universal General MIDI DLS Extension SDK (HKLM-x32\...\{6F54BF87-2EE6-FA6D-431D-33A665992D49}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Update for (KB2504637) (HKLM-x32\...\{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}.KB2504637) (Version: 1 - Microsoft Corporation)
Update for Windows 10 for x64-based Systems (KB4023057) (HKLM\...\{16AD6161-2E47-4BF1-AA77-0946EFE93E08}) (Version: 2.61.0.0 - Microsoft Corporation)
Uplay (HKLM-x32\...\Uplay) (Version: 45.0 - Ubisoft)
USBHelperLauncher (HKCU\...\USBHelperLauncher) (Version: 0.15 - FailedShack)
VALORANT (HKCU\...\Riot Game valorant.live) (Version: - Riot Games, Inc)
vcpp_crt.redist.clickonce (HKLM-x32\...\{10D9FDCA-0D16-4C80-91DD-EDDA62A0F29D}) (Version: 14.28.29334 - Microsoft Corporation) Hidden
vcpp_crt.redist.clickonce (HKLM-x32\...\{253D6AD3-5786-4B3B-B4E1-E082482A1F26}) (Version: 14.16.27033 - Microsoft Corporation) Hidden
Visual C++ 2008 - x64 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{6DA2B636-698A-3294-BF4A-B5E11B238CDD}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x64 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x64 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x64 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x86 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x86 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{14866AAD-1F23-39AC-A62B-7091ED1ADE64}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x86 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{4B90093A-5D9C-3956-8ABB-95848BE6EFAD}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x86 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual Studio Community 2019 (HKLM-x32\...\9db064f2) (Version: 16.8.6 - Microsoft Corporation)
Voicemod (HKLM\...\{8435A407-F778-4647-9CDB-46E5EC50BAD0}_is1) (Version: 2.23.1.2 - Voicemod S.L.)
VRChat (HKLM\...\Steam App 438100) (Version: - VRChat Inc.)
VS Immersive Activate Helper (HKLM-x32\...\{A71406B5-E487-4B01-8E59-D466841350F5}) (Version: 16.0.102.0 - Microsoft Corporation) Hidden
VS JIT Debugger (HKLM\...\{C7E8A4F2-EF09-42A8-B892-69D5ED99D965}) (Version: 16.0.102.0 - Microsoft Corporation) Hidden
VS Script Debugging Common (HKLM\...\{A4272808-82F5-410F-A5F9-1BF6F63F6B9A}) (Version: 16.0.102.0 - Microsoft Corporation) Hidden
vs_BlendMsi (HKLM-x32\...\{B5E3A3E1-1529-4D5A-9E95-34971FA07825}) (Version: 16.0.28329 - Microsoft Corporation) Hidden
vs_BlendMsi (HKLM-x32\...\{C5D83E0F-12E7-4BA3-98E6-DAE0E73B5BF9}) (Version: 15.0.27205 - Microsoft Corporation) Hidden
vs_clickoncebootstrappermsi (HKLM-x32\...\{78696386-A4B6-4F69-B558-2667CD3A579D}) (Version: 16.8.30530 - Microsoft Corporation) Hidden
vs_clickoncebootstrappermsires (HKLM-x32\...\{271F1F42-B547-4498-825F-590DBB1774F7}) (Version: 16.0.28329 - Microsoft Corporation) Hidden
vs_clickoncesigntoolmsi (HKLM-x32\...\{30D97A69-3C0F-4552-9A72-60E591B210C7}) (Version: 16.0.28329 - Microsoft Corporation) Hidden
vs_communitymsi (HKLM-x32\...\{DEB11EB7-B61A-4883-8CB0-99013A4873AB}) (Version: 16.8.30608 - Microsoft Corporation) Hidden
vs_communitymsires (HKLM-x32\...\{95E79BBC-97FD-4FEB-91B5-CC0231324812}) (Version: 16.0.28329 - Microsoft Corporation) Hidden
vs_devenvmsi (HKLM-x32\...\{AD0C92A4-1514-4BC1-A723-A272A8343924}) (Version: 16.0.28329 - Microsoft Corporation) Hidden
vs_devenvmsi (HKLM-x32\...\{BFFA2FFB-1095-4ADD-A352-368806D2412B}) (Version: 15.0.26621 - Microsoft Corporation) Hidden
vs_filehandler_amd64 (HKLM-x32\...\{E9439DB7-BF01-4820-8CB1-80957150AB86}) (Version: 16.8.30530 - Microsoft Corporation) Hidden
