Overheating Issue Resolved - Enter Yet Another Problem
I apologize for the no response @furious16. I'm the owner of PCHF so I will assist you :)
Let's start from the beginning shall we?
Please download the Sysnative BSOD Dump + System File Collection App - save to Documents folder.
Run the app - Double-click on the downloaded EXE file
Output = new folder created in Documents + a zipped version -- SysnativeFileCollectionApp folder + SysnativeFileCollectionApp.zip.
Please note that the app averages ~3 minutes to run on most systems; other systems - it my take as long as 10-15 minutes to run. Please be patient.
Also note: The app auto-zips the SysnativeFileCollectionApp output folder. It is located in your Documents folder.
Windows Explorer should open and highlight the zipped folder
Please attach the SysnativeFileCollectionApp.zip to your post and await further instructions :)
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Sorry for the delay.
I have all of the requested information posted in Post #35. I have not used the computer since posting that information as it has become borderline unusable anyway, so nothing will have changed.
@jmarket is waiting for information requested as per post 43.
Right. The same information requested in post 43 is already posted in post 35, because that same information was requested of me in post 32. I did not hear back from anyone after that last request. I've also been mostly unable to use the computer since about that time. Post 35 contains:
Sysnative
Minitoolkit
Chkdsk
If its really necessary, I will go and run the scans again. I have been recovering from surgery for over a week (related to the reason why I disappeared for a while a few months back, unfortunately).
Because things might've changed, I do need the information I requested unfortunately.
It's a troublesome but necessary step I'm afraid :(
Let me see if I can get it into safe mode since it seems to work best in that state, and run the scans again.
Any updates for us? After 48 hrs this thread will be closed.
Sorry. Recovery after my surgery + catching up at work = very little time to run scans on computer that barely works anymore. Info to follow in next post.
Danger: Wall of Text Incoming!
SysNative cannot be posted as attachment. I receive an error message telling me the file is too large to attach to the forum. Is there an alternative method?
Hope this information helps. Computer is just unusable due to frequency of BSOD. If it looks like there aren't many instances of it, that is because in anger I hit the reset button on the PC immediately when the crash occurs, which probably doesn't give time for a dump file.
MiniToolKit - 5/3/2018
Ran by Mike (administrator) on 03-05-2018 at 10:55:51
Running from "C:\Users\Mike\Downloads"
Microsoft Windows 7 Home Premium Service Pack 1 (X64)
Model: To be filled by O.E.M. Manufacturer: To be filled by O.E.M.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
127.0.0.1 localhost
Realtek PCIe GBE Family Controller = Local Area Connection (Connected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Mike-PC
DNS Suffix Search List. . . . . . : fios-router.home
Connection-specific DNS Suffix . : fios-router.home
Physical Address. . . . . . . . . : 40-16-7E-AF-54-0B
Link-local IPv6 Address . . . . . : fe80::18b2:6e89:355a:d9a7%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.156(Preferred)
Lease Obtained. . . . . . . . . . : Thursday, May 03, 2018 8:52:39 AM
Lease Expires . . . . . . . . . . : Friday, May 04, 2018 8:52:39 AM
DHCPv6 IAID . . . . . . . . . . . : 239081086
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-1D-27-FD-40-16-7E-AF-54-0B
Tunnel adapter isatap.fios-router.home:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5cf2:8c15:28a2:3bab:3f57:fe63(Preferred)
Link-local IPv6 Address . . . . . : fe80::28a2:3bab:3f57:fe63%12(Preferred)
Default Gateway . . . . . . . . . : ::
Server: FIOS_Quantum_Gateway.fios-router.home
Address: 192.168.1.1
Addresses: 2607:f8b0:4006:813::200e
216.58.219.206
Pinging google.com [216.58.219.206] with 32 bytes of data:
Reply from 216.58.219.206: bytes=32 time=13ms TTL=56
Reply from 216.58.219.206: bytes=32 time=7ms TTL=56
Ping statistics for 216.58.219.206:
Minimum = 7ms, Maximum = 13ms, Average = 10ms
Addresses: 2001:4998:44:41d::4
2001:4998:58:1836::10
2001:4998:44:41d::3
2001:4998:58:1836::11
2001:4998:c:1023::5
2001:4998:c:1023::4
98.137.246.8
98.138.219.231
72.30.35.10
98.138.219.232
98.137.246.7
72.30.35.9
Pinging yahoo.com [98.137.246.7] with 32 bytes of data:
Reply from 98.137.246.7: bytes=32 time=69ms TTL=55
Reply from 98.137.246.7: bytes=32 time=72ms TTL=55
Ping statistics for 98.137.246.7:
Minimum = 69ms, Maximum = 72ms, Average = 70ms
Interface List
10...40 16 7e af 54 0b ......Realtek PCIe GBE Family Controller
11...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
12...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.156 10
192.168.1.0 255.255.255.0 On-link 192.168.1.156 266
192.168.1.156 255.255.255.255 On-link 192.168.1.156 266
192.168.1.255 255.255.255.255 On-link 192.168.1.156 266
224.0.0.0 240.0.0.0 On-link 192.168.1.156 266
255.255.255.255 255.255.255.255 On-link 192.168.1.156 266
Persistent Routes:
None
IPv6 Route Table
Active Routes:
12 58 ::/0 On-link
1 306 ::1/128 On-link
12 58 2001::/32 On-link
12 306 2001:0:5cf2:8c15:28a2:3bab:3f57:fe63/128
On-link
10 266 fe80::/64 On-link
12 306 fe80::/64 On-link
10 266 fe80::18b2:6e89:355a:d9a7/128
On-link
12 306 fe80::28a2:3bab:3f57:fe63/128
On-link
1 306 ff00::/8 On-link
12 306 ff00::/8 On-link
10 266 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\Windows\SysWOW64\NLAapi.dll [52224] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\napinsp.dll [52224] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [20992] (Microsoft Corporation)
Catalog5 07 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [145648] (Microsoft Corp.)
Catalog5 08 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [145648] (Microsoft Corp.)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\NLAapi.dll [70656] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [28672] (Microsoft Corporation)
x64-Catalog5 07 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [171760] (Microsoft Corp.)
x64-Catalog5 08 C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL [171760] (Microsoft Corp.)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
Application errors:
Error: (05/03/2018 10:09:48 AM) (Source: Application Error) (User: )
Description: Faulting application name: Battle.net.exe, version: 1.11.3.10047, time stamp: 0x5add86ad
Faulting module name: Qt5Gui.dll, version: 5.9.3.0, time stamp: 0x5a555720
Exception code: 0xc0000005
Fault offset: 0x00063b80
Faulting process id: 0x1264
Faulting application start time: 0xBattle.net.exe0
Faulting application path: Battle.net.exe1
Faulting module path: Battle.net.exe2
Report Id: Battle.net.exe3
Error: (04/28/2018 12:41:29 AM) (Source: Application Hang) (User: )
Description: The program Wow-64.exe version 7.3.5.26365 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
Process ID: e84
Start Time: 01d3dea6c24e6656
Termination Time: 130
Application Path: E:\Program Files (x86)\World of Warcraft\World of Warcraft\Wow-64.exe
Report Id: 696130ae-4a9e-11e8-bd1e-40167eaf540b
Error: (04/26/2018 04:10:08 PM) (Source: Application Hang) (User: )
Process ID: 1b8
Start Time: 01d3dd99d6b8fde3
Termination Time: 8038
Report Id: 9ce3a080-498d-11e8-bcca-40167eaf540b
Error: (04/24/2018 01:27:29 PM) (Source: Application Error) (User: )
Description: Faulting application name: Wow-64.exe, version: 7.3.5.26365, time stamp: 0x5ac3eb3e
Faulting module name: Wow-64.exe, version: 7.3.5.26365, time stamp: 0x5ac3eb3e
Fault offset: 0x00000000002e6506
Faulting process id: 0x98c
Faulting application start time: 0xWow-64.exe0
Faulting application path: Wow-64.exe1
Faulting module path: Wow-64.exe2
Report Id: Wow-64.exe3
Error: (04/22/2018 06:22:01 PM) (Source: Application Error) (User: )
Description: Faulting application name: Dwm.exe, version: 6.1.7600.16385, time stamp: 0x4a5bc541
Faulting module name: atidxx64.dll, version: 23.20.15017.3010, time stamp: 0x5a724cf0
Fault offset: 0x0000000000769947
Faulting process id: 0xae8
Faulting application start time: 0xDwm.exe0
Faulting application path: Dwm.exe1
Faulting module path: Dwm.exe2
Report Id: Dwm.exe3
Error: (04/14/2018 12:45:02 AM) (Source: Application Error) (User: )
Description: Faulting application name: wmplayer.exe, version: 12.0.7601.23930, time stamp: 0x59deb649
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Fault offset: 0xf06976c6
Faulting process id: 0xfc0
Faulting application start time: 0xwmplayer.exe0
Faulting application path: wmplayer.exe1
Faulting module path: wmplayer.exe2
Report Id: wmplayer.exe3
Error: (04/13/2018 05:15:57 PM) (Source: Application Error) (User: )
Fault offset: 0x0000000000320ef1
Faulting process id: 0xec4
Error: (04/12/2018 09:01:38 AM) (Source: Application Error) (User: )
Fault offset: 0x00000000002e472b
Faulting process id: 0xf58
Error: (04/12/2018 08:25:34 AM) (Source: Application Hang) (User: )
Process ID: 50c
Start Time: 01d3d25877f91905
Termination Time: 150
Report Id: 94731ce9-3e4c-11e8-b9f9-40167eaf540b
Error: (04/09/2018 08:20:54 PM) (Source: Application Hang) (User: )
Process ID: b64
Start Time: 01d3d05d34c4dd6f
Termination Time: 195
Report Id: 06239b33-3c55-11e8-b0bb-40167eaf540b
System errors:
Error: (05/03/2018 10:40:52 AM) (Source: volsnap) (User: )
Description: The shadow copies of volume C: were aborted because the shadow copy storage could not grow due to a user imposed limit.
Error: (05/03/2018 08:52:57 AM) (Source: Service Control Manager) (User: )
Description: The Peer Networking Grouping service depends on the Peer Name Resolution Protocol service which failed to start because of the following error:
%%-2140993535
Description: The Peer Name Resolution Protocol service terminated with the following error:
%%-2140993535
%%-2140993535
%%-2140993535
Error: (05/03/2018 08:52:57 AM) (Source: PNRPSvc) (User: )
Description: 0x80630801
Error: (05/03/2018 08:52:46 AM) (Source: Service Control Manager) (User: )
%%-2140993535
%%-2140993535
Error: (05/03/2018 08:52:46 AM) (Source: PNRPSvc) (User: )
Microsoft Office Sessions:
Error: (05/13/2017 08:11:37 PM) (Source: Microsoft Office 12 Sessions)(User: )
Description: ID: 0, Application Name: Microsoft Office Word, Application Version: 12.0.6768.5000, Microsoft Office Version: 12.0.6612.1000. This session lasted 19624 seconds with 3960 seconds of active time. This session ended with a crash.
Error: (04/29/2016 12:43:49 AM) (Source: Microsoft Office 12 Sessions)(User: )
Description: ID: 0, Application Name: Microsoft Office Word, Application Version: 12.0.6747.5000, Microsoft Office Version: 12.0.6612.1000. This session lasted 42868 seconds with 240 seconds of active time. This session ended with a crash.
Error: (12/06/2015 02:45:00 PM) (Source: Microsoft Office 12 Sessions)(User: )
Description: ID: 0, Application Name: Microsoft Office Word, Application Version: 12.0.6735.5000, Microsoft Office Version: 12.0.6612.1000. This session lasted 23 seconds with 0 seconds of active time. This session ended with a crash.
Error: (12/06/2015 02:44:25 PM) (Source: Microsoft Office 12 Sessions)(User: )
Description: ID: 0, Application Name: Microsoft Office Word, Application Version: 12.0.6735.5000, Microsoft Office Version: 12.0.6612.1000. This session lasted 93577 seconds with 660 seconds of active time. This session ended with a crash.
CodeIntegrity Errors:
Date: 2017-11-15 16:48:05.000
Description: Code Integrity is unable to verify the image integrity of the file \Device\HarddiskVolume2\Windows\System32\drivers\SETD2E0.tmp because the set of per-page image hashes could not be found on the system.
Date: 2017-11-15 16:48:04.598
Date: 2017-11-15 16:48:04.211
Date: 2017-11-15 16:48:03.842
Date: 2017-11-15 16:48:03.450
Date: 2017-11-15 16:48:03.058
Date: 2017-11-15 16:44:04.119
Date: 2017-11-15 16:44:03.729
Date: 2017-11-15 16:44:03.136
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 18.011.20038 - Adobe Systems Incorporated)
Adobe Flash Player 28 ActiveX (HKLM-x32\...\Adobe Flash Player ActiveX) (Version: 28.0.0.161 - Adobe Systems Incorporated)
Adobe Flash Player 28 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 28.0.0.161 - Adobe Systems Incorporated)
AMD Software (HKLM\...\AMD Catalyst Install Manager) (Version: 18.2.1 - Advanced Micro Devices, Inc.)
Asmedia ASM104x USB 3.0 Host Controller Driver (HKLM-x32\...\{E4FB0B39-C991-4EE7-95DD-1A1A7857D33D}) (Version: 1.16.12.0 - Asmedia Technology)
Blizzard App (HKLM-x32\...\Battle.net) (Version: - Blizzard Entertainment)
CameraHelperMsi (HKLM-x32\...\{15634701-BACE-4449-8B25-1567DA8C9FD3}) (Version: 13.51.815.0 - Logitech) Hidden
Command & Conquer™ Red Alert 2 and Yuri’s Revenge (HKLM-x32\...\{F5275D1C-D133-486D-8F07-D6C571F0A8EC}) (Version: 1.0.0.0 - Electronic Arts, Inc.)
Command and Conquer: Red Alert 3 (HKLM-x32\...\Steam App 17480) (Version: - EA Los Angeles)
Contagion (HKLM-x32\...\Steam App 238430) (Version: - Monochrome LLC)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
Dead Island (HKLM-x32\...\Steam App 91310) (Version: - Techland)
Dead State (HKLM\...\Steam App 239840) (Version: - DoubleBear Productions)
Deus Ex: Game of the Year Edition (HKLM-x32\...\Steam App 6910) (Version: - Ion Storm)
Deus Ex: Human Revolution - The Missing Link (HKLM-x32\...\Steam App 201280) (Version: - Eidos Montreal)
Deus Ex: Human Revolution (HKLM-x32\...\Steam App 28050) (Version: - Eidos Montreal)
Diablo III (HKLM-x32\...\Diablo III) (Version: - Blizzard Entertainment)
Dragon Age: Origins - Ultimate Edition (HKLM-x32\...\Steam App 47810) (Version: - BioWare)
Dragon's Lair (HKLM-x32\...\Steam App 227380) (Version: - Digital Leisure Inc.)
DuckTales Remastered (HKLM-x32\...\Steam App 237630) (Version: - WayForward)
erLT (HKLM-x32\...\{3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C}) (Version: 1.20.138.34 - Logitech, Inc.) Hidden
ffdshow [rev 2653] [2009-02-04] (HKLM\...\ffdshow64_is1) (Version: 1.0 - )
File Association Helper (HKLM\...\{C168639F-5810-4EC8-B1E8-0251AA8A771C}) (Version: 1.2.225.65451 - WinZip Computing International, LLC)
Firewatch (HKLM\...\Steam App 383870) (Version: - Campo Santo)
Friday the 13th: The Game BETA (HKLM\...\Steam App 569300) (Version: - )
Gone Home (HKLM-x32\...\Steam App 232430) (Version: - The Fullbright Company)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 66.0.3359.139 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.7 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
Heroes of the Storm (HKLM-x32\...\Heroes of the Storm) (Version: - Blizzard Entertainment)
Java 7 Update 67 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F03217067FF}) (Version: 7.0.670 - Oracle)
Junk Mail filter update (HKLM-x32\...\{0BE9E708-5DC0-4963-9CFD-0AA519090E79}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Jurassic Park: The Game (HKLM-x32\...\Steam App 201830) (Version: - Telltale Games)
Killing Time (HKLM\...\Steam App 493320) (Version: - The 3DO Company)
Logitech Gaming Software 8.94 (HKLM\...\Logitech Gaming Software) (Version: 8.94.108 - Logitech Inc.)
Logitech Unifying Software 2.50 (HKLM\...\Logitech Unifying) (Version: 2.50.25 - Logitech)
Logitech Webcam Software (HKLM-x32\...\{D40EB009-0499-459c-A8AF-C9C110766215}) (Version: 2.51 - Logitech Inc.)
Malwarebytes version 3.3.1.2183 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.3.1.2183 - Malwarebytes)
Marvel Heroes 2015 (HKLM-x32\...\Steam App 226320) (Version: - Gazillion Entertainment)
Microsoft .NET Framework 4.7.1 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.7.02558 - Microsoft Corporation)
Microsoft Games for Windows - LIVE (HKLM-x32\...\{F112F66E-25CA-42DD-983C-6118EB38F606}) (Version: 3.0.89.0 - Microsoft Corporation)
Microsoft Games for Windows - LIVE Redistributable (HKLM-x32\...\{2E660A2A-A55F-43CD-9F73-CAD7382EEB78}) (Version: 3.0.19.0 - Microsoft Corporation)
Microsoft Office 2007 Service Pack 3 (SP3) (HKLM-x32\...\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{6E107EB7-8B55-48BF-ACCB-199F86A2CD93}) (Version: - Microsoft)
Microsoft Office File Validation Add-In (HKLM-x32\...\{90140000-2005-0000-0000-0000000FF1CE}) (Version: 14.0.5130.5003 - Microsoft Corporation)
Microsoft Office Home and Student 2007 (HKLM-x32\...\HOMESTUDENTR) (Version: 12.0.6612.1000 - Microsoft Corporation)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 17.0.4035.0328 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32\...\{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.50727 (HKLM-x32\...\{15134cb0-b767-4960-a911-f2d16ae54797}) (Version: 11.0.50727.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.50727 (HKLM-x32\...\{22154f09-719a-4619-bb71-5b3356999fbf}) (Version: 11.0.50727.1 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24215 (HKLM-x32\...\{d992c12e-cab2-426f-bde3-fb8c53950b0d}) (Version: 14.0.24215.1 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32\...\{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
Movie Maker (HKLM-x32\...\{38F03569-A636-4CF3-BDDE-032C8C251304}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{DD67BE4B-7E62-4215-AFA3-F123A800A389}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
MURDERED: SOUL SUSPECT™ (HKLM-x32\...\Steam App 233290) (Version: - Airtight Games)
Nexus Mod Manager (HKLM\...\6af12c54-643b-4752-87d0-8335503010de_is1) (Version: 0.60.16 - Black Tree Gaming)
Nexus: The Jupiter Incident (HKLM-x32\...\Steam App 6420) (Version: - Mithis Games)
Norton Security Scan (HKLM-x32\...\NSS) (Version: 4.6.1.150 - Symantec Corporation)
NVIDIA PhysX (HKLM-x32\...\{8B922CF8-8A6C-41CE-A858-F1755D7F5D29}) (Version: 9.12.1031 - NVIDIA Corporation)
OpenAL (HKLM-x32\...\OpenAL) (Version: - )
Outlast (HKLM-x32\...\Steam App 238320) (Version: - Red Barrels)
Performance Profile Client (HKLM-x32\...\{99831D81-ED00-E2EC-02F7-C2197D1854C9}) (Version: 2.3.0.0 - Advanced Micro Devices, Inc.) Hidden
Plague Inc: Evolved (HKLM\...\Steam App 246620) (Version: - Ndemic Creations)
Police Quest Collection (HKLM\...\Steam App 494740) (Version: - Sierra)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.109.526.2017 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7023 - Realtek Semiconductor Corp.)
Saints Row: The Third (HKLM-x32\...\Steam App 55230) (Version: - Volition)
SAMSUNG USB Driver for Mobile Phones (HKLM\...\{D0795B21-0CDA-4a92-AB9E-6E92D8111E44}) (Version: 1.5.49.0 - SAMSUNG Electronics Co., Ltd.)
Sid Meier's Civilization V (HKLM-x32\...\Steam App 8930) (Version: - Firaxis Games)
Sins of a Solar Empire®: Trinity (HKLM-x32\...\Steam App 201290) (Version: - Ironclad Games)
Skyrim Creation Kit (HKLM-x32\...\Steam App 202480) (Version: - bgs.bethsoft.com)
Space Hulk (HKLM-x32\...\Steam App 242570) (Version: - Full Control Studios)
Space Hulk: Deathwing (HKLM\...\Steam App 298900) (Version: - Streum On Studio)
StarCraft II (HKLM-x32\...\StarCraft II) (Version: - Blizzard Entertainment)
State of Decay (HKLM-x32\...\Steam App 241540) (Version: - Undead Labs)
Steam (HKLM-x32\...\Steam) (Version: - Valve Corporation)
Stranded Deep (HKLM\...\Steam App 313120) (Version: - Beam Team Games)
Talisman: The Horus Heresy (HKLM\...\Steam App 358460) (Version: - Nomad Games)
The Bureau: XCOM Declassified (HKLM-x32\...\Steam App 65930) (Version: - 2K Marin)
The Elder Scrolls V: Skyrim (HKLM-x32\...\Steam App 72850) (Version: - Bethesda Game Studios)
The Forest (HKLM\...\Steam App 242760) (Version: - Endnight Games Ltd)
The Lord of the Rings: War in the North (HKLM-x32\...\Steam App 32800) (Version: - Snowblind Studios)
The Room (HKLM\...\Steam App 288160) (Version: - Fireproof Games)
The Stanley Parable (HKLM-x32\...\Steam App 221910) (Version: - Galactic Cafe)
The Witcher: Enhanced Edition (HKLM-x32\...\Steam App 20900) (Version: - CD Projekt RED)
Tomb Raider (HKLM-x32\...\Steam App 203160) (Version: - Crystal Dynamics)
Total War: SHOGUN 2 (HKLM\...\Steam App 34330) (Version: - The Creative Assembly)
Twitch (HKCU\...\{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 7.0.0.0 - Twitch Interactive, Inc.)
Update for 2007 Microsoft Office System (KB967642) (HKLM-x32\...\{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{C444285D-5E4F-48A4-91DD-47AAAA68E92D}) (Version: - Microsoft)
Vampire: The Masquerade - Redemption (HKLM\...\Steam App 559680) (Version: - Nihilistic Software)
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.1 - VideoLAN)
Vulkan Run Time Libraries 1.0.65.0 (HKLM\...\VulkanRT1.0.65.0) (Version: 1.0.65.0 - LunarG, Inc.) Hidden
Warhammer 40,000: Eternal Crusade (HKLM\...\Steam App 375230) (Version: - Behaviour Digital Inc.)
Warhammer 40,000: Regicide (HKLM\...\Steam App 322910) (Version: - Hammerfall Publishing)
Warhammer® 40,000™: Dawn of War® II - Chaos Rising™ (HKLM-x32\...\Steam App 20570) (Version: - Relic Entertainment)
Warhammer® 40,000™: Dawn of War® II – Retribution™ (HKLM-x32\...\Steam App 56400) (Version: - Relic Entertainment)
Warhammer® 40,000™: Dawn of War® II (HKLM-x32\...\Steam App 15620) (Version: - Relic Entertainment)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3528.0331 - Microsoft Corporation)
WinRAR 5.50 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.50.0 - win.rar GmbH)
WinZip 21.0 (HKLM\...\{CD95F661-A5C4-44F5-A6AA-ECDD91C2410D}) (Version: 21.0.12288 - WinZip Computing, S.L. )
World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment)
XCOM 2 (HKLM\...\Steam App 268500) (Version: - Firaxis)
XCOM: Enemy Unknown (HKLM-x32\...\Steam App 200510) (Version: - Firaxis Games)
Description: AODDriver4.2.0
Class Guid: {8ECC055D-047F-11D1-A537-0000F8753ED1}
Manufacturer:
Service: AODDriver4.2.0
Device ID: ROOT\LEGACY_AODDRIVER4.2.0\0000
Problem: : This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)
Resolution: The device is installed incorrectly. The problem could be a hardware failure, or a new driver might be needed.
Devices stay in this state if they have been prepared for removal.
After you remove the device, this error disappears.Remove the device, and this error should be resolved.
Description: AODDriver4.3.0
Manufacturer:
Service: AODDriver4.3.0
Device ID: ROOT\LEGACY_AODDRIVER4.3.0\0000
Percentage of memory in use: 35%
Total physical RAM: 3996.84 MB
Available physical RAM: 2586.52 MB
Total Virtual: 7991.86 MB
Available Virtual: 5418.61 MB
1 Drive c: () (Fixed) (Total:111.69 GB) (Free:34.52 GB) NTFS
3 Drive e: (New Volume) (Fixed) (Total:931.51 GB) (Free:386.65 GB) NTFS
User accounts for \\MIKE-PC
Administrator Guest Mcx1-MIKE-PC
Mike
**** End of log ****
PCHunter Scan - 5/3/2018
PC Hunter Standard --- Computer Examination Report
Examination Date: 2018-05-03 10:59
OS Information: Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
Internet Explorer: 9.11.9600.18977
Examination Items:
Process
Process Modules
Process Threads
Kernel Module
Notify Routine
Filter
DPC Timer
Worker Thread
HalDispatchTable
HalPrivateDispatchTable
HalAcpiDispatchTable
Wdf01000 Dispatch Fun
WdfFunction
MiniFilter
File System
Sfilter FileSystem Filter Callback
ClassInitData Callback
Npfs Dispatch Fun
Msfs Dispatch Fun
Usbport Dispatch Fun
System Debug
Object Hijack
Direct IO
GDT
SSDT
Shadow SSDT
FSD
Keyboard
I8042prt
Mouclass
Partmgr
Classpnp
Atapi
Acpi
Scsi
Kernel Hook
PTE HOOK
Object Type
IDT
Message Hook
Process Hook
KernelCallbackTable
Port
Tcpip
Nsiproxy
Tdx
Ndis Handler
IE Plugin
IE Shell
Spi
Hosts File
Startup
Service
Schedule Task
File Association
IFEO
IME/CTF
Firewall Rule
System User Name
Scan MBR Rootkit
Process
Process Modules
Process Threads
Kernel Module
amd_sata.sys - C:\Windows\system32\DRIVERS\amd_sata.sys - Advanced Micro Devices
amd_xata.sys - C:\Windows\system32\DRIVERS\amd_xata.sys - Advanced Micro Devices
amdxata.sys - C:\Windows\system32\drivers\amdxata.sys - Advanced Micro Devices
atikmpag.sys - C:\Windows\system32\DRIVERS\atikmpag.sys - Advanced Micro Devices, Inc.
atikmdag.sys - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
Rt64win7.sys - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
asmtxhci.sys - C:\Windows\system32\DRIVERS\asmtxhci.sys - ASMedia Technology Inc
usbfilter.sys - C:\Windows\system32\DRIVERS\usbfilter.sys - Advanced Micro Devices
LGBusEnum.sys - C:\Windows\system32\drivers\LGBusEnum.sys - Logitech Inc.
LGJoyXlCore.sys - C:\Windows\system32\drivers\LGJoyXlCore.sys - Logitech Inc.
AtihdW76.sys - C:\Windows\system32\drivers\AtihdW76.sys - Advanced Micro Devices
RTKVHD64.sys - C:\Windows\system32\drivers\RTKVHD64.sys - Realtek Semiconductor Corp.
asmthub3.sys - C:\Windows\system32\DRIVERS\asmthub3.sys - ASMedia Technology Inc
dump_diskdump.sys - C:\Windows\System32\Drivers\dump_diskdump.sys - File not found
dump_amd_sata.sys - C:\Windows\System32\Drivers\dump_amd_sata.sys - File not found
dump_dumpfve.sys - C:\Windows\System32\Drivers\dump_dumpfve.sys - File not found
LGSHidFilt.Sys - C:\Windows\system32\DRIVERS\LGSHidFilt.Sys - Logitech Inc.
BrUsbSIb.sys - C:\Windows\system32\DRIVERS\BrUsbSIb.sys - Brother Industries Ltd.
BrSerIb.sys - C:\Windows\system32\DRIVERS\BrSerIb.sys - Brother Industries Ltd.
lgcoretemp.sys - C:\Program Files\Logitech Gaming Software\Drivers\LgCoreTemp\lgcoretemp.sys - Logitech
speedfan.sys - C:\Windows\SysWOW64\speedfan.sys - Almico Software
PCHunter64ao.sys - C:\Users\Mike\Desktop\PCHunter64ao.sys - File not found
[UnloadDriver] AODDriver2.sys - C:\Program Files (x86)\AMD\Performance Profile Client\amd64\AODDriver2.sys - File not found
[UnloadDriver] AODDriver2.sys - C:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\AODDriver2.sys - File not found
[UnloadDriver] cpuz143_x64.sys - C:\Users\Mike\AppData\Local\Temp\cpuz143\cpuz143_x64.sys - File not found
[UnloadDriver] BrSerWdm.sys - C:\Windows\System32\Drivers\BrSerWdm.sys - Brother Industries Ltd.
[UnloadDriver] BrUsbMdm.sys - C:\Windows\System32\Drivers\BrUsbMdm.sys - Brother Industries Ltd.
[UnloadDriver] BrUsbSer.sys - C:\Windows\System32\Drivers\BrUsbSer.sys - Brother Industries Ltd.
[UnloadDriver] Brserid.sys - C:\Windows\System32\Drivers\Brserid.sys - Brother Industries Ltd.
[UnloadDriver] mbamswissarmy.sys - C:\Windows\System32\Drivers\mbamswissarmy.sys - Malwarebytes
[UnloadDriver] BrFiltLo.sys - C:\Windows\system32\DRIVERS\BrFiltLo.sys - Brother Industries, Ltd.
[UnloadDriver] BrFiltUp.sys - C:\Windows\system32\DRIVERS\BrFiltUp.sys - Brother Industries, Ltd.
[UnloadDriver] MegaSR.sys - C:\Windows\system32\DRIVERS\MegaSR.sys - LSI Corporation, Inc.
[UnloadDriver] SiSRaid2.sys - C:\Windows\system32\DRIVERS\SiSRaid2.sys - Silicon Integrated Systems Corp.
[UnloadDriver] adp94xx.sys - C:\Windows\system32\DRIVERS\adp94xx.sys - Adaptec, Inc.
[UnloadDriver] adpahci.sys - C:\Windows\system32\DRIVERS\adpahci.sys - Adaptec, Inc.
[UnloadDriver] adpu320.sys - C:\Windows\system32\DRIVERS\adpu320.sys - Adaptec, Inc.
[UnloadDriver] amdsbs.sys - C:\Windows\system32\DRIVERS\amdsbs.sys - AMD Technologies Inc.
[UnloadDriver] arc.sys - C:\Windows\system32\DRIVERS\arc.sys - Adaptec, Inc.
[UnloadDriver] arcsas.sys - C:\Windows\system32\DRIVERS\arcsas.sys - Adaptec, Inc.
[UnloadDriver] b57nd60a.sys - C:\Windows\system32\DRIVERS\b57nd60a.sys - Broadcom Corporation
[UnloadDriver] bxvbda.sys - C:\Windows\system32\DRIVERS\bxvbda.sys - Broadcom Corporation
[UnloadDriver] elxstor.sys - C:\Windows\system32\DRIVERS\elxstor.sys - Emulex
[UnloadDriver] evbda.sys - C:\Windows\system32\DRIVERS\evbda.sys - Broadcom Corporation
[UnloadDriver] iirsp.sys - C:\Windows\system32\DRIVERS\iirsp.sys - Intel Corp./ICP vortex GmbH
[UnloadDriver] lsi_fc.sys - C:\Windows\system32\DRIVERS\lsi_fc.sys - LSI Corporation
[UnloadDriver] lsi_sas.sys - C:\Windows\system32\DRIVERS\lsi_sas.sys - LSI Corporation
[UnloadDriver] lsi_sas2.sys - C:\Windows\system32\DRIVERS\lsi_sas2.sys - LSI Corporation
[UnloadDriver] lsi_scsi.sys - C:\Windows\system32\DRIVERS\lsi_scsi.sys - LSI Corporation
[UnloadDriver] lvbflt64.sys - C:\Windows\system32\DRIVERS\lvbflt64.sys - Logitech Inc.
[UnloadDriver] lvrs64.sys - C:\Windows\system32\DRIVERS\lvrs64.sys - Logitech Inc.
[UnloadDriver] lvuvc64.sys - C:\Windows\system32\DRIVERS\lvuvc64.sys - Logitech Inc.
[UnloadDriver] megasas.sys - C:\Windows\system32\DRIVERS\megasas.sys - LSI Corporation
[UnloadDriver] nfrd960.sys - C:\Windows\system32\DRIVERS\nfrd960.sys - IBM Corporation
[UnloadDriver] qcusbser.sys - C:\Windows\system32\DRIVERS\qcusbser.sys - QUALCOMM Incorporated
[UnloadDriver] ql2300.sys - C:\Windows\system32\DRIVERS\ql2300.sys - QLogic Corporation
[UnloadDriver] ql40xx.sys - C:\Windows\system32\DRIVERS\ql40xx.sys - QLogic Corporation
[UnloadDriver] sisraid4.sys - C:\Windows\system32\DRIVERS\sisraid4.sys - Silicon Integrated Systems
[UnloadDriver] ssudbus.sys - C:\Windows\system32\DRIVERS\ssudbus.sys - DEVGURU Co., LTD.(www.devguru.co.kr)
[UnloadDriver] ssudmdm.sys - C:\Windows\system32\DRIVERS\ssudmdm.sys - DEVGURU Co., LTD.(www.devguru.co.kr)
[UnloadDriver] stexstor.sys - C:\Windows\system32\DRIVERS\stexstor.sys - Promise Technology
[UnloadDriver] vsmraid.sys - C:\Windows\system32\DRIVERS\vsmraid.sys - VIA Technologies Inc.,Ltd
[UnloadDriver] HpSAMD.sys - C:\Windows\system32\drivers\HpSAMD.sys - Hewlett-Packard Company
[UnloadDriver] LGVirHid.sys - C:\Windows\system32\drivers\LGVirHid.sys - Logitech Inc.
[UnloadDriver] aliide.sys - C:\Windows\system32\drivers\aliide.sys - Acer Laboratories Inc.
[UnloadDriver] amdsata.sys - C:\Windows\system32\drivers\amdsata.sys - Advanced Micro Devices
[UnloadDriver] cmdide.sys - C:\Windows\system32\drivers\cmdide.sys - CMD Technology, Inc.
[UnloadDriver] hcw85cir.sys - C:\Windows\system32\drivers\hcw85cir.sys - Hauppauge Computer Works, Inc.
[UnloadDriver] iaStorV.sys - C:\Windows\system32\drivers\iaStorV.sys - Intel Corporation
[UnloadDriver] nvraid.sys - C:\Windows\system32\drivers\nvraid.sys - NVIDIA Corporation
[UnloadDriver] nvstor.sys - C:\Windows\system32\drivers\nvstor.sys - NVIDIA Corporation
[UnloadDriver] viaide.sys - C:\Windows\system32\drivers\viaide.sys - VIA Technologies, Inc.
