Overheating Issue Resolved - Enter Yet Another Problem
Yes. Please refer to my last post outlining new problems that have arisen. Toolkit and hijackthis results posted as requested.
Latest issues summarization:
BSOD - Has returned in force. I am experiencing 3 - 5 of these per every 30 - 90 minute gaming session. This has been a constant problem that was resolved previously for several months but has inexplicably returned. There have been no new programs installed that would facilitate this issue.
Massive Windows Lag - the computer is now completely incapable of running more than one program at once. It is not limited to Chrome as previously thought. IE, Chrome, and ANY other type of program open at the same time as a game causes crushing lag on the computer. Previously, I could have run a resource intensive game (such as Warcraft) and have Chrome open with a dozen or more tabs open at once. Now, the computer cannot handle more than one program of any type being open simultaneously. Doing so causes massive game lag and application lag. It can take anywhere from 5 to 20 minutes for a webpage to load. This is a brand new problem.
Windows Explorer Failures - another brand new problem. Programs are crashing left and right. Windows is also not responding to Ctrl+alt+delete command to open System Tasks. It takes dozens upon dozens of attempts to call up Task Manager.
This computer has gotten to the point of being completely unusable despite the previously suggested steps. This has become a critical situation.
Attached.
Frustratingly, it seems that the dump files are only saving selectively - I have only 3 logs spaced about a week apart each.
The message I get for each BSOD is "IRQL_NOT_LESS_OR_EQUAL" which is indicative of a memory issue. Given the fact that the computer cannot handle more than 1 task at a time, this is not surprising.
Can you please remove Norton then run the removal tool,then reboot your machine, And start the machine under aclean boot.
This worked briefly. I was able to run Chrome while having a game open simultaneously. However, within 20 minutes system-wide slowdown began. When trying to close out of Chrome, it took over 10 minutes after clicking the X before the window actually shut, during which time the computer slowed to a crawl.
Ok, lets just try and full remove Norton for the moment, then Please post a fresh hijack this log, we will work from there. Also, while you wait, please run a check disk on the machine,.
Run chkdsk /f /r from elevated command prompt.
Any updates for us?
Sorry for the delay. Update coming tomorrow. BSOD has once again returned with such frequency that regular gameplay has become completely impossible. Absolutely cannot figure out why this keeps happening.
I'm getting to the point where I may decide to just junk (i.e. disassemble and smash to pieces every single internal component out of anger) the whole rig and start saving up for another one.
PC Hunter Scan!
Download PCHunter
Disable your antivirus prior to this scan!!
Unzip the program to your desktop.
You will need to run the version that is compatible with your windows.
Right click either the 64 or 32 bit version and Run as Administrator.
After the program starts, go to the Examination Tab.
Click it once -- Look at the bottom and check mark Hide Safe Items.
Then click Generate Examination Report.
Allow 5 to 10 minutes for the program to generate the report.
Once complete you will be able to click the Export Examination Report button.
Save it where you like and name it what you like.
Then copy the entire report, and paste it here in your next reply.
Also, lets dig into the BSOD issue....
Sysnative Tool.
1. Download the Sysnative BSOD Dump + System File Collection App - save to Documents folder -
2. Run the app - Double-click on the downloaded EXE file
Output = new folder created in Documents + a zipped version -- SysnativeFileCollectionApp + SysnativeFileCollectionApp.zip
Here we go. Incoming wall of text.
@Malnutrition @vger
Chkdsk results:
Checking file system on C:
The type of the file system is NTFS.
A disk check has been scheduled.
Windows will now check the disk.
CHKDSK is verifying files (stage 1 of 5)...
357120 file records processed. File verification completed.
1795 large file records processed. 0 bad file records processed. 0 EA records processed. 60 reparse records processed. CHKDSK is verifying indexes (stage 2 of 5)...
449972 index entries processed. Index verification completed.
0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 5)...
357120 file SDs/SIDs processed. Cleaning up 3 unused index entries from index $SII of file 0x9.
Cleaning up 3 unused index entries from index $SDH of file 0x9.
Cleaning up 3 unused security descriptors.
Security descriptor verification completed.
46427 data files processed. CHKDSK is verifying Usn Journal...
34594464 USN bytes processed. Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
357104 files processed. File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
9381763 free clusters processed. Free space verification is complete.
Windows has checked the file system and found no problems.
117115903 KB total disk space.
78999460 KB in 193915 files.
124700 KB in 46428 indexes.
0 KB in bad sectors.
464691 KB in use by the system.
65536 KB occupied by the log file.
37527052 KB available on disk.
4096 bytes in each allocation unit.
