Samsung TV no sound after third Oculus Setup
I already did that test, it simply says my PC is Oculus Ready. As I said, I can use the Oculus Rift without Problems now. It is only the TV, and it only has the sound problem. It has it with and without the Oculus plugged in.
Had I known wouldnt have suggested it, still its something else ruled out.
f I do that deinstalling the monitor, won't it immediately disable my monitor? Do I just restart my PC then, will it automatically recognize and reinstall my monitor?
So I go to Device Manager, then Monitor, then Generic PnP Monitor (that's how the monitor was always called there), then right-click and uninstall, then turn off and restart my PC, and then the PC does the rest?
That is the idea, don`t forget to create a new restore point first, this will ensure that you still have the old settings to go back to should you need to.
Sorry, didn't want to sound impolite or imply you should have known :) .
I have made a restore point, I will try it out and report back, wish me luck!
No worries but fwiw to save time it is always best to include everything that you have tried in your first post.
Definitely wishing you good luck (y)
Got an early start in the morning so will be going offline soon I`m afraid.
No, sadly it also didn't help... I uninstalled the monitor (though it didn't turn off my TV), restarted the PC, but nothing changed.
Yeah, I need to go to bed soon too, but I kinda can't knowing I still have that problem -_- .
Sadly, it didn't help. Still no sound. Not even completely uninstalling the Oculus Software helps. I am really getting desperate right know...
I still wondered what could have happened? Why were there no problems the first 2 times I did the setup? What happened this time? I don't get it...
Only around briefly as I am working until late today :(
We could do with some additional information;
Is the computer under any warranty.
Are you ok with opening up a computer if it is needed for testing, full steps will be provided by us.
No problem, I am just glad someone is helping me, if you don't have time now, we can do it later. A friend lent me his Laptop so I can at least finish my work I had.
No Warranty anymore.
If you provide detailed steps, then I guess I would be okay with it. But only if necessary, I never like opening my PC, only doing it occasionally to clean it. But if necessary, I would be okay with it.
http://speccy.piriform.com/results/vLjAg7eDoP2TynlYVw4L7K5
EDIT: To clarify, right now my Monitor is plugged into the DisplayPort HDMI Adapter which is plugged into the Displayport of my PC, while my Oculus is plugged into the HDMI Port.
Okay, got something new.
I tried a new clean install of my GPU Drivers via AMD Radeon Settings. At first, the setup runs and then forces a reboot. After rebooting, it continues the install. When it finishes, it tells me to restart the PC, but I can choose not to. Strangely, at this point the PC actually recognizes my TV! In the Device Manager, under Sound, Video and Game Controllers it shows it as AMD HDMI Audio, and there are several instances of it under Audio Devices under Playback. There (Playback) it shows it as unplugged, and still doesn't make sounds.
But after rebooting my PC again, it is again gone, just like before. I did a clean install twice, and it happened both times.
EDIT: i started the Program Driver Easy which checks for outdated driver, and AMD High Definition Audio Device, which would be for my TV (I suppose), is listed under "unplugged devices". Even though my TV is plugged in.
Apologies for the delay getting back to you, Mondays are always a busy day for me and so I may not always be around :(
Couple of things that jumped out at me in your Speccy report, one or both may be the cause of the problem with one of the two that will definitely corrupt Windows and real soon.
Your audio is shown to be being provided by a USB Audio Class 1.0 and 2.0 Device Driver - this aside for a moment as you have more pressing things to attend to.
You are low on free storage spaces on more than one of your storage devices with the SSD that has Windows on it being the most dangerous, see my canned info below for an explanation;
Partition 1
Disk Letter: C:
File System: NTFS
Volume Serial Number: 9EBCF078
Used Space: 108 GB (96%)
Free Space: 3.43 GB (4%)
On a 120GB SSD you need to have at least 30GB free at all times so that Windows can swap files around and be updated.
Please note that in order to avoid data corruption and/or mechanical HDD failure for you must always have a minimum of 20 to 25% of the HDDs or partitions overall storage capacity available as free space where Windows is installed and between 10 and 15% of a HDDs overall storage capacity available as free space if there is data only on it, the free space allows for information to be copied to and from the drive efficiently particularily important for Windows file swapping and the installation of OS and AV updates.
Not having the above can render a computer inoperable if the HDD concerned has the OS on it due to the MBR (Master Boot Record) becoming damaged/corrupt, please see information here and here
Not having enough free storage space not only causes all sorts of stability issues but also puts you at risk of malware attack because Windows cannot be updated etc, your last Windows security update was successfully installed on 20-09-16 which is real bad :(
Apart from Windows what else do you have on the SSD.
Reactions: AugustusCaesar
Partition 1
Disk Letter: C:
File System: NTFS
Didn't I tell you not to apologize ;) . I am glad anyone helps, I also asked for help on other forums, but no one except you answers my call for help. So thank you very much! My problem seems to be a very unique one.
About the space, yeah, I know I have way too little. E: is my Gaming Drive where I install my Games. I need to uninstall some. Other than Games, not much on it.
About C:, I tried countless times to make more space, but I never seem to get much lower. I always uninstall small programs I no longer need, I tried deleting all my Game Saves and other files, but it never gets much lower than 10GB. And it was that way for a long time, I don't think I ever had much more. On C:, I only install Programs which I most of the times delete once I don't need them longer. Other than that, there is of course Hardware and PC related stuff on it.