Notify Routine
CreateProcess - 0xFFFFF88011079740 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
BugCheckReasonCallback - 0xFFFFF8801101ADA0 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
PowerSettingCallback - 0xFFFFF8801101D120 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
Filter
PnpManager - \Driver\LGBusEnum->\Driver\PnpManager - 0xFFFFFA8005393860[] - C:\Windows\system32\drivers\LGBusEnum.sys - Logitech Inc.
PnpManager - \Driver\LGJoyXlCore->\Driver\LGBusEnum - 0xFFFFFA8005393630[] - C:\Windows\system32\drivers\LGJoyXlCore.sys - Logitech Inc.
PnpManager - \Driver\ACPI_HAL->\Driver\PnpManager - 0xFFFFFA8003CD7040[] - -
DPC Timer
Worker Thread
Nothing
HalDispatchTable
Nothing
Nothing
Nothing
Nothing
WdfFunction
Nothing
MiniFilter
Nothing
File System
Nothing
Nothing
Nothing
Npfs Dispatch Fun
Nothing
Msfs Dispatch Fun
Nothing
Nothing
System Debug
Nothing
Object Hijack
Nothing
Direct IO
GDT
Nothing
SSDT
Int2e/Sysenter Hook, The Path[int2e/sysenter to ssdt] has been Hooked: 0xFFFFF8000330FA00(C:\Windows\system32\ntoskrnl.exe)
Shadow SSDT
Nothing
FSD
Nothing
Keyboard
Nothing
I8042prt
Nothing
Mouclass
Nothing
Partmgr
Nothing
Classpnp
Nothing
Atapi
Nothing
Acpi
Nothing
Scsi
Nothing
Kernel Hook
Inline - len(4) ExFreePool[ntoskrnl.exe] - [0xFFFFF8000343F010]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF80003302DE2]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF80003302F4B]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF80003303102]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF8000330326D]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF80003436001]->[-]
PTE HOOK
Nothing
Object Type
- PowerState(0xFFFFFA8003DAB700::0xFFFFFA8004A6C170) - Callback_Object - 0xFFFFF88004941448 - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
- PowerState(0xFFFFFA8003DAB700::0xFFFFFA8004E5E140) - Callback_Object - 0xFFFFF8800582B078 - C:\Windows\system32\drivers\RTKVHD64.sys - Realtek Semiconductor Corp.
- AMD_CALLBACK_OBJ_NAME__32335CF9-4817-4644-B367-(0xFFFFFA80049C2190::0xFFFFFA800485E170) - Callback_Object - 0xFFFFF88011F0F530 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
- AMD_CALLBACK_OBJ_NAME_FOR_PROXY_INIT(0xFFFFFA80049BE190::0xFFFFFA8004855DB0) - Callback_Object - 0xFFFFF880110792F0 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
IDT
Nothing
Message Hook
Nothing
Process Hook
Nothing
KernelCallbackTable
Nothing
Port
Tcp 0.0.0.0 : 135 - 0.0.0.0 : 0 - LISTENING - 848 - C:\Windows\System32\svchost.exe
Tcp 192.168.1.156 : 139 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 554 - 0.0.0.0 : 0 - LISTENING - 3692 - C:\Program Files\Windows Media Player\wmpnetwk.exe
Tcp 192.168.1.156 : 2869 - 192.168.1.1 : 47356 - TIME_WAIT - 0 -
Tcp 0.0.0.0 : 3390 - 0.0.0.0 : 0 - LISTENING - 1152 - C:\Windows\System32\svchost.exe
Tcp 127.0.0.1 : 5357 - 127.0.0.1 : 53094 - TIME_WAIT - 0 -
Tcp 127.0.0.1 : 5357 - 127.0.0.1 : 53072 - TIME_WAIT - 0 -
Tcp 127.0.0.1 : 5357 - 127.0.0.1 : 53088 - TIME_WAIT - 0 -
Tcp 127.0.0.1 : 5357 - 127.0.0.1 : 53093 - TIME_WAIT - 0 -
Tcp 127.0.0.1 : 5357 - 127.0.0.1 : 53070 - TIME_WAIT - 0 -
Tcp 127.0.0.1 : 5357 - 127.0.0.1 : 53089 - TIME_WAIT - 0 -
Tcp 0.0.0.0 : 49152 - 0.0.0.0 : 0 - LISTENING - 536 - C:\Windows\System32\wininit.exe
Tcp 0.0.0.0 : 49153 - 0.0.0.0 : 0 - LISTENING - 148 - C:\Windows\System32\svchost.exe
Tcp 0.0.0.0 : 49154 - 0.0.0.0 : 0 - LISTENING - 608 - C:\Windows\System32\svchost.exe
Tcp 0.0.0.0 : 49155 - 0.0.0.0 : 0 - LISTENING - 584 - C:\Windows\System32\services.exe
Tcp 0.0.0.0 : 49156 - 0.0.0.0 : 0 - LISTENING - 1364 - C:\Windows\System32\spoolsv.exe
Tcp 0.0.0.0 : 49157 - 0.0.0.0 : 0 - LISTENING - 612 - C:\Windows\System32\lsass.exe
Tcp 192.168.1.156 : 53059 - 104.24.107.65 : 443 - ESTABLISHED - 5032 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 53062 - 216.58.219.226 : 443 - ESTABLISHED - 5032 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 53063 - 216.58.219.214 : 443 - ESTABLISHED - 5032 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 53064 - 192.168.1.101 : 9098 - ESTABLISHED - 5032 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 53071 - 192.168.1.1 : 44680 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 53077 - 192.168.1.101 : 8081 - ESTABLISHED - 492 - C:\Windows\System32\svchost.exe
Tcp 192.168.1.156 : 53078 - 192.168.1.101 : 8091 - ESTABLISHED - 492 - C:\Windows\System32\svchost.exe
Tcp 192.168.1.156 : 53079 - 192.168.1.101 : 9098 - ESTABLISHED - 492 - C:\Windows\System32\svchost.exe
Tcp 192.168.1.156 : 53083 - 192.168.1.101 : 8081 - ESTABLISHED - 492 - C:\Windows\System32\svchost.exe
Tcp 192.168.1.156 : 53084 - 192.168.1.101 : 8091 - ESTABLISHED - 492 - C:\Windows\System32\svchost.exe
Tcp 192.168.1.156 : 53086 - 192.168.1.1 : 1990 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 53090 - 192.168.1.1 : 44680 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 53091 - 192.168.1.1 : 44680 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 53092 - 192.168.1.1 : 44680 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 53095 - 120.133.3.228 : 80 - CLOSE_WAIT - 968 - C:\Users\Mike\Desktop\PCHunter64.exe
Tcp 0.0.0.0 : 445 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 2869 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 2869 - 0.0.0.0 : 53075 - ESTABLISHED - 4 - System
Tcp 0.0.0.0 : 5357 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 10243 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 53075 - 0.0.0.0 : 2869 - ESTABLISHED - 492 - C:\Windows\System32\svchost.exe
Udp 192.168.1.156 : 137 - * : * - 4 - System
Udp 192.168.1.156 : 138 - * : * - 4 - System
Udp 0.0.0.0 : 500 - * : * - 608 - C:\Windows\System32\svchost.exe
Udp 127.0.0.1 : 1900 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 192.168.1.156 : 1900 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 3544 - * : * - 608 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 3702 - * : * - 492 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 3702 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 4500 - * : * - 608 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 5004 - * : * - 3692 - C:\Program Files\Windows Media Player\wmpnetwk.exe
Udp 0.0.0.0 : 5005 - * : * - 3692 - C:\Program Files\Windows Media Player\wmpnetwk.exe
Udp 0.0.0.0 : 5353 - * : * - 5032 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Udp 0.0.0.0 : 5355 - * : * - 1152 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 52454 - * : * - 492 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 52456 - * : * - 492 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 58528 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 192.168.1.156 : 63225 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 127.0.0.1 : 63226 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 192.168.1.156 : 63537 - * : * - 608 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 546 - * : * - 148 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 1900 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 52455 - * : * - 492 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 52457 - * : * - 492 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 58529 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 63223 - * : * - 1648 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 63224 - * : * - 1648 - C:\Windows\System32\svchost.exe
Tcpip
Nothing
Nsiproxy
Nothing
Tdx
Nothing
Ndis Handler
0xFFFFFA8006C96010 - NdisOpenBlock - 0xFFFFF88004871D68 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006C96010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C96010 - NdisOpenBlock - 0xFFFFF8800563AD98 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
0xFFFFFA8006C96010 - NdisOpenBlock - 0xFFFFF8800563A97C - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
0xFFFFFA8006C96010 - NdisOpenBlock - 0xFFFFF88004871D68 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006C96010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C96010 - NdisOpenBlock - 0xFFFFF8800563A78C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
0xFFFFFA8006C96010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF88005625AAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF88005625368 - PnPEventHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF88005624E54 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF88005625B50 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF88005625350 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF880056252F0 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF880056254FC - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF88005625908 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93010 - NdisProtocolBlock - 0xFFFFF8800562B9D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF880014A6EF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF88005625AAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF88004871D68 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF88005625908 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF880056254FC - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF88004871D68 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF8800562B9D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA8006C93400 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042CB008 - OpenAdapterCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042CB030 - CloseAdapterCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BEF00 - (Wan)SendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BEF00 - (Wan)TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BDBBC - BindAdapterHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BE2A0 - UnbindAdapterHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042CB064 - PnPEventHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BEEA4 - UnloadHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BEF0C - CoStatusHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BEFA8 - CoReceivePacketHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616A4D0 - NdisProtocolBlock - 0xFFFFF880042BE80C - CoAfRegisterNotifyHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880043CA954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006186010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880043CA954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042C6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042C6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042C6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042BD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061854A0 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880043AA270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006183010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880043AA270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042C6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042C6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042C6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042BD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006182840 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880045D6D0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617F010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880045D6D0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042C6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042C6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042C6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042BD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C840 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880045A6AF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172840 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880045A6AF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042C6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042C6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042C6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042BD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006172010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF88001543EB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF88001544570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880014BE970 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF8800459C5D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF88004590B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880014BE970 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF8800459C5D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF88001543EB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF88004590AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C840 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF88001543EB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF88001544570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042BEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042BE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880014BE970 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042BEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF8800459C5D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF88004590B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042C6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042C6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042C6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042BD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880014BE970 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF8800459C5D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF88001543EB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF880042BEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF88004590AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616C010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045D9AC4 - OpenAdapterCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045DA050 - CloseAdapterCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045E8F28 - (Wan)SendCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045E9778 - (Wan)TransferDataCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045D9BA4 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045E9468 - (Wan)ReceiveHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045E9904 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045DA11C - StatusHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045D9B98 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045E8FF0 - ReceivePacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045D9348 - BindAdapterHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045D9DE0 - UnbindAdapterHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045DA1E8 - PnPEventHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396990 - NdisProtocolBlock - 0xFFFFF880045E2550 - UnloadHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF880043A1820 - OpenAdapterCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF880043A1F70 - CloseAdapterCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF8800439EA00 - (Wan)SendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF88004383620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF8800437FB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF8800439E7B0 - (Wan)ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF8800437A5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF880043855D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF880043829D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF8800437F0E0 - BindAdapterHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF88004384BA0 - UnbindAdapterHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF8800437F980 - PnPEventHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF880043835A0 - UnloadHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF880043902C0 - CoSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF88004385220 - CoStatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF8800438F190 - CoReceivePacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053817A0 - NdisProtocolBlock - 0xFFFFF8800437ED80 - CoAfRegisterNotifyHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88001546A60 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF8800439E7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF8800437A5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF8800437FB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88004383620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF880043855D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF880043829D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88009ED66B4 - WSendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF88001546A60 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF8800439EA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051988D0 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800439E7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800437A5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800437FB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88004383620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF880043855D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF880043829D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF880043CA954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800437D360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800439EA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006184350 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800439E7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800437A5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800437FB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88004383620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF880043855D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF880043829D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF880043AA270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800437D360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800439EA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061805F0 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800439E7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800437A5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800437FB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88004383620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF880043855D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF880043829D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF880045D6D0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800437D360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800439EA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617C010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88001544920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800439E7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800437A5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800437FB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88004383620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF880043855D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF880043829D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF880045A6AF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800437D360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800439EA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006171010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88001543EB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88001544570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800439E7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800437A5A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800437FB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF880014BE970 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88004383620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF880043855D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF880043829D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800459C5D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88004590B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800437E0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800437D360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88001544480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF880014BE970 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800459C5D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88001543EB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800439EA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800150C170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF88004590AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800154C560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800616F840 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DADE30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DB8A30 - PnPEventHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DAE6B0 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DB9970 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DB7330 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DB98F0 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DAD010 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DAD3A0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80052061D0 - NdisProtocolBlock - 0xFFFFF88002DAEAF0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF880014A6EF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88002DADE30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF8800437AAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88002DAD3A0 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88002DAD010 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF88002DAEAF0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA800617B840 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DADE30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DB8A30 - PnPEventHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DAE6B0 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DB9970 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DB7330 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DB98F0 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DAD010 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DAD3A0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80051F2370 - NdisProtocolBlock - 0xFFFFF88002DAEAF0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF880014A6EF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88002DADE30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF8800437AAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88002DAD3A0 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88002DAD010 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88001543A60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF88002DAEAF0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8006179010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF88001616990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF8800161DCC0 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF880016DFB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF880016DFA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF880016DFA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF880016DF9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF880016DF980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF8800161CB90 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF880016077F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF880016DF3B0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF88001607EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF88001657C20 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF8800165C960 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF8800168BB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C69B0 - NdisProtocolBlock - 0xFFFFF880016CFCB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF88001542920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880014A6EF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880015427E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF88001542710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF88001616990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DFB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DFA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DFA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DF9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DF980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DF600 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF88001734330 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016DF550 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF8800165C960 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF88001657C20 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF88000E6A210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF8800168BB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF880016CFCB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80066FA010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880014A6EF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88001616990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88000E6A210 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016DFB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016DFA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016DFA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016DF9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016DF980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016D9EF0 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016D9EF0 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016D9EF0 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016D9EF0 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88001734330 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88001717FE0 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF8800165C960 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88001657C20 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88000E6A210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF8800168BB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF880016CFCB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80053B9010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF88001616990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF88001742210 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF880016DFB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF880016DFA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF880016DFA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF880016DF9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF880016DF980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF8800161CB90 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF880016077F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF880016DF3B0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF88001607EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF88001657C20 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF8800165C960 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF8800168BB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044C6CE0 - NdisProtocolBlock - 0xFFFFF880016CFCB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF88001616990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF88001742290 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF880016DFB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF880016DFA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF880016DFA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF880016DF9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF880016DF980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF8800161CB90 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF880016077F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF880016DF3B0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF88001607EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF88001657C20 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF8800165C960 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF8800168BB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045FA420 - NdisProtocolBlock - 0xFFFFF880016CFCB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880014A6EF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88001616990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88004871D68 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DFB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DFA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DFA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DF9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DF980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DF600 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88001734330 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016DF550 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF8800165C960 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88001657C20 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88004871D68 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF8800168BB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF880016CFCB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006145010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF88001616990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF88001742250 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF880016DFB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF880016DFA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF880016DFA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF880016DF9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF880016DF980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF8800161CB90 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF880016077F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF880016DF3B0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF88001607EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF88001657C20 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF8800165C960 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF8800168BB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80044AA850 - NdisProtocolBlock - 0xFFFFF880016CFCB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88001543CF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880015430A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880014A6EF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88001546630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88001540370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88001616990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88004871D68 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DFB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DFA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DFA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DF9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DF980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DF600 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DF650 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88001734330 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016DF550 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF8800153F620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF8800165C960 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88001657C20 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88004871D68 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF88001543CF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF8800168BB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF880016CFCB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8006136010 - NdisOpenBlock - 0xFFFFF8800148F590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D5E930 - SetOptionsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D68630 - SetFilterModuleOptionsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D638A0 - AttachHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D63710 - DetachHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D6F6F0 - RestartHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D61190 - PauseHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D5A0C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D5A010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D6DAD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D6DAB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80051FC2C0 - NdisFilterDriverBlock - 0xFFFFF88002D67540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF8800153FD70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF8800153F260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF8800148B770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF8800153F8F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF880014A6EF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D68630 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D5A170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D5A140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D5CA80 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D63290 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D5A170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D5A140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D5CA80 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D63290 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D5A0C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D5A010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D6DAD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D6DAB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88002D67540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF88001495900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF8800148B650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006179A10 - NdisFilterBlock - 0xFFFFF880014A7A00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF8800153FD70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF8800153F260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF8800148B770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF8800153F8F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF880014A6EF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D68630 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D5A170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D5A140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D5CA80 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D63290 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D5A170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D5A140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D5CA80 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D63290 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D5A0C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D5A010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D6DAD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D6DAB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88002D67540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF88001495900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF8800148B650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80061764E0 - NdisFilterBlock - 0xFFFFF880014A7A00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF8800153FD70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF8800153F260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF8800148B770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF8800153F8F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF880014A6EF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D68630 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D5A170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D5A140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D5CA80 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D63290 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D5A170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D5A140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D5CA80 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D63290 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D5A0C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D5A010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D6DAD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D6DAB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88002D67540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF88001495900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF8800148B650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006174970 - NdisFilterBlock - 0xFFFFF880014A7A00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF8800153F440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF8800153F260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF8800148B770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF8800486CFD0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88004871D68 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D68630 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D5A170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D5A140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D5CA80 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D5A170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D5A140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D5CA80 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D5A0C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D5A010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D6DAD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D6DAB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88002D67540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF88001495900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF8800148B650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800603E010 - NdisFilterBlock - 0xFFFFF880014A7A00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D51BDC - SetFilterModuleOptionsHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D51008 - AttachHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D51380 - DetachHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D512DC - RestartHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D51284 - PauseHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D515C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D51684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D517DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D517F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80051FB010 - NdisFilterDriverBlock - 0xFFFFF88002D517C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88002D5A170 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF8800153F260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF8800148B770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF8800486CFD0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88002D5CA80 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88002D51BDC - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88002D515C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88002D51684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88002D517DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88002D517F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88002D517C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF88001495900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF8800148B650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8006136C80 - NdisFilterBlock - 0xFFFFF880014A7A00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800509A3C0 - NdisMiniDriverBlock - 0xFFFFF88009ED7E1C - HaltHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA800509A3C0 - NdisMiniDriverBlock - 0xFFFFF88009ED7E7C - InitializeHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA800509A3C0 - NdisMiniDriverBlock - 0xFFFFF88009ED567C - QueryInformationHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA800509A3C0 - NdisMiniDriverBlock - 0xFFFFF88009ED8398 - ReconfigureHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA800509A3C0 - NdisMiniDriverBlock - 0xFFFFF88009ED83A4 - ResetHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA800509A3C0 - NdisMiniDriverBlock - 0xFFFFF88009ED66B4 - (Wan)SendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA800509A3C0 - NdisMiniDriverBlock - 0xFFFFF88009ED5924 - SetInformationHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D5328 - UnloadHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D5BB0 - HaltHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D5F54 - InitializeHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043CA2D4 - ResetHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D7008 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D7068 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D70B0 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D70F8 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043CA954 - CoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D7068 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF880043D70B0 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA800536F940 - NdisMiniDriverBlock - 0xFFFFF8800148CEA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043BE400 - UnloadHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043B09E0 - HaltHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043C21B0 - InitializeHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043ACBF0 - ResetHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043B7DB0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043BE3B0 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043BE360 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043B82D0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043AA270 - CoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043BE3B0 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF880043BE360 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA8005371020 - NdisMiniDriverBlock - 0xFFFFF8800148CEA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045E12B4 - UnloadHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045D64B4 - HaltHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045E1AB4 - InitializeHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045D6604 - ResetHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045E3008 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045E3150 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045E3198 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045E31E0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045D6D0C - CoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045E3150 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF880045E3198 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8005396CD0 - NdisMiniDriverBlock - 0xFFFFF8800148CEA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF8800439BB00 - UnloadHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF88004384DA0 - HaltHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF880043A1350 - InitializeHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF880043839A0 - ReconfigureHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF880043838D0 - ResetHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF8800437A6F0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF8800437AAD0 - SendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF88004383850 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF880043837D0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF88004383750 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF880043836D0 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF88004385670 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF8800437D760 - CoRequestHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF88004383850 - MiniportCharacteristics.CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF880043837D0 - MiniportCharacteristics.CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF88004383750 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF880043836D0 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8005383950 - NdisMiniDriverBlock - 0xFFFFF8800148CEA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045C3120 - UnloadHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045C3010 - HaltHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045C1500 - InitializeHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045A9470 - ResetHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045B23D0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045BD930 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045BD930 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045B35A0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045A6AF0 - CoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045BD930 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF880045BD930 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80054A36C0 - NdisMiniDriverBlock - 0xFFFFF8800148CEA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590B7C - CoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590B7C - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590B7C - CoActivateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590B7C - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459C418 - CoSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590AEC - CoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459131C - CmCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459159C - CmDeleteVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590D18 - CmOpenAfHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590DA4 - CmCloseAfHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF880045918A8 - CmRegisterSapHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004591A10 - CmDeregisterSapHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004591E7C - CmMakeCallHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004591DDC - CmCloseCallHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459C650 - CmIncomingCallCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459C83C - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459CA50 - CmDeactivateVcCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459CB38 - CmModifyCallQoSHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459254C - CmOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004592598 - CmOidRequestCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004592598 - CmNotifyCloseAfCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459B138 - SetOptionsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459AC60 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF880045902D4 - HaltHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459A328 - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF880045904DC - PauseHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590550 - RestartHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459C5D0 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459C5DC - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459C5D0 - CancelSendHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459058C - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004590B70 - ResetHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF8800459B364 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004592598 - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80054A3020 - NdisMiniDriverBlock - 0xFFFFF88004592598 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486B270 - FilterResourceRequirementsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486B1F8 - SetOptionsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486B314 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486C9EC - HaltHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800487262C - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486C560 - PauseHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486C69C - RestartHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800487A64C - OidRequestHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486D1F4 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486CFD0 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF88004871D68 - CancelSendHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486C9E0 - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486CB68 - ResetHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF88004872264 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF8800486F604 - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053BC900 - NdisMiniDriverBlock - 0xFFFFF880048848A4 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E68F84 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E69D80 - HaltHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E797DC - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E69ED8 - PauseHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E6A000 - RestartHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E69CCC - OidRequestHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E69D54 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E69D44 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E6A210 - CancelSendHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E6D7AC - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E79944 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E6A0FC - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800523E020 - NdisMiniDriverBlock - 0xFFFFF88000E697F8 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880014CA020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880014C43F0 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880014CA020 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880014CA020 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF880014CA020 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8007BBE1A0 - NdisMiniportBlock - 0xFFFFF88009ED66B4 - (Wan)SendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF88001545730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF880043D7008 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF880043D7008 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C31A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF88001545730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF880043B7DB0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF880043B7DB0 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053CB1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF88001545730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF880045E3008 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF880045E3008 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053C91A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153FAB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001545B10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001549C30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800154B0D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800437AAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153FAB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880014833B0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880014833B0 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001548010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800437A6F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880015470C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88002D5CA80 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88002D5A140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88002D63290 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88002D5A170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053911A0 - NdisMiniportBlock - 0xFFFFF88001548010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153FAB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001545B10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001549C30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800154B0D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800437AAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153FAB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880014833B0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880014833B0 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001548010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800437A6F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880015470C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88002D5CA80 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88002D5A140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88002D63290 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88002D5A170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053951A0 - NdisMiniportBlock - 0xFFFFF88001548010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153FAB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001545B10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001549C30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800154B0D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800437AAD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153FAB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880014833B0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880014833B0 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001548010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800437A6F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880015470C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88002D5CA80 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88002D5A140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88002D63290 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88002D5A170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800539B1A0 - NdisMiniportBlock - 0xFFFFF88001548010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF88001543A60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF88001545730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153FE60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF880045B23D0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF880045B23D0 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153FD70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800153F8F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539D1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF880014CA020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF88001510910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF88004592598 - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF880015470C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800459C5D0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800459C5DC - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800459C5D0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800459C5DC - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800539F1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001548010 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001548010 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880014833B0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880014833B0 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800486F604 - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001548010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF880015470C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88004871D68 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800486CFD0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88002D5CA80 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88002D5A140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF8800486CFD0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88002D5A170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053AF1A0 - NdisMiniportBlock - 0xFFFFF88001548010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88000E6A0FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF880015470C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88000E6A210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88000E69D44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88000E6A210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF88000E69D44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052431A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF880014CA020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF880014A6F90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88001510910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88000E6A0FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF880015470C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88000E6A210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88000E69D44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88000E6A210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF88000E69D44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80052411A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF880014CA020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800153FFA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800151B3B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800151BC80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88001549650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800154A280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88001549570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800154A1F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800150ABB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88001510BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88001544720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800151B5C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800151B4D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF880015433C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF880015158A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF880015157D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF880014A6EF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800153F7D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88001510910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800153F1B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800150C5B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF880014C9150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88000E6A0FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88001508900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF880015470C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88000E6A210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88000E69D44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800153F440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88000E6A210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800153F260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800148B770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF88000E69D44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800478A1A0 - NdisMiniportBlock - 0xFFFFF8800151E340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047AC330 - NdisIfProviderBlock - 0xFFFFF88002DAD4B0 - QueryObjectHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80047AC330 - NdisIfProviderBlock - 0xFFFFF88002DB96B0 - SetObjectHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004413750 - NdisIfProviderBlock - 0xFFFFF88001488E30 - QueryObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004413750 - NdisIfProviderBlock - 0xFFFFF880014AC770 - SetObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80044137B0 - NdisIfProviderBlock - 0xFFFFF88001486020 - QueryObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80044137B0 - NdisIfProviderBlock - 0xFFFFF880014AC770 - SetObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
IE Plugin
Browser Helper Objects - - - - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408}
Browser Helper Objects(Wow64) - - - - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408}
Browser Helper Objects(Wow64) - Java(tm) Plug-In SSV Helper - C:\Program Files (x86)\Java\jre7\bin\ssv.dll - Oracle Corporation - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43}
Browser Helper Objects(Wow64) - Java(tm) Plug-In 2 SSV Helper - C:\Program Files (x86)\Java\jre7\bin\jp2ssv.dll - Oracle Corporation - {DBC80044-A445-435b-BC74-9C25C1C588A9}
Browser Extensions(Wow64) - @C:\Program Files (x86)\Windows Live\Writer\WindowsLiveWriterShortcuts.dll,-1004 - - - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600}
Browser Extensions(Wow64) - Send to OneNote - - - {2670000A-7350-4f3c-8081-5663EE0C6C49}
Browser Extensions(Wow64) - Research - - - {92780B25-18CC-41C8-B9BE-3C9C571A8263}
ActiveX - - - - {5852F5ED-8BF4-11D4-A245-0080C6F74284}
ActiveX - - - - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408}
ActiveX - - - - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43}
ActiveX - - - - {9BE31822-FDAD-461B-AD51-BE1D1C159921}
ActiveX - Adobe PDF Reader - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroPDF64.dll - Adobe Systems, Inc. - {CA8A9780-280D-11CF-A24D-444553540000}
ActiveX - Shockwave Flash Object - C:\Windows\System32\Macromed\Flash\Flash64_28_0_0_161.ocx - Adobe Systems, Inc. - {D27CDB6E-AE6D-11CF-96B8-444553540000}
ActiveX - - - - {DBC80044-A445-435B-BC74-9C25C1C588A9}
ActiveX - Microsoft Silverlight - C:\Program Files\Microsoft Silverlight\5.1.50907.0\npctrl.dll - Microsoft Corporation - {DFEAF541-F3E1-4C24-ACAC-99C30715084A}
IE Shell
Nothing
Spi
Nothing
Hosts File
127.0.0.1 localhost
::1 localhost
Startup
Twitch.lnk - C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe - Twitch Interactive, Inc. - [C:\Users\Mike\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Twitch.lnk]
DllDirectory32 - C:\Windows\system32\ - - [\Registry\Machine\SYSTEM\CurrentControlSet\Control\Session Manager\KnownDLLs DllDirectory32]
FAHDll.dll(FileAssociationHelper) - C:\Program Files\File Association Helper\FAHDll.dll - Nico Mak Computing - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers FileAssociationHelper]
RarExt.dll(WinRAR) - C:\Program Files\WinRAR\RarExt.dll - Alexander Roshal - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers WinRAR]
WZSHLS64.dll(WinZip) - C:\Program Files\WinZip\WZSHLS64.dll - WinZip Computing, S.L. - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers WinZip]
mbshlext.dll(MBAMShlExt) - C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll - Malwarebytes - [\Registry\Machine\SOFTWARE\Classes\AllFilesystemObjects\shellex\ContextMenuHandlers MBAMShlExt]
mbshlext.dll(MBAMShlExt) - C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll - Malwarebytes - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers MBAMShlExt]
RarExt.dll(WinRAR) - C:\Program Files\WinRAR\RarExt.dll - Alexander Roshal - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers WinRAR]
WZSHLS64.dll(WinZip) - C:\Program Files\WinZip\WZSHLS64.dll - WinZip Computing, S.L. - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers WinZip]
Google Chrome({8A69D345-D564-463c-AFF1-A69D9E530F96}) - C:\Program Files (x86)\Google\Chrome\Application\66.0.3359.139\Installer\chrmstp.exe - Google Inc. - [\Registry\Machine\SOFTWARE\Microsoft\Active Setup\Installed Components {8A69D345-D564-463c-AFF1-A69D9E530F96}]
Google Chrome({8A69D345-D564-463c-AFF1-A69D9E530F96}) - C:\Program Files (x86)\Google\Chrome\Application\58.0.3029.81\Installer\chrmstp.exe - File not found - [\Registry\Machine\SOFTWARE\Wow6432Node\Microsoft\Active Setup\Installed Components {8A69D345-D564-463c-AFF1-A69D9E530F96}]
Service
AdobeARMservice - Started - Automatic - "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe" - Adobe Systems Incorporated - -
AdobeFlashPlayerUpdateSvc - Stopped - Disabled - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe - Adobe Systems Incorporated - -
AMD External Events Utility - Started - Automatic - C:\Windows\System32\atiesrxx.exe - AMD - -
DAUpdaterSvc - Stopped - Disabled - E:\Steam\steamapps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe - BioWare - -
gupdate - Stopped - Disabled - "C:\Program Files (x86)\Google\Update\GoogleUpdate.exe" /svc - Google Inc. - -
gupdatem - Stopped - Disabled - "C:\Program Files (x86)\Google\Update\GoogleUpdate.exe" /medsvc - Google Inc. - -
IEEtwCollectorService - Stopped - Manual - C:\Windows\syswow64\IEEtwCollector.exe /V - File not found - -
LogiRegistryService - Stopped - Disabled - "C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.exe" - Logitech Inc. - -
MBAMService - Stopped - Disabled - "C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe" - Malwarebytes - -
PAExec - Stopped - Manual - C:\Windows\PAExec.exe -service - Power Admin LLC - -
ss_conn_service - Stopped - Disabled - "C:\Program Files\SAMSUNG\USB Drivers\25_escape\conn\ss_conn_service.exe" - DEVGURU Co., LTD. - -
Steam Client Service - Stopped - Manual - "C:\Program Files (x86)\Common Files\Steam\SteamService.exe" /RunAsService - File not found - -
UMVPFSrv - Stopped - Disabled - C:\Program Files (x86)\Common Files\logishrd\LVMVFM\UMVPFSrv.exe - Logitech Inc. - -
Schedule Task
RunDAOD - \ASUS\RunDAOD - C:\Windows\DAODx.exe - - Enable -
AitAgent - \Microsoft\Windows\Application Experience\AitAgent - aitagent - Aggregates and uploads Application Telemetry information if opted-in to the Microsoft Customer Experience Improvement Program. - Enable -
GatherNetworkInfo - \Microsoft\Windows\NetTrace\GatherNetworkInfo - C:\Windows\System32\gatherNetworkInfo.vbs - Network information collector - Enable -
Adobe Acrobat Update Task - \Adobe Acrobat Update Task - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe - This task keeps your Adobe Reader and Acrobat applications up to date with the latest enhancements and security fixes - Enable - Adobe Systems Incorporated
Adobe Flash Player Updater - \Adobe Flash Player Updater - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe - This task keeps your Adobe Flash Player installation up to date with the latest enhancements and security fixes. If this task is disabled or removed, Adobe Flash Player will be unable to automatically secure your machine with the latest security fixes. - Enable - Adobe Systems Incorporated
GoogleUpdateTaskMachineCore - \GoogleUpdateTaskMachineCore - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe - Keeps your Google software up to date. If this task is disabled or stopped, your Google software will not be kept up to date, meaning security vulnerabilities that may arise cannot be fixed and features may not work. This task uninstalls itself when there is no Google software using it. - Enable - Google Inc.
GoogleUpdateTaskMachineUA - \GoogleUpdateTaskMachineUA - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe - Keeps your Google software up to date. If this task is disabled or stopped, your Google software will not be kept up to date, meaning security vulnerabilities that may arise cannot be fixed and features may not work. This task uninstalls itself when there is no Google software using it. - Enable - Google Inc.
StartCN - \StartCN - C:\Program Files\AMD\CNext\CNext\cncmd.exe - - Enable - Advanced Micro Devices, Inc.
StartDVR - \StartDVR - C:\Program Files\AMD\CNext\CNext\dvrcmd.exe - - Enable - Advanced Micro Devices, Inc.