29278975 total allocation units on disk.
9381763 allocation units available on disk.
Internal Info:
00 73 05 00 e2 aa 03 00 54 cc 06 00 00 00 00 00 .s......T.......
a8 01 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 ....<...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Windows has finished checking your disk.
Please wait while your computer restarts.
I see that the chkdsk only covered volume C:\ which is were Windows is located. Volume E:\ is where the greater majority of my files (games, etc.) are located. Should I do another?
PCHunter Scan
PC Hunter Standard --- Computer Examination Report
Examination Date: 2018-03-08 14:55
OS Information: Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
Internet Explorer: 9.11.9600.18920
Examination Items:
Process
Process Modules
Process Threads
Kernel Module
Notify Routine
Filter
DPC Timer
Worker Thread
HalDispatchTable
HalPrivateDispatchTable
HalAcpiDispatchTable
Wdf01000 Dispatch Fun
WdfFunction
MiniFilter
File System
Sfilter FileSystem Filter Callback
ClassInitData Callback
Npfs Dispatch Fun
Msfs Dispatch Fun
Usbport Dispatch Fun
System Debug
Object Hijack
Direct IO
GDT
SSDT
Shadow SSDT
FSD
Keyboard
I8042prt
Mouclass
Partmgr
Classpnp
Atapi
Acpi
Scsi
Kernel Hook
PTE HOOK
Object Type
IDT
Message Hook
Process Hook
KernelCallbackTable
Port
Tcpip
Nsiproxy
Tdx
Ndis Handler
IE Plugin
IE Shell
Spi
Hosts File
Startup
Service
Schedule Task
File Association
IFEO
IME/CTF
Firewall Rule
System User Name
Scan MBR Rootkit
Process
Process Modules
Process Threads
Kernel Module
amd_sata.sys - C:\Windows\system32\DRIVERS\amd_sata.sys - Advanced Micro Devices
amd_xata.sys - C:\Windows\system32\DRIVERS\amd_xata.sys - Advanced Micro Devices
amdxata.sys - C:\Windows\system32\drivers\amdxata.sys - Advanced Micro Devices
atikmpag.sys - C:\Windows\system32\DRIVERS\atikmpag.sys - Advanced Micro Devices, Inc.
atikmdag.sys - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
Rt64win7.sys - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
asmtxhci.sys - C:\Windows\system32\DRIVERS\asmtxhci.sys - ASMedia Technology Inc
usbfilter.sys - C:\Windows\system32\DRIVERS\usbfilter.sys - Advanced Micro Devices
LGBusEnum.sys - C:\Windows\system32\drivers\LGBusEnum.sys - Logitech Inc.
LGJoyXlCore.sys - C:\Windows\system32\drivers\LGJoyXlCore.sys - Logitech Inc.
AtihdW76.sys - C:\Windows\system32\drivers\AtihdW76.sys - Advanced Micro Devices
RTKVHD64.sys - C:\Windows\system32\drivers\RTKVHD64.sys - Realtek Semiconductor Corp.
asmthub3.sys - C:\Windows\system32\DRIVERS\asmthub3.sys - ASMedia Technology Inc
BrUsbSIb.sys - C:\Windows\system32\DRIVERS\BrUsbSIb.sys - Brother Industries Ltd.
BrSerIb.sys - C:\Windows\system32\DRIVERS\BrSerIb.sys - Brother Industries Ltd.
dump_diskdump.sys - C:\Windows\System32\Drivers\dump_diskdump.sys - File not found
dump_amd_sata.sys - C:\Windows\System32\Drivers\dump_amd_sata.sys - File not found
dump_dumpfve.sys - C:\Windows\System32\Drivers\dump_dumpfve.sys - File not found
LGSHidFilt.Sys - C:\Windows\system32\DRIVERS\LGSHidFilt.Sys - Logitech Inc.
lgcoretemp.sys - C:\Program Files\Logitech Gaming Software\Drivers\LgCoreTemp\lgcoretemp.sys - Logitech
speedfan.sys - C:\Windows\SysWOW64\speedfan.sys - Almico Software
PCHunter64ao.sys - C:\Users\Mike\AppData\Local\Temp\Rar$EXa3912.8975\PCHunter64ao.sys - File not found
[UnloadDriver] AODDriver2.sys - C:\Program Files (x86)\AMD\Performance Profile Client\amd64\AODDriver2.sys - File not found
[UnloadDriver] AODDriver2.sys - C:\Program Files\ATI Technologies\ATI.ACE\Fuel\amd64\AODDriver2.sys - File not found
[UnloadDriver] cpuz143_x64.sys - C:\Users\Mike\AppData\Local\Temp\cpuz143\cpuz143_x64.sys - File not found
[UnloadDriver] BrSerWdm.sys - C:\Windows\System32\Drivers\BrSerWdm.sys - Brother Industries Ltd.