vs_filehandler_x86 (HKLM-x32\...\{8990F1B6-F880-4E73-A2D9-7A611F4C38A1}) (Version: 16.8.30530 - Microsoft Corporation) Hidden
vs_FileTracker_Singleton (HKLM-x32\...\{3C4B2ED3-2296-4203-A420-AC042BE8484D}) (Version: 16.8.30509 - Microsoft Corporation) Hidden
vs_Graphics_Singletonx64 (HKLM\...\{2EE7854B-D67F-41D8-94F4-D885FA7C4385}) (Version: 16.8.30608 - Microsoft Corporation) Hidden
vs_Graphics_Singletonx86 (HKLM-x32\...\{4085E209-B871-4079-B58D-778D5293AFD5}) (Version: 16.8.30608 - Microsoft Corporation) Hidden
vs_minshellinteropmsi (HKLM-x32\...\{27B16914-BC5D-4018-8074-071262A27F6D}) (Version: 16.2.28917 - Microsoft Corporation) Hidden
vs_minshellmsi (HKLM-x32\...\{08AF5DA9-F3BD-4B59-8D99-C47CC4D53CAD}) (Version: 16.8.30530 - Microsoft Corporation) Hidden
vs_minshellmsi (HKLM-x32\...\{68B8AD33-CE97-4C3D-9583-669C39D21BA5}) (Version: 15.9.28302 - Microsoft Corporation) Hidden
vs_minshellmsires (HKLM-x32\...\{DE982ACB-A44E-44A5-BEA5-F0816490312C}) (Version: 16.8.30530 - Microsoft Corporation) Hidden
vs_SQLClickOnceBootstrappermsi (HKLM-x32\...\{E1FD1D9D-0611-4DE5-826F-37FAC17706AC}) (Version: 16.8.30615 - Microsoft Corporation) Hidden
vs_tipsmsi (HKLM-x32\...\{E208E682-50EE-4F2F-9860-C91B906B8A03}) (Version: 16.0.28329 - Microsoft Corporation) Hidden
vs_vswebprotocolselectormsi (HKLM-x32\...\{BEEB2E56-91DB-4AFB-AC88-8E98B18DD889}) (Version: 16.8.30509 - Microsoft Corporation) Hidden
Vulkan Run Time Libraries 1.0.65.1 (HKLM\...\VulkanRT1.0.65.1) (Version: 1.0.65.1 - LunarG, Inc.) Hidden
Vulkan Run Time Libraries 1.0.65.1 (HKLM\...\VulkanRT1.0.65.1-2) (Version: 1.0.65.1 - LunarG, Inc.) Hidden
Vulkan Run Time Libraries 1.0.65.1 (HKLM\...\VulkanRT1.0.65.1-3) (Version: 1.0.65.1 - LunarG, Inc.) Hidden
Wacom Tablet (HKLM\...\Wacom Tablet Driver) (Version: 6.3.37-3 - Wacom Technology Corp.)
Wallpaper Engine (HKLM\...\Steam App 431960) (Version: - Wallpaper Engine Team)
Warframe (HKLM\...\Steam App 230410) (Version: - Digital Extremes)
WebAdvisor by McAfee (HKLM-x32\...\{35ED3F83-4BDC-4c44-8EC6-6A8301C7413A}) (Version: 4.1.1.659 - McAfee, LLC)
WhatsApp (HKCU\...\WhatsApp) (Version: 2.2147.16 - WhatsApp)
WinAppDeploy (HKLM-x32\...\{8E3AE0EF-D067-700C-BDB4-10D5552155DC}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Windows PC Health Check (HKLM\...\{B1E7D0FD-7CFE-4E0C-A5DA-0F676499DB91}) (Version: 3.2.2110.14001 - Microsoft Corporation)
Windows SDK AddOn (HKLM-x32\...\{1E76DFA7-96F3-4281-8E41-8A226C3E42EE}) (Version: 10.1.0.0 - Microsoft Corporation)
Windows Software Development Kit - Windows 10.0.18362.1 (HKLM-x32\...\{126dedf0-cc0e-4b48-9ece-806b0e437195}) (Version: 10.1.18362.1 - Microsoft Corporation)
WinRT Intellisense Desktop - en-us (HKLM-x32\...\{E67F1F03-FB4A-3D61-8999-E6A4C4B26F34}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
WinRT Intellisense Desktop - Other Languages (HKLM-x32\...\{7EF010FF-7800-28BA-FF49-2D219EC7BA82}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
WinRT Intellisense IoT - en-us (HKLM-x32\...\{36AE12FB-4349-6EAA-B6E4-5F4E06FA8AE8}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
WinRT Intellisense IoT - Other Languages (HKLM-x32\...\{6B03A6A4-643C-57CE-CA6F-4E19BF47497A}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
WinRT Intellisense Mobile - en-us (HKLM-x32\...\{918A448F-59E8-FBF5-B087-D3F07160C7E0}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
WinRT Intellisense PPI - en-us (HKLM-x32\...\{66483041-F590-EC46-4AF0-EE39C62FB680}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
WinRT Intellisense PPI - Other Languages (HKLM-x32\...\{9C61E6D2-C43E-6746-B519-6185558C4A24}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