File Association
hlpfile - %SystemRoot%\winhlp32.exe %1 - HKEY_CLASSES_ROOT\hlpfile\Shell\Open\Command
vbsfile - "%SystemRoot%\System32\WScript.exe" "%1" %* - HKEY_CLASSES_ROOT\vbsfile\Shell\Open\Command
jsfile - C:\Windows\System32\WScript.exe "%1" %* - HKEY_CLASSES_ROOT\jsfile\Shell\Open\Command
HKCU .bat Progid - "%1" %* - HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.bat\OpenWithProgids
IFEO
Nothing
IME/CTF
Nothing
Firewall Rule
NetPres-In-TCP-NoScope --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=6|Profile=Domain|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31761|Desc=@FirewallAPI.dll,-31764|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-Out-TCP-NoScope --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=6|Profile=Domain|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31765|Desc=@FirewallAPI.dll,-31768|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-WSD-In-UDP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=17|LPort=3702|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31753|Desc=@FirewallAPI.dll,-31756|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-WSD-Out-UDP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=17|RPort=3702|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31757|Desc=@FirewallAPI.dll,-31760|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-In-TCP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=6|Profile=Private|Profile=Public|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31761|Desc=@FirewallAPI.dll,-31764|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-Out-TCP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=6|Profile=Private|Profile=Public|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31765|Desc=@FirewallAPI.dll,-31768|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
{204523DB-ECE5-44DC-B20E-D3771411D969} --> C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{330531C7-7EB7-44DE-AD00-514D78DA6082} --> C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{63685001-A660-4C55-8040-0928EA485E33} --> C:\Program Files (x86)\Battle.net\Battle.net.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Battle.net\Battle.net.exe|Name=Battle.net| - Enabled - File not found
{B7E226B4-6E16-418E-AC44-9B0AC8E8D4D4} --> C:\Program Files (x86)\Battle.net\Battle.net.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Battle.net\Battle.net.exe|Name=Battle.net| - Enabled - File not found
{38F8CFA0-49DB-406D-9694-1CBC18050ABB} --> C:\Program Files (x86)\Diablo III\Diablo III.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Diablo III\Diablo III.exe|Name=Diablo III| - Enabled - File not found
{80E28519-0F39-4094-9E80-3EE1B31AE91A} --> C:\Program Files (x86)\Diablo III\Diablo III.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Diablo III\Diablo III.exe|Name=Diablo III| - Enabled - File not found
{B63ADA1B-7A0A-4E61-8BDB-E9AA4F3D11AC} --> E:\Steam\Steam.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\Steam.exe|Name=Steam| - Enabled - Valve Corporation
{E496D788-C304-4BB0-9D66-6D47FB915919} --> E:\Steam\Steam.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\Steam.exe|Name=Steam| - Enabled - Valve Corporation
{24D88DBA-DAE1-403D-B1EE-05D1A475F557} --> E:\Steam\SteamApps\common\Contagion\contagion.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Contagion\contagion.exe|Name=Contagion| - Enabled -
{3DF5206E-E507-49B2-BE42-CAFE4FF0CDA3} --> E:\Steam\SteamApps\common\Contagion\contagion.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Contagion\contagion.exe|Name=Contagion| - Enabled -
{4EB98C22-831F-4E5B-ABE0-3CF831D15A7B} --> E:\Steam\SteamApps\common\Contagion\contagionds.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Contagion\contagionds.exe|Name=ContagionDSBeta| - Enabled -
{43488864-C1CA-45F0-92F0-897DB8C09F8E} --> E:\Steam\SteamApps\common\Contagion\contagionds.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Contagion\contagionds.exe|Name=ContagionDSBeta| - Enabled -
{0E00EAD6-01A4-4E93-AC69-F13B368C5EB6} --> E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe|Name=State of Decay| - Enabled -
{CC602AB4-6FD1-4C6D-AEAF-E6B009BCB548} --> E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe|Name=State of Decay| - Enabled -
{A6D6A61F-4A3C-4031-8A28-76EBD852ABC7} --> E:\Steam\SteamApps\common\Dawn of War 2\DOW2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dawn of War 2\DOW2.exe|Name=Warhammer® 40,000™: Dawn of War® II| - Enabled - Sega Corporation
{1DB121AE-6A08-445F-BF4E-08175FEA23B9} --> E:\Steam\SteamApps\common\Dawn of War 2\DOW2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dawn of War 2\DOW2.exe|Name=Warhammer® 40,000™: Dawn of War® II| - Enabled - Sega Corporation
{048A2BD0-B4C7-4E14-9A0C-DB373BAD1F41} --> E:\Steam\SteamApps\common\Dawn of War II - Retribution\DOW2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dawn of War II - Retribution\DOW2.exe|Name=Warhammer® 40,000™: Dawn of War® II – Retribution™| - Enabled - Sega Corporation
{C3636805-4BD1-4911-B77B-A2E56DAFA051} --> E:\Steam\SteamApps\common\Dawn of War II - Retribution\DOW2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dawn of War II - Retribution\DOW2.exe|Name=Warhammer® 40,000™: Dawn of War® II – Retribution™| - Enabled - Sega Corporation
{166DF566-73F7-4A12-9076-628C9B2A7892} --> E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe|Name=Command and Conquer: Red Alert 3| - Enabled -
{8B27EBE7-7A8B-4778-8FDB-5BF49FBE9713} --> E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe|Name=Command and Conquer: Red Alert 3| - Enabled -
{1045CBC8-35FD-47D2-8E63-AF4B21CC76CA} --> E:\Steam\SteamApps\common\Tomb Raider\TombRaider.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Tomb Raider\TombRaider.exe|Name=Tomb Raider| - Enabled - Square Enix
{C6086797-A8C1-434E-A789-D89E5ACC2F4B} --> E:\Steam\SteamApps\common\Tomb Raider\TombRaider.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Tomb Raider\TombRaider.exe|Name=Tomb Raider| - Enabled - Square Enix
{78308042-0E31-4ED6-B88C-C09515035626} --> E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe|Name=MURDERED: SOUL SUSPECT™| - Enabled -
{7E3962FB-BFD4-47EE-834C-AA04D89B7F72} --> E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe|Name=MURDERED: SOUL SUSPECT™| - Enabled -
{5C844D98-43BC-4089-9164-6E07CC7ABC33} --> E:\Steam\SteamApps\common\Skyrim\SkyrimLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Skyrim\SkyrimLauncher.exe|Name=The Elder Scrolls V: Skyrim| - Enabled - Bethesda Softworks
{164255EE-6193-44BD-BCCA-D96BC09F95CE} --> E:\Steam\SteamApps\common\Skyrim\SkyrimLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Skyrim\SkyrimLauncher.exe|Name=The Elder Scrolls V: Skyrim| - Enabled - Bethesda Softworks
{B9925F77-8800-4202-A56C-B7CAE9CEDC4F} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe|Name=Marvel Heroes 2015| - Enabled - File not found
{D274E088-584D-4780-9F2F-7E1D3C64B03D} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe|Name=Marvel Heroes 2015| - Enabled - File not found
{08BE82A2-AA6B-4C05-B536-1F1AB306B4BF} --> E:\Steam\SteamApps\common\Space Hulk\game.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Space Hulk\game.exe|Name=Space Hulk| - Enabled -
{8B944443-1DA5-4843-8C70-BD83454D7982} --> E:\Steam\SteamApps\common\Space Hulk\game.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Space Hulk\game.exe|Name=Space Hulk| - Enabled -
{27271B2F-654F-454D-88EC-93BBA61961FF} --> E:\Steam\SteamApps\common\Gone Home\GoneHome.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Gone Home\GoneHome.exe|Name=Gone Home| - Enabled -
{C4719301-7D23-4C64-8C5C-67B214096824} --> E:\Steam\SteamApps\common\Gone Home\GoneHome.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Gone Home\GoneHome.exe|Name=Gone Home| - Enabled -
{BC19AAA4-BD6A-4287-AAEB-582E91BBBC24} --> E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe|Name=DuckTales Remastered| - Enabled -
{DF4C3EBF-B2FE-4B10-B6A7-B05A88FB1D78} --> E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe|Name=DuckTales Remastered| - Enabled -
{D5DDBB79-FDAA-409B-9320-C5E81745EEBA} --> E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe|Name=The Stanley Parable| - Enabled -
{68EE5B9F-35D3-4991-B2C9-6C63B5B79271} --> E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe|Name=The Stanley Parable| - Enabled -
{7BA5C408-A6B7-4A0D-B958-6909A370F7D5} --> E:\Steam\bin\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\bin\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - File not found
{1D7AEC08-A5E3-46AF-99F5-5E0AB2DFE371} --> E:\Steam\bin\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\bin\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - File not found
TCP Query User{10423A7B-48E4-4122-B9A5-83695CB09768}C:\programdata\battle.net\agent\agent.3286\agent.exe --> C:\programdata\battle.net\agent\agent.3286\agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\programdata\battle.net\agent\agent.3286\agent.exe|Name=Battle.net Update Agent|Desc=Battle.net Update Agent|Defer=User| - Enabled - File not found
UDP Query User{14DBE92F-6882-44C2-8991-27D4103C46E8}C:\programdata\battle.net\agent\agent.3286\agent.exe --> C:\programdata\battle.net\agent\agent.3286\agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\programdata\battle.net\agent\agent.3286\agent.exe|Name=Battle.net Update Agent|Desc=Battle.net Update Agent|Defer=User| - Enabled - File not found
{026C99E0-AEDE-4421-AF5D-D82CF1FD3F89} --> C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|App=C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe|Name=Windows Live Messenger|Edge=TRUE| - Enabled - File not found
{3CF6FE21-49E7-444B-8392-5474F180220C} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Diplomacy.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Diplomacy.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{1B698CC9-5E10-40D8-98F9-3D8B19ADD3E6} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Diplomacy.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Diplomacy.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{81078AF4-7B6F-4C0A-90A0-061A79D7B316} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Entrenchment.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Entrenchment.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{16FA5F60-ED6C-4D9B-A367-EEBEC5FE383E} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Entrenchment.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Entrenchment.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{7B05C10F-1FBD-45E0-AE5D-ADAC5D38D9BA} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{D204FD5F-EB15-4C0B-BAFE-93327FD3AC38} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{255BEC1A-C06C-432E-ACB3-D3C72D6AD942} --> E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\witcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\witcher.exe|Name=The Witcher: Enhanced Edition| - Enabled - CD Projekt Red
{265E4297-7E60-47D4-9F9C-A8F5BB31F299} --> E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\witcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\witcher.exe|Name=The Witcher: Enhanced Edition| - Enabled - CD Projekt Red
{EA8DAB0F-62B2-4C4F-98A7-DD08B1C85DB7} --> E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\djinni!.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\djinni!.exe|Name=The Witcher: Enhanced Edition| - Enabled - CD Projekt Red
{62B5B36D-60DD-4BC8-B075-761B818F7671} --> E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\djinni!.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\djinni!.exe|Name=The Witcher: Enhanced Edition| - Enabled - CD Projekt Red
{FB534D17-ED3B-40D8-A761-B83BFABF9049} --> E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\DAOriginsLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\DAOriginsLauncher.exe|Name=Dragon Age: Origins - Ultimate Edition| - Enabled - BioWare
{211F2ABA-16F8-4D8C-8989-28A00ED1BEDE} --> E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\DAOriginsLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\DAOriginsLauncher.exe|Name=Dragon Age: Origins - Ultimate Edition| - Enabled - BioWare
{73AF861C-ECE4-4378-9923-1A41B1E95E86} --> E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe|Name=The Bureau: XCOM Declassified| - Enabled - 2K Marin, Inc.
{73B704C1-3302-409E-AE26-3B17C1125ED8} --> E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe|Name=The Bureau: XCOM Declassified| - Enabled - 2K Marin, Inc.
{98413589-2324-4D4B-A50E-84170B3414E5} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe|Name=Nexus: The Jupiter Incident| - Enabled - File not found
{26CEFF01-D9CB-4A95-B7C4-E0E3F7568B7B} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe|Name=Nexus: The Jupiter Incident| - Enabled - File not found
{14C0A219-D89E-4078-85DC-E1C116D8C145} --> E:\Steam\SteamApps\common\Outlast\OutlastLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Outlast\OutlastLauncher.exe|Name=Outlast| - Enabled - Red Barrels Inc.
{95048367-12BC-421B-AC20-5FD9ED9505C9} --> E:\Steam\SteamApps\common\Outlast\OutlastLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Outlast\OutlastLauncher.exe|Name=Outlast| - Enabled - Red Barrels Inc.
{0965A874-5235-4EA3-B5E6-7224962232FD} --> E:\Steam\SteamApps\common\Sid Meier's Civilization V\Launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sid Meier's Civilization V\Launcher.exe|Name=Sid Meier's Civilization V| - Enabled - Firaxis Games
{D0A83254-1BE4-4B20-B96B-5AD0E9CE47A5} --> E:\Steam\SteamApps\common\Sid Meier's Civilization V\Launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sid Meier's Civilization V\Launcher.exe|Name=Sid Meier's Civilization V| - Enabled - Firaxis Games
{46CA8E78-4E57-435A-9F01-543CA6597655} --> E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|App=E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe|Name=Dragon Age Origins Updater| - Enabled - BioWare
{7BD57F5D-BE76-4A78-9E08-16ADBD8CCE63} --> E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|App=E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe|Name=Dragon Age Origins Updater| - Enabled - BioWare
{01921918-583B-454B-9B53-626571D91F6A} --> E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe|Name=Dragon's Lair| - Enabled -
{057CBD5D-8121-4948-8EA8-F65C23D41C85} --> E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe|Name=Dragon's Lair| - Enabled -
{03CFE2B1-2F61-4DE0-8CF1-B5E197BBD818} --> C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{C20C8FCC-DA76-48B0-AE56-D465BFEA9B3D} --> C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{A2D38890-4450-4E81-911C-7B55B674F0F0} --> C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{AA898690-1D7D-453F-8600-571011E0BA10} --> C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{91019C81-FB01-47CD-8071-3E378E27004C} --> C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{63267EAA-A94A-46DE-A618-59616BA1200F} --> C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{3CED9BD6-5ABB-4C32-90B1-EA5E0BCF2E80} --> C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{51016FD8-C288-4F8B-9B17-B14349B2DC09} --> C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{AE09238B-E8AA-47B1-BD42-6E259B359250} --> C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{A3026DF8-AC67-4C99-8BA0-B5C9D89D95F6} --> C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{7957AA71-D52F-49C5-B66F-FE76025F8ECE} --> E:\Steam\SteamApps\common\War in the North\witn.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\War in the North\witn.exe|Name=The Lord of the Rings: War in the North| - Enabled - WB Games Inc.
{F2D21545-57C1-46B8-87C8-25786A475453} --> E:\Steam\SteamApps\common\War in the North\witn.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\War in the North\witn.exe|Name=The Lord of the Rings: War in the North| - Enabled - WB Games Inc.
{A34BE1AD-8AC9-4A26-8FB8-E7B7C98FE65A} --> C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{C26C8727-4F31-47B7-B5E8-3009CDF977FC} --> C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{119CAE3D-9CDB-4F91-9E20-640D9F4E8D0E} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe|Name=Marvel Heroes 2015| - Enabled - File not found
{6DCC1704-C9FB-4B54-80B5-9DAE36323672} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe|Name=Marvel Heroes 2015| - Enabled - File not found
{29243C02-9E73-4D45-9526-2DA5F92502F1} --> C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{62EB6B6B-5B43-466E-B0C7-E9089C496A21} --> C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{B8134D53-C8EA-4034-88C2-A66F3E31862B} --> E:\Steam\SteamApps\common\XCom-Enemy-Unknown\Binaries\Win32\XComGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\XCom-Enemy-Unknown\Binaries\Win32\XComGame.exe|Name=XCOM: Enemy Unknown| - Enabled - Firaxis Games
{796F44F8-3786-4DB1-8352-D5B6B0DAFBDE} --> E:\Steam\SteamApps\common\XCom-Enemy-Unknown\Binaries\Win32\XComGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\XCom-Enemy-Unknown\Binaries\Win32\XComGame.exe|Name=XCOM: Enemy Unknown| - Enabled - Firaxis Games
{7F280529-461D-423F-B2E9-86BFCDED3EFF} --> E:\Steam\SteamApps\common\Saints Row the Third\game_launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\game_launcher.exe|Name=Saints Row: The Third| - Enabled - THQ Inc.
{AA3B4DF1-F8ED-4C08-B493-59F0FAB04AE0} --> E:\Steam\SteamApps\common\Saints Row the Third\game_launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\game_launcher.exe|Name=Saints Row: The Third| - Enabled - THQ Inc.
{27FB8D2E-6CBF-4DC6-BAC9-B448D3CC6A20} --> E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird.exe|Name=Saints Row: The Third| - Enabled - THQ Inc.
{C307F0F6-7267-497A-B7E4-6FAD00B4507E} --> E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird.exe|Name=Saints Row: The Third| - Enabled - THQ Inc.
{0953CD49-C8C1-480D-8748-8216D873B516} --> E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird_DX11.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird_DX11.exe|Name=Saints Row: The Third DX11| - Enabled - THQ Inc.
{D2E26BF6-EDDF-4007-BD99-2F5C4F255D36} --> E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird_DX11.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird_DX11.exe|Name=Saints Row: The Third DX11| - Enabled - THQ Inc.
{8AA555D4-C388-4AA4-88EB-44A5D4224E91} --> E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe|Name=Deus Ex: Game of the Year Edition| - Enabled -
{FE33F4D6-D576-4F5D-90D0-6B837F96C7BE} --> E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe|Name=Deus Ex: Game of the Year Edition| - Enabled -
{364C014F-2AA8-4E90-87EE-98C8620D8FA4} --> E:\Steam\SteamApps\common\Dead Island\DeadIslandGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dead Island\DeadIslandGame.exe|Name=Dead Island| - Enabled - Techland
{007B368A-F089-4BF2-ADA4-9F0C553BBEB1} --> E:\Steam\SteamApps\common\Dead Island\DeadIslandGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dead Island\DeadIslandGame.exe|Name=Dead Island| - Enabled - Techland
{3CF81BE6-3B1A-4686-B3D2-B99E2BC4D70E} --> E:\Steam\SteamApps\common\Deus Ex - Human Revolution\dxhr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Deus Ex - Human Revolution\dxhr.exe|Name=Deus Ex: Human Revolution| - Enabled - Square Enix Limited
{F2EC55AD-C1EC-436B-9DFB-975F07A9162E} --> E:\Steam\SteamApps\common\Deus Ex - Human Revolution\dxhr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Deus Ex - Human Revolution\dxhr.exe|Name=Deus Ex: Human Revolution| - Enabled - Square Enix Limited
{64B79135-159F-40E0-B975-19C99686403F} --> E:\Steam\SteamApps\common\DXHRML\dxhrml.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\DXHRML\dxhrml.exe|Name=Deus Ex: Human Revolution - The Missing Link| - Enabled - Square Enix Limited
{9A34A54E-665E-41B8-AAA6-AB84CFF5AA41} --> E:\Steam\SteamApps\common\DXHRML\dxhrml.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\DXHRML\dxhrml.exe|Name=Deus Ex: Human Revolution - The Missing Link| - Enabled - Square Enix Limited
TCP Query User{C9C2606F-F67B-404F-ADF9-ED9664973D59}E:\steam\steamapps\common\xcom-enemy-unknown\xew\binaries\win32\xcomew.exe --> E:\Steam\steamapps\common\xcom-enemy-unknown\XEW\Binaries\Win32\XComEW.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|Profile=Public|App=E:\steam\steamapps\common\xcom-enemy-unknown\xew\binaries\win32\xcomew.exe|Name=XCOM: Enemy Within|Desc=XCOM: Enemy Within|Defer=User| - Enabled - Firaxis Games
UDP Query User{4B43E231-EDAE-4528-8BC7-59EB671821D4}E:\steam\steamapps\common\xcom-enemy-unknown\xew\binaries\win32\xcomew.exe --> E:\Steam\steamapps\common\xcom-enemy-unknown\XEW\Binaries\Win32\XComEW.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|Profile=Public|App=E:\steam\steamapps\common\xcom-enemy-unknown\xew\binaries\win32\xcomew.exe|Name=XCOM: Enemy Within|Desc=XCOM: Enemy Within|Defer=User| - Enabled - Firaxis Games
{9D157DFB-B5FD-4D75-9778-FF47D1E3F2FD} --> E:\Steam\SteamApps\common\Skyrim\CreationKit.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Skyrim\CreationKit.exe|Name=Skyrim Creation Kit| - Enabled - Bethesda Softworks
{5EC0C182-7DA3-447C-8408-DB355C812D96} --> E:\Steam\SteamApps\common\Skyrim\CreationKit.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Skyrim\CreationKit.exe|Name=Skyrim Creation Kit| - Enabled - Bethesda Softworks
{D1606FA9-C2B8-4AAD-AD14-E1F85963FFDC} --> E:\Program Files (x86)\Origin Games\Command and Conquer Red Alert II\RA2Launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=E:\Program Files (x86)\Origin Games\Command and Conquer Red Alert II\RA2Launcher.exe|Name=Command & Conquer™ Red Alert 2 and Yuri’s Revenge| - Enabled - Kalloc Studios
{8BCFE501-6FF8-4C3C-9E42-7C51646768F1} --> E:\Program Files (x86)\Origin Games\Command and Conquer Red Alert II\RA2Launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=E:\Program Files (x86)\Origin Games\Command and Conquer Red Alert II\RA2Launcher.exe|Name=Command & Conquer™ Red Alert 2 and Yuri’s Revenge| - Enabled - Kalloc Studios
{A58B33D0-BC26-4F9A-B49B-A62BA65F28DC} --> C:\Program Files (x86)\Raptr\raptr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr\raptr.exe|Name=Raptr Desktop App| - Enabled - File not found
{5FBC2EAD-17E4-43A7-8F7D-8500F5312811} --> C:\Program Files (x86)\Raptr\raptr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr\raptr.exe|Name=Raptr Desktop App| - Enabled - File not found
{6F3E6FA2-07C8-4B80-9EE6-1AFCB424E090} --> C:\Program Files (x86)\Raptr\raptr_im.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr\raptr_im.exe|Name=Raptr IM| - Enabled - File not found
{F62EB103-89ED-44A6-89EC-213AFA4C97A7} --> C:\Program Files (x86)\Raptr\raptr_im.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr\raptr_im.exe|Name=Raptr IM| - Enabled - File not found
{5E7D5DD7-BBB2-4272-ABE0-A3E568382D62} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{C7E1F2F3-B957-45EE-8CF5-7D50BA0CA1FB} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{31F9FFF5-A9F4-40F0-A293-65D60FBC9588} --> E:\Steam\SteamApps\common\JurassicPark\JurassicPark100.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\JurassicPark\JurassicPark100.exe|Name=Jurassic Park: The Game| - Enabled - Telltale Games
{C700C7EC-CD04-4816-B379-A995B0263A74} --> E:\Steam\SteamApps\common\JurassicPark\JurassicPark100.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\JurassicPark\JurassicPark100.exe|Name=Jurassic Park: The Game| - Enabled - Telltale Games
{7635C5A1-2355-4BC2-BC2F-2AC35A81C8D2} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{58F44C40-4B7E-480C-8A6A-7D7C37F441D4} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{5347DEF1-74FA-4EC6-A7E6-17BDC2FC5FF6} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{000F2CCF-9014-4F19-A19C-76CC9F1DF342} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{C1FCAE84-E209-47FB-BEF4-D2C2DFF576B2} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe|Name=Marvel Heroes 2016| - Enabled - File not found
{A271C9FB-E76F-4B5C-903C-E0FB304F9711} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe|Name=Marvel Heroes 2016| - Enabled - File not found
{0A8BAFE6-AFFD-405F-A03A-AC8A9BAE5DAC} --> C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe|Name=Raptr Desktop App| - Enabled - File not found
{6DCA5260-67C8-4CF6-BCF4-FCE9708263A2} --> C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe|Name=Raptr Desktop App| - Enabled - File not found
{E50A44FE-6182-4951-BFA2-81547DAC95FB} --> C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe|Name=Raptr IM| - Enabled - File not found
{BB36AF9E-3A2D-4FA8-B9E2-8CDE4A028A51} --> C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe|Name=Raptr IM| - Enabled - File not found
TCP Query User{B8D6574A-230E-46CA-A71C-A09A09CB16FF}E:\program files (x86)\diablo iii\diablo iii.exe --> E:\program files (x86)\diablo iii\diablo iii.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=E:\program files (x86)\diablo iii\diablo iii.exe|Name=Diablo III Retail|Desc=Diablo III Retail|Defer=User| - Enabled - Blizzard Entertainment
UDP Query User{781F11DA-E7E5-41F0-91D7-86106D98C2C9}E:\program files (x86)\diablo iii\diablo iii.exe --> E:\program files (x86)\diablo iii\diablo iii.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=E:\program files (x86)\diablo iii\diablo iii.exe|Name=Diablo III Retail|Desc=Diablo III Retail|Defer=User| - Enabled - Blizzard Entertainment
TCP Query User{B0BFEBD8-F610-49C8-A210-50C2B83F441C}C:\program files (x86)\counterpath\bria stretto\briastretto.exe --> C:\program files (x86)\counterpath\bria stretto\briastretto.exe - v2.10|Action=Block|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\program files (x86)\counterpath\bria stretto\briastretto.exe|Name=Bria Stretto|Desc=Bria Stretto| - Disable - File not found
UDP Query User{0E70B7F9-D2D7-436E-917F-BED0D00C5BC4}C:\program files (x86)\counterpath\bria stretto\briastretto.exe --> C:\program files (x86)\counterpath\bria stretto\briastretto.exe - v2.10|Action=Block|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\program files (x86)\counterpath\bria stretto\briastretto.exe|Name=Bria Stretto|Desc=Bria Stretto| - Disable - File not found
{64DE038F-4711-46BF-AB83-1154D7BE463B} --> C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe|Name=Plays.tv client| - Enabled - File not found
{CB6E88B3-9C3E-44A3-B272-A87AA4C64790} --> C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe|Name=Plays.tv client| - Enabled - File not found
{27F3FCB1-6835-42CC-9A4D-462BABBE00D7} --> E:\Steam\SteamApps\common\XCOM 2\Binaries\Win64\Launcher\ModLauncherWPF.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\XCOM 2\Binaries\Win64\Launcher\ModLauncherWPF.exe|Name=XCOM 2| - Enabled - Microsoft
{1717AF62-46C4-430E-B2E8-6A408B339499} --> E:\Steam\SteamApps\common\XCOM 2\Binaries\Win64\Launcher\ModLauncherWPF.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\XCOM 2\Binaries\Win64\Launcher\ModLauncherWPF.exe|Name=XCOM 2| - Enabled - Microsoft
TCP Query User{13163DF9-D2AA-421A-A545-1B044CA22736}E:\steam\steamapps\common\xcom 2\binaries\win64\xcom2.exe --> E:\Steam\steamapps\common\XCOM 2\Binaries\Win64\XCom2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|Profile=Public|App=E:\steam\steamapps\common\xcom 2\binaries\win64\xcom2.exe|Name=XCOM 2|Desc=XCOM 2|Defer=User| - Enabled - Firaxis Games
UDP Query User{5C2DADA8-E48D-44B9-8D36-2D369782A1A7}E:\steam\steamapps\common\xcom 2\binaries\win64\xcom2.exe --> E:\Steam\steamapps\common\XCOM 2\Binaries\Win64\XCom2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|Profile=Public|App=E:\steam\steamapps\common\xcom 2\binaries\win64\xcom2.exe|Name=XCOM 2|Desc=XCOM 2|Defer=User| - Enabled - Firaxis Games
{9CE7EE83-0607-4154-B0E4-6081BC2593D3} --> E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe|Name=Talisman: The Horus Heresy| - Enabled - Marmalade Technologies Ltd
{6167C9A7-0E89-41D1-8E93-589B845E6CEF} --> E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe|Name=Talisman: The Horus Heresy| - Enabled - Marmalade Technologies Ltd
{A6E0B9D7-46DA-4BA3-9CB0-16C9B2270BD5} --> E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe|Name=Police Quest Collection| - Enabled - Vivendi Universal Games
{26720516-0FB3-463D-BDAA-5733C2933D0D} --> E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe|Name=Police Quest Collection| - Enabled - Vivendi Universal Games
{71B2AE31-321C-4CC8-A2C6-3709B180B7D0} --> E:\Steam\bin\cef\cef.win7\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\bin\cef\cef.win7\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - Valve Corporation
{A0AEB9E9-F9A5-4364-B499-2CC88A54D779} --> E:\Steam\bin\cef\cef.win7\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\bin\cef\cef.win7\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - Valve Corporation
{6F279A62-3CEE-4CAD-A4C5-CADB9DD11C89} --> E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe|Name=Space Hulk: Deathwing| - Enabled -
{2A4C5138-1794-4E90-A5B1-A4C07FA5888F} --> E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe|Name=Space Hulk: Deathwing| - Enabled -
{BFFAD919-52EE-4E03-85E7-22EB6DFE0899} --> E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe|Name=Friday the 13th: The Game BETA| - Enabled -
{94B611A9-8B99-4B9C-A6A5-4C2A605169E9} --> E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe|Name=Friday the 13th: The Game BETA| - Enabled -
{F4036343-5049-4EF3-B40D-CE3E536CD910} --> E:\Steam\SteamApps\common\Dead State\ZRPG.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dead State\ZRPG.exe|Name=Dead State| - Enabled - DoubleBear Productions, Iron Tower Studio
{F17D2244-7DB6-4B8D-B298-084E4E6F24AE} --> E:\Steam\SteamApps\common\Dead State\ZRPG.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dead State\ZRPG.exe|Name=Dead State| - Enabled - DoubleBear Productions, Iron Tower Studio
{85F311B7-E6CE-4BDB-B341-A7AFC9D75998} --> E:\Steam\SteamApps\common\TheRoom\TheRoom.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\TheRoom\TheRoom.exe|Name=The Room| - Enabled -
{DBDC55A0-7379-4A03-A92B-90509ABDB7D6} --> E:\Steam\SteamApps\common\TheRoom\TheRoom.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\TheRoom\TheRoom.exe|Name=The Room| - Enabled -
{B5A37BCD-94D4-4628-9CCA-DDE263B65E3C} --> E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe|Name=Warhammer 40,000: Regicide| - Enabled -
{EE680A25-86FB-4157-95B7-203F2C0A592D} --> E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe|Name=Warhammer 40,000: Regicide| - Enabled -
TCP Query User{D5BA13C4-8EB3-42D4-B2CA-22A2A3BE7E2A}E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe --> E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|Profile=Public|App=E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe|Name=Heroes of the Storm|Desc=Heroes of the Storm|Defer=User| - Enabled - File not found
UDP Query User{41B28AE0-48B6-43CB-9F80-D48CBB086CD0}E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe --> E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|Profile=Public|App=E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe|Name=Heroes of the Storm|Desc=Heroes of the Storm|Defer=User| - Enabled - File not found
{C48A36A6-4A14-4FE4-A7FF-CB73E4875A37} --> E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe|Name=Plague Inc: Evolved| - Enabled -
{2FF4AB51-0353-47A0-A61D-68A2FA9D37BD} --> E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe|Name=Plague Inc: Evolved| - Enabled -
{E1D3ACF9-A910-4F53-BE2D-6005A77ECD5D} --> E:\Steam\SteamApps\common\Warhammer 40,000 - Eternal Crusade\EternalCrusadeClient.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Warhammer 40,000 - Eternal Crusade\EternalCrusadeClient.exe|Name=Warhammer 40,000: Eternal Crusade| - Enabled - EasyAntiCheat Ltd
{AF68201D-AB64-4E1E-B8AB-5FD9959F0FF6} --> E:\Steam\SteamApps\common\Warhammer 40,000 - Eternal Crusade\EternalCrusadeClient.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Warhammer 40,000 - Eternal Crusade\EternalCrusadeClient.exe|Name=Warhammer 40,000: Eternal Crusade| - Enabled - EasyAntiCheat Ltd
{B9718C95-EFD7-467B-A932-1739913F4A5F} --> E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE|Name=Killing Time| - Enabled - File not found
{DF60188E-22FC-49D7-AC10-8185B59A6E5E} --> E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE|Name=Killing Time| - Enabled - File not found
{B3EAB2B3-0930-4FD9-8374-8E0C22DB0010} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe|Name=Marvel Heroes Omega| - Enabled - Gazillion, Inc.
{3B016CC3-F3CB-49B0-96E7-E6F035C1483E} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe|Name=Marvel Heroes Omega| - Enabled - Gazillion, Inc.
{3DF33BBF-5A10-4282-AC43-0A4CE629AFA7} --> E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe|Name=Stranded Deep| - Enabled -
{DD950824-0E60-44D1-B0A2-F0754C156B84} --> E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe|Name=Stranded Deep| - Enabled -
{503DAAC1-EDBD-4B77-A7F2-E91E6C69D5B7} --> E:\Steam\SteamApps\common\The Forest\TheForest.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Forest\TheForest.exe|Name=The Forest| - Enabled -
{6A76B832-9950-41BB-97ED-A4581D14E6BC} --> E:\Steam\SteamApps\common\The Forest\TheForest.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Forest\TheForest.exe|Name=The Forest| - Enabled -
{AD8DFFEA-1DC6-4D07-AA54-6D91ED2B2046} --> E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe|Name=Vampire: The Masquerade - Redemption| - Enabled -
{D2D3334E-F0B0-4A58-A151-0B64D6C34608} --> E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe|Name=Vampire: The Masquerade - Redemption| - Enabled -
{3F1B4BE2-16E1-401A-ABB0-C2DB65865152} --> E:\Steam\SteamApps\common\Firewatch\Firewatch.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Firewatch\Firewatch.exe|Name=Firewatch| - Enabled -
{CF807903-A7B7-4B6C-8D20-ADF4A496D9C9} --> E:\Steam\SteamApps\common\Firewatch\Firewatch.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Firewatch\Firewatch.exe|Name=Firewatch| - Enabled -
{5C0A5BC7-95F1-426A-AED9-7373B31E448E} --> E:\Steam\SteamApps\common\Total War SHOGUN 2\Shogun2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Total War SHOGUN 2\Shogun2.exe|Name=Total War: SHOGUN 2| - Enabled - The Creative Assembly Ltd
{22194631-5066-4FE9-9640-E00470260120} --> E:\Steam\SteamApps\common\Total War SHOGUN 2\Shogun2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Total War SHOGUN 2\Shogun2.exe|Name=Total War: SHOGUN 2| - Enabled - The Creative Assembly Ltd
{379F9EF1-959D-45B9-9175-A32EE4E39161} --> C:\Program Files (x86)\BlueStacks\HD-Plus-Service.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|App=C:\Program Files (x86)\BlueStacks\HD-Plus-Service.exe|Name=BlueStacks Service| - Enabled - File not found
TCP Query User{7347BDCE-E796-498D-85FA-62DDB80A9D72}C:\program files\logitech gaming software\lcore.exe --> C:\program files\logitech gaming software\LCore.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|Profile=Public|App=C:\program files\logitech gaming software\lcore.exe|Name=Logitech Gaming Framework|Desc=Logitech Gaming Framework|Defer=User| - Enabled - Logitech Inc.
UDP Query User{C4FEBBB9-D8C8-4D15-BCAB-86C67FEF2211}C:\program files\logitech gaming software\lcore.exe --> C:\program files\logitech gaming software\LCore.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|Profile=Public|App=C:\program files\logitech gaming software\lcore.exe|Name=Logitech Gaming Framework|Desc=Logitech Gaming Framework|Defer=User| - Enabled - Logitech Inc.