The Windows Folder takes up 52GB, Steam 16.2GB, McAfee 3.69GB, Oculus 3.65GB (sadly it can only be installed on C:) and under User 12.1GB, the rest are smaller programs that I still need. I am now going to move Steam to E:, so that should clear up some space.
About the security update, I was under the impression there are no more updates for Windows 7, am I wrong there? I always thought about updating to Windows 10, but I am low on cash right now, and I'm wary of it itself. But it is something I will do in the near future.
(y):)
The low storage space on the C: drive is your most pressing issue atm, solve this and you just may resolve the audio issue as well, in your case this = Windows 7 - McAfee - system drivers and Oculus only.
Support for Windows 7 will end on January 14, 2020 so you still have a further 2+ yrs of updates to come and a 120GB storage device is about as smaller capacity of storage device that is recommended just for Windows, the system drivers and your AV software, anything else should be kept on a separate storage device.
(y):)
I will clean up the C: Drive and report back! With Steam moved, I now have at the very least 25GB free. How much should I at least have free?
But what do you make of the fact that the HDMI Audio Output is listed after updating the GPU Software, but before the final reboot? It was listed as unplugged and I still had no sound, but at least it was listed.
30GB minimum if you can as you will lose a chunk of it once you have fully updated Windows.
Your MB and your GPU both have HD audio and therefore HD audio drivers are available for both, having both installed can and often does cause conflicts, this is why you should only install drivers for any device that you are using as in if you are using the MBs HD audio chip you should only install the drivers for the Realtek ALC892 audio device, why we often need to do a custom install of GPU drivers is to only install those that we need, not sure how good it is these days but from when I used to use AMD GPUs I remember their CCC (catalyst control centre) software being a pain in the proverbial.
What I would suggest, after fully updating Windows, disconnect the Oculus device, the same for any other device that has audio capabilities, once done connect the bare minimum of speakers to the MBs audio port/s and see if you can get HD audio from that then post back with an update for us.
Edit to add, should have mentioned then connecting the HDMI cable to the screen etc as well if you do get audio from the
MBs integrated sound chip.
I now have 33GB free on C:, and Windows has found the updates. I will install them now.
I am sorry if I ask stupid questions, but how exactly, or where do I connect speakers to my MB? And what kind of speakers should I connect? I only have my TV, I don't have any separate Speakers.
To clarify, I only ever used my TV with this PC, which I always, until I got the Oculus, connected via a HDMI Cable to the HDMI Port of my PC. Only other device I used for Audio were my headphones I connect via USB.
Should I maybe tell you what options I have for a custom install with the AMD CCC?
(y)
No such thing as a stupid question other than ones that don`t get asked.
Wasnt aware that you did not have any separate speakers as Speccy lists the following;
Audio
Sound Cards
Oculus VR Headset
Realtek High Definition Audio
Playback Devices
Speakers (Realtek High Definition Audio)
Speakers (4- USB Audio Device): (default)
My edit may have confused things, connect your screen to the MBs HDMI port at the rear of the case.
Not atm, get Windows fully updated (may take a while) and do the MBs HDMI audi chip test first please.
Got to head out for a few hrs but will try and make sure I get back to you later.
(y)
Audio
Sound Cards
Oculus VR Headset
Playback Devices
Hm, it did always list some speakers under Playback, but no, I don't have any. I upload a pic of the current devices listed under Playback.
(y)
Audio
Sound Cards
Oculus VR Headset
Playback Devices
So, Windows got updated. I already had no Sound Device but my TV connected to the HDMI Port, no sound. I then dis- and reconnected my TV, and still no sound. It still isn't listed anywhere, not Playback and not under Device Manager.
Connect your TV to the R9 video card using the HDMI cable and then do the following for us please (a bit of work to do I`m afraid.)
Disconnect the above device and the the Oculus, we need to try and get video and audio from the TV using its HDMI port and the HDMI port on your video card, if we can do this it is a start, atm we are bit all over the place, too many devices attached etc.
Can you post an updated Speccy url and a list of drivers that are installed for us, see below;
Download DriverView from nirsoft.net
Run DriverView.
Save the results as a Text File.
Copy/paste the info into your next reply for us.
Run DriverView.
Strange thing is, my headphones are now shown under Playback as Speaker, but I think (not 100% sure, but almost) they were listed as headphones before.
So, now the only Audio capable device connected is my TV via a HDMI Cable to the HDMI Port on the back of my PC case. Still no sound of course.
http://speccy.piriform.com/results/qC3w3ZzhbjSOwov1GJujJyD
You still do not have enough free storage space on the C: drive I`m afraid :( we are fighting a losing battle until the correct amount of space is freed, we are effectively trying to fix one thing when we know for sure that something else is broken.
But atm there are no headphones connected, is this correct.
Just checking but you say "via a HDMI Cable to the HDMI Port on the back of my PC" is the HDMI cable connected to the add on video card and not to the motherboard.
Have you ever downloaded the latest BIOS for your video card.
Have you noticed in Speccy that your Samsung TV is detected and that your default audio device is now shown as - Audio - Realtek High Definition Audio, no mention of AMD which if you should have if the correct drivers are installed and you are connected to the HDMI port on the R9 video card.
Will take me a while to get through the drivers list but will get back to you shortly.