WinRT Intellisense UAP - en-us (HKLM-x32\...\{6B37CC5B-78DF-5050-2215-68479716A587}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
WinRT Intellisense UAP - Other Languages (HKLM-x32\...\{250D5341-0879-4016-399C-BBCD87B80E95}) (Version: 10.1.18362.1 - Microsoft Corporation) Hidden
Worksharing Monitor for Autodesk Revit 2019 (HKLM\...\{5063E738-1901-0010-0000-7B7B9AB0B696}) (Version: 19.0.1.1 - Autodesk) Hidden
Worksharing Monitor for Autodesk Revit 2019 (HKLM\...\Worksharing Monitor for Autodesk Revit 2019) (Version: 19.0.1.1 - Autodesk)
Yarn (HKLM-x32\...\{31A0DA57-5E85-4046-995D-8CD691AA4B84}) (Version: 1.22.5 - Yarn Contributors)
Zoom (HKCU\...\ZoomUMX) (Version: 5.8.0 (1324) - Zoom Video Communications, Inc.)
Name: Realtek High Definition Audio
Description: Realtek High Definition Audio
Class Guid: {4d36e96c-e325-11ce-bfc1-08002be10318}
Manufacturer: Realtek
Service: IntcAzAudAddService
Device ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_1168&SUBSYS_10438723&REV_1000\4&292560CE&0&0001
Problem: : This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
Resolution: Update the driver
Name: Microsoft Hyper-V Virtualization Infrastructure Driver
Description: Microsoft Hyper-V Virtualization Infrastructure Driver
Class Guid: {4d36e97d-e325-11ce-bfc1-08002be10318}
Manufacturer: Microsoft
Service: Vid
Device ID: ROOT\VID\0000
Name: HD Pro Webcam C920
Description: HD Pro Webcam C920
Manufacturer: Logitech
Service: usbaudio
Device ID: USB\VID_046D&PID_082D&MI_02\6&1196637&0&0002
Percentage of memory in use: 19%
Total physical RAM: 16319.46 MB
Available physical RAM: 13141 MB
Total Virtual: 30143.46 MB
Available Virtual: 27239.25 MB
1 Drive c: () (Fixed) (Total:464.71 GB) (Free:57.58 GB) NTFS
2 Drive d: (Storage) (Fixed) (Total:1862.89 GB) (Free:148.17 GB) NTFS
3 Drive f: (LARO USB3) (Removable) (Total:57.7 GB) (Free:55.61 GB) FAT32
User accounts for \\LARO-DESKTOP
ivanr WDAGUtilityAccount
**** End of log ****
The application errors seem to all be for when I was attempting to install Minitool and might be related to... memory?
Forgot to mention: This is a desktop and it's got a Corsair RMx 750 Watts (80+ Gold Certified) ATX Power Supply
See now that Speccy and Minitoolbox is installed that we can get a report in normal mode.
Lets see what happens when the system is in a clean boot. Can be used to narrow down problem software.
Have you tried reseating the RAM and or any of the hardware?
(Unless you have thermal paste do not touch the CPU)
If you think it maybe the RAM over night you can run Memtester and see if it pick up anythig. Run for several passes just because it fins nothing does not mean that it wont on the second or fourth.
Hi! So Speccy and Minitoolbox crash in normal mode-- so it doesn't seem to be possible. I can install and run MemTest86 but I can anticipate I'll only be able to do it in Safe Mode.
I thought that the problem vanishing during Safe Mode pointed at it not being a hardware issue. I'll try reseating things just in case, however.
MemTest86 will create a self booting USB drive that will run independently of the OS.
Boots from a USB flash drive to test the RAM in your computer for faults.
Did the clean boot make and differance?
The other thing you can try is run a DIMC and SFC.
Hello,
I tried reseating the RAM and tightening other things but it didn't make a difference.
I needed the issue fixed asap so I ended up doing a fresh reinstall of Windows 10. That fixed the issue.
Never pressing "Ctrl + Shift" again at the same time in my lifetime-- haha.
Thank you so much for helping me try to solve the issue!!