TCP Query User{2143CF31-74D4-46F8-88C3-EEA86AF676BC}E:\program files (x86)\diablo iii\x64\diablo iii64.exe --> E:\program files (x86)\diablo iii\x64\diablo iii64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=E:\program files (x86)\diablo iii\x64\diablo iii64.exe|Name=Diablo III Retail|Desc=Diablo III Retail|Defer=User| - Enabled - Blizzard Entertainment
UDP Query User{EE52F9F5-1344-49BA-A37F-11CB8B3A7606}E:\program files (x86)\diablo iii\x64\diablo iii64.exe --> E:\program files (x86)\diablo iii\x64\diablo iii64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=E:\program files (x86)\diablo iii\x64\diablo iii64.exe|Name=Diablo III Retail|Desc=Diablo III Retail|Defer=User| - Enabled - Blizzard Entertainment
{E45E0E9B-ED52-4C49-A70F-75A27CD504DB} --> C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|App=C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe|Name=BitTorrent (TCP-In)|Desc=Allow BitTorrent network traffic with Edge Traversal|Edge=TRUE| - Enabled - File not found
{FF92BA05-DAFB-4969-84E0-7B1664C1F369} --> C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|App=C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe|Name=BitTorrent (UDP-In)|Desc=Allow BitTorrent network traffic with Edge Traversal|Edge=TRUE| - Enabled - File not found
TCP Query User{5DCDA691-17AF-46BE-910B-2AA2A2310F7F}C:\programdata\battle.net\agent\agent.6082\agent.exe --> C:\programdata\Battle.net\Agent\agent.6082\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\programdata\battle.net\agent\agent.6082\agent.exe|Name=Blizzard Update Agent|Desc=Blizzard Update Agent|Defer=User| - Enabled - Blizzard Entertainment
UDP Query User{A078B926-203A-4710-B33C-57EB3B622823}C:\programdata\battle.net\agent\agent.6082\agent.exe --> C:\programdata\Battle.net\Agent\agent.6082\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\programdata\battle.net\agent\agent.6082\agent.exe|Name=Blizzard Update Agent|Desc=Blizzard Update Agent|Defer=User| - Enabled - Blizzard Entertainment
{81CAF3E5-F44B-4606-BB8E-BE431FBC5274} --> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|LPort=5353|App=C:\Program Files (x86)\Google\Chrome\Application\chrome.exe|Name=Google Chrome (mDNS-In)|Desc=Inbound rule for Google Chrome to allow mDNS traffic.|EmbedCtxt=Google Chrome| - Enabled - Google Inc.
System User Name
Nothing
Scan MBR Rootkit
MBR OK!
Is there additional information needed?
Still waiting on recommendation for uploading Sysnative info due to forum rejecting file as too large.
ZHP Diag Scan
Download ZHP Diag to your desktop.
1. Right Click Run as Admin.
2. Click the Options button.
Click on Check All
Then Click Validate
Then click close.
upload_2017-4-26_17-16-39-png.2074
2. Click the Scanner button.
upload_2017-2-23_3-32-26-png.1647
A notepad will open... copy and paste the report in your next reply.
Reactions: veeg
FYI - there was no "validate" option available. When first opening the program I am prompted to update which takes me in an endless loop to a French site (again, I do not like putting programs on my computer in languages I don't understand) where I was unable to download any sort of new version. Regardless, it seems to have worked without having to "update" as prompted by the program.
Also - any suggestions as far as uploading Sysnative attachment due to file being "too big"?
Scan Results
~ ZHPDiag v2018.5.14.108 By Nicolas Coolman (2018/05/14)
~ Run by Mike (Administrator) (2018/05/15 08:29:32)
~ Blog: https://nicolascoolman.eu/
~ Facebook: https://www.facebook.com/nicolascoolman1
~ Certificate ZHPDiag: Legal
~ State version: Version KO
~ Mode: Scan
~ Report: C:\Users\Mike\Desktop\ZHPDiag.txt
~ Report: C:\Users\Mike\AppData\Roaming\ZHP\ZHPDiag.txt
~ UAC: Activate
~ System startup: Normal (Normal boot)
Windows 7 Home Premium, 64-bit Service Pack 1 (Build 7601) =>.Microsoft Corporation
---\ Internet Browsers (2) - 0s
~ GCIE: Google Chrome v66.0.3359.139
~ MSIE: Internet Explorer v11.0.9600.19002
---\ Windows Product Information (4) - 3s
~ Windows Server License Manager Script : OK
~ Licence Script File Génération : OK
Windows Automatic Updates : OK
Windows Activation Technologies : OK
---\ System protection software (2) - 1s
Norton Security Scan v4.6.1.150 (Protection)
Malwarebytes version 3.4.5.2467 v3.4.5.2467 (Protection)
---\ Surveillance software (3) - 1s
~ Adobe Flash Player 28 ActiveX (Surveillance)
~ Adobe Flash Player 28 NPAPI (Surveillance)
~ Adobe Acrobat Reader DC (Surveillance)
---\ Informations on the system (6) - 0s
~ Operating System: AMD64 Family 21 Model 2 Stepping 0, AuthenticAMD
~ Operating System: 64-bit
~ Boot mode: Normal (Normal boot)
Total RAM: 4092.768 MB (48% free) : OK =>.RAM Value
System Restore: Activé (Enable)
System drive C: has 34 GB (29%) free of 114 GB : OK =>.Disk Space
---\ Connection to the system mode (3) - 0s
~ Computer Name: MIKE-PC
~ User Name: Mike
~ Logged in as Administrator
---\ Enumeration of the disk units (2) - 0s
~ Drive C: has 34 GB free of 114 GB (System)
~ Drive E: has 395 GB free of 953 GB
---\ State of the Windows Security Center (11) - 0s
[HKLM\Software\WOW6432Node\Microsoft\Security Center\Svc] AntiSpywareOverride: OK
[HKLM\Software\WOW6432Node\Microsoft\Security Center\Svc] AntiVirusOverride: OK
[HKLM\Software\WOW6432Node\Microsoft\Security Center\Svc] FirewallOverride: OK
[HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Policies\Explorer] NoActiveDesktopChanges: Modified
[HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\policies\system] EnableLUA: OK
[HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\NOHIDDEN] CheckedValue: Modified
[HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL] CheckedValue: OK
[HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Explorer\Associations] Application: OK
[HKLM\Software\WOW6432Node\Microsoft\Windows NT\CurrentVersion\Winlogon] Shell: OK
[HKLM64\SYSTEM\CurrentControlSet\Services\COMSysApp] Type: OK
[HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install] LastSuccessTime : OK
---\ Search Generic System Files (24) - 0s
[MD5.38AE1B3C38FAEF56FE4907922F0385BA] - 29/08/2016 - (.Microsoft Corporation - Windows Explorer.) -- C:\Windows\Explorer.exe [3229696] =>.Microsoft Corporation
[MD5.C36BB659F08F046B139C8D1B980BF1AC] - 30/03/2017 - (.Microsoft Corporation - Windows host process (Rundll32).) -- C:\Windows\System32\rundll32.exe [46080] =>.Microsoft Corporation
[MD5.94355C28C1970635A31B3FE52EB7CEBA] - 13/07/2009 - (.Microsoft Corporation - Windows Start-Up Application.) -- C:\Windows\System32\Wininit.exe [129024] =>.Microsoft Corporation
[MD5.79A5C72A23A56FC20D2572F9095AE7F5] - 22/04/2018 - (.Microsoft Corporation - Internet Extensions for Win32.) -- C:\Windows\System32\wininet.dll [3241472] =>.Microsoft Corporation
[MD5.11D6A262B617130F7C16E308C12E0D41] - 31/12/2017 - (.Microsoft Corporation - Windows Logon Application.) -- C:\Windows\System32\Winlogon.exe [455680] =>.Microsoft Corporation
[MD5.067FA52BFB59A56110A12312EF9AF243] - 20/11/2010 - (.Microsoft Corporation - Software Licensing Library.) -- C:\Windows\System32\sppcomapi.dll [232448] =>.Microsoft Corporation
[MD5.492D07D79E7024CA310867B526D9636D] - 03/03/2011 - (.Microsoft Corporation - DNS Client API DLL.) -- C:\Windows\System32\dnsapi.dll [357888] =>.Microsoft Corporation
[MD5.B40420876B9288E0A1C8CCA8A84E5DC9] - 03/03/2011 - (.Microsoft Corporation - DNS Client API DLL.) -- C:\Windows\Syswow64\dnsapi.dll [270336] =>.Microsoft Corporation
[MD5.0DC2A9882540DEA4A55B08785E09D8FC] - 04/04/2017 - (.Microsoft Corporation - Ancillary Function Driver for WinSock.) -- C:\Windows\System32\drivers\AFD.sys [496128] =>.Microsoft Corporation
[MD5.02062C0B390B7729EDC9E69C680A6F3C] - 13/07/2009 - (.Microsoft Corporation - ATAPI IDE Miniport Driver.) -- C:\Windows\System32\drivers\atapi.sys [24128] =>.Microsoft Corporation
[MD5.B8BD2BB284668C84865658C77574381A] - 13/07/2009 - (.Microsoft Corporation - CD-ROM File System Driver.) -- C:\Windows\System32\drivers\Cdfs.sys [92160] =>.Microsoft Corporation
[MD5.F036CE71586E93D94DAB220D7BDF4416] - 20/11/2010 - (.Microsoft Corporation - SCSI CD-ROM Driver.) -- C:\Windows\System32\drivers\Cdrom.sys [147456] =>.Microsoft Corporation
[MD5.7D2D2284833760A82308CF09F7618E8B] - 31/12/2017 - (.Microsoft Corporation - DFS Namespace Client Driver.) -- C:\Windows\System32\drivers\DfsC.sys [106496] =>.Microsoft Corporation
[MD5.97BFED39B6B79EB12CDDBFEED51F56BB] - 20/11/2010 - (.Microsoft Corporation - High Definition Audio Bus Driver.) -- C:\Windows\System32\drivers\HDAudBus.sys [122368] =>.Microsoft Corporation
[MD5.FA55C73D4AFFA7EE23AC4BE53B4592D3] - 13/07/2009 - (.Microsoft Corporation - i8042 Port Driver.) -- C:\Windows\System32\drivers\i8042prt.sys [105472] =>.Microsoft Corporation
[MD5.AF9B39A7E7B6CAA203B3862582E9F2D0] - 13/07/2009 - (.Microsoft Corporation - IP Network Address Translator.) -- C:\Windows\System32\drivers\IpNat.sys [116224] =>.Microsoft Corporation
[MD5.E9165E57CC6DD261A626514D2B3961CA] - 22/04/2018 - (.Microsoft Corporation - Windows NT SMB Minirdr.) -- C:\Windows\System32\drivers\MRxSmb.sys [160256] =>.Microsoft Corporation
[MD5.734837208CAFD6E0959A7A0333C95C9D] - 11/08/2017 - (.Microsoft Corporation - MBT Transport driver.) -- C:\Windows\System32\drivers\netBT.sys [262656] =>.Microsoft Corporation
[MD5.A97B92D11270695B15C3663BCCB737D3] - 31/12/2017 - (.Microsoft Corporation - NT File System Driver.) -- C:\Windows\System32\drivers\ntfs.sys [1680616] =>.Microsoft Corporation
[MD5.0086431C29C35BE1DBC43F52CC273887] - 13/07/2009 - (.Microsoft Corporation - Parallel Port Driver.) -- C:\Windows\System32\drivers\Parport.sys [97280] =>.Microsoft Corporation
[MD5.471815800AE33E6F1C32FB1B97C490CA] - 20/11/2010 - (.Microsoft Corporation - RAS L2TP mini-port/call-manager driver.) -- C:\Windows\System32\drivers\Rasl2tp.sys [129536] =>.Microsoft Corporation
[MD5.548260A7B8654E024DC30BF8A7C5BAA4] - 13/07/2009 - (.Microsoft Corporation - SMB Transport driver.) -- C:\Windows\System32\drivers\smb.sys [93184] =>.Microsoft Corporation
[MD5.4DD986720F7CB7A8A5D1226793097B9A] - 29/07/2017 - (.Microsoft Corporation - TDI Translation Driver.) -- C:\Windows\System32\drivers\tdx.sys [117248] =>.Microsoft Corporation
[MD5.DF8126BD41180351A093A3AD2FC8903B] - 25/02/2011 - (.Microsoft Corporation - Volume Shadow Copy Driver.) -- C:\Windows\System32\drivers\volsnap.sys [296320] =>.Microsoft Corporation
---\ Non Microsoft non disabled Windows Services (3) - 0s
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) . (.Adobe Systems Incorporated - Adobe Acrobat Update Service.) - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe =>.Adobe Systems, Incorporated®
O23 - Service: (AMD External Events Utility) . (.AMD - AMD External Events Service Module.) - C:\Windows\System32\atiesrxx.exe =>.AMD
O23 - Service: Malwarebytes Service (MBAMService) . (.Malwarebytes - Malwarebytes Service.) - C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe =>.Malwarebytes Corporation®
---\ Services not Microsoft (SR=Run, SS=Stop) (11) - 2s
SR - Auto [09/02/2018] [ 83984] Adobe Acrobat Update Service (AdobeARMservice) . (.Adobe Systems Incorporated.) - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe =>.Adobe Systems, Incorporated®
SS - Disabl [07/02/2018] [ 272384] Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) . (.Adobe Systems Incorporated.) - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe =>.Adobe Systems Incorporated®
SR - Auto [31/01/2018] [ 472456] (AMD External Events Utility) . (.AMD.) - C:\Windows\System32\atiesrxx.exe =>.Advanced Micro Devices, Inc.®
SS - Disabl [30/09/2014] [ 25832] Dragon Age: Origins - Content Updater (DAUpdaterSvc) . (.BioWare.) - E:\Steam\steamapps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe =>.BioWare®
SS - Disabl [27/08/2015] [ 144200] Google Update Service (gupdate) (gupdate) . (.Google Inc..) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe =>.Google Inc®
SS - Disabl [27/08/2015] [ 144200] Google Update Service (gupdatem) (gupdatem) . (.Google Inc..) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe =>.Google Inc®
SS - Disabl [10/07/2017] [ 225400] Logitech Gaming Registry Service (LogiRegistryService) . (.Logitech Inc..) - C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.exe =>.Logitech Inc®
SS - Auto [27/03/2018] [ 6479136] Malwarebytes Service (MBAMService) . (.Malwarebytes.) - C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe =>.Malwarebytes Corporation®
SS - Demand [09/10/2017] [ 189112] PAExec (PAExec) . (.Power Admin LLC.) - C:\Windows\PAExec.exe =>.Power Admin LLC®
SS - Disabl [13/10/2014] [ 743688] SAMSUNG Mobile Connectivity Service (ss_conn_service) . (.DEVGURU Co., LTD..) - C:\Program Files\SAMSUNG\USB Drivers\25_escape\conn\ss_conn_service.exe =>.DEVGURU CO LTD®
SS - Disabl [18/01/2012] [ 450848] (UMVPFSrv) . (.Logitech Inc..) - C:\Program Files (x86)\Common Files\logishrd\LVMVFM\UMVPFSrv.exe =>.Logitech, Inc.®
---\ Task Planned Automatically (Register) (16) - 1s
O38 - TASK: {057296E0-3D8A-455D-B70E-14D63AF2BB33} [64Bits][\ASUS\RunDAOD] - (.ASUSTeK - .) -- C:\Windows\DAODx.exe [32768] =>.ASUSTeK
O38 - TASK: {09B3A6E7-AB37-46E6-9944-5CC214E53507} [64Bits][\{ABF8DB55-2624-4AA2-A494-30A75C880CC3}] - (. - Display_Driver_Uninstaller.) -- C:\Users\Mike\Documents\[Guru3D.com]-DDU\Display Driver Uninstaller.exe [1441792]
O38 - TASK: {2B78B087-8307-4183-B4B0-5EC5E5042CF0} [64Bits][\GoogleUpdateTaskMachineCore] - (.Google Inc. - Google Installer.) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [144200] =>.Google Inc.
O38 - TASK: {73EBAF6F-6ACA-4173-A011-F20C9D05B8FA} [64Bits][\GoogleUpdateTaskMachineUA] - (.Google Inc. - Google Installer.) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [144200] =>.Google Inc.
O38 - TASK: {80630653-5697-49A9-8ADF-9294A7A3C8C1} [64Bits][\StartCN] - (.Advanced Micro Devices, Inc. - Radeon Settings: Command Line Interface.) -- C:\Program Files\AMD\CNext\CNext\cncmd.exe [49544] =>.Advanced Micro Devices, Inc.
O38 - TASK: {840BD775-31BC-4D20-A2AD-58EB9378E71B} [64Bits][\StartDVR] - (.Advanced Micro Devices, Inc. - AMD ReLive: Command Line Interface.) -- C:\Program Files\AMD\CNext\CNext\dvrcmd.exe [69512] =>.Advanced Micro Devices, Inc.
O38 - TASK: {9C589C87-CED7-48D6-B5ED-DA0724CA6CD4} [64Bits][\Adobe Acrobat Update Task] - (.Adobe Systems Incorporated - Adobe Reader and Acrobat Manager.) -- C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [1183256] =>.Adobe Systems Incorporated
O38 - TASK: {DD8C08AC-12F6-4DAA-B6D2-7B766777B07E} [64Bits][\Adobe Flash Player Updater] - (.Adobe Systems Incorporated - Adobe® Flash® Player Update Service 28.0 r0.) -- C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [272384] =>.Adobe Systems Incorporated
C:\Windows\System32\Tasks\ASUS\RunDAOD - (.ASUSTeK.) -- C:\Windows\DAODx.exe [] =>.ASUSTeK
C:\Windows\System32\Tasks\{ABF8DB55-2624-4AA2-A494-30A75C880CC3} - (..) -- C:\Users\Mike\Documents\[Guru3D.com]-DDU\Display Driver Uninstaller.exe [C:\Users\Mike\Documents\[Guru3D.com]-DDU\Display Driver Uninstaller.exe]
C:\Windows\System32\Tasks\GoogleUpdateTaskMachineCore - (.Google Inc..) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [/c] =>.Google Inc.
C:\Windows\System32\Tasks\GoogleUpdateTaskMachineUA - (.Google Inc..) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [/ua] =>.Google Inc.
C:\Windows\System32\Tasks\StartCN - (.Advanced Micro Devices, Inc..) -- C:\Program Files\AMD\CNext\CNext\cncmd.exe [startwithdelay] =>.Advanced Micro Devices, Inc.
C:\Windows\System32\Tasks\StartDVR - (.Advanced Micro Devices, Inc..) -- C:\Program Files\AMD\CNext\CNext\dvrcmd.exe [] =>.Advanced Micro Devices, Inc.
C:\Windows\System32\Tasks\Adobe Acrobat Update Task - (.Adobe Systems Incorporated.) -- C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [] =>.Adobe Systems Incorporated
C:\Windows\System32\Tasks\Adobe Flash Player Updater - (.Adobe Systems Incorporated.) -- C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [] =>.Adobe Systems Incorporated
---\ Auto loading programs from Registry and folders (2) - 0s
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] . (.Microsoft Corporation - MCTAdmin.) -- C:\Windows\System32\mctadmin.exe =>.Microsoft Corporation
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] . (.Microsoft Corporation - MCTAdmin.) -- C:\Windows\System32\mctadmin.exe =>.Microsoft Corporation
---\ Process running (22) - 1s
[MD5.416ED4546C2B77AF676DA19A52FEC3CD] - (.AMD - AMD External Events Service Module.) -- C:\Windows\System32\atiesrxx.exe [472456] [PID.936] =>.AMD
[MD5.A31C11BF1DA132AE784141ECAC44AF3A] - (.AMD - AMD External Events Client Module.) -- C:\Windows\System32\atieclxx.exe [700296] [PID.1460] =>.AMD
[MD5.CA805DA983594B01F3554464B2E5158F] - (.Adobe Systems Incorporated - Adobe Acrobat Update Service.) -- C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [83984] [PID.1544] =>.Adobe Systems, Incorporated®
[MD5.357CABBF155AFD1D3926E62539D2A3A7] - (.Microsoft Corp. - Microsoft® Windows Live ID Service.) -- C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE [2292480] [PID.1752] =>.Microsoft Corporation®
[MD5.D790CAFEFF0291D0AF8C76F5A1EE2E4E] - (.Microsoft Corp. - Microsoft® Windows Live ID Service Monitor.) -- C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVCM.EXE [223488] [PID.1624] =>.Microsoft Corporation®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (...) -- C:\Windows\DAODx.exe [32768] [PID.2904]
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Advanced Micro Devices, Inc. - Radeon Settings: Host Application.) -- C:\Program Files\AMD\CNext\CNext\RadeonSettings.exe [15430536] [PID.816] =>.Advanced Micro Devices, Inc.®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Twitch Interactive, Inc. - Twitch.) -- C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe [1567552] [PID.3076] =>.Twitch Interactive, Inc.®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Advanced Micro Devices, Inc. - AMD ReLive: Host Application.) -- C:\Program Files\AMD\CNext\CNext\amddvr.exe [1814920] [PID.3592] =>.Advanced Micro Devices, Inc.®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Twitch Interactive, Inc. - Twitch.) -- C:\Users\Mike\AppData\Roaming\Twitch\Bin\Electron\TwitchUI.exe [50211136] [PID.3716] =>.Twitch Interactive, Inc.®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Twitch Interactive, Inc. - Twitch.) -- C:\Users\Mike\AppData\Roaming\Twitch\Bin\Electron\TwitchUI.exe [50211136] [PID.984] =>.Twitch Interactive, Inc.®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Twitch Interactive, Inc. - Twitch.) -- C:\Users\Mike\AppData\Roaming\Twitch\Bin\Electron\TwitchUI.exe [50211136] [PID.4136] =>.Twitch Interactive, Inc.®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Advanced Micro Devices, Inc. - AMD ReLive: Desktop Overlay.) -- C:\Program Files\AMD\CNext\CNext\amdow.exe [58248] [PID.4572] =>.Advanced Micro Devices, Inc.®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Nicolas Coolman - ZHPDiag.) -- C:\Users\Mike\Downloads\ZHPDiag3 (1).exe [3099008] [PID.2028] =>.Nicolas Coolman
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Nicolas Coolman - ZHPDiag.) -- C:\Users\Mike\Downloads\ZHPDiag3.exe [3099008] [PID.4336] =>.Nicolas Coolman
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe [1586008] [PID.1664] =>.Google Inc®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe [1586008] [PID.2888] =>.Google Inc®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe [1586008] [PID.5516] =>.Google Inc®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe [1586008] [PID.1056] =>.Google Inc®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe [1586008] [PID.2700] =>.Google Inc®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe [1586008] [PID.5260] =>.Google Inc®
[MD5.6954474CE8D7C32918CF3448160F8DFC] - (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe [1586008] [PID.2140] =>.Google Inc®
---\ Google Chrome, Start,Search,Extensions (21) - 0s
G0 - GCSP: Preferences [User Data\Default][HomePage] http://adservice.google.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://apis.google.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://cdn.materialdesignicons.com
G0 - GCSP: Preferences [User Data\Default][HomePage] http://fonts.googleapis.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://fonts.gstatic.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://maxcdn.bootstrapcdn.com
G0 - GCSP: Preferences [User Data\Default][HomePage] http://pchelpforum.net
G0 - GCSP: Preferences [User Data\Default][HomePage] http://ssl.gstatic.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.google.com =>.Google Inc.
G0 - GCSP: Preferences [User Data\Default][HomePage] http://www.gstatic.com =>.Google Inc.
G0 - GCSP: Secure Preferences [User Data\Default][HomePage] http://www.google.com =>.Google Inc.
G2 - GCE: Preference [Mike][User Data\Default] [aapocclcgogkmnckokdopfmhonfmgoek] =>.Google Inc. {Slides}
G2 - GCE: Preference [Mike][User Data\Default] [aohghmighlieiainnegkcijnfilokake] =>.Google Inc. {Docs}
G2 - GCE: Preference [Mike][User Data\Default] [apdfllckaahabafndbhieahigkjlhalf] http://drive.google.com/ =>.Google Inc. {Drive}
G2 - GCE: Preference [Mike][User Data\Default] [blpcfgokakmgnkcojhhkbfbldkacnbeo] http://www.youtube.com =>.Youtube {Youtube}
G2 - GCE: Preference [Mike][User Data\Default] [coobgpohoikkiipiblmjeljniedjpjpf] http://www.google.com/ =>.Google Inc. {Hidden Chrome extensions}
G2 - GCE: Preference [Mike][User Data\Default] [efaidnbmnnnibpcajpcglclefindmkaj] =>.Adobe Inc. {Acrobat}
G2 - GCE: Preference [Mike][User Data\Default] [felcaaldnbdncclmgdcncolpebgiejap] =>.Google Inc. {Sheets}
G2 - GCE: Preference [Mike][User Data\Default] [nmmhkkegccagdldgiimedpiccmgmieda] =>.Google Inc. {Wallet}
G2 - GCE: Preference [Mike][User Data\Default] [pjkljhegncpnkpknbcohdijeoejaedia] http://mail.google.com/ =>.Google Inc. {Gmail}
G2 - GCE: Preference [Mike][User Data\Default] [pkedcjkdefgpdelpbcmbmeomcjbeemfm] Chrome Media Router =>.Google Inc.
---\ Mozilla Firefox,Plugins,Start,Search,Extensions (1) - 0s
P2 - FPN: [HKLM] [@adobe.com/FlashPlayer] - (.Adobe Systems Incorporated.) -- C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_28_0_0_161.dll =>.Adobe Systems Incorporated
---\ Internet Explorer Extensions, Start, Search (17) - 0s
R0 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
R0 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
R0 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Bar = preserve =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/ =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons =>.Microsoft Corporation
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk =>.Microsoft Corporation
R1 - HKEY_USERS\S-1-5-21-491581378-2402689455-2613464800-1000\SOFTWARE\Microsoft\Internet Explorer\Main,Search Bar = preserve =>.Microsoft Corporation
R3 - URLSearchHook: (no name)[HKCU] - {CFBFAE00-17A6-11D0-99CB-00C04FD64497} . (.Microsoft Corporation - Internet Browser.) (11.00.9600.19003 (winblue_ltsb_escrow.180421-2027)) -- C:\Windows\System32\ieframe.dll =>.Microsoft Corporation
---\ INTERNET EXPLORER, trusted site and sensitive site (2) - 0s
~ Microsoft Internet Explorer Restricted Site(s) Domains: 0(Good) / 0(Bad)
~ Microsoft Internet Explorer Restricted Site(s) EscDomains: 0(Good) / 0(Bad)
---\ Internet Explorer, Proxy Management (6) - 0s
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyEnable = 0 =>.Default.Value
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,MigrateProxy = 1 =>.Default.Value
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,EnableHttp1_1 = 1 =>.Default.Value
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyHttp1.1 = 1 =>.Default.Value
R5 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings,AutoConfigProxy = wininet.dll
R5 - HKLM\SYSTEM\CurrentControlSet\services\NlaSvc\Parameters\Internet\ManualProxies [] =>.Microsoft
---\ Line Analysis, IniFiles, Auto loading programs (3) - 0s
F2 - REG:system.ini: UserInit=userinit.exe (.Microsoft Corporation.) =>.Microsoft Corporation
F2 - REG:system.ini: Shell=C:\Windows\explorer.exe (.Microsoft Corporation.) =>.Microsoft Corporation
F2 - REG:system.ini: VMApplet=C:\Windows\SysWOW64\SystemPropertiesPerformance.exe (.Microsoft Corporation.) =>.Microsoft Corporation
---\ Hosts file redirection (1) - 0s
~ Le fichier hôte est sain (The hosts file is clean) (4)
---\ Browser Helper Object (BHO) (2) - 1s
O2 - BHO: (no name) [64Bits] - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} (.Orphan.)
O2 - BHO: Windows Live ID Sign-in Helper [64Bits] - {9030D464-4C02-4ABF-8ECC-5164760863C6} . (.Microsoft Corp. - Microsoft® Windows Live ID Login Helper.) -- C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll =>.Microsoft Corporation®
---\ Internet Explorer Toolbars (2) - 0s
O3 - Toolbar: 0xE3EFEB7F196B494398D2FFB09D4B49CA0103030000 - [HKCU]{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} . (...) -- (.not file.)
O3 - Toolbar: 0xB1C218236549D4119B18009027A5CD4F - [HKCU]{2318C2B1-4965-11D4-9B18-009027A5CD4F} . (...) -- (.not file.)
---\ Global shortcuts Startup (120) - 3s
O4 - GS\Desktop [Administrator]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\Desktop [Administrator]: Skyrim (SKSE).lnk . (.Copyright (C) 2006-2015 - A component of the Skyrim Script Extender.) E:\Steam\SteamApps\common\Skyrim\skse_loader.exe
O4 - GS\Desktop [Administrator]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\Desktop [Administrator]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\Mike\AppData\Roaming\ZHP\ZHPDiag3.exe =>.Nicolas Coolman
O4 - GS\Quicklaunch [Administrator]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\Quicklaunch [Administrator]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\sendTo [Administrator]: Fax Recipient.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\Windows\system32\WFS.exe /SendTo =>.Microsoft Corporation
O4 - GS\TaskBar [Administrator]: Acrobat Reader DC.lnk . (.Flexera Software LLC - InstallShield.) C:\Windows\Installer\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}\SC_Reader.ico =>.Flexera Software LLC
O4 - GS\TaskBar [Administrator]: Blizzard App.lnk . (.Blizzard Entertainment - Blizzard Battle.net App Launcher.) E:\Blizzard App\Battle.net Launcher.exe =>.Blizzard Entertainment, Inc.®
O4 - GS\TaskBar [Administrator]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\TaskBar [Administrator]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\TaskBar [Administrator]: Windows Explorer.lnk . (.Microsoft Corporation - Windows Explorer.) C:\Windows\explorer.exe =>.Microsoft Corporation
O4 - GS\TaskBar [Administrator]: Windows Media Player.lnk . (.Microsoft Corporation - Windows Media Player.) C:\Program Files (x86)\Windows Media Player\wmplayer.exe /prefetch:1 =>.Microsoft Corporation
O4 - GS\Startup [Administrator]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe /startup =>.Twitch Interactive, Inc.®
O4 - GS\Programs [Administrator]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Administrator]: Microsoft OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\Mike\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe =>.Microsoft Corporation®
O4 - GS\Programs [Administrator]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\Desktop [Guest]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\Desktop [Guest]: Skyrim (SKSE).lnk . (.Copyright (C) 2006-2015 - A component of the Skyrim Script Extender.) E:\Steam\SteamApps\common\Skyrim\skse_loader.exe
O4 - GS\Desktop [Guest]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\Desktop [Guest]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\Mike\AppData\Roaming\ZHP\ZHPDiag3.exe =>.Nicolas Coolman
O4 - GS\Quicklaunch [Guest]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\Quicklaunch [Guest]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\sendTo [Guest]: Fax Recipient.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\Windows\system32\WFS.exe /SendTo =>.Microsoft Corporation
O4 - GS\TaskBar [Guest]: Acrobat Reader DC.lnk . (.Flexera Software LLC - InstallShield.) C:\Windows\Installer\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}\SC_Reader.ico =>.Flexera Software LLC
O4 - GS\TaskBar [Guest]: Blizzard App.lnk . (.Blizzard Entertainment - Blizzard Battle.net App Launcher.) E:\Blizzard App\Battle.net Launcher.exe =>.Blizzard Entertainment, Inc.®
O4 - GS\TaskBar [Guest]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\TaskBar [Guest]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\TaskBar [Guest]: Windows Explorer.lnk . (.Microsoft Corporation - Windows Explorer.) C:\Windows\explorer.exe =>.Microsoft Corporation
O4 - GS\TaskBar [Guest]: Windows Media Player.lnk . (.Microsoft Corporation - Windows Media Player.) C:\Program Files (x86)\Windows Media Player\wmplayer.exe /prefetch:1 =>.Microsoft Corporation
O4 - GS\Startup [Guest]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe /startup =>.Twitch Interactive, Inc.®
O4 - GS\Programs [Guest]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Guest]: Microsoft OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\Mike\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe =>.Microsoft Corporation®
O4 - GS\Programs [Guest]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\Desktop [Mcx1-MIKE-PC]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\Desktop [Mcx1-MIKE-PC]: Skyrim (SKSE).lnk . (.Copyright (C) 2006-2015 - A component of the Skyrim Script Extender.) E:\Steam\SteamApps\common\Skyrim\skse_loader.exe
O4 - GS\Desktop [Mcx1-MIKE-PC]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\Desktop [Mcx1-MIKE-PC]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\Mike\AppData\Roaming\ZHP\ZHPDiag3.exe =>.Nicolas Coolman
O4 - GS\Quicklaunch [Mcx1-MIKE-PC]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\Quicklaunch [Mcx1-MIKE-PC]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\sendTo [Mcx1-MIKE-PC]: Fax Recipient.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\Windows\system32\WFS.exe /SendTo =>.Microsoft Corporation
O4 - GS\TaskBar [Mcx1-MIKE-PC]: Acrobat Reader DC.lnk . (.Flexera Software LLC - InstallShield.) C:\Windows\Installer\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}\SC_Reader.ico =>.Flexera Software LLC
O4 - GS\TaskBar [Mcx1-MIKE-PC]: Blizzard App.lnk . (.Blizzard Entertainment - Blizzard Battle.net App Launcher.) E:\Blizzard App\Battle.net Launcher.exe =>.Blizzard Entertainment, Inc.®
O4 - GS\TaskBar [Mcx1-MIKE-PC]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\TaskBar [Mcx1-MIKE-PC]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\TaskBar [Mcx1-MIKE-PC]: Windows Explorer.lnk . (.Microsoft Corporation - Windows Explorer.) C:\Windows\explorer.exe =>.Microsoft Corporation
O4 - GS\TaskBar [Mcx1-MIKE-PC]: Windows Media Player.lnk . (.Microsoft Corporation - Windows Media Player.) C:\Program Files (x86)\Windows Media Player\wmplayer.exe /prefetch:1 =>.Microsoft Corporation
O4 - GS\Startup [Mcx1-MIKE-PC]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe /startup =>.Twitch Interactive, Inc.®
O4 - GS\Programs [Mcx1-MIKE-PC]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Mcx1-MIKE-PC]: Microsoft OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\Mike\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe =>.Microsoft Corporation®
O4 - GS\Programs [Mcx1-MIKE-PC]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\Desktop [Mike]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\Desktop [Mike]: Skyrim (SKSE).lnk . (.Copyright (C) 2006-2015 - A component of the Skyrim Script Extender.) E:\Steam\SteamApps\common\Skyrim\skse_loader.exe
O4 - GS\Desktop [Mike]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\Desktop [Mike]: ZHPDiag.lnk . (.Nicolas Coolman - ZHPDiag.) C:\Users\Mike\AppData\Roaming\ZHP\ZHPDiag3.exe =>.Nicolas Coolman
O4 - GS\Quicklaunch [Mike]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\Quicklaunch [Mike]: Launch Internet Explorer Browser.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\sendTo [Mike]: Fax Recipient.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\Windows\system32\WFS.exe /SendTo =>.Microsoft Corporation
O4 - GS\TaskBar [Mike]: Acrobat Reader DC.lnk . (.Flexera Software LLC - InstallShield.) C:\Windows\Installer\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}\SC_Reader.ico =>.Flexera Software LLC
O4 - GS\TaskBar [Mike]: Blizzard App.lnk . (.Blizzard Entertainment - Blizzard Battle.net App Launcher.) E:\Blizzard App\Battle.net Launcher.exe =>.Blizzard Entertainment, Inc.®
O4 - GS\TaskBar [Mike]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\TaskBar [Mike]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\TaskBar [Mike]: Windows Explorer.lnk . (.Microsoft Corporation - Windows Explorer.) C:\Windows\explorer.exe =>.Microsoft Corporation
O4 - GS\TaskBar [Mike]: Windows Media Player.lnk . (.Microsoft Corporation - Windows Media Player.) C:\Program Files (x86)\Windows Media Player\wmplayer.exe /prefetch:1 =>.Microsoft Corporation
O4 - GS\Startup [Mike]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe /startup =>.Twitch Interactive, Inc.®
O4 - GS\Programs [Mike]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Mike]: Microsoft OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\Mike\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe =>.Microsoft Corporation®
O4 - GS\Programs [Mike]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\CommonDesktop [Public]: Acrobat Reader DC.lnk . (.Adobe Systems Incorporated - Adobe Acrobat Reader DC.) C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe =>.Adobe Systems, Incorporated®
O4 - GS\CommonDesktop [Public]: Blizzard App.lnk . (.Blizzard Entertainment - Blizzard Battle.net App Launcher.) E:\Blizzard App\Battle.net Launcher.exe =>.Blizzard Entertainment, Inc.®
O4 - GS\CommonDesktop [Public]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\CommonDesktop [Public]: Heroes of the Storm.lnk . (.Blizzard Entertainment - Heroes of the Storm.) E:\Program Files (x86)\Heroes of the Storm\Heroes of the Storm.exe =>.Blizzard Entertainment, Inc.®
O4 - GS\CommonDesktop [Public]: Logitech Webcam Software .lnk . (...) C:\Program Files (x86)\Common Files\logishrd\LWSPlugins\LWS\Applets\HelpMain\launchershortcut.exe =>.Logitech, Inc.®
O4 - GS\CommonDesktop [Public]: Malwarebytes.lnk . (.Malwarebytes - Malwarebytes.) C:\Program Files\Malwarebytes\Anti-Malware\mbam.exe =>.Malwarebytes Corporation®
O4 - GS\CommonDesktop [Public]: Nexus Mod Manager.lnk . (.Black Tree Gaming - Nexus Mod Manager.) E:\Nexus Mod Manager\NexusClient.exe =>.Black Tree Gaming Ltd.®
O4 - GS\CommonDesktop [Public]: Norton Security Scan.LNK . (.Symantec Corporation - Norton Security Scan.) C:\Program Files (x86)\Norton Security Scan\Engine\4.6.1.150\Nss.exe =>.Symantec Corporation®
O4 - GS\CommonDesktop [Public]: StarCraft II.lnk . (.Blizzard Entertainment - StarCraft II.) E:\Program Files (x86)\StarCraft II\StarCraft II.exe =>.Blizzard Entertainment, Inc.®
O4 - GS\CommonDesktop [Public]: Steam.lnk . (.Valve Corporation - Steam Client Bootstrapper.) E:\Steam\Steam.exe =>.Valve®
O4 - GS\CommonDesktop [Public]: World of Warcraft.lnk . (.Blizzard Entertainment - World of Warcraft Setup.) E:\Program Files (x86)\World of Warcraft\World of Warcraft\World of Warcraft Launcher.exe =>.Blizzard Entertainment, Inc.®
O4 - GS\Programs [Public]: Internet Explorer.lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe =>.Microsoft Corporation®
O4 - GS\Programs [Public]: Microsoft OneDrive.lnk . (.Microsoft Corporation - Microsoft OneDrive.) C:\Users\Mike\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe =>.Microsoft Corporation®
O4 - GS\Programs [Public]: Twitch.lnk . (.Twitch Interactive, Inc. - Twitch.) C:\Users\Mike\AppData\Roaming\Twitch\Bin\Twitch.exe =>.Twitch Interactive, Inc.®
O4 - GS\Accessories [Public]: Command Prompt.lnk . (.Microsoft Corporation - Windows Command Processor.) C:\Windows\system32\cmd.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Notepad.lnk . (.Microsoft Corporation - Notepad.) C:\Windows\system32\notepad.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Windows Explorer.lnk . (.Microsoft Corporation - Windows Explorer.) C:\Windows\explorer.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Internet Explorer (No Add-ons).lnk . (.Microsoft Corporation - Internet Explorer.) C:\Program Files (x86)\Internet Explorer\iexplore.exe -extoff =>.Microsoft Corporation®
O4 - GS\SystemTools [Public]: Private Character Editor.lnk . (.Microsoft Corporation - Private Character Editor.) C:\Windows\system32\eudcedit.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Calculator.lnk . (.Microsoft Corporation - Windows Calculator.) C:\Windows\system32\calc.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: displayswitch.lnk . (.Microsoft Corporation - Display Switch.) C:\Windows\system32\displayswitch.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Math Input Panel.lnk . (.Microsoft Corporation - Math Input Panel Accessory.) C:\Program Files (x86)\Common Files\Microsoft Shared\Ink\mip.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Mobility Center.lnk . (.Microsoft Corporation - Windows Mobility Center.) C:\Windows\system32\mblctr.exe /open =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Paint.lnk . (.Microsoft Corporation - Paint.) C:\Windows\system32\mspaint.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Remote Desktop Connection.lnk . (.Microsoft Corporation - Remote Desktop Connection.) C:\Windows\system32\mstsc.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Snipping Tool.lnk . (.Microsoft Corporation - Snipping Tool.) C:\Windows\system32\SnippingTool.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Sound Recorder.lnk . (.Microsoft Corporation - Windows Sound Recorder.) C:\Windows\system32\SoundRecorder.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Sticky Notes.lnk . (.Microsoft Corporation - Sticky Notes.) C:\Windows\system32\StikyNot.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Sync Center.lnk . (.Microsoft Corporation - Microsoft Sync Center.) C:\Windows\System32\mobsync.exe =>.Microsoft Corporation
O4 - GS\Accessories [Public]: Welcome Center.lnk . (.Microsoft Corporation - Windows host process (Rundll32).) C:\Windows\system32\rundll32.exe %SystemRoot%\system32\OobeFldr.dll,ShowWelcomeCenter LaunchedBy_StartMenuShortcut =>..Microsoft Corporation
O4 - GS\Accessories [Public]: Wordpad.lnk . (.Microsoft Corporation - Windows Wordpad Application.) C:\Program Files (x86)\Windows NT\Accessories\wordpad.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Character Map.lnk . (.Microsoft Corporation - Character Map.) C:\Windows\system32\charmap.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: dfrgui.lnk . (.Microsoft Corporation - Microsoft® Disk Defragmenter.) C:\Windows\system32\dfrgui.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Disk Cleanup.lnk . (.Microsoft Corporation - Disk Space Cleanup Manager for Windows.) C:\Windows\system32\cleanmgr.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Resource Monitor.lnk . (.Microsoft Corporation - Resource and Performance Monitor.) C:\Windows\system32\perfmon.exe /res =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: System Information.lnk . (.Microsoft Corporation - System Information.) C:\Windows\system32\msinfo32.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: System Restore.lnk . (.Microsoft Corporation - Microsoft® Windows System Restore.) C:\Windows\system32\rstrui.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Task Scheduler.lnk . (...) C:\Windows\system32\taskschd.msc /s =>..Microsoft Corporation
O4 - GS\SystemTools [Public]: Windows Easy Transfer Reports.lnk . (.Microsoft Corporation - Windows Easy Transfer Post Migration Applic.) C:\Windows\system32\migwiz\postmig.exe =>.Microsoft Corporation
O4 - GS\SystemTools [Public]: Windows Easy Transfer.lnk . (.Microsoft Corporation - Windows Easy Transfer Application.) C:\Windows\system32\migwiz\migwiz.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Acrobat Reader DC.lnk . (.Flexera Software LLC - InstallShield.) C:\Windows\Installer\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}\SC_Reader.ico =>.Flexera Software LLC
O4 - GS\ProgramsCommon [Public]: Google Chrome.lnk . (.Google Inc. - Google Chrome.) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O4 - GS\ProgramsCommon [Public]: Media Center.lnk . (.Microsoft Corporation - Windows Media Center.) C:\Windows\ehome\ehshell.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Movie Maker.lnk . (.Microsoft Corporation - Movie Maker.) C:\Program Files (x86)\Windows Live\Photo Gallery\MovieMaker.exe =>.Microsoft Corporation®
O4 - GS\ProgramsCommon [Public]: Photo Gallery.lnk . (.Microsoft Corporation - Photo Gallery.) C:\Program Files (x86)\Windows Live\Photo Gallery\WLXPhotoGallery.exe =>.Microsoft Corporation®
O4 - GS\ProgramsCommon [Public]: Sidebar.lnk . (.Microsoft Corporation - Windows Desktop Gadgets.) C:\Program Files (x86)\Windows Sidebar\sidebar.exe /showgadgets =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Windows Anytime Upgrade.lnk . (.Microsoft Corporation - Windows Anytime Upgrade User Interface.) C:\Windows\system32\WindowsAnytimeUpgradeUI.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Windows DVD Maker.lnk . (.Microsoft Corporation - .) C:\Program Files (x86)\DVD Maker\DVDMaker.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Windows Fax and Scan.lnk . (.Microsoft Corporation - Microsoft Windows Fax and Scan.) C:\Windows\system32\WFS.exe =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: Windows Live Mail.lnk . (.Microsoft Corporation - Windows Live Mail.) C:\Program Files (x86)\Windows Live\Mail\wlmail.exe =>.Microsoft Corporation®
O4 - GS\ProgramsCommon [Public]: Windows Media Player.lnk . (.Microsoft Corporation - Windows Media Player.) C:\Program Files (x86)\Windows Media Player\wmplayer.exe /prefetch:1 =>.Microsoft Corporation
O4 - GS\ProgramsCommon [Public]: XPS Viewer.lnk . (.Microsoft Corporation - XPS Viewer.) C:\Windows\system32\xpsrchvw.exe =>.Microsoft Corporation
---\ Lop.com/Domain Hijackers (4) - 0s
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpDomain = fios-router.home
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1 =>.Local IP Adress
O17 - HKLM\System\CCS\Services\Tcpip\..\{8AFFD7A3-8D64-4AE0-87F3-188F080423E9}: DhcpNameServer = 192.168.1.1 =>.Local IP Adress
O17 - HKLM\System\CCS\Services\Tcpip\..\{8AFFD7A3-8D64-4AE0-87F3-188F080423E9}: DhcpDomain = fios-router.home
---\ Extra protocols (21) - 0s
O18 - Handler: about [64Bits] - {3050F406-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\System32\mshtml.dll =>.Microsoft Corporation
O18 - Handler: cdl [64Bits] - {3dd53d40-7b8b-11D0-b013-00aa0059ce02} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\System32\urlmon.dll =>.Microsoft Corporation
O18 - Handler: dvd [64Bits] - {12D51199-0DB5-46FE-A120-47A3D7D937CC} . (.Microsoft Corporation - ActiveX control for streaming video.) -- C:\Windows\System32\MSVidCtl.dll =>.Microsoft Corporation
O18 - Handler: file [64Bits] - {79eac9e7-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\System32\urlmon.dll =>.Microsoft Corporation
O18 - Handler: ftp [64Bits] - {79eac9e3-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\System32\urlmon.dll =>.Microsoft Corporation
O18 - Handler: http [64Bits] - {79eac9e2-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\System32\urlmon.dll =>.Microsoft Corporation
O18 - Handler: https [64Bits] - {79eac9e5-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\System32\urlmon.dll =>.Microsoft Corporation
O18 - Handler: its [64Bits] - {9D148291-B9C8-11D0-A4CC-0000F80149F6} . (.Microsoft Corporation - Microsoft® InfoTech Storage System Library.) -- C:\Windows\System32\itss.dll =>.Microsoft Corporation
O18 - Handler: javascript [64Bits] - {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\System32\mshtml.dll =>.Microsoft Corporation
O18 - Handler: local [64Bits] - {79eac9e7-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\System32\urlmon.dll =>.Microsoft Corporation
O18 - Handler: mailto [64Bits] - {3050f3DA-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\System32\mshtml.dll =>.Microsoft Corporation
O18 - Handler: mhtml [64Bits] - {05300401-BCBC-11d0-85E3-00C04FD85AB4} . (.Microsoft Corporation - Microsoft Internet Messaging API Resources.) -- C:\Windows\System32\inetcomm.dll =>.Microsoft Corporation
O18 - Handler: mk [64Bits] - {79eac9e6-baf9-11ce-8c82-00aa004ba90b} . (.Microsoft Corporation - OLE32 Extensions for Win32.) -- C:\Windows\System32\urlmon.dll =>.Microsoft Corporation
O18 - Handler: ms-its [64Bits] - {9D148291-B9C8-11D0-A4CC-0000F80149F6} . (.Microsoft Corporation - Microsoft® InfoTech Storage System Library.) -- C:\Windows\System32\itss.dll =>.Microsoft Corporation
O18 - Handler: res [64Bits] - {3050F3BC-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\System32\mshtml.dll =>.Microsoft Corporation
O18 - Handler: tv [64Bits] - {CBD30858-AF45-11D2-B6D6-00C04FBBDE6E} . (.Microsoft Corporation - ActiveX control for streaming video.) -- C:\Windows\System32\MSVidCtl.dll =>.Microsoft Corporation
O18 - Handler: vbscript [64Bits] - {3050F3B2-98B5-11CF-BB82-00AA00BDCE0B} . (.Microsoft Corporation - Microsoft (R) HTML Viewer.) -- C:\Windows\System32\mshtml.dll =>.Microsoft Corporation
O18 - Filter: application/octet-stream [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) -- C:\Windows\System32\mscoree.dll =>.Microsoft Corporation®
O18 - Filter: application/x-complus [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) -- C:\Windows\System32\mscoree.dll =>.Microsoft Corporation®
O18 - Filter: application/x-msdownload [64Bits] - {1E66F26B-79EE-11D2-8710-00C04F79ED0D} . (.Microsoft Corporation - Microsoft .NET Runtime Execution Engine.) -- C:\Windows\System32\mscoree.dll =>.Microsoft Corporation®
O18 - Filter: text/xml [64Bits] - {807563E5-5146-11D5-A672-00B0D022E945} . (.Microsoft Corporation - Microsoft Office XML MIME Filter.) -- C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.DLL =>.Microsoft Corporation®
---\ AppInit_DLLs Registry value Autorun (1) - 0s
O20 - Winlogon : UserInit . (.Microsoft Corporation - Userinit Logon Application.) - C:\Windows\system32\userinit.exe =>.Microsoft Corporation
---\ ASIC (ActiveSetup Installed Components) (11) - 0s
O40 - ASIC: Microsoft Windows Media Player [64Bits] - >{22d6f312-b0f6-11d0-94ab-0080c74c7e95} . (.Microsoft Corporation - Microsoft Windows Media Player Setup Utilit.) -- C:\Windows\System32\unregmp2.exe =>.Microsoft Corporation
O40 - ASIC: Microsoft Windows Media Player 12.0 [64Bits] - {22d6f312-b0f6-11d0-94ab-0080c74c7e95} . (.Microsoft Corporation - Windows Media Player Extension.) -- C:\Windows\System32\wmpdxm.dll =>.Microsoft Corporation
O40 - ASIC: Themes Setup [64Bits] - {2C7339CF-2B09-4501-B3F3-F3508C9228ED} . (.Microsoft Corporation - Microsoft(C) Register Server.) -- C:\Windows\System32\regsvr32.exe =>.Microsoft Corporation
O40 - ASIC: Internet Explorer [64Bits] - {2D46B6DC-2207-486B-B523-A557E6D54B47} . (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\system32\ie4uinit.exe =>.Microsoft Corporation
O40 - ASIC: Microsoft Windows [64Bits] - {44BBA840-CC51-11CF-AAFA-00AA00B6015C} . (.Microsoft Corporation - Windows Mail.) -- C:\Program Files\Windows Mail\WinMail.exe =>.Microsoft Corporation
O40 - ASIC: Enable TLS1.1 and 1.2 [64Bits] - {66C64F22-FC60-4E6C-A6B5-F0D580E680CE} . (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
O40 - ASIC: Microsoft Windows Media Player [64Bits] - {6BF52A52-394A-11d3-B153-00C04F79FAA6} . (.Microsoft Corporation - Microsoft Windows Media Player Setup Utilit.) -- C:\Windows\System32\unregmp2.exe =>.Microsoft Corporation
O40 - ASIC: Disable SSL3 [64Bits] - {7D715857-A67C-4C2F-A929-038448584D63} . (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
O40 - ASIC: Web Platform Customizations [64Bits] - {89820200-ECBD-11cf-8B85-00AA005B4383} . (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
O40 - ASIC: (no name) [64Bits] - {89B4C1CD-B018-4511-B0A1-5476DBF70820} . (.Microsoft Corporation - Microsoft .NET IE SECURITY REGISTRATION.) -- C:\Windows\System32\mscories.dll =>.Microsoft Corporation®
O40 - ASIC: Google Chrome [64Bits] - {8A69D345-D564-463c-AFF1-A69D9E530F96} . (.Google Inc. - Google Chrome Installer.) -- C:\Program Files (x86)\Google\Chrome\Application\66.0.3359.139\Installer\chrmstp.exe =>.Google Inc®
---\ Software installed (105) - 18s
O42 - Logiciel: Adobe Acrobat Reader DC - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- {AC76BA86-7AD7-1033-7B44-AC0F074E4100} =>.Adobe Systems Incorporated
O42 - Logiciel: Adobe Flash Player 28 ActiveX - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- Adobe Flash Player ActiveX =>.Adobe Systems Incorporated®
O42 - Logiciel: Adobe Flash Player 28 NPAPI - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- Adobe Flash Player NPAPI =>.Adobe Systems Incorporated®
O42 - Logiciel: Adobe Refresh Manager - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- {AC76BA86-0804-1033-1959-001824265200} =>.Adobe Systems Incorporated
O42 - Logiciel: Asmedia ASM104x USB 3.0 Host Controller Driver - (.Asmedia Technology.) [HKLM][64Bits] -- {E4FB0B39-C991-4EE7-95DD-1A1A7857D33D} =>.Asmedia Technology
O42 - Logiciel: Blizzard App - (.Blizzard Entertainment.) [HKLM][64Bits] -- Battle.net =>.Blizzard Entertainment, Inc.®
O42 - Logiciel: CameraHelperMsi - (.Logitech.) [HKLM][64Bits] -- {15634701-BACE-4449-8B25-1567DA8C9FD3} =>.Logitech
O42 - Logiciel: Command & Conquer™ Red Alert 2 and Yuri’s Revenge - (.Electronic Arts, Inc..) [HKLM][64Bits] -- {F5275D1C-D133-486D-8F07-D6C571F0A8EC} =>.Electronic Arts®
O42 - Logiciel: Command and Conquer: Red Alert 3 - (.EA Los Angeles.) [HKLM][64Bits] -- Steam App 17480 =>.Valve®
O42 - Logiciel: Contagion - (.Monochrome LLC.) [HKLM][64Bits] -- Steam App 238430 =>.Valve®
O42 - Logiciel: D3DX10 - (.Microsoft.) [HKLM][64Bits] -- {E09C4DB7-630C-4F06-A631-8EA7239923AF} =>.Microsoft
O42 - Logiciel: Dead Island - (.Techland.) [HKLM][64Bits] -- Steam App 91310 =>.Valve®
O42 - Logiciel: Dead State - (.DoubleBear Productions.) [HKLM][64Bits] -- Steam App 239840 =>.Valve®
O42 - Logiciel: Deus Ex: Game of the Year Edition - (.Ion Storm.) [HKLM][64Bits] -- Steam App 6910 =>.Valve®
O42 - Logiciel: Deus Ex: Human Revolution - (.Eidos Montreal.) [HKLM][64Bits] -- Steam App 28050 =>.Valve®
O42 - Logiciel: Deus Ex: Human Revolution - The Missing Link - (.Eidos Montreal.) [HKLM][64Bits] -- Steam App 201280 =>.Valve®
O42 - Logiciel: Diablo III - (.Blizzard Entertainment.) [HKLM][64Bits] -- Diablo III =>.Blizzard Entertainment, Inc.®
O42 - Logiciel: Dragon Age: Origins - Ultimate Edition - (.BioWare.) [HKLM][64Bits] -- Steam App 47810 =>.Valve®
O42 - Logiciel: Dragon's Lair - (.Digital Leisure Inc..) [HKLM][64Bits] -- Steam App 227380 =>.Valve®
O42 - Logiciel: DuckTales Remastered - (.WayForward.) [HKLM][64Bits] -- Steam App 237630 =>.Valve®
O42 - Logiciel: erLT - (.Logitech, Inc..) [HKLM][64Bits] -- {3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C} =>.Logitech, Inc.
O42 - Logiciel: ffdshow [rev 2653] [2009-02-04] - (.Open Source.) [HKLM][64Bits] -- ffdshow64_is1 =>.Open source
O42 - Logiciel: File Association Helper - (.WinZip Computing International, LLC.) [HKLM][64Bits] -- {C168639F-5810-4EC8-B1E8-0251AA8A771C} =>.WinZip Computing International, LLC
O42 - Logiciel: Firewatch - (.Campo Santo.) [HKLM][64Bits] -- Steam App 383870 =>.Valve®
O42 - Logiciel: Friday the 13th: The Game BETA - (..) [HKLM][64Bits] -- Steam App 569300 =>.Valve®
O42 - Logiciel: Gone Home - (.The Fullbright Company.) [HKLM][64Bits] -- Steam App 232430 =>.Valve®
O42 - Logiciel: Google Chrome - (.Google Inc..) [HKLM][64Bits] -- Google Chrome =>.Google Inc®
O42 - Logiciel: Google Update Helper - (.Google Inc..) [HKLM][64Bits] -- {60EC980A-BDA2-4CB6-A427-B07A5498B4CA} =>.Google Inc.
O42 - Logiciel: Google Update Helper - (.Google Inc..) [HKLM][64Bits] -- {A92DAB39-4E2C-4304-9AB6-BC44E68B55E2} =>.Google Inc.
O42 - Logiciel: Heroes of the Storm - (.Blizzard Entertainment.) [HKLM][64Bits] -- Heroes of the Storm =>.Blizzard Entertainment, Inc.®
O42 - Logiciel: Java 7 Update 67 - (.Oracle.) [HKLM][64Bits] -- {26A24AE4-039D-4CA4-87B4-2F03217067FF} =>.Oracle
O42 - Logiciel: Java Auto Updater - (.Oracle, Inc..) [HKLM][64Bits] -- {4A03706F-666A-4037-7777-5F2748764D10} =>.Oracle, Inc.
O42 - Logiciel: Junk Mail filter update - (.Microsoft Corporation.) [HKLM][64Bits] -- {0BE9E708-5DC0-4963-9CFD-0AA519090E79} =>.Microsoft Corporation
O42 - Logiciel: Jurassic Park: The Game - (.Telltale Games.) [HKLM][64Bits] -- Steam App 201830 =>.Valve®
O42 - Logiciel: Killing Time - (.The 3DO Company.) [HKLM][64Bits] -- Steam App 493320 =>.Valve®
O42 - Logiciel: Logitech Gaming Software 8.94 - (.Logitech Inc..) [HKLM][64Bits] -- Logitech Gaming Software =>.Logitech Inc®
O42 - Logiciel: Logitech Unifying Software 2.50 - (.Logitech.) [HKLM][64Bits] -- Logitech Unifying =>.Logitech
O42 - Logiciel: Logitech Webcam Software - (.Logitech Inc..) [HKLM][64Bits] -- {D40EB009-0499-459c-A8AF-C9C110766215} =>.Logitech®
O42 - Logiciel: LWS Facebook - (.Logitech.) [HKLM][64Bits] -- {FF167195-9EE4-46C0-8CD7-FBA3457E88AB} =>.Logitech
O42 - Logiciel: LWS Gallery - (.Logitech.) [HKLM][64Bits] -- {6F76EC3C-34B1-436E-97FB-48C58D7BEDCD} =>.Logitech
O42 - Logiciel: LWS Help_main - (.Logitech.) [HKLM][64Bits] -- {1651216E-E7AD-4250-92A1-FB8ED61391C9} =>.Logitech
O42 - Logiciel: LWS Launcher - (.Logitech.) [HKLM][64Bits] -- {83C8FA3C-F4EA-46C4-8392-D3CE353738D6} =>.Logitech
O42 - Logiciel: LWS Motion Detection - (.Logitech.) [HKLM][64Bits] -- {71E66D3F-A009-44AB-8784-75E2819BA4BA} =>.Logitech
O42 - Logiciel: LWS Pictures And Video - (.Logitech.) [HKLM][64Bits] -- {08610298-29AE-445B-B37D-EFBE05802967} =>.Logitech
O42 - Logiciel: LWS Twitter - (.Logitech.) [HKLM][64Bits] -- {174A3B31-4C43-43DD-866F-73C9DB887B48} =>.Logitech
O42 - Logiciel: LWS Webcam Software - (.Logitech.) [HKLM][64Bits] -- {8937D274-C281-42E4-8CDB-A0B2DF979189} =>.Logitech
O42 - Logiciel: LWS WLM Plugin - (.Logitech.) [HKLM][64Bits] -- {9DAEA76B-E50F-4272-A595-0124E826553D} =>.Logitech
O42 - Logiciel: LWS YouTube Plugin - (.Logitech.) [HKLM][64Bits] -- {21DF0294-6B9D-4741-AB6F-B2ABFBD2387E} =>.Logitech
O42 - Logiciel: Malwarebytes version 3.4.5.2467 - (.Malwarebytes.) [HKLM][64Bits] -- {35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1 =>.Malwarebytes Corporation®
O42 - Logiciel: Marvel Heroes 2015 - (.Gazillion Entertainment.) [HKLM][64Bits] -- Steam App 226320 =>.Valve®
O42 - Logiciel: Microsoft Application Error Reporting - (.Microsoft Corporation.) [HKLM][64Bits] -- {95120000-00B9-0409-1000-0000000FF1CE} =>.Microsoft Corporation
O42 - Logiciel: Microsoft Games for Windows - LIVE - (.Microsoft Corporation.) [HKLM][64Bits] -- {F112F66E-25CA-42DD-983C-6118EB38F606} =>.Microsoft Corporation
O42 - Logiciel: Microsoft Games for Windows - LIVE Redistributable - (.Microsoft Corporation.) [HKLM][64Bits] -- {2E660A2A-A55F-43CD-9F73-CAD7382EEB78} =>.Microsoft Corporation
O42 - Logiciel: Microsoft OneDrive - (.Microsoft Corporation.) [HKCU][64Bits] -- OneDriveSetup.exe =>.Microsoft Corporation®
O42 - Logiciel: Microsoft Silverlight - (.Microsoft Corporation.) [HKLM][64Bits] -- {89F4137D-6C26-4A84-BDB8-2E5A4BB71E00} =>.Microsoft Corporation
O42 - Logiciel: MSVCRT - (.Microsoft.) [HKLM][64Bits] -- {8DD46C6A-0056-4FEC-B70A-28BB16A1F11F} =>.Microsoft
O42 - Logiciel: MSVCRT_amd64 - (.Microsoft.) [HKLM][64Bits] -- {D0B44725-3666-492D-BEF6-587A14BD9BD9} =>.Microsoft
O42 - Logiciel: MSVCRT110 - (.Microsoft.) [HKLM][64Bits] -- {8E14DDC8-EA60-4E18-B3E3-1937104D5BDA} =>.Microsoft
O42 - Logiciel: MSVCRT110_amd64 - (.Microsoft.) [HKLM][64Bits] -- {E9FA781F-3E80-4399-825A-AD3E11C28C77} =>.Microsoft
O42 - Logiciel: MURDERED: SOUL SUSPECT™ - (.Airtight Games.) [HKLM][64Bits] -- Steam App 233290 =>.Valve®
O42 - Logiciel: Nexus Mod Manager - (.Black Tree Gaming.) [HKLM][64Bits] -- 6af12c54-643b-4752-87d0-8335503010de_is1 =>.Black Tree Gaming Ltd.®
O42 - Logiciel: Nexus: The Jupiter Incident - (.Mithis Games.) [HKLM][64Bits] -- Steam App 6420 =>.Valve®
O42 - Logiciel: Norton Security Scan - (.Symantec Corporation.) [HKLM][64Bits] -- NSS =>.Symantec Corporation®
O42 - Logiciel: NVIDIA PhysX - (.NVIDIA Corporation.) [HKLM][64Bits] -- {8B922CF8-8A6C-41CE-A858-F1755D7F5D29} =>.NVIDIA Corporation
O42 - Logiciel: OpenAL - (.Open Audio Library.) [HKLM][64Bits] -- OpenAL =>.Creative Labs Inc®
O42 - Logiciel: Outlast - (.Red Barrels.) [HKLM][64Bits] -- Steam App 238320 =>.Valve®
O42 - Logiciel: Plague Inc: Evolved - (.Ndemic Creations.) [HKLM][64Bits] -- Steam App 246620 =>.Valve®
O42 - Logiciel: Police Quest Collection - (.Sierra.) [HKLM][64Bits] -- Steam App 494740 =>.Valve®
O42 - Logiciel: Realtek Ethernet Controller Driver - (.Realtek.) [HKLM][64Bits] -- {8833FFB6-5B0C-4764-81AA-06DFEED9A476} =>.Realtek Semiconductor Corp.®
O42 - Logiciel: Realtek High Definition Audio Driver - (.Realtek Semiconductor Corp..) [HKLM][64Bits] -- {F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC} =>.Macrovision Corporation®
O42 - Logiciel: Saints Row: The Third - (.Volition.) [HKLM][64Bits] -- Steam App 55230 =>.Valve®
O42 - Logiciel: SAMSUNG USB Driver for Mobile Phones - (.SAMSUNG Electronics Co., Ltd..) [HKLM][64Bits] -- {D0795B21-0CDA-4a92-AB9E-6E92D8111E44} =>.DEVGURU CO LTD®
O42 - Logiciel: Sid Meier's Civilization V - (.Firaxis Games.) [HKLM][64Bits] -- Steam App 8930 =>.Valve®
O42 - Logiciel: Sins of a Solar Empire®: Trinity - (.Ironclad Games.) [HKLM][64Bits] -- Steam App 201290 =>.Valve®
O42 - Logiciel: Skyrim Creation Kit - (.bgs.bethsoft.com.) [HKLM][64Bits] -- Steam App 202480 =>.Valve®
O42 - Logiciel: Space Hulk - (.Full Control Studios.) [HKLM][64Bits] -- Steam App 242570 =>.Valve®
O42 - Logiciel: Space Hulk: Deathwing - (.Streum On Studio.) [HKLM][64Bits] -- Steam App 298900 =>.Valve®
O42 - Logiciel: StarCraft II - (.Blizzard Entertainment.) [HKLM][64Bits] -- StarCraft II =>.Blizzard Entertainment, Inc.®
O42 - Logiciel: State of Decay - (.Undead Labs.) [HKLM][64Bits] -- Steam App 241540 =>.Valve®
O42 - Logiciel: Steam - (.Valve Corporation.) [HKLM][64Bits] -- Steam =>.Valve®
O42 - Logiciel: Stranded Deep - (.Beam Team Games.) [HKLM][64Bits] -- Steam App 313120 =>.Valve®
O42 - Logiciel: Talisman: The Horus Heresy - (.Nomad Games.) [HKLM][64Bits] -- Steam App 358460 =>.Valve®
O42 - Logiciel: The Bureau: XCOM Declassified - (.2K Marin.) [HKLM][64Bits] -- Steam App 65930 =>.Valve®
O42 - Logiciel: The Elder Scrolls V: Skyrim - (.Bethesda Game Studios.) [HKLM][64Bits] -- Steam App 72850 =>.Valve®
O42 - Logiciel: The Forest - (.Endnight Games Ltd.) [HKLM][64Bits] -- Steam App 242760 =>.Valve®
O42 - Logiciel: The Lord of the Rings: War in the North - (.Snowblind Studios.) [HKLM][64Bits] -- Steam App 32800 =>.Valve®
O42 - Logiciel: The Room - (.Fireproof Games.) [HKLM][64Bits] -- Steam App 288160 =>.Valve®
O42 - Logiciel: The Stanley Parable - (.Galactic Cafe.) [HKLM][64Bits] -- Steam App 221910 =>.Valve®
O42 - Logiciel: The Witcher: Enhanced Edition - (.CD Projekt RED.) [HKLM][64Bits] -- Steam App 20900 =>.Valve®
O42 - Logiciel: Tomb Raider - (.Crystal Dynamics.) [HKLM][64Bits] -- Steam App 203160 =>.Valve®
O42 - Logiciel: Total War: SHOGUN 2 - (.The Creative Assembly.) [HKLM][64Bits] -- Steam App 34330 =>.Valve®
O42 - Logiciel: Twitch - (.Twitch Interactive, Inc..) [HKCU][64Bits] -- {DEE70742-F4E9-44CA-B2B9-EE95DCF37295} =>.Twitch Interactive, Inc.®
O42 - Logiciel: Vampire: The Masquerade - Redemption - (.Nihilistic Software.) [HKLM][64Bits] -- Steam App 559680 =>.Valve®
O42 - Logiciel: VLC media player - (.VideoLAN.) [HKLM][64Bits] -- VLC media player =>.VideoLAN
O42 - Logiciel: Vulkan Run Time Libraries 1.0.65.0 - (.LunarG, Inc..) [HKLM][64Bits] -- VulkanRT1.0.65.0 =>.LunarG, Inc.®
O42 - Logiciel: Warhammer 40,000: Eternal Crusade - (.Behaviour Digital Inc..) [HKLM][64Bits] -- Steam App 375230 =>.Valve®
O42 - Logiciel: Warhammer 40,000: Regicide - (.Hammerfall Publishing.) [HKLM][64Bits] -- Steam App 322910 =>.Valve®
O42 - Logiciel: Warhammer® 40,000™: Dawn of War® II - (.Relic Entertainment.) [HKLM][64Bits] -- Steam App 15620 =>.Valve®
O42 - Logiciel: Warhammer® 40,000™: Dawn of War® II - Chaos Rising™ - (.Relic Entertainment.) [HKLM][64Bits] -- Steam App 20570 =>.Valve®
O42 - Logiciel: Warhammer® 40,000™: Dawn of War® II – Retribution™ - (.Relic Entertainment.) [HKLM][64Bits] -- Steam App 56400 =>.Valve®
O42 - Logiciel: WinRAR 5.50 (64-bit) - (.win.rar GmbH.) [HKLM][64Bits] -- WinRAR archiver =>.win.rar GmbH®
O42 - Logiciel: WinZip 21.0 - (.WinZip Computing, S.L..) [HKLM][64Bits] -- {CD95F661-A5C4-44F5-A6AA-ECDD91C2410D} =>.WinZip Computing, S.L.
O42 - Logiciel: World of Warcraft - (.Blizzard Entertainment.) [HKLM][64Bits] -- World of Warcraft =>.Blizzard Entertainment, Inc.®
O42 - Logiciel: XCOM 2 - (.Firaxis.) [HKLM][64Bits] -- Steam App 268500 =>.Valve®
O42 - Logiciel: XCOM: Enemy Unknown - (.Firaxis Games.) [HKLM][64Bits] -- Steam App 200510 =>.Valve®
---\ HKCU & HKLM Software Keys (205) - 18s
HKLM\SOFTWARE\Activision =>.Activision
HKLM\SOFTWARE\Adobe =>.Adobe
HKLM\SOFTWARE\AGEIA Technologies =>.AGEIA Technologies
HKLM\SOFTWARE\AMD =>.AMD
HKLM\SOFTWARE\ASUS =>.ASUS
HKLM\SOFTWARE\ATI =>.ATI
HKLM\SOFTWARE\ATI Technologies =>.ATI Technologies
HKLM\SOFTWARE\Belarc =>.Belarc
HKLM\SOFTWARE\bethesda softworks =>.Bethesda Softworks
HKLM\SOFTWARE\Big Fish Games =>.Big Fish Games
HKLM\SOFTWARE\bioware =>.BioWare
HKLM\SOFTWARE\Blizzard Entertainment =>.Blizzard Entertainment
HKLM\SOFTWARE\Brother =>.Brother
HKLM\SOFTWARE\cd projekt red =>.CD Projekt RED
HKLM\SOFTWARE\CounterPath =>.CounterPath
HKLM\SOFTWARE\digital leisure =>.Digital Leisure
HKLM\SOFTWARE\EA Games =>.EA Games
HKLM\SOFTWARE\EasyAntiCheat =>.EasyAntiCheat
HKLM\SOFTWARE\electronic arts =>.Electronic Arts
HKLM\SOFTWARE\Google =>.Google
HKLM\SOFTWARE\Intel =>.Intel
HKLM\SOFTWARE\JavaSoft =>.JavaSoft
HKLM\SOFTWARE\JreMetrics =>.JreMetrics
HKLM\SOFTWARE\Khronos =>.Khronos
HKLM\SOFTWARE\Lavasoft =>.Lavasoft
HKLM\SOFTWARE\Licenses =>.Microsoft Corporation
HKLM\SOFTWARE\logishrd =>.LogiShrd
HKLM\SOFTWARE\Logitech =>.Logitech
HKLM\SOFTWARE\Macromedia =>.Macromedia
HKLM\SOFTWARE\Malwarebytes Anti-Rootkit =>.Malwarebytes
HKLM\SOFTWARE\Malwarebytes' Anti-Malware =>.Malwarebytes' Anti-Malware
HKLM\SOFTWARE\McAfee.com =>.McAfee Inc.
HKLM\SOFTWARE\mcafeeupdater =>.McAfee Inc.
HKLM\SOFTWARE\Mozilla =>.Mozilla
HKLM\SOFTWARE\MozillaPlugins =>.MozillaPlugins
HKLM\SOFTWARE\Nico Mak Computing =>.Nico Mak Computing
HKLM\SOFTWARE\Norton =>.Symantec Corporation
HKLM\SOFTWARE\NRNR
HKLM\SOFTWARE\Nuance =>.Nuance
HKLM\SOFTWARE\NVIDIA Corporation =>.nVidia Corporation
HKLM\SOFTWARE\ODBC =>.DB Connectivity Solutions
HKLM\SOFTWARE\OldTimer Tools =>.OldTimer Tools
HKLM\SOFTWARE\OpenAL =>.Open Audio Library
HKLM\SOFTWARE\Origin Games =>.Electronic Arts, Inc.
HKLM\SOFTWARE\Realtek =>.Realtek Semiconductor Corp.
HKLM\SOFTWARE\Realtek Semiconductor Corp. =>.Realtek Semiconductor Corp.
HKLM\SOFTWARE\Safer Networking Limited =>.Safer Networking Limited
HKLM\SOFTWARE\Skype =>.Skype
HKLM\SOFTWARE\stardock =>.Stardock
HKLM\SOFTWARE\Symantec =>.Symantec
HKLM\SOFTWARE\techland =>.Techland
HKLM\SOFTWARE\telltale games =>.Telltale Games
HKLM\SOFTWARE\THQ =>.THQ
HKLM\SOFTWARE\TrendMicro =>.TrendMicro
HKLM\SOFTWARE\Trymedia Systems =>PUP.Optional.Trymedia
HKLM\SOFTWARE\Unreal Technology =>.Unreal Software
HKLM\SOFTWARE\Valve =>.Valve
HKLM\SOFTWARE\VERIZON_AR =>.Verizon Wireless
HKLM\SOFTWARE\VideoLAN =>.VideoLAN
HKLM\SOFTWARE\Westwood
HKLM\SOFTWARE\WON =>.Orange SA
HKLM\SOFTWARE\Wow6432Node =>.Microsoft Corporation
HKLM\SOFTWARE\RegisteredApplications =>.Microsoft Corporation
HKLM\SOFTWARE\WOW6432Node\Activision =>.Activision
HKLM\SOFTWARE\WOW6432Node\Adobe =>.Adobe
HKLM\SOFTWARE\WOW6432Node\AGEIA Technologies =>.AGEIA Technologies
HKLM\SOFTWARE\WOW6432Node\AMD =>.AMD
HKLM\SOFTWARE\WOW6432Node\ASUS =>.ASUS
HKLM\SOFTWARE\WOW6432Node\ATI =>.ATI
HKLM\SOFTWARE\WOW6432Node\ATI Technologies =>.ATI Technologies
HKLM\SOFTWARE\WOW6432Node\Belarc =>.Belarc
HKLM\SOFTWARE\WOW6432Node\bethesda softworks =>.Bethesda Softworks
HKLM\SOFTWARE\WOW6432Node\Big Fish Games =>.Big Fish Games
HKLM\SOFTWARE\WOW6432Node\bioware =>.BioWare
HKLM\SOFTWARE\WOW6432Node\Blizzard Entertainment =>.Blizzard Entertainment
HKLM\SOFTWARE\WOW6432Node\Brother =>.Brother
HKLM\SOFTWARE\WOW6432Node\cd projekt red =>.CD Projekt RED
HKLM\SOFTWARE\WOW6432Node\CounterPath =>.CounterPath
HKLM\SOFTWARE\WOW6432Node\digital leisure =>.Digital Leisure
HKLM\SOFTWARE\WOW6432Node\EA Games =>.EA Games
HKLM\SOFTWARE\WOW6432Node\EasyAntiCheat =>.EasyAntiCheat
HKLM\SOFTWARE\WOW6432Node\electronic arts =>.Electronic Arts
HKLM\SOFTWARE\WOW6432Node\Google =>.Google
HKLM\SOFTWARE\WOW6432Node\Intel =>.Intel
HKLM\SOFTWARE\WOW6432Node\JavaSoft =>.JavaSoft
HKLM\SOFTWARE\WOW6432Node\JreMetrics =>.JreMetrics
HKLM\SOFTWARE\WOW6432Node\Khronos =>.Khronos
HKLM\SOFTWARE\WOW6432Node\Lavasoft =>.Lavasoft
HKLM\SOFTWARE\WOW6432Node\Licenses =>.Microsoft Corporation
HKLM\SOFTWARE\WOW6432Node\logishrd =>.LogiShrd
HKLM\SOFTWARE\WOW6432Node\Logitech =>.Logitech
HKLM\SOFTWARE\WOW6432Node\Macromedia =>.Macromedia
HKLM\SOFTWARE\WOW6432Node\Malwarebytes Anti-Rootkit =>.Malwarebytes
HKLM\SOFTWARE\WOW6432Node\Malwarebytes' Anti-Malware =>.Malwarebytes' Anti-Malware
HKLM\SOFTWARE\WOW6432Node\McAfee.com =>.McAfee Inc.
HKLM\SOFTWARE\WOW6432Node\mcafeeupdater =>.McAfee Inc.
HKLM\SOFTWARE\WOW6432Node\Mozilla =>.Mozilla
HKLM\SOFTWARE\WOW6432Node\MozillaPlugins =>.MozillaPlugins
HKLM\SOFTWARE\WOW6432Node\Nico Mak Computing =>.Nico Mak Computing
HKLM\SOFTWARE\WOW6432Node\Norton =>.Symantec Corporation
HKLM\SOFTWARE\WOW6432Node\NRNR
HKLM\SOFTWARE\WOW6432Node\Nuance =>.Nuance
HKLM\SOFTWARE\WOW6432Node\NVIDIA Corporation =>.nVidia Corporation
HKLM\SOFTWARE\WOW6432Node\ODBC =>.DB Connectivity Solutions
HKLM\SOFTWARE\WOW6432Node\OldTimer Tools =>.OldTimer Tools
HKLM\SOFTWARE\WOW6432Node\OpenAL =>.Open Audio Library
HKLM\SOFTWARE\WOW6432Node\Origin Games =>.Electronic Arts, Inc.
HKLM\SOFTWARE\WOW6432Node\Realtek =>.Realtek Semiconductor Corp.
HKLM\SOFTWARE\WOW6432Node\Realtek Semiconductor Corp. =>.Realtek Semiconductor Corp.
HKLM\SOFTWARE\WOW6432Node\Safer Networking Limited =>.Safer Networking Limited
HKLM\SOFTWARE\WOW6432Node\Skype =>.Skype
HKLM\SOFTWARE\WOW6432Node\stardock =>.Stardock
HKLM\SOFTWARE\WOW6432Node\Symantec =>.Symantec
HKLM\SOFTWARE\WOW6432Node\techland =>.Techland
HKLM\SOFTWARE\WOW6432Node\telltale games =>.Telltale Games
HKLM\SOFTWARE\WOW6432Node\THQ =>.THQ
HKLM\SOFTWARE\WOW6432Node\TrendMicro =>.TrendMicro
HKLM\SOFTWARE\WOW6432Node\Trymedia Systems =>PUP.Optional.Trymedia
HKLM\SOFTWARE\WOW6432Node\Unreal Technology =>.Unreal Software
HKLM\SOFTWARE\WOW6432Node\Valve =>.Valve
HKLM\SOFTWARE\WOW6432Node\VERIZON_AR =>.Verizon Wireless
HKLM\SOFTWARE\WOW6432Node\VideoLAN =>.VideoLAN
HKLM\SOFTWARE\WOW6432Node\Westwood
HKLM\SOFTWARE\WOW6432Node\WON =>.Orange SA
HKLM\SOFTWARE\WOW6432Node\Wow6432Node =>.Microsoft Corporation
HKLM\SOFTWARE\WOW6432Node\RegisteredApplications =>.Microsoft Corporation
HKCU\SOFTWARE\activeMARK
HKCU\SOFTWARE\ActiveMARK Software
HKCU\SOFTWARE\AD
HKCU\SOFTWARE\Adobe =>.Adobe
HKCU\SOFTWARE\AMD =>.AMD
HKCU\SOFTWARE\America Online =>.America Online
HKCU\SOFTWARE\AppDataLow =>.Microsoft Corporation
HKCU\SOFTWARE\ASUS =>.ASUS
HKCU\SOFTWARE\ATI =>.ATI
HKCU\SOFTWARE\Beam Team Games =>.BEAM Team Games
HKCU\SOFTWARE\Belarc =>.Belarc
HKCU\SOFTWARE\Big Fish Games =>.Big Fish Games
HKCU\SOFTWARE\BitTorrent =>.BitTorrent (P2P)
HKCU\SOFTWARE\Blizzard Entertainment =>.Blizzard Entertainment
HKCU\SOFTWARE\BlueStacks =>.BlueStack Systems, Inc.
HKCU\SOFTWARE\Brother =>.Brother
HKCU\SOFTWARE\Bugsplat =>.Bugsplat Game
HKCU\SOFTWARE\CampoSanto
HKCU\SOFTWARE\cd projekt red =>.CD Projekt RED
HKCU\SOFTWARE\Chromium =>.Chromium
HKCU\SOFTWARE\Corel =>.Corel
HKCU\SOFTWARE\CounterPath =>.CounterPath
HKCU\SOFTWARE\electronic arts =>.Electronic Arts
HKCU\SOFTWARE\Epic Games =>.Epic Games
HKCU\SOFTWARE\Fireproof Games
HKCU\SOFTWARE\Full Control
HKCU\SOFTWARE\Geek Uninstaller =>.Geek Uninstaller
HKCU\SOFTWARE\GNU =>.GNU
HKCU\SOFTWARE\Google =>.Google
HKCU\SOFTWARE\Hammerfall Publishing
HKCU\SOFTWARE\IM Providers =>.IM Providers
HKCU\SOFTWARE\JavaSoft =>.JavaSoft
HKCU\SOFTWARE\Leadertech =>.Leadertech Systems
HKCU\SOFTWARE\Licenses =>.Microsoft Corporation
HKCU\SOFTWARE\Little Worlds Studio
HKCU\SOFTWARE\LogiShrd =>.LogiShrd
HKCU\SOFTWARE\Logitech =>.Logitech
HKCU\SOFTWARE\Macromedia =>.Macromedia
HKCU\SOFTWARE\Macrovision =>.Macrovision
HKCU\SOFTWARE\Malwarebytes =>.Malwarebytes
HKCU\SOFTWARE\MCAFEE =>.McAfee Inc.
HKCU\SOFTWARE\MozillaPlugins =>.MozillaPlugins
HKCU\SOFTWARE\Ndemic Creations =>.Ndemic Creations
HKCU\SOFTWARE\Netscape =>.Netscape
HKCU\SOFTWARE\Nico Mak Computing =>.Nico Mak Computing
HKCU\SOFTWARE\Norton =>.Symantec Corporation
HKCU\SOFTWARE\ODBC =>.DB Connectivity Solutions
HKCU\SOFTWARE\ProtectedStorage =>.Microsoft Corporation
HKCU\SOFTWARE\QtProject =>.QtProject
HKCU\SOFTWARE\Raptr =>.Raptr
HKCU\SOFTWARE\Razer =>.Razer
HKCU\SOFTWARE\Realtek =>.Realtek Semiconductor Corp.
HKCU\SOFTWARE\Safer Networking Limited =>.Safer Networking Limited
HKCU\SOFTWARE\Shaman Games
HKCU\SOFTWARE\Skype =>.Skype
HKCU\SOFTWARE\Square Enix =>.Square Enix
HKCU\SOFTWARE\Stardock =>.Stardock
HKCU\SOFTWARE\Sysinternals =>.Sysinternals
HKCU\SOFTWARE\techPowerUp =>.TechPowerUp
HKCU\SOFTWARE\Telltale Games =>.Telltale Games
HKCU\SOFTWARE\The Creative Assembly =>.The Creative Assembly
HKCU\SOFTWARE\The Fullbright Company =>.The Fullbright Company
HKCU\SOFTWARE\The Fun Pimps =>.The Fun Pimps
HKCU\SOFTWARE\THQ =>.THQ
HKCU\SOFTWARE\Trolltech =>.Trolltech
HKCU\SOFTWARE\Unity =>.Unity
HKCU\SOFTWARE\Valve =>.Valve
HKCU\SOFTWARE\Volition =>.Volition
HKCU\SOFTWARE\WinRAR =>.WinRAR
HKCU\SOFTWARE\WinRAR SFX =>.RarLab
HKCU\SOFTWARE\Wintertree =>.Wintertree Software
HKCU\SOFTWARE\WinZip Computing =>.WinZip Computing
HKCU\SOFTWARE\WinZip Computing, S.L. =>.WinZip Computing, S.L.
HKCU\SOFTWARE\Wow6432Node =>.Microsoft Corporation
HKCU\SOFTWARE\ZHP =>.Nicolas Coolman
HKCU\SOFTWARE\AppDataLow\Software =>.Microsoft Corporation
HKCU\SOFTWARE\AppDataLow\Software\adawarebp =>PUP.Optional.ToolbarCleaner
HKCU\SOFTWARE\AppDataLow\Software\JavaSoft =>.JavaSoft
HKCU\SOFTWARE\AppDataLow\Software\Norton =>.Symantec Corporation
---\ Contents of the Common Files folders (191) - 8s
O43 - CFD: 15/02/2018 - [] D -- C:\Program Files\AMD =>.Advanced Micro Devices, Inc.®
O43 - CFD: 15/03/2017 - [] D -- C:\Program Files\DVD Maker =>.Aone Software
O43 - CFD: 09/06/2014 - [] D -- C:\Program Files\ffdshow =>.Open Source
O43 - CFD: 26/07/2014 - [] D -- C:\Program Files\File Association Helper =>.WinZip Computing LLC®
O43 - CFD: 16/01/2018 - [0] D -- C:\Program Files\Google =>.Google
O43 - CFD: 30/08/2017 - [] D -- C:\Program Files\Logitech Gaming Software =>.Logitech Inc®
O43 - CFD: 10/11/2017 - [] D -- C:\Program Files\Malwarebytes =>.Malwarebytes
O43 - CFD: 01/06/2014 - [] D -- C:\Program Files\Realtek =>.Realtek
O43 - CFD: 06/09/2014 - [] D -- C:\Program Files\SAMSUNG =>.Samsung Electronics
O43 - CFD: 29/09/2017 - [] D -- C:\Program Files\WinRAR =>.win.rar GmbH®
O43 - CFD: 17/07/2017 - [] D -- C:\Program Files\WinZip =>.Add-in Express®
O43 - CFD: 03/09/2015 - [] D -- C:\Program Files (x86)\Adobe =>.Adobe Systems, Incorporated®
O43 - CFD: 15/02/2018 - [] D -- C:\Program Files (x86)\AMD =>.Advanced Micro Devices, Inc.®
O43 - CFD: 01/06/2014 - [] D -- C:\Program Files (x86)\ASM104xUSB3 =>.ASMedia Technology Inc
O43 - CFD: 07/02/2018 - [0] D -- C:\Program Files (x86)\Belarc =>.Belarc, Inc.
O43 - CFD: 21/07/2017 - [0] AD -- C:\Program Files (x86)\BlueStacks =>.BlueStack Systems, Inc.
O43 - CFD: 16/01/2018 - [] D -- C:\Program Files (x86)\Google =>.Google Inc®
O43 - CFD: 11/11/2017 - [] HD -- C:\Program Files (x86)\InstallShield Installation Information =>.InstallShield
O43 - CFD: 26/09/2014 - [] D -- C:\Program Files (x86)\Java =>.Oracle
O43 - CFD: 23/06/2016 - [] D -- C:\Program Files (x86)\Logitech =>.Logitech, Inc.®
O43 - CFD: 14/02/2018 - [] D -- C:\Program Files (x86)\Norton Security Scan =>.Symantec
O43 - CFD: 14/02/2018 - [] D -- C:\Program Files (x86)\NortonInstaller =>.Symantec
O43 - CFD: 07/06/2014 - [] D -- C:\Program Files (x86)\NVIDIA Corporation =>.nVidia Corporation
O43 - CFD: 28/12/2016 - [] D -- C:\Program Files (x86)\OpenAL =>.Open Audio Library
O43 - CFD: 17/07/2017 - [] D -- C:\Program Files (x86)\Realtek =>.Realtek
O43 - CFD: 11/11/2017 - [0] D -- C:\Program Files (x86)\Samsung =>.Samsung Electronics
O43 - CFD: 16/01/2018 - [] D -- C:\Program Files (x86)\Spybot - Search & Destroy 2 =>.SaferNetworking
O43 - CFD: 09/06/2014 - [] D -- C:\Program Files (x86)\VideoLAN =>.VideoLan Team
O43 - CFD: 15/02/2018 - [] D -- C:\Program Files (x86)\VulkanRT =>.LunarG, Inc
O43 - CFD: 14/07/2009 - [] RD -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools =>.Administrative Tools
O43 - CFD: 15/02/2018 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AMD Problem Report Wizard
O43 - CFD: 15/02/2018 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AMD Radeon Settings =>.Samsung Electronics
O43 - CFD: 19/07/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Blizzard App
O43 - CFD: 14/10/2015 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Command and Conquer Red Alert 2
O43 - CFD: 27/07/2015 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Delicious - Emily's True Love
O43 - CFD: 27/07/2015 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Delicious - Emilys Childhood Memories
O43 - CFD: 09/06/2014 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ffdshow x64 =>.Open Source
O43 - CFD: 11/11/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\GameHouse =>.GameHouse
O43 - CFD: 15/02/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Heroes of the Storm =>.Games Software
O43 - CFD: 26/09/2014 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java =>.Oracle
O43 - CFD: 30/08/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Logitech =>.Logitech
O43 - CFD: 03/05/2018 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes =>.Malwarebytes
O43 - CFD: 25/10/2015 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Nexus Mod Manager =>.Winstep Software Technologies
O43 - CFD: 14/02/2018 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Norton Security Scan =>.Symantec
O43 - CFD: 03/01/2016 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StarCraft II
O43 - CFD: 07/06/2014 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Steam =>.Steam Games
O43 - CFD: 09/06/2014 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN =>.VideoLan Team
O43 - CFD: 29/09/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR =>.WinRAR
O43 - CFD: 17/07/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinZip 21.0
O43 - CFD: 19/07/2017 - [] D -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\World of Warcraft =>.Blizzard Entertainment
O43 - CFD: 30/04/2016 - [] D -- C:\ProgramData\activeMARK
O43 - CFD: 03/09/2015 - [] D -- C:\ProgramData\Adobe =>.Adobe
O43 - CFD: 03/01/2016 - [] D -- C:\ProgramData\Battle.net =>.Games Software
O43 - CFD: 11/10/2017 - [] D -- C:\ProgramData\Big Fish =>.Big Fish
O43 - CFD: 01/10/2014 - [] D -- C:\ProgramData\BioWare =>.BioWare
O43 - CFD: 17/02/2017 - [] D -- C:\ProgramData\Blizzard Entertainment =>.Blizzard Entertainment
O43 - CFD: 30/04/2016 - [0] D -- C:\ProgramData\boost_interprocess =>.boost.org
O43 - CFD: 12/07/2014 - [] D -- C:\ProgramData\Brother =>.Brother
O43 - CFD: 29/11/2014 - [] D -- C:\ProgramData\com.gamehouse.acid
O43 - CFD: 30/04/2016 - [] D -- C:\ProgramData\com.gamehouse.aminstaller
O43 - CFD: 18/04/2016 - [] D -- C:\ProgramData\CounterPath Corporation =>.CounterPath Corporation
O43 - CFD: 22/06/2015 - [] D -- C:\ProgramData\Gogii =>.Games Software
O43 - CFD: 25/09/2014 - [] D -- C:\ProgramData\Ironclad Games =>.Ironclad Games
O43 - CFD: 17/08/2014 - [] D -- C:\ProgramData\LogiShrd =>.Logitech Inc.
O43 - CFD: 03/05/2018 - [] D -- C:\ProgramData\Malwarebytes =>.Malwarebytes
O43 - CFD: 15/11/2017 - [0] D -- C:\ProgramData\Malwarebytes' Anti-Malware (portable) =>.Malwarebytes
O43 - CFD: 26/07/2014 - [] D -- C:\ProgramData\McAfee =>.McAfee
O43 - CFD: 14/02/2018 - [] D -- C:\ProgramData\Norton =>.Symantec Corporation
O43 - CFD: 14/02/2018 - [] D -- C:\ProgramData\NortonInstaller =>.Symantec
O43 - CFD: 26/09/2014 - [0] D -- C:\ProgramData\Oracle =>.Oracle
O43 - CFD: 11/11/2017 - [] D -- C:\ProgramData\Origin =>.Electronic Arts, Inc.
O43 - CFD: 06/09/2014 - [] D -- C:\ProgramData\Samsung =>.Samsung Electronics
O43 - CFD: 11/11/2017 - [] D -- C:\ProgramData\Skype =>.Skype
O43 - CFD: 16/01/2018 - [] D -- C:\ProgramData\Spybot - Search & Destroy =>.SaferNetworking
O43 - CFD: 25/09/2014 - [] D -- C:\ProgramData\Stardock =>.Stardock
O43 - CFD: 26/09/2014 - [] D -- C:\ProgramData\Sun =>.Oracle
O43 - CFD: 11/10/2017 - [] D -- C:\ProgramData\Trymedia =>PUP.Optional.Trymedia
O43 - CFD: 26/04/2018 - [] D -- C:\ProgramData\Twitch
O43 - CFD: 17/07/2017 - [] D -- C:\ProgramData\WinZip =>.WinZip
O43 - CFD: 03/09/2015 - [] D -- C:\Program Files (x86)\Common Files\Adobe =>.Adobe
O43 - CFD: 19/07/2017 - [0] D -- C:\Program Files (x86)\Common Files\Blizzard Entertainment =>.Blizzard Entertainment
O43 - CFD: 16/09/2014 - [] D -- C:\Program Files (x86)\Common Files\DESIGNER =>.Designer
O43 - CFD: 27/11/2016 - [] HD -- C:\Program Files (x86)\Common Files\EAInstaller =>.Electronic Arts, Inc.
O43 - CFD: 01/06/2014 - [] D -- C:\Program Files (x86)\Common Files\InstallShield =>.InstallShield
O43 - CFD: 26/09/2014 - [] D -- C:\Program Files (x86)\Common Files\Java =>.Oracle
O43 - CFD: 23/06/2016 - [] D -- C:\Program Files (x86)\Common Files\logishrd =>.Logitech Inc.
O43 - CFD: 12/12/2016 - [] D -- C:\Users\Mike\AppData\Roaming\7DaysToDie =>.Games Software
O43 - CFD: 03/09/2015 - [] D -- C:\Users\Mike\AppData\Roaming\Adobe =>.Adobe
O43 - CFD: 30/12/2017 - [] D -- C:\Users\Mike\AppData\Roaming\Battle.net =>.Games Software
O43 - CFD: 09/05/2016 - [] D -- C:\Users\Mike\AppData\Roaming\BlamGames =>.Blam! Games
O43 - CFD: 21/07/2017 - [] D -- C:\Users\Mike\AppData\Roaming\BlueStacksFriends
O43 - CFD: 27/06/2016 - [] RD -- C:\Users\Mike\AppData\Roaming\Brother =>.Brother
O43 - CFD: 18/04/2016 - [] D -- C:\Users\Mike\AppData\Roaming\CounterPath Corporation =>.CounterPath Corporation
O43 - CFD: 28/11/2015 - [] D -- C:\Users\Mike\AppData\Roaming\Easeware =>.Easeware
O43 - CFD: 17/06/2015 - [] D -- C:\Users\Mike\AppData\Roaming\Eipix =>.Eipix Games
O43 - CFD: 29/05/2016 - [] D -- C:\Users\Mike\AppData\Roaming\Elephant Games =>.Elephant Games
O43 - CFD: 29/11/2016 - [] D -- C:\Users\Mike\AppData\Roaming\FiraxisLive =>.Firaxis
O43 - CFD: 19/07/2014 - [] D -- C:\Users\Mike\AppData\Roaming\Full Control
O43 - CFD: 27/05/2016 - [] D -- C:\Users\Mike\AppData\Roaming\GameHouse =>.GameHouse
O43 - CFD: 14/06/2015 - [] D -- C:\Users\Mike\AppData\Roaming\Gamelab =>.GameLab
O43 - CFD: 16/01/2018 - [] D -- C:\Users\Mike\AppData\Roaming\Geek Uninstaller =>.Geek Uninstaller
O43 - CFD: 04/01/2018 - [] D -- C:\Users\Mike\AppData\Roaming\Google =>.Google
O43 - CFD: 23/07/2016 - [] D -- C:\Users\Mike\AppData\Roaming\Hidden Objects Alice2
O43 - CFD: 29/03/2015 - [] D -- C:\Users\Mike\AppData\Roaming\HomeMakeover
O43 - CFD: 01/05/2016 - [] D -- C:\Users\Mike\AppData\Roaming\IncredibleZoo
O43 - CFD: 23/06/2016 - [] D -- C:\Users\Mike\AppData\Roaming\Leadertech =>.Leadertech Systems
O43 - CFD: 01/06/2014 - [] D -- C:\Users\Mike\AppData\Roaming\library_dir =>.library_dir
O43 - CFD: 30/08/2017 - [] D -- C:\Users\Mike\AppData\Roaming\Logishrd =>.Logitech Inc.
O43 - CFD: 30/08/2017 - [] D -- C:\Users\Mike\AppData\Roaming\Logitech =>.Logitech
O43 - CFD: 01/06/2014 - [] D -- C:\Users\Mike\AppData\Roaming\Macromedia =>.Macromedia
O43 - CFD: 29/11/2016 - [] D -- C:\Users\Mike\AppData\Roaming\ModLauncherWPF =>.Games Software
O43 - CFD: 26/09/2014 - [] D -- C:\Users\Mike\AppData\Roaming\Oracle =>.Oracle
O43 - CFD: 10/10/2015 - [] D -- C:\Users\Mike\AppData\Roaming\Origin =>.Electronic Arts, Inc.
O43 - CFD: 14/06/2014 - [] D -- C:\Users\Mike\AppData\Roaming\Red Alert 3
O43 - CFD: 27/07/2014 - [] D -- C:\Users\Mike\AppData\Roaming\ShamanGS
O43 - CFD: 17/05/2017 - [] D -- C:\Users\Mike\AppData\Roaming\Skype =>.Skype
O43 - CFD: 08/12/2016 - [] D -- C:\Users\Mike\AppData\Roaming\Talisman The Horus Heresy
O43 - CFD: 13/07/2017 - [] D -- C:\Users\Mike\AppData\Roaming\The Creative Assembly =>.The Creative Assembly
O43 - CFD: 14/05/2018 - [] D -- C:\Users\Mike\AppData\Roaming\Twitch
O43 - CFD: 11/11/2017 - [] D -- C:\Users\Mike\AppData\Roaming\VERIZON =>.Verizon Wireless
O43 - CFD: 30/04/2016 - [] D -- C:\Users\Mike\AppData\Roaming\ViquaSoft
O43 - CFD: 21/07/2017 - [] D -- C:\Users\Mike\AppData\Roaming\vlc =>.VideoLan Team
O43 - CFD: 28/07/2014 - [] D -- C:\Users\Mike\AppData\Roaming\Wayforward Technologies =>.Wayforward Technologies
O43 - CFD: 29/09/2017 - [] D -- C:\Users\Mike\AppData\Roaming\WinRAR =>.WinRAR
O43 - CFD: 24/12/2016 - [] D -- C:\Users\Mike\AppData\Roaming\WinZip =>.WinZip
O43 - CFD: 26/07/2014 - [] D -- C:\Users\Mike\AppData\Roaming\YoudaGames =>.Youdagames
O43 - CFD: 15/05/2018 - [] D -- C:\Users\Mike\AppData\Roaming\ZHP =>.Nicolas Coolman
O43 - CFD: 03/09/2015 - [] D -- C:\Users\Mike\AppData\Local\Adobe =>.Adobe
O43 - CFD: 15/02/2018 - [] D -- C:\Users\Mike\AppData\Local\AMD =>.AMD
O43 - CFD: 11/10/2017 - [] D -- C:\Users\Mike\AppData\Local\AOL =>.AOL
O43 - CFD: 16/08/2015 - [] D -- C:\Users\Mike\AppData\Local\assembly =>.Assembly
O43 - CFD: 15/05/2018 - [] D -- C:\Users\Mike\AppData\Local\Battle.net =>.Games Software
O43 - CFD: 27/07/2014 - [] D -- C:\Users\Mike\AppData\Local\Big Fish =>.Big Fish
O43 - CFD: 26/07/2014 - [] D -- C:\Users\Mike\AppData\Local\Black_Tree_Gaming =>.Black Tree Gaming Ltd
O43 - CFD: 19/07/2017 - [] D -- C:\Users\Mike\AppData\Local\Blizzard =>.Blizzard
O43 - CFD: 01/06/2014 - [] D -- C:\Users\Mike\AppData\Local\Blizzard Entertainment =>.Blizzard Entertainment
O43 - CFD: 21/07/2017 - [] D -- C:\Users\Mike\AppData\Local\Bluestacks =>.BlueStack Systems, Inc.
O43 - CFD: 19/07/2017 - [] D -- C:\Users\Mike\AppData\Local\BlueStacksFriends
O43 - CFD: 22/07/2015 - [] D -- C:\Users\Mike\AppData\Local\CEF =>.CEF
O43 - CFD: 12/12/2016 - [] D -- C:\Users\Mike\AppData\Local\Chromium =>.Chromium
O43 - CFD: 11/10/2017 - [] D -- C:\Users\Mike\AppData\Local\com.gamehouse.acid
O43 - CFD: 18/04/2016 - [] D -- C:\Users\Mike\AppData\Local\CounterPath =>.CounterPath
O43 - CFD: 13/06/2015 - [0] SHD -- C:\Users\Mike\AppData\Local\EmieBrowserModeList =>.Enterprise mode Site List Mgr
O43 - CFD: 13/06/2015 - [0] SHD -- C:\Users\Mike\AppData\Local\EmieSiteList =>.Enterprise mode Site List Mgr
O43 - CFD: 13/06/2015 - [0] SHD -- C:\Users\Mike\AppData\Local\EmieUserList =>.Enterprise mode Site List Mgr
O43 - CFD: 09/07/2017 - [] D -- C:\Users\Mike\AppData\Local\EternalCrusade
O43 - CFD: 16/01/2018 - [] D -- C:\Users\Mike\AppData\Local\Google =>.Google
O43 - CFD: 02/06/2015 - [] D -- C:\Users\Mike\AppData\Local\GWX =>.GWX
O43 - CFD: 25/09/2014 - [] D -- C:\Users\Mike\AppData\Local\Ironclad Games =>.Ironclad Games
O43 - CFD: 30/08/2017 - [] D -- C:\Users\Mike\AppData\Local\Logitech =>.Logitech
O43 - CFD: 23/06/2016 - [] D -- C:\Users\Mike\AppData\Local\Logitech® Webcam Software =>.Logitech Inc.
O43 - CFD: 11/10/2017 - [] D -- C:\Users\Mike\AppData\Local\LOOT
O43 - CFD: 22/04/2017 - [] D -- C:\Users\Mike\AppData\Local\Ndemic Creations =>.Ndemic Creations
O43 - CFD: 18/06/2017 - [] D -- C:\Users\Mike\AppData\Local\NPE =>.NPE
O43 - CFD: 18/04/2016 - [] D -- C:\Users\Mike\AppData\Local\Plantronics =>.Plantronics
O43 - CFD: 15/02/2018 - [] D -- C:\Users\Mike\AppData\Local\RadeonInstaller
O43 - CFD: 16/05/2017 - [0] D -- C:\Users\Mike\AppData\Local\Skype =>.Skype
O43 - CFD: 15/08/2015 - [] D -- C:\Users\Mike\AppData\Local\Skyrim =>.Skyrim Games
O43 - CFD: 11/10/2017 - [] D -- C:\Users\Mike\AppData\Local\SlimWare Utilities Inc =>.SUP.SlimWareUtilities
O43 - CFD: 16/12/2016 - [] D -- C:\Users\Mike\AppData\Local\SpaceHulkGame
O43 - CFD: 12/12/2016 - [] D -- C:\Users\Mike\AppData\Local\Steam =>.Steam Games
O43 - CFD: 23/12/2016 - [] D -- C:\Users\Mike\AppData\Local\SystemInfo
O43 - CFD: 27/06/2015 - [] D -- C:\Users\Mike\AppData\Local\The Witcher =>.Atari Inc
O43 - CFD: 16/12/2016 - [] D -- C:\Users\Mike\AppData\Local\UnrealEngine =>.Unreal Software
O43 - CFD: 05/03/2015 - [] D -- C:\Users\Mike\AppData\Local\WB Games =>.WB Games
O43 - CFD: 17/07/2017 - [] D -- C:\Users\Mike\AppData\Local\WinZip =>.WinZip
O43 - CFD: 15/05/2018 - [] D -- C:\Users\Mike\AppData\Local\ZHP =>.Nicolas Coolman
O43 - CFD: 03/09/2015 - [] D -- C:\Users\Mike\AppData\LocalLow\Adobe =>.Adobe
O43 - CFD: 15/02/2018 - [] D -- C:\Users\Mike\AppData\LocalLow\AMD =>.AMD
O43 - CFD: 07/07/2017 - [] D -- C:\Users\Mike\AppData\LocalLow\Beam Team Games
O43 - CFD: 27/06/2016 - [] D -- C:\Users\Mike\AppData\LocalLow\Brother =>.Brother
O43 - CFD: 10/07/2017 - [] D -- C:\Users\Mike\AppData\LocalLow\CampoSanto
O43 - CFD: 13/06/2015 - [0] SHD -- C:\Users\Mike\AppData\LocalLow\EmieBrowserModeList =>.Enterprise mode Site List Mgr
O43 - CFD: 13/06/2015 - [0] SHD -- C:\Users\Mike\AppData\LocalLow\EmieSiteList =>.Enterprise mode Site List Mgr
O43 - CFD: 13/06/2015 - [0] SHD -- C:\Users\Mike\AppData\LocalLow\EmieUserList =>.Enterprise mode Site List Mgr
O43 - CFD: 14/07/2017 - [] D -- C:\Users\Mike\AppData\LocalLow\Fireproof Games
O43 - CFD: 22/03/2016 - [] D -- C:\Users\Mike\AppData\LocalLow\Google =>.Google
O43 - CFD: 02/01/2017 - [] D -- C:\Users\Mike\AppData\LocalLow\Hammerfall Publishing
O43 - CFD: 26/09/2014 - [] D -- C:\Users\Mike\AppData\LocalLow\Sun =>.Oracle
O43 - CFD: 03/08/2014 - [] D -- C:\Users\Mike\AppData\LocalLow\The Fullbright Company =>.The Fullbright Company
O43 - CFD: 13/02/2018 - [] D -- C:\Users\Mike\Desktop\dump
O43 - CFD: 27/05/2015 - [] D -- C:\Users\Mike\Desktop\Emily's Daycare Receipts
O43 - CFD: 15/11/2017 - [] D -- C:\Users\Mike\Desktop\mbar
O43 - CFD: 15/02/2018 - [] RD -- C:\Users\Mike\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools =>.Administrative Tools
O43 - CFD: 27/07/2015 - [] D -- C:\Users\Mike\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Delicious - Emily's True Love
O43 - CFD: 27/07/2015 - [] D -- C:\Users\Mike\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Delicious - Emilys Childhood Memories
O43 - CFD: 29/09/2017 - [] D -- C:\Users\Mike\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR =>.WinRAR
O43 - CFD: 24/12/2016 - [0] D -- C:\Users\Mike\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinZip 21.0
O43 - CFD: 01/06/2014 - [] -- C:\Windows\System32\Config\systemprofile\AppData\Local\Google =>.Google
O43 - CFD: 10/10/2017 - [] -- C:\Windows\System32\Config\systemprofile\AppData\Roaming\Macromedia =>.Macromedia
O43 - CFD: 12/03/2016 - [] -- C:\Windows\System32\Config\systemprofile\AppData\Roaming\PlaysTV =>.PlaysTV
---\ ShellIconOverlayIdentifiers (SIOI) (2) - 0s
O106 - SIOI: Enhanced Storage Icon Overlay Handler Class [EnhancedStorageShell] - {D9144DCD-E998-4ECA-AB6A-DCD83CCBA16D}. (.Microsoft Corporation - Windows Enhanced Storage Shell Extension DL.) -- C:\Windows\System32\EhStorShell.dll =>.Microsoft Corporation
O106 - SIOI: Sharing Overlay (Private) [SharingPrivate] - {08244EE6-92F0-47f2-9FC9-929BAA2E7235}. (.Microsoft Corporation - Shell extensions for sharing.) -- C:\Windows\System32\ntshrui.dll =>.Microsoft Corporation
---\ Search Context Menu Handlers (SCMH) (29) - 0s
O108 - CMH1: BriefcaseMenu [64Bits] - {85BBD920-42A0-1069-A2E4-08002B30309D} . (.Microsoft Corporation - Windows Briefcase.) -- C:\Windows\System32\syncui.dll =>.Microsoft Corporation
O108 - CMH1: FileAssociationHelper [64Bits] - {D5CF14A2-B3CA-49DC-8E3E-0BB233B26D09} . (.Nico Mak Computing - File Association Helper.) -- C:\Program Files\File Association Helper\FAHDll.dll =>.WinZip Computing LLC®
O108 - CMH1: Open With [64Bits] - {09799AFB-AD67-11d1-ABCD-00C04FC30936} . (.Microsoft Corporation - Windows Shell Common Dll.) -- C:\Windows\System32\shell32.dll =>.Microsoft Corporation
O108 - CMH1: Open With EncryptionMenu [64Bits] - {A470F8CF-A1E8-4f65-8335-227475AA5C46} . (.Microsoft Corporation - Windows Shell Common Dll.) -- C:\Windows\System32\shell32.dll =>.Microsoft Corporation
O108 - CMH1: Sharing [64Bits] - {f81e9010-6ea4-11ce-a7ff-00aa003ca9f6} . (.Microsoft Corporation - Shell extensions for sharing.) -- C:\Windows\System32\ntshrui.dll =>.Microsoft Corporation
O108 - CMH1: WinRAR [64Bits] - {B41DB860-64E4-11D2-9906-E49FADC173CA} . (.Alexander Roshal - WinRAR shell extension.) -- C:\Program Files\WinRAR\RarExt.dll =>.win.rar GmbH®
O108 - CMH1: WinRAR32 [64Bits] - {B41DB860-8EE4-11D2-9906-E49FADC173CA} . (.Orphan.)
O108 - CMH1: WinZip [64Bits] - {E0D79304-84BE-11CE-9641-444553540000} . (.WinZip Computing, S.L. - WinZip Shell Extension DLL.) -- C:\Program Files\WinZip\WZSHLS64.dll =>.WinZip Computing LLC®
O108 - CMH2: Compatibility [64Bits] - {1d27f844-3a1f-4410-85ac-14651078412d} . (.Microsoft Corporation - Compatibility Tab Shell Extension Library.) -- C:\Windows\System32\acppage.dll =>.Microsoft Corporation
O108 - CMH2: OpenContainingFolderMenu [64Bits] - {37ea3a21-7493-4208-a011-7f9ea79ce9f5} . (.Microsoft Corporation - Windows Shell Common Dll.) -- C:\Windows\System32\shell32.dll =>.Microsoft Corporation
O108 - CMH2: WinZip [64Bits] - {E0D79304-84BE-11CE-9641-444553540000} . (.WinZip Computing, S.L. - WinZip Shell Extension DLL.) -- C:\Program Files\WinZip\WZSHLS64.dll =>.WinZip Computing LLC®
O108 - CMH3: CopyAsPathMenu [64Bits] - {f3d06e7c-1e45-4a26-847e-f9fcdee59be0} . (.Microsoft Corporation - Windows Shell Common Dll.) -- C:\Windows\System32\shell32.dll =>.Microsoft Corporation
O108 - CMH3: MBAMShlExt [64Bits] - {57CE581A-0CB6-4266-9CA0-19364C90A0B3} . (.Malwarebytes - Malwarebytes.) -- C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll =>.Malwarebytes Corporation®
O108 - CMH3: SendTo [64Bits] - {7BA4C740-9E81-11CF-99D3-00AA004AE837} . (.Microsoft Corporation - Windows Shell Common Dll.) -- C:\Windows\System32\shell32.dll =>.Microsoft Corporation
O108 - CMH4: EncryptionMenu [64Bits] - {A470F8CF-A1E8-4f65-8335-227475AA5C46} . (.Microsoft Corporation - Windows Shell Common Dll.) -- C:\Windows\System32\shell32.dll =>.Microsoft Corporation
O108 - CMH4: Sharing [64Bits] - {f81e9010-6ea4-11ce-a7ff-00aa003ca9f6} . (.Microsoft Corporation - Shell extensions for sharing.) -- C:\Windows\System32\ntshrui.dll =>.Microsoft Corporation
O108 - CMH4: WinZip [64Bits] - {E0D79304-84BE-11CE-9641-444553540000} . (.WinZip Computing, S.L. - WinZip Shell Extension DLL.) -- C:\Program Files\WinZip\WZSHLS64.dll =>.WinZip Computing LLC®
O108 - CMH5: ACE [64Bits] - {5E2121EE-0300-11D4-8D3B-444553540000} . (.Advanced Micro Devices, Inc. - Radeon Settings: Desktop Control Panel.) -- C:\Program Files\AMD\CNext\CNext\atiacm64.dll =>.Advanced Micro Devices, Inc.
O108 - CMH5: Gadgets [64Bits] - {6B9228DA-9C15-419e-856C-19E768A13BDC} . (.Microsoft Corporation - Sidebar droptarget.) -- C:\Program Files\Windows Sidebar\sbdrop.dll =>.Microsoft Corporation
O108 - CMH5: New [64Bits] - {D969A300-E7FF-11d0-A93B-00A0C90F2719} . (.Microsoft Corporation - Windows Shell Common Dll.) -- C:\Windows\System32\shell32.dll =>.Microsoft Corporation
O108 - CMH5: Sharing [64Bits] - {f81e9010-6ea4-11ce-a7ff-00aa003ca9f6} . (.Microsoft Corporation - Shell extensions for sharing.) -- C:\Windows\System32\ntshrui.dll =>.Microsoft Corporation
O108 - CMH6: BriefcaseMenu [64Bits] - {85BBD920-42A0-1069-A2E4-08002B30309D} . (.Microsoft Corporation - Windows Briefcase.) -- C:\Windows\System32\syncui.dll =>.Microsoft Corporation
O108 - CMH6: Library Location [64Bits] - {3dad6c5d-2167-4cae-9914-f99e41c12cfa} . (.Microsoft Corporation - Windows Shell Common Dll.) -- C:\Windows\System32\shell32.dll =>.Microsoft Corporation
O108 - CMH6: MBAMShlExt [64Bits] - {57CE581A-0CB6-4266-9CA0-19364C90A0B3} . (.Malwarebytes - Malwarebytes.) -- C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll =>.Malwarebytes Corporation®
O108 - CMH6: WinRAR [64Bits] - {B41DB860-64E4-11D2-9906-E49FADC173CA} . (.Alexander Roshal - WinRAR shell extension.) -- C:\Program Files\WinRAR\RarExt.dll =>.win.rar GmbH®
O108 - CMH6: WinRAR32 [64Bits] - {B41DB860-8EE4-11D2-9906-E49FADC173CA} . (.Orphan.)
O108 - CMH6: WinZip [64Bits] - {E0D79304-84BE-11CE-9641-444553540000} . (.WinZip Computing, S.L. - WinZip Shell Extension DLL.) -- C:\Program Files\WinZip\WZSHLS64.dll =>.WinZip Computing LLC®
O108 - CMH7: EnhancedStorageShell [64Bits] - {2854F705-3548-414C-A113-93E27C808C85} . (.Microsoft Corporation - Windows Enhanced Storage Shell Extension DL.) -- C:\Windows\System32\EhStorShell.dll =>.Microsoft Corporation
O108 - CMH7: Sharing [64Bits] - {f81e9010-6ea4-11ce-a7ff-00aa003ca9f6} . (.Microsoft Corporation - Shell extensions for sharing.) -- C:\Windows\System32\ntshrui.dll =>.Microsoft Corporation
---\ Image File Execution Options (4) - 0s
O50 - IFEO:C:\Windows\System32\ie4uinit.exe - (.Microsoft Corporation - IE Per-User Initialization Utility.) [MitigationOptions\\256] =>.Microsoft Corporation
O50 - IFEO:C:\Windows\System32\ieUnatt.exe - (.Microsoft Corporation - IE 7.0 Unattended Install Utility.) [MitigationOptions\\256] =>.Microsoft Corporation
O50 - IFEO:C:\Windows\System32\msfeedssync.exe - (.Microsoft Corporation - Microsoft Feeds Synchronization.) [MitigationOptions\\256] =>.Microsoft Corporation
O50 - IFEO:C:\Windows\System32\mshta.exe - (.Microsoft Corporation - Microsoft (R) HTML Application host.) [MitigationOptions\\256] =>.Microsoft Corporation
---\ ShareTools MSconfig StartupReg (4) - 0s
O53 - SMSR:HKLM\...\startupreg\Launch LCore [Key] [64Bits] . (.Logitech Inc. - Logitech Gaming Framework.) -- C:\Program Files\Logitech Gaming Software\LCore.exe =>.Logitech Inc.
O53 - SMSR:HKLM\...\startupreg\LWS [Key] [64Bits] . (.Logitech Inc. - Logitech Webcam Software.) -- C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe =>.Logitech Inc.
O53 - SMSR:HKLM\...\startupreg\Raptr [Key] [64Bits] . (...) -- C:\Program Files (x86)\Raptr Inc\Raptr\raptrstub.exe (.not file.)
O53 - SMSR:HKLM\...\startupreg\RTHDVCPL [Key] [64Bits] . (.Realtek Semiconductor - Realtek HD Audio Manager.) -- C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe =>.Realtek Semiconductor
---\ System Drivers List (68) - 12s
O58 - SDL:2017/11/15 17:43:38 A . (.Malwarebytes - Malwarebytes SwissArmy.) -- C:\Windows\System32\drivers\2442656D.sys [255928] =>.Malwarebytes Corporation®
O58 - SDL:2009/07/13 21:52:21 A . (.Adaptec, Inc. - Adaptec Windows SAS/SATA Storport Driver.) -- C:\Windows\System32\drivers\adp94xx.sys [491088] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:52:21 A . (.Adaptec, Inc. - Adaptec Windows SATA Storport Driver.) -- C:\Windows\System32\drivers\adpahci.sys [339536] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:52:21 A . (.Adaptec, Inc. - Adaptec StorPort Ultra320 SCSI Driver (X64).) -- C:\Windows\System32\drivers\adpu320.sys [182864] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:52:21 A . (.Acer Laboratories Inc. - ALi mini IDE Driver.) -- C:\Windows\System32\drivers\aliide.sys [15440] =>.Microsoft Windows®
O58 - SDL:2018/01/31 20:10:12 A . (.Advanced Micro Devices - AMD ACP Binaries.) -- C:\Windows\System32\drivers\amdacpksd.sys [305544] =>.Advanced Micro Devices, Inc.®
O58 - SDL:2011/03/11 02:41:12 A . (.Advanced Micro Devices - AHCI 1.2 Device Driver.) -- C:\Windows\System32\drivers\amdsata.sys [107904] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:52:20 A . (.AMD Technologies Inc. - AMD Technology AHCI Compatible Controller D.) -- C:\Windows\System32\drivers\amdsbs.sys [194128] =>.Microsoft Windows®
O58 - SDL:2011/03/11 02:41:12 A . (.Advanced Micro Devices - Storage Filter Driver.) -- C:\Windows\System32\drivers\amdxata.sys [27008] =>.Microsoft Windows®
O58 - SDL:2012/04/10 21:40:58 A . (.Advanced Micro Devices - AHCI 1.2 Device Driver.) -- C:\Windows\System32\drivers\amd_sata.sys [82560] =>.Advanced Micro Devices, Inc.®
O58 - SDL:2012/04/10 21:40:58 A . (.Advanced Micro Devices - Stor Filter Driver.) -- C:\Windows\System32\drivers\amd_xata.sys [42624] =>.Advanced Micro Devices, Inc.®
O58 - SDL:2009/07/13 21:52:21 A . (.Adaptec, Inc. - Adaptec RAID Storport Driver.) -- C:\Windows\System32\drivers\arc.sys [87632] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:52:21 A . (.Adaptec, Inc. - Adaptec SAS RAID WS03 Driver.) -- C:\Windows\System32\drivers\arcsas.sys [97856] =>.Microsoft Windows®
O58 - SDL:2013/08/16 16:37:12 A . (.ASMedia Technology Inc - ASMedia USB3 Hub Driver.) -- C:\Windows\System32\drivers\asmthub3.sys [140032] =>.MCCI Corporation®
O58 - SDL:2013/08/16 16:37:12 A . (.ASMedia Technology Inc - ASMEDIA XHCI Host Controller Driver.) -- C:\Windows\System32\drivers\asmtxhci.sys [424192] =>.MCCI Corporation®
O58 - SDL:2017/09/01 19:15:08 A . (.Advanced Micro Devices - AMD High Definition Audio Function Driver.) -- C:\Windows\System32\drivers\AtihdW76.sys [96256] =>.Advanced Micro Devices
O58 - SDL:2018/01/31 20:10:30 A . (.Advanced Micro Devices, Inc. - ATI Radeon Kernel Mode Driver.) -- C:\Windows\System32\drivers\atikmdag.sys [41570184] =>.Advanced Micro Devices, Inc.®
O58 - SDL:2018/01/31 20:11:36 A . (.Advanced Micro Devices, Inc. - AMD multi-vendor Miniport Driver.) -- C:\Windows\System32\drivers\atikmpag.sys [536968] =>.Advanced Micro Devices, Inc.®
O58 - SDL:2009/06/10 16:34:23 A . (.Broadcom Corporation - Broadcom NetXtreme Gigabit Ethernet NDIS6.x.) -- C:\Windows\System32\drivers\b57nd60a.sys [270848] =>.Broadcom Corporation
O58 - SDL:2009/06/10 16:41:06 A . (.Brother Industries, Ltd. - Windows ME USB Mass-Storage Bulk-Only Lower.) -- C:\Windows\System32\drivers\BrFiltLo.sys [18432] =>.Brother Industries, Ltd.
O58 - SDL:2009/06/10 16:41:06 A . (.Brother Industries, Ltd. - Windows ME USB Mass-Storage Bulk-Only Upper.) -- C:\Windows\System32\drivers\BrFiltUp.sys [8704] =>.Brother Industries, Ltd.
O58 - SDL:2013/05/22 13:32:44 A . (.Brother Industries Ltd. - Brother MFC Serial Interface Driver(WDM).) -- C:\Windows\System32\drivers\BrSerIb.sys [95344] =>.Brother Industries, Ltd.®
O58 - SDL:2009/07/13 21:19:07 A . (.Brother Industries Ltd. - Brotehr Serial I/F Driver (WDM).) -- C:\Windows\System32\drivers\BrSerId.sys [286720] =>.Brother Industries Ltd.
O58 - SDL:2009/06/10 16:41:10 A . (.Brother Industries Ltd. - Brother Serial driver (WDM version).) -- C:\Windows\System32\drivers\BrSerWdm.sys [47104] =>.Brother Industries Ltd.
O58 - SDL:2009/06/10 16:41:10 A . (.Brother Industries Ltd. - Brother USB MDM Driver.) -- C:\Windows\System32\drivers\BrUsbMdm.sys [14976] =>.Brother Industries Ltd.
O58 - SDL:2009/06/10 16:41:10 A . (.Brother Industries Ltd. - Brother USB Serial Driver.) -- C:\Windows\System32\drivers\BrUsbSer.sys [14720] =>.Brother Industries Ltd.
O58 - SDL:2013/05/22 13:32:42 A . (.Brother Industries Ltd. - Brother MFC Serial USB Driver(WDM).) -- C:\Windows\System32\drivers\BrUsbSib.sys [21872] =>.Brother Industries, Ltd.®
O58 - SDL:2009/06/10 16:34:28 A . (.Broadcom Corporation - Broadcom NetXtreme II GigE VBD.) -- C:\Windows\System32\drivers\bxvbda.sys [468480] =>.Broadcom Corporation
O58 - SDL:2009/07/13 21:52:31 A . (.CMD Technology, Inc. - CMD PCI IDE Bus Driver.) -- C:\Windows\System32\drivers\cmdide.sys [17488] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:47:48 A . (.Emulex - Storport Miniport Driver for LightPulse HBA.) -- C:\Windows\System32\drivers\elxstor.sys [530496] =>.Microsoft Windows®
O58 - SDL:2009/06/10 16:34:33 A . (.Broadcom Corporation - Broadcom NetXtreme II 10 GigE VBD.) -- C:\Windows\System32\drivers\evbda.sys [3286016] =>.Broadcom Corporation
O58 - SDL:2009/06/10 16:31:59 A . (.Hauppauge Computer Works, Inc. - Hauppauge WinTV 885 Consumer IR Driver for.) -- C:\Windows\System32\drivers\hcw85cir.sys [31232] =>.Hauppauge Computer Works, Inc.
O58 - SDL:2010/11/20 09:33:35 A . (.Hewlett-Packard Company - Smart Array SAS/SATA Controller Media Drive.) -- C:\Windows\System32\drivers\HpSAMD.sys [78720] =>.Microsoft Windows®
O58 - SDL:2011/03/11 02:41:26 A . (.Intel Corporation - Intel Matrix Storage Manager driver - x64.) -- C:\Windows\System32\drivers\iaStorV.sys [410496] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:48:04 A . (.Intel Corp./ICP vortex GmbH - Intel/ICP Raid Storport Driver.) -- C:\Windows\System32\drivers\iirsp.sys [44112] =>.Microsoft Windows®
O58 - SDL:2017/07/10 18:35:44 A . (.Logitech Inc. - Logitech WingMan Virtual Bus Enumerator Dri.) -- C:\Windows\System32\drivers\LGBusEnum.sys [36496] =>.Logitech Inc®
O58 - SDL:2017/07/10 18:35:44 A . (.Logitech Inc. - Logitech Gaming Software Joystick Translati.) -- C:\Windows\System32\drivers\LGJoyXlCore.sys [67736] =>.Logitech Inc®
O58 - SDL:2017/07/10 18:35:44 A . (.Logitech Inc. - Logitech Gaming HID Filter Driver..) -- C:\Windows\System32\drivers\LGSHidFilt.Sys [64280] =>.Logitech®
O58 - SDL:2017/07/10 18:35:44 A . (.Logitech Inc. - Logitech GamePanel Virtual Hid Device Drive.) -- C:\Windows\System32\drivers\LGVirHid.sys [26008] =>.Logitech Inc®
O58 - SDL:2018/01/03 21:09:21 A . (.Logitech, Inc. - Logitech Non-Plug and Play Driver..) -- C:\Windows\System32\drivers\LNonPnP.sys [18960] =>.Logitech®
O58 - SDL:2009/07/13 21:48:04 A . (.LSI Corporation - LSI Fusion-MPT FC Driver (StorPort).) -- C:\Windows\System32\drivers\lsi_fc.sys [114752] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:48:04 A . (.LSI Corporation - LSI Fusion-MPT SAS Driver (StorPort).) -- C:\Windows\System32\drivers\lsi_sas.sys [106560] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:48:04 A . (.LSI Corporation - LSI SAS Gen2 Driver (StorPort).) -- C:\Windows\System32\drivers\lsi_sas2.sys [65600] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:48:04 A . (.LSI Corporation - LSI Fusion-MPT SCSI Driver (StorPort).) -- C:\Windows\System32\drivers\lsi_scsi.sys [115776] =>.Microsoft Windows®
O58 - SDL:2012/09/21 15:04:24 A . (.Logitech Inc. - Logitech USB Video Class Filter Driver.) -- C:\Windows\System32\drivers\lvbflt64.sys [24608] =>.Logitech, Inc.®
O58 - SDL:2012/09/21 15:04:22 A . (.Logitech Inc. - Logitech Kernel Audio Improvement Filter Dr.) -- C:\Windows\System32\drivers\lvrs64.sys [351520] =>.Logitech, Inc.®
O58 - SDL:2012/09/21 15:04:22 A . (.Logitech Inc. - Logitech USB Video Class Driver.) -- C:\Windows\System32\drivers\LVUVC64.sys [4763680] =>.Logitech, Inc.®
O58 - SDL:2018/03/19 12:57:14 A . (...) -- C:\Windows\System32\drivers\mbae64.sys [76192] =>.Malwarebytes Corporation®
O58 - SDL:2009/07/13 21:48:04 A . (.LSI Corporation - MEGASAS RAID Controller Driver for Windows.) -- C:\Windows\System32\drivers\megasas.sys [35392] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:48:04 A . (.LSI Corporation, Inc. - LSI MegaRAID Software RAID Driver.) -- C:\Windows\System32\drivers\MegaSR.sys [284736] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:48:26 A . (.IBM Corporation - IBM ServeRAID Controller Driver.) -- C:\Windows\System32\drivers\nfrd960.sys [51264] =>.Microsoft Windows®
O58 - SDL:2011/03/11 02:41:34 A . (.NVIDIA Corporation - NVIDIA® nForce(TM) RAID Driver.) -- C:\Windows\System32\drivers\nvraid.sys [148352] =>.Microsoft Windows®
O58 - SDL:2011/03/11 02:41:34 A . (.NVIDIA Corporation - NVIDIA® nForce(TM) Sata Performance Driver.) -- C:\Windows\System32\drivers\nvstor.sys [166272] =>.Microsoft Windows®
O58 - SDL:2015/07/22 06:32:22 A . (.QUALCOMM Incorporated - USB Modem/Serial Device Driver.) -- C:\Windows\System32\drivers\qcusbser.sys [270048] =>.Microsoft Windows Hardware Compatibility Publisher®
O58 - SDL:2009/07/13 21:45:46 A . (.QLogic Corporation - QLogic Fibre Channel Stor Miniport Driver.) -- C:\Windows\System32\drivers\ql2300.sys [1524816] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:45:45 A . (.QLogic Corporation - QLogic iSCSI Storport Miniport Driver.) -- C:\Windows\System32\drivers\ql40xx.sys [128592] =>.Microsoft Windows®
O58 - SDL:2017/06/27 02:07:53 A . (.Realtek - Realtek 8136/8168/8169 NDIS 6.20 64-bit Dri.) -- C:\Windows\System32\drivers\Rt64win7.sys [1048576] =>.Realtek Semiconductor Corp.®
O58 - SDL:2016/11/09 11:49:02 A . (.Realtek Semiconductor Corp. - Realtek(r) High Definition Audio Function D.) -- C:\Windows\System32\drivers\RTKVHD64.sys [5437960] =>.Realtek Semiconductor Corp.®
O58 - SDL:2009/06/10 16:37:19 A . (.Macrovision Corporation, Macrovision Europe Limited, - Macrovision SECURITY Driver.) -- C:\Windows\System32\drivers\secdrv.sys [23040] =>.Rovi Corporation
O58 - SDL:2009/07/13 20:00:40 A . (.Brother Industries Ltd. - Brotehr Serial I/F Driver (WDM).) -- C:\Windows\System32\drivers\serial.sys [94208] =>.Brother Industries Ltd.
O58 - SDL:2009/07/13 21:45:45 A . (.Silicon Integrated Systems Corp. - SiS RAID Stor Miniport Driver.) -- C:\Windows\System32\drivers\sisraid2.sys [43584] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:45:46 A . (.Silicon Integrated Systems - SiS AHCI Stor-Miniport Driver.) -- C:\Windows\System32\drivers\sisraid4.sys [80464] =>.Microsoft Windows®
O58 - SDL:2014/10/13 01:57:48 A . (.DEVGURU Co., LTD.(www.devguru.co.kr) - SAMSUNG USB Composite Device Driver (MSS Ve.) -- C:\Windows\System32\drivers\ssudbus.sys [110336] =>.DEVGURU CO LTD®
O58 - SDL:2014/10/13 01:57:48 A . (.DEVGURU Co., LTD.(www.devguru.co.kr) - SAMSUNG Android Modem Device Driver (MSS Ve.) -- C:\Windows\System32\drivers\ssudmdm.sys [206080] =>.DEVGURU CO LTD®
O58 - SDL:2009/07/13 21:45:55 A . (.Promise Technology - Promise SuperTrak EX Series Driver for Win.) -- C:\Windows\System32\drivers\stexstor.sys [24656] =>.Microsoft Windows®
O58 - SDL:2012/08/28 08:27:24 RA . (.Advanced Micro Devices - AMD USB Filter Driver.) -- C:\Windows\System32\drivers\usbfilter.sys [58536] =>.Advanced Micro Devices, Inc.®
O58 - SDL:2009/07/13 21:45:55 A . (.VIA Technologies, Inc. - VIA Generic PCI IDE Bus Driver.) -- C:\Windows\System32\drivers\viaide.sys [17488] =>.Microsoft Windows®
O58 - SDL:2009/07/13 21:45:55 A . (.VIA Technologies Inc.,Ltd - VIA RAID DRIVER FOR AMD-X86-64.) -- C:\Windows\System32\drivers\vsmraid.sys [161872] =>.Microsoft Windows®
---\ File Associations Shell Spawning (10) - 0s
O67 - Shell Spawning: <.bat> [HKLM\..\open\Command] (...) -- '%1' %* =>.Default.Value
O67 - Shell Spawning: <.cpl> [HKLM\..\cplopen\Command] (.Microsoft Corporation - Windows Control Panel.) -- C:\Windows\System32\control.exe =>.Microsoft Corporation
O67 - Shell Spawning: <.cmd> [HKLM\..\open\Command] (...) -- '%1' %* =>.Default.Value
O67 - Shell Spawning: <.com> [HKLM\..\open\Command] (...) -- '%1' %* =>.Default.Value
O67 - Shell Spawning: <.evt> [HKLM\..\open\Command] (.Microsoft Corporation - Event Viewer Snapin Launcher.) -- C:\Windows\System32\eventvwr.exe =>.Microsoft Corporation
O67 - Shell Spawning: <.exe> [HKLM\..\open\Command] (...) -- '%1' %* =>.Default.Value
O67 - Shell Spawning: <.html> [HKLM\..\open\Command] (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O67 - Shell Spawning: <.js> [HKLM\..\open\Command] (...) -- C:\Windows\System32\WScript.exe '%1' %* =>.Default.Value
O67 - Shell Spawning: <.reg> [HKLM\..\open\Command] (.Microsoft Corporation - Registry Editor.) -- C:\Windows\regedit.exe =>.Microsoft Corporation
O67 - Shell Spawning: <.scr> [HKLM\..\open\Command] (...) -- '%1' /S =>.Default.Value
---\ Start Menu Internet (8) - 0s
O68 - StartMenuInternet: [64Bits][HKLM\..\Shell\open\Command] (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc®
O68 - StartMenuInternet: [64Bits][HKLM\..\Shell\open\Command] (...) -- iexplore.exe
O68 - StartMenuInternet: [64Bits][HKLM\..\InstallInfo\ShowIconsCommand] (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc.
O68 - StartMenuInternet: [64Bits][HKLM\..\InstallInfo\ShowIconsCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
O68 - StartMenuInternet: [64Bits][HKLM\..\InstallInfo\ReinstallCommand] (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc.
O68 - StartMenuInternet: [64Bits][HKLM\..\InstallInfo\ReinstallCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
O68 - StartMenuInternet: [64Bits][HKLM\..\InstallInfo\HideIconsCommand] (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe =>.Google Inc.
O68 - StartMenuInternet: [64Bits][HKLM\..\InstallInfo\HideIconsCommand] (.Microsoft Corporation - IE Per-User Initialization Utility.) -- C:\Windows\System32\ie4uinit.exe =>.Microsoft Corporation
---\ Search Browser Infection (3) - 0s
O69 - SBI: SearchScopes [HKCU] [64Bits]{0633EE93-D776-472f-A0FF-E1416B8B2E3A} [DefaultScope] - (Bing) - http://www.bing.com/ =>.Bing.com
O69 - SBI: SearchScopes [HKLM] [64Bits]{0633EE93-D776-472f-A0FF-E1416B8B2E3A} - (@ieframe.dll,-12512) - http://www.bing.com/ =>.Bing.com
O69 - SBI: SearchScopes [HKLM] [64Bits]{31090377-0740-419E-BEFC-A56E50500D5B} - (Google) - http://www.google.com/ =>.Google Inc.
---\ Search Svchost Services (32) - 1s
O83 - Search Svchost Services: AeLookupSvc (AeLookupSvc) . (.Microsoft Corporation - Application Experience Service.) -- C:\Windows\System32\aelupsvc.dll [72192] =>.Microsoft Corporation
O83 - Search Svchost Services: CertPropSvc (CertPropSvc) . (.Microsoft Corporation - Microsoft Smartcard Certificate Propagation.) -- C:\Windows\System32\certprop.dll [80384] =>.Microsoft Corporation
O83 - Search Svchost Services: SCPolicySvc (SCPolicySvc) . (.Microsoft Corporation - Microsoft Smartcard Certificate Propagation.) -- C:\Windows\System32\certprop.dll [80384] =>.Microsoft Corporation
O83 - Search Svchost Services: lanmanserver (lanmanserver) . (.Microsoft Corporation - Server Service DLL.) -- C:\Windows\System32\srvsvc.dll [236032] =>.Microsoft Corporation
O83 - Search Svchost Services: gpsvc (gpsvc) . (.Microsoft Corporation - Group Policy Client.) -- C:\Windows\System32\gpsvc.dll [794624] =>.Microsoft Corporation
O83 - Search Svchost Services: IKEEXT (IKEEXT) . (.Microsoft Corporation - IKE extension.) -- C:\Windows\System32\IKEEXT.DLL [863232] =>.Microsoft Corporation
O83 - Search Svchost Services: AudioSrv (AudioSrv) . (.Microsoft Corporation - Windows Audio Service.) -- C:\Windows\System32\audiosrv.dll [680448] =>.Microsoft Corporation
O83 - Search Svchost Services: Rasauto (Rasauto) . (.Microsoft Corporation - Remote Access AutoDial Manager.) -- C:\Windows\System32\rasauto.dll [99328] =>.Microsoft Corporation
O83 - Search Svchost Services: Rasman (Rasman) . (.Microsoft Corporation - Remote Access Connection Manager.) -- C:\Windows\System32\rasmans.dll [344064] =>.Microsoft Corporation
O83 - Search Svchost Services: Remoteaccess (Remoteaccess) . (.Microsoft Corporation - Dynamic Interface Manager.) -- C:\Windows\System32\mprdim.dll [97792] =>.Microsoft Corporation
O83 - Search Svchost Services: SENS (SENS) . (.Microsoft Corporation - System Event Notification Service (SENS).) -- C:\Windows\System32\Sens.dll [64512] =>.Microsoft Corporation
O83 - Search Svchost Services: Sharedaccess (Sharedaccess) . (.Microsoft Corporation - Microsoft NAT Helper Components.) -- C:\Windows\System32\ipnathlp.dll [359424] =>.Microsoft Corporation
O83 - Search Svchost Services: Tapisrv (Tapisrv) . (.Microsoft Corporation - Microsoft® Windows(TM) Telephony Server.) -- C:\Windows\System32\tapisrv.dll [316928] =>.Microsoft Corporation
O83 - Search Svchost Services: TermService (TermService) . (.Microsoft Corporation - Remote Desktop Session Host Server Remote C.) -- C:\Windows\System32\termsrv.dll [683520] =>.Microsoft Corporation
O83 - Search Svchost Services: wuauserv (wuauserv) . (.Microsoft Corporation - Windows Update Agent.) -- C:\Windows\System32\wuaueng.dll [2651648] =>.Microsoft Corporation
O83 - Search Svchost Services: BITS (BITS) . (.Microsoft Corporation - Background Intelligent Transfer Service.) -- C:\Windows\System32\qmgr.dll [849920] =>.Microsoft Corporation
O83 - Search Svchost Services: ShellHWDetection (ShellHWDetection) . (.Microsoft Corporation - Windows Shell Services Dll.) -- C:\Windows\System32\shsvcs.dll [370688] =>.Microsoft Corporation
O83 - Search Svchost Services: iphlpsvc (iphlpsvc) . (.Microsoft Corporation - Service that offers IPv6 connectivity over.) -- C:\Windows\System32\iphlpsvc.dll [569344] =>.Microsoft Corporation
O83 - Search Svchost Services: seclogon (seclogon) . (.Microsoft Corporation - Secondary Logon Service DLL.) -- C:\Windows\System32\seclogon.dll [30720] =>.Microsoft Corporation
O83 - Search Svchost Services: AppInfo (AppInfo) . (.Microsoft Corporation - Application Information Service.) -- C:\Windows\System32\appinfo.dll [70144] =>.Microsoft Corporation
O83 - Search Svchost Services: msiscsi (msiscsi) . (.Microsoft Corporation - iSCSI Discovery service.) -- C:\Windows\System32\iscsiexe.dll [156672] =>.Microsoft Corporation
O83 - Search Svchost Services: MMCSS (MMCSS) . (.Microsoft Corporation - Multimedia Class Scheduler Service.) -- C:\Windows\System32\mmcss.dll [67584] =>.Microsoft Corporation
O83 - Search Svchost Services: winmgmt (winmgmt) . (.Microsoft Corporation - WMI.) -- C:\Windows\System32\wbem\WMIsvc.dll [242688] =>.Microsoft Corporation
O83 - Search Svchost Services: SessionEnv (SessionEnv) . (.Microsoft Corporation - Remote Desktop Configuration service.) -- C:\Windows\System32\SessEnv.dll [121856] =>.Microsoft Corporation
O83 - Search Svchost Services: browser (browser) . (.Microsoft Corporation - Computer Browser Service DLL.) -- C:\Windows\System32\browser.dll [136704] =>.Microsoft Corporation
O83 - Search Svchost Services: EapHost (EapHost) . (.Microsoft Corporation - Microsoft EAPHost service.) -- C:\Windows\System32\eapsvc.dll [111104] =>.Microsoft Corporation
O83 - Search Svchost Services: schedule (schedule) . (.Microsoft Corporation - Task Scheduler Service.) -- C:\Windows\System32\schedsvc.dll [1110528] =>.Microsoft Corporation
O83 - Search Svchost Services: hkmsvc (hkmsvc) . (.Microsoft Corporation - Key Management Service.) -- C:\Windows\System32\KMSVC.DLL [90624] =>.Microsoft Corporation
O83 - Search Svchost Services: wercplsupport (wercplsupport) . (.Microsoft Corporation - Problem Reports and Solutions.) -- C:\Windows\System32\wercplsupport.dll [84480] =>.Microsoft Corporation
O83 - Search Svchost Services: ProfSvc (ProfSvc) . (.Microsoft Corporation - ProfSvc.) -- C:\Windows\System32\profsvc.dll [210432] =>.Microsoft Corporation
O83 - Search Svchost Services: Themes (Themes) . (.Microsoft Corporation - Windows Shell Theme Service Dll.) -- C:\Windows\System32\themeservice.dll [44544] =>.Microsoft Corporation
O83 - Search Svchost Services: BDESVC (BDESVC) . (.Microsoft Corporation - BDE Service.) -- C:\Windows\System32\bdesvc.dll [100864] =>.Microsoft Corporation
---\ Firewall Active Exception List (110) - 13s
O87 - FAEL: '{204523DB-ECE5-44DC-B20E-D3771411D969}' [In-None-P6-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{330531C7-7EB7-44DE-AD00-514D78DA6082}' [In-None-P17-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{63685001-A660-4C55-8040-0928EA485E33}' [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Battle.net\Battle.net.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{B7E226B4-6E16-418E-AC44-9B0AC8E8D4D4}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Battle.net\Battle.net.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{38F8CFA0-49DB-406D-9694-1CBC18050ABB}' [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Diablo III\Diablo III.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{80E28519-0F39-4094-9E80-3EE1B31AE91A}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Diablo III\Diablo III.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{24D88DBA-DAE1-403D-B1EE-05D1A475F557}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Contagion\contagion.exe =>.Steam Games
O87 - FAEL: '{3DF5206E-E507-49B2-BE42-CAFE4FF0CDA3}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Contagion\contagion.exe =>.Steam Games
O87 - FAEL: '{4EB98C22-831F-4E5B-ABE0-3CF831D15A7B}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Contagion\contagionds.exe =>.Steam Games
O87 - FAEL: '{43488864-C1CA-45F0-92F0-897DB8C09F8E}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Contagion\contagionds.exe =>.Steam Games
O87 - FAEL: '{0E00EAD6-01A4-4E93-AC69-F13B368C5EB6}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe =>.Steam Games
O87 - FAEL: '{CC602AB4-6FD1-4C6D-AEAF-E6B009BCB548}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe =>.Steam Games
O87 - FAEL: '{166DF566-73F7-4A12-9076-628C9B2A7892}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe =>.Steam Games
O87 - FAEL: '{8B27EBE7-7A8B-4778-8FDB-5BF49FBE9713}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe =>.Steam Games
O87 - FAEL: '{78308042-0E31-4ED6-B88C-C09515035626}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe =>.Steam Games
O87 - FAEL: '{7E3962FB-BFD4-47EE-834C-AA04D89B7F72}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe =>.Steam Games
O87 - FAEL: '{B9925F77-8800-4202-A56C-B7CAE9CEDC4F}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe (.not file.) =>.Steam Games
O87 - FAEL: '{D274E088-584D-4780-9F2F-7E1D3C64B03D}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe (.not file.) =>.Steam Games
O87 - FAEL: '{08BE82A2-AA6B-4C05-B536-1F1AB306B4BF}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Space Hulk\game.exe =>.Steam Games
O87 - FAEL: '{8B944443-1DA5-4843-8C70-BD83454D7982}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Space Hulk\game.exe =>.Steam Games
O87 - FAEL: '{27271B2F-654F-454D-88EC-93BBA61961FF}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Gone Home\GoneHome.exe =>.Steam Games
O87 - FAEL: '{C4719301-7D23-4C64-8C5C-67B214096824}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Gone Home\GoneHome.exe =>.Steam Games
O87 - FAEL: '{BC19AAA4-BD6A-4287-AAEB-582E91BBBC24}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe =>.Steam Games
O87 - FAEL: '{DF4C3EBF-B2FE-4B10-B6A7-B05A88FB1D78}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe =>.Steam Games
O87 - FAEL: '{D5DDBB79-FDAA-409B-9320-C5E81745EEBA}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe =>.Steam Games
O87 - FAEL: '{68EE5B9F-35D3-4991-B2C9-6C63B5B79271}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe =>.Steam Games
O87 - FAEL: '{7BA5C408-A6B7-4A0D-B958-6909A370F7D5}' [In-None-P6-TRUE] .(...) -- E:\Steam\bin\steamwebhelper.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{1D7AEC08-A5E3-46AF-99F5-5E0AB2DFE371}' [In-None-P17-TRUE] .(...) -- E:\Steam\bin\steamwebhelper.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: 'TCP Query User{10423A7B-48E4-4122-B9A5-83695CB09768}C:\programdata\battle.net\agent\agent.3286\agent.exe' [In-None-P6-TRUE] .(...) -- C:\programdata\battle.net\agent\agent.3286\agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: 'UDP Query User{14DBE92F-6882-44C2-8991-27D4103C46E8}C:\programdata\battle.net\agent\agent.3286\agent.exe' [In-None-P17-TRUE] .(...) -- C:\programdata\battle.net\agent\agent.3286\agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{026C99E0-AEDE-4421-AF5D-D82CF1FD3F89}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{73AF861C-ECE4-4378-9923-1A41B1E95E86}' [In-None-P6-TRUE] .(.2K Marin, Inc. - The Bureau: XD.) -- E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe =>.Steam SteamApps Games
O87 - FAEL: '{73B704C1-3302-409E-AE26-3B17C1125ED8}' [In-None-P17-TRUE] .(.2K Marin, Inc. - The Bureau: XD.) -- E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe =>.Steam SteamApps Games
O87 - FAEL: '{98413589-2324-4D4B-A50E-84170B3414E5}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe (.not file.) =>.Steam Games
O87 - FAEL: '{26CEFF01-D9CB-4A95-B7C4-E0E3F7568B7B}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe (.not file.) =>.Steam Games
O87 - FAEL: '{01921918-583B-454B-9B53-626571D91F6A}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe =>.Steam Games
O87 - FAEL: '{057CBD5D-8121-4948-8EA8-F65C23D41C85}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe =>.Steam Games
O87 - FAEL: '{03CFE2B1-2F61-4DE0-8CF1-B5E197BBD818}' [In-None-P6-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{C20C8FCC-DA76-48B0-AE56-D465BFEA9B3D}' [In-None-P17-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{A2D38890-4450-4E81-911C-7B55B674F0F0}' [In-None-P6-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{AA898690-1D7D-453F-8600-571011E0BA10}' [In-None-P17-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{91019C81-FB01-47CD-8071-3E378E27004C}' [In-None-P6-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{63267EAA-A94A-46DE-A618-59616BA1200F}' [In-None-P17-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{3CED9BD6-5ABB-4C32-90B1-EA5E0BCF2E80}' [In-None-P6-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{51016FD8-C288-4F8B-9B17-B14349B2DC09}' [In-None-P17-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{AE09238B-E8AA-47B1-BD42-6E259B359250}' [In-None-P6-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{A3026DF8-AC67-4C99-8BA0-B5C9D89D95F6}' [In-None-P17-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{7957AA71-D52F-49C5-B66F-FE76025F8ECE}' [In-None-P6-TRUE] .(.WB Games Inc. - The Lord of the Rings: War in the North.) -- E:\Steam\SteamApps\common\War in the North\witn.exe =>.Steam SteamApps Games
O87 - FAEL: '{F2D21545-57C1-46B8-87C8-25786A475453}' [In-None-P17-TRUE] .(.WB Games Inc. - The Lord of the Rings: War in the North.) -- E:\Steam\SteamApps\common\War in the North\witn.exe =>.Steam SteamApps Games
O87 - FAEL: '{A34BE1AD-8AC9-4A26-8FB8-E7B7C98FE65A}' [In-None-P6-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{C26C8727-4F31-47B7-B5E8-3009CDF977FC}' [In-None-P17-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{119CAE3D-9CDB-4F91-9E20-640D9F4E8D0E}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe (.not file.) =>.Steam Games
O87 - FAEL: '{6DCC1704-C9FB-4B54-80B5-9DAE36323672}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe (.not file.) =>.Steam Games
O87 - FAEL: '{29243C02-9E73-4D45-9526-2DA5F92502F1}' [In-None-P6-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{62EB6B6B-5B43-466E-B0C7-E9089C496A21}' [In-None-P17-TRUE] .(...) -- C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{8AA555D4-C388-4AA4-88EB-44A5D4224E91}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe =>.Steam Games
O87 - FAEL: '{FE33F4D6-D576-4F5D-90D0-6B837F96C7BE}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe =>.Steam Games
O87 - FAEL: '{A58B33D0-BC26-4F9A-B49B-A62BA65F28DC}' [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Raptr\raptr.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{5FBC2EAD-17E4-43A7-8F7D-8500F5312811}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Raptr\raptr.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{6F3E6FA2-07C8-4B80-9EE6-1AFCB424E090}' [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Raptr\raptr_im.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{F62EB103-89ED-44A6-89EC-213AFA4C97A7}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Raptr\raptr_im.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{5E7D5DD7-BBB2-4272-ABE0-A3E568382D62}' [In-None-P6-TRUE] .(.Nordic Games - Nexus Launcher.) -- E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe =>.Steam SteamApps Games
O87 - FAEL: '{C7E1F2F3-B957-45EE-8CF5-7D50BA0CA1FB}' [In-None-P17-TRUE] .(.Nordic Games - Nexus Launcher.) -- E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe =>.Steam SteamApps Games
O87 - FAEL: '{7635C5A1-2355-4BC2-BC2F-2AC35A81C8D2}' [In-None-P6-TRUE] .(.Nordic Games - Nexus: The Jupiter Incident.) -- E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe =>.Steam SteamApps Games
O87 - FAEL: '{58F44C40-4B7E-480C-8A6A-7D7C37F441D4}' [In-None-P17-TRUE] .(.Nordic Games - Nexus: The Jupiter Incident.) -- E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe =>.Steam SteamApps Games
O87 - FAEL: '{5347DEF1-74FA-4EC6-A7E6-17BDC2FC5FF6}' [In-None-P6-TRUE] .(.Nordic Games - Nexus Modifiation Tools Launcher.) -- E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe =>.Steam SteamApps Games
O87 - FAEL: '{000F2CCF-9014-4F19-A19C-76CC9F1DF342}' [In-None-P17-TRUE] .(.Nordic Games - Nexus Modifiation Tools Launcher.) -- E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe =>.Steam SteamApps Games
O87 - FAEL: '{C1FCAE84-E209-47FB-BEF4-D2C2DFF576B2}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe (.not file.) =>.Steam Games
O87 - FAEL: '{A271C9FB-E76F-4B5C-903C-E0FB304F9711}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe (.not file.) =>.Steam Games
O87 - FAEL: '{0A8BAFE6-AFFD-405F-A03A-AC8A9BAE5DAC}' [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{6DCA5260-67C8-4CF6-BCF4-FCE9708263A2}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{E50A44FE-6182-4951-BFA2-81547DAC95FB}' [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{BB36AF9E-3A2D-4FA8-B9E2-8CDE4A028A51}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: 'TCP Query User{B0BFEBD8-F610-49C8-A210-50C2B83F441C}C:\program files (x86)\counterpath\bria stretto\briastretto.exe' [In-None-P6-TRUE] .(...) -- C:\program files (x86)\counterpath\bria stretto\briastretto.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: 'UDP Query User{0E70B7F9-D2D7-436E-917F-BED0D00C5BC4}C:\program files (x86)\counterpath\bria stretto\briastretto.exe' [In-None-P17-TRUE] .(...) -- C:\program files (x86)\counterpath\bria stretto\briastretto.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{64DE038F-4711-46BF-AB83-1154D7BE463B}' [In-None-P6-TRUE] .(...) -- C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{CB6E88B3-9C3E-44A3-B272-A87AA4C64790}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{9CE7EE83-0607-4154-B0E4-6081BC2593D3}' [In-None-P6-TRUE] .(.Marmalade Technologies Ltd - s3e application launcher.) -- E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe =>.Steam SteamApps Games
O87 - FAEL: '{6167C9A7-0E89-41D1-8E93-589B845E6CEF}' [In-None-P17-TRUE] .(.Marmalade Technologies Ltd - s3e application launcher.) -- E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe =>.Steam SteamApps Games
O87 - FAEL: '{A6E0B9D7-46DA-4BA3-9CB0-16C9B2270BD5}' [In-None-P6-TRUE] .(.Vivendi Universal Games - Sierra Launcher.) -- E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe =>.Steam SteamApps Games
O87 - FAEL: '{26720516-0FB3-463D-BDAA-5733C2933D0D}' [In-None-P17-TRUE] .(.Vivendi Universal Games - Sierra Launcher.) -- E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe =>.Steam SteamApps Games
O87 - FAEL: '{6F279A62-3CEE-4CAD-A4C5-CADB9DD11C89}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe {5F11DE21CBDC4A392F6EDDCD1F11530A} =>.Steam Games
O87 - FAEL: '{2A4C5138-1794-4E90-A5B1-A4C07FA5888F}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe {5F11DE21CBDC4A392F6EDDCD1F11530A} =>.Steam Games
O87 - FAEL: '{BFFAD919-52EE-4E03-85E7-22EB6DFE0899}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe =>.Steam Games
O87 - FAEL: '{94B611A9-8B99-4B9C-A6A5-4C2A605169E9}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe =>.Steam Games
O87 - FAEL: '{F4036343-5049-4EF3-B40D-CE3E536CD910}' [In-None-P6-TRUE] .(.DoubleBear Productions, Iron Tower Studio - Dead State binary.) -- E:\Steam\SteamApps\common\Dead State\ZRPG.exe =>.Steam SteamApps Games
O87 - FAEL: '{F17D2244-7DB6-4B8D-B298-084E4E6F24AE}' [In-None-P17-TRUE] .(.DoubleBear Productions, Iron Tower Studio - Dead State binary.) -- E:\Steam\SteamApps\common\Dead State\ZRPG.exe =>.Steam SteamApps Games
O87 - FAEL: '{85F311B7-E6CE-4BDB-B341-A7AFC9D75998}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\TheRoom\TheRoom.exe =>.Steam Games
O87 - FAEL: '{DBDC55A0-7379-4A03-A92B-90509ABDB7D6}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\TheRoom\TheRoom.exe =>.Steam Games
O87 - FAEL: '{B5A37BCD-94D4-4628-9CCA-DDE263B65E3C}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe =>.Steam Games
O87 - FAEL: '{EE680A25-86FB-4157-95B7-203F2C0A592D}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe =>.Steam Games
O87 - FAEL: 'TCP Query User{D5BA13C4-8EB3-42D4-B2CA-22A2A3BE7E2A}E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe' [In-None-P6-TRUE] .(...) -- E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: 'UDP Query User{41B28AE0-48B6-43CB-9F80-D48CBB086CD0}E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe' [In-None-P17-TRUE] .(...) -- E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{C48A36A6-4A14-4FE4-A7FF-CB73E4875A37}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe =>.Steam Games
O87 - FAEL: '{2FF4AB51-0353-47A0-A61D-68A2FA9D37BD}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe =>.Steam Games
O87 - FAEL: '{B9718C95-EFD7-467B-A932-1739913F4A5F}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE (.not file.) =>.Steam Games
O87 - FAEL: '{DF60188E-22FC-49D7-AC10-8185B59A6E5E}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE (.not file.) =>.Steam Games
O87 - FAEL: '{B3EAB2B3-0930-4FD9-8374-8E0C22DB0010}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe {00C3FE2E759A70BEB4} =>.Steam SteamApps Games
O87 - FAEL: '{3B016CC3-F3CB-49B0-96E7-E6F035C1483E}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe {00C3FE2E759A70BEB4} =>.Steam SteamApps Games
O87 - FAEL: '{3DF33BBF-5A10-4282-AC43-0A4CE629AFA7}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe =>.Steam Games
O87 - FAEL: '{DD950824-0E60-44D1-B0A2-F0754C156B84}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe =>.Steam Games
O87 - FAEL: '{503DAAC1-EDBD-4B77-A7F2-E91E6C69D5B7}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\The Forest\TheForest.exe =>.Steam Games
O87 - FAEL: '{6A76B832-9950-41BB-97ED-A4581D14E6BC}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\The Forest\TheForest.exe =>.Steam Games
O87 - FAEL: '{AD8DFFEA-1DC6-4D07-AA54-6D91ED2B2046}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe =>.Steam Games
O87 - FAEL: '{D2D3334E-F0B0-4A58-A151-0B64D6C34608}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe =>.Steam Games
O87 - FAEL: '{3F1B4BE2-16E1-401A-ABB0-C2DB65865152}' [In-None-P6-TRUE] .(...) -- E:\Steam\SteamApps\common\Firewatch\Firewatch.exe =>.Steam Games
O87 - FAEL: '{CF807903-A7B7-4B6C-8D20-ADF4A496D9C9}' [In-None-P17-TRUE] .(...) -- E:\Steam\SteamApps\common\Firewatch\Firewatch.exe =>.Steam Games
O87 - FAEL: '{379F9EF1-959D-45B9-9175-A32EE4E39161}' [In-None-P17-TRUE] .(...) -- C:\Program Files (x86)\BlueStacks\HD-Plus-Service.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{E45E0E9B-ED52-4C49-A70F-75A27CD504DB}' [In-None-P6-TRUE] .(...) -- C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe (.not file.) =>.SUP.Orphan
O87 - FAEL: '{FF92BA05-DAFB-4969-84E0-7B1664C1F369}' [In-None-P17-TRUE] .(...) -- C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe (.not file.) =>.SUP.Orphan
---\ Product Upgrade Codes (3) - 0s
O90 - PUC: '166F59DC4C5A5F446AAACEDD192C14D0' [HKLM] . (.WinZip 21.0.)
O90 - PUC: '18D1389900DECE2E207F2C91D781459C' [HKLM] . (.Performance Profile Client.) -- C:\Windows\Installer\{99831D81-ED00-E2EC-02F7-C2197D1854C9}\ARPPRODUCTICON.exe
O90 - PUC: 'F936861C01858CE41B8E2015AAA877C1' [HKLM] . (.File Association Helper.) -- C:\Windows\Installer\{C168639F-5810-4EC8-B1E8-0251AA8A771C}\icon.ico
---\ Windows Installer Scan (54) - 15s
[MD5.00C0C5627BF8CD5FEDB9CEF7E6E683CA] [WIS][2014/06/01 14:24:01] (.Asmedia Technology - Asmedia ASM104x USB 3.0 Host Controller Dri.) -- C:\Windows\Installer\14b18.msi [5131776] =>.Asmedia Technology
[MD5.76C0E820D9E682471F52F6F96D0DA815] [WIS][2018/02/05 15:05:22] (.Advanced Micro Devices, Inc. - AMD Settings.) -- C:\Windows\Installer\1dea34.msi [32987136] =>.Advanced Micro Devices, Inc.
[MD5.992F648B09250355C6305CDCF4477720] [WIS][2018/02/05 15:13:28] (.Advanced Micro Devices, Inc. - AMD Settings.) -- C:\Windows\Installer\1dea3b.msi [63963136] =>.Advanced Micro Devices, Inc.
[MD5.78D613766452D263BB538DB7C1BE111D] [WIS][2017/09/13 06:43:16] (.Advanced Micro Devices, Inc. - Branding.) -- C:\Windows\Installer\1dea41.msi [2674176] =>.Advanced Micro Devices, Inc.
[MD5.CB3EC1B6AD16D7EE40E9CC73D4D06274] [WIS][2018/02/05 15:02:52] (.Advanced Micro Devices, Inc. - AMD Problem Report Wizard (64 bit).) -- C:\Windows\Installer\1dea48.msi [6907392] =>.Advanced Micro Devices, Inc.
[MD5.4753ABEA9FC6A2FA45A2484C10EFCBAB] [WIS][2017/07/17 12:00:52] (.Copyright (c) 1991-2016 VAPC (Lux) S.a.r.L. All rights reserved. - WinZip Compression Utility.) -- C:\Windows\Installer\2f8e7c.msi [77549568]
[MD5.D0B60B6BA91A9EDDBF928A25DEE17D31] [WIS][2014/09/26 12:05:39] (.Oracle - Java SE Runtime Environment 7.0.) -- C:\Windows\Installer\344fc0c4.msi [25695744] =>.Oracle
[MD5.73EA2B309A0495D7981FFB10F9CEF6D6] [WIS][2014/09/26 12:06:22] (.The J2SE Runtime Environment with European languages. This requires [Core]MB on your hard drive. - Additional Font and Media Support.) -- C:\Windows\Installer\344fc0ca.msi [159232]
[MD5.F0EE2E7F283866A2A0FEA9BE2D12A979] [WIS][2017/11/14 11:38:04] (.Google Inc. - Google Update Helper.) -- C:\Windows\Installer\46ce492.msi [40960] =>.Google Inc.
[MD5.7F9BBDB60B98B6AB6A09446AFADA65CB] [WIS][2018/02/27 20:26:32] (.Adobe Systems Incorporated - Adobe ARM Installer.) -- C:\Windows\Installer\574412d.msi [884736] =>.Adobe Systems Incorporated
[MD5.1B8CF0A4397F21E0098C841D8AF326B2] [WIS][2014/02/06 20:39:12] (.WinZip Computing International, LLC - FAH.) -- C:\Windows\Installer\5b5bbcbe.msi [2154496] =>.WinZip Computing International, LLC
[MD5.C8AE92CC4A184E8F368B5EDD8ACB65DE] [WIS][2012/09/26 19:34:20] (.Logitech - LWS Help_main.) -- C:\Windows\Installer\63e018.msi [1691648] =>.Logitech
[MD5.A664C0BF6CD02C194E2F93B173EFAB99] [WIS][2012/09/13 03:41:18] (.Logitech - LWS Webcam Software.) -- C:\Windows\Installer\63e01e.msi [12635648] =>.Logitech
[MD5.9936EC725C156F51806D40A1EEB9C303] [WIS][2012/09/13 03:41:16] (.Logitech - CameraHelperMsi.) -- C:\Windows\Installer\63e024.msi [734720] =>.Logitech
[MD5.77DA1CE3C93828E7EADDFCA901B02509] [WIS][2012/09/26 19:46:08] (.Logitech, Inc. - Logitech eReg 1.12 merge module-to-MSI conv.) -- C:\Windows\Installer\63e02a.msi [889344] =>.Logitech, Inc.
[MD5.7FF38CF9D5CC70E556BB45F21588B9C8] [WIS][2012/07/23 18:15:18] (.Logitech - LWS Facebook.) -- C:\Windows\Installer\63e030.msi [487936] =>.Logitech
[MD5.C99CBE7F8073112543FBCABFF867425A] [WIS][2012/09/26 18:19:08] (.Logitech - LWS Gallery.) -- C:\Windows\Installer\63e036.msi [1406976] =>.Logitech
[MD5.9CD4095CC64D5AF82868E44AA925B272] [WIS][2012/09/26 19:36:58] (.Logitech - LWS Launcher.) -- C:\Windows\Installer\63e03c.msi [1686528] =>.Logitech
[MD5.7D6A576EB4F0A6153EDF3DDD8AF0DBF3] [WIS][2012/09/13 03:41:12] (.Logitech - LWS Motion Detection.) -- C:\Windows\Installer\63e042.msi [4755456] =>.Logitech
[MD5.D1D7DE61C671118600B2C6A944071F55] [WIS][2012/09/13 03:41:22] (.Logitech - LWS Pictures And Video.) -- C:\Windows\Installer\63e048.msi [4807680] =>.Logitech
[MD5.E5B88BEDB15EFA1DE3A295C2A3F73875] [WIS][2011/07/26 22:51:16] (.Logitech - LWS Twitter.) -- C:\Windows\Installer\63e04e.msi [468992] =>.Logitech
[MD5.3405E6FB3D2484BBEE16CBF5DD7A9CD6] [WIS][2011/06/12 23:26:48] (.Logitech - LWS WLM Plugin.) -- C:\Windows\Installer\63e054.msi [119296] =>.Logitech
[MD5.A273D9D2C1BBB6ABCF10364331ACD926] [WIS][2011/11/11 18:14:28] (.Logitech - LWS YouTube Plugin.) -- C:\Windows\Installer\63e05a.msi [379904] =>.Logitech
[MD5.72888A4512084F0DF9B4D02EA508679F] [WIS][2014/11/14 17:39:14] (.Google Inc. - Google Update Helper.) -- C:\Windows\Installer\7cf623b.msi [26112] =>.Google Inc.
[MD5.6511A4CC7D66D57B3E558F49FFC52626] [WIS][2014/06/07 00:55:50] (.NVIDIA Corporation - Install/UnInstall PhysX Driver + Engines: 2.) -- C:\Windows\Installer\9c12053.msi [26728448] =>.NVIDIA Corporation
[MD5.AE4DA6FB3DAF68E7AEA7BB478051FF5E] [WIS][2017/09/22 21:53:24] (.Advanced Micro Devices, Inc. - Performance Profile Client.) -- C:\Windows\Installer\d3573c.msi [2525696] =>.Advanced Micro Devices, Inc.
[MD5.23B97F4BEDD554D3F629B60637AFC936] [WIS][2015/03/17 04:42:22] (.Adobe Systems Incorporated.) -- C:\Windows\Installer\d51b852.msi [2792960] =>.Adobe Systems Incorporated
[MD5.72C91237F7C7A0527FA5F0752CF81A66] [WIS][2017/01/19 06:28:55] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\1092951c.msp [1937408] =>.Adobe Systems, Incorporated
[MD5.A58EAEAA86B7D4FA1891CA2EEDDCA3DD] [WIS][2018/02/12 10:26:08] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\12179dc.msp [103362560] =>.Adobe Systems, Incorporated
[MD5.339631DF934AFC2BE35E2B27A6F7DB06] [WIS][2016/11/03 03:25:06] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\13938c21.msp [1642496] =>.SUP.Obsolete.Adobe
[MD5.65817E8993AA2B73C93E57CDECFBAECA] [WIS][2015/10/12 23:26:31] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\14528f61.msp [21102592] =>.SUP.Obsolete.Adobe
[MD5.08615067E75539285F388EF4B41D669E] [WIS][2016/01/11 23:19:17] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\190b3bb.msp [46080000] =>.SUP.Obsolete.Adobe
[MD5.E3869EFD0836C950E46B02D3CBC67184] [WIS][2017/01/08 23:41:00] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\1f96a0d8.msp [25853952] =>.Adobe Systems, Incorporated
[MD5.BD4423645209FA4CE380C43C1633F4E4] [WIS][2016/07/11 23:25:29] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\21d6ba6.msp [39538688] =>.SUP.Obsolete.Adobe
[MD5.0762EDB0E4C8D62A4328C3360BC7AD2C] [WIS][2017/07/11 00:57:12] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\23375a1.msp [1732608] =>.Adobe Systems, Incorporated
[MD5.77AB51250501ADDD4D491DECDB6121FD] [WIS][2017/08/28 12:40:46] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\24d0499.msp [2424832] =>.Adobe Systems, Incorporated
[MD5.C233BD1DB45AF8BACD0F3C0D8A646740] [WIS][2016/05/18 23:30:11] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\24d370a.msp [1429504] =>.SUP.Obsolete.Adobe
[MD5.A9095FC652E0273E10F1D9481C59067D] [WIS][2018/02/23 09:25:19] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\30ef26e.msp [1343488] =>.Adobe Systems, Incorporated
[MD5.CECF2A7991F74C858965EA972A43CE3F] [WIS][2017/04/10 01:34:32] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\4b9a530.msp [57815040] =>.Adobe Systems, Incorporated
[MD5.4D64DE5B41C39FA6192C22CBCD826FBA] [WIS][2016/10/10 03:29:03] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\88f4219.msp [36499456] =>.SUP.Obsolete.Adobe
[MD5.82F476D2A7125BB7EBF5A2A657BAB293] [WIS][2017/11/13 00:26:16] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\9bed7.msp [23506944] =>.Adobe Systems, Incorporated
[MD5.F767152C881F505C5BBAC71A825C1263] [WIS][2017/02/21 08:33:51] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\a76291.msp [12845056] =>.Adobe Systems, Incorporated
[MD5.3617A09ABC822D955214EBE86A991CF3] [WIS][2017/11/29 06:42:28] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\a9b89.msp [1355776] =>.Adobe Systems, Incorporated
[MD5.CF478CA41BB57CA934019B65FCD35FB2] [WIS][2017/08/11 06:05:31] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\b3ed2.msp [100052992] =>.Adobe Systems, Incorporated
[MD5.894FC96EAD193C8AD29C2997EF797CFD] [WIS][2015/10/14 05:40:18] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\b571ad0.msp [1224704] =>.SUP.Obsolete.Adobe
[MD5.D2315820CBF3F165769574F4F57F9D59] [WIS][2015/11/25 05:42:23] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\b90b1.msp [212992] =>.SUP.Obsolete.Adobe
[MD5.BFE991AC9BA8B9709C30ABBC85CDD6AB] [WIS][2015/10/29 03:48:45] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\bfd77.msp [1208320] =>.SUP.Obsolete.Adobe
[MD5.307FCA5A8C1EDF5A94F46095589379CE] [WIS][2016/03/07 23:45:31] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\c0556.msp [2719744] =>.SUP.Obsolete.Adobe
[MD5.F9FD1AB516C661D9938213AA661350B7] [WIS][2016/08/02 07:49:06] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\cd358c.msp [1511424] =>.SUP.Obsolete.Adobe
[MD5.50A28B22FFDE4D837B145DB7A22E94C5] [WIS][2016/05/09 23:20:29] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\cd915.msp [58986496] =>.SUP.Obsolete.Adobe
[MD5.557170C4FCC0754B372A5FC174735242] [WIS][2016/06/02 00:48:41] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\d04f9.msp [2772992] =>.SUP.Obsolete.Adobe
[MD5.5C1A7A8BB44DBD7C1773AF0FCAB08A6B] [WIS][2015/07/03 02:02:49] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\d51b853.msp [49188864] =>.SUP.Obsolete.Adobe
[MD5.E05CA6506E1D5ECE25152018D3FF00CE] [WIS][2018/05/12 02:05:37] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\ec25e2e.msp [7094272] =>.Adobe Systems, Incorporated
[MD5.25F86D2EE0FAB79D6DCA727411962C32] [WIS][2016/02/16 08:48:12] (.Adobe Systems, Incorporated.) -- C:\Windows\Installer\feeb6.msp [9687040] =>.SUP.Obsolete.Adobe
---\ Additional Scan (O88) (44) - 2s
HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} =>.SUP.Orphan
C:\ProgramData\Trymedia =>PUP.Optional.Trymedia
C:\Users\Mike\AppData\Local\SlimWare Utilities Inc =>.SUP.SlimWareUtilities
HKLM\Software\Classes\*\ShellEx\ContextMenuHandlers\WinRAR32 =>.SUP.Orphan
HKLM\Software\Classes\CLSID\{B41DB860-8EE4-11D2-9906-E49FADC173CA} =>.SUP.Orphan
HKLM\Software\Classes\Folder\ShellEx\ContextMenuHandlers\WinRAR32 =>.SUP.Orphan
C:\Windows\Installer\13938c21.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\14528f61.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\190b3bb.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\21d6ba6.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\24d370a.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\88f4219.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\b571ad0.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\b90b1.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\bfd77.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\c0556.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\cd358c.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\cd915.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\d04f9.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\d51b853.msp =>.SUP.Obsolete.Adobe
C:\Windows\Installer\feeb6.msp =>.SUP.Obsolete.Adobe
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\008 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\325 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\347 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\389 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\391 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\392 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\393 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\396 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\398 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\406 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\407 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\408 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\409 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\413 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\417 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\418 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\420 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\422 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\449 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\486 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\558 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\559 =>.SUP.Temporary.Chrome
C:\Users\Mike\AppData\Local\Google\Chrome\User Data\Default\File System\560 =>.SUP.Temporary.Chrome
---\ Summary of the elements found (6) - 0s
https://nicolascoolman.eu/2017/09/12/origine-lignes-orphelines/ =>.SUP.Orphan
https://nicolascoolman.eu/2017/10/04/adware-trymedia/ =>PUP.Optional.Trymedia
https://www.nicolascoolman.com/fr/pup-toolbarcleaner/ =>PUP.Optional.ToolbarCleaner
https://nicolascoolman.eu/2017/03/03/superfluous-slimwareutilities/ =>.SUP.SlimWareUtilities
https://nicolascoolman.eu/2017/01/20/logiciels-superflus/ =>.SUP.Obsolete.Adobe
https://nicolascoolman.eu/2017/01/20/logiciels-superflus/ =>.SUP.Temporary.Chrome
~ Unselected Options:
~ End of the scan, 8463 items in 01mn37s (1307)(0)