[UnloadDriver] BrUsbMdm.sys - C:\Windows\System32\Drivers\BrUsbMdm.sys - Brother Industries Ltd.
[UnloadDriver] BrUsbSer.sys - C:\Windows\System32\Drivers\BrUsbSer.sys - Brother Industries Ltd.
[UnloadDriver] Brserid.sys - C:\Windows\System32\Drivers\Brserid.sys - Brother Industries Ltd.
[UnloadDriver] mbamswissarmy.sys - C:\Windows\System32\Drivers\mbamswissarmy.sys - Malwarebytes
[UnloadDriver] BrFiltLo.sys - C:\Windows\system32\DRIVERS\BrFiltLo.sys - Brother Industries, Ltd.
[UnloadDriver] BrFiltUp.sys - C:\Windows\system32\DRIVERS\BrFiltUp.sys - Brother Industries, Ltd.
[UnloadDriver] MegaSR.sys - C:\Windows\system32\DRIVERS\MegaSR.sys - LSI Corporation, Inc.
[UnloadDriver] SiSRaid2.sys - C:\Windows\system32\DRIVERS\SiSRaid2.sys - Silicon Integrated Systems Corp.
[UnloadDriver] adp94xx.sys - C:\Windows\system32\DRIVERS\adp94xx.sys - Adaptec, Inc.
[UnloadDriver] adpahci.sys - C:\Windows\system32\DRIVERS\adpahci.sys - Adaptec, Inc.
[UnloadDriver] adpu320.sys - C:\Windows\system32\DRIVERS\adpu320.sys - Adaptec, Inc.
[UnloadDriver] amdsbs.sys - C:\Windows\system32\DRIVERS\amdsbs.sys - AMD Technologies Inc.
[UnloadDriver] arc.sys - C:\Windows\system32\DRIVERS\arc.sys - Adaptec, Inc.
[UnloadDriver] arcsas.sys - C:\Windows\system32\DRIVERS\arcsas.sys - Adaptec, Inc.
[UnloadDriver] b57nd60a.sys - C:\Windows\system32\DRIVERS\b57nd60a.sys - Broadcom Corporation
[UnloadDriver] bxvbda.sys - C:\Windows\system32\DRIVERS\bxvbda.sys - Broadcom Corporation
[UnloadDriver] elxstor.sys - C:\Windows\system32\DRIVERS\elxstor.sys - Emulex
[UnloadDriver] evbda.sys - C:\Windows\system32\DRIVERS\evbda.sys - Broadcom Corporation
[UnloadDriver] iirsp.sys - C:\Windows\system32\DRIVERS\iirsp.sys - Intel Corp./ICP vortex GmbH
[UnloadDriver] lsi_fc.sys - C:\Windows\system32\DRIVERS\lsi_fc.sys - LSI Corporation
[UnloadDriver] lsi_sas.sys - C:\Windows\system32\DRIVERS\lsi_sas.sys - LSI Corporation
[UnloadDriver] lsi_sas2.sys - C:\Windows\system32\DRIVERS\lsi_sas2.sys - LSI Corporation
[UnloadDriver] lsi_scsi.sys - C:\Windows\system32\DRIVERS\lsi_scsi.sys - LSI Corporation
[UnloadDriver] lvbflt64.sys - C:\Windows\system32\DRIVERS\lvbflt64.sys - Logitech Inc.
[UnloadDriver] lvrs64.sys - C:\Windows\system32\DRIVERS\lvrs64.sys - Logitech Inc.
[UnloadDriver] lvuvc64.sys - C:\Windows\system32\DRIVERS\lvuvc64.sys - Logitech Inc.
[UnloadDriver] megasas.sys - C:\Windows\system32\DRIVERS\megasas.sys - LSI Corporation
[UnloadDriver] nfrd960.sys - C:\Windows\system32\DRIVERS\nfrd960.sys - IBM Corporation
[UnloadDriver] qcusbser.sys - C:\Windows\system32\DRIVERS\qcusbser.sys - QUALCOMM Incorporated
[UnloadDriver] ql2300.sys - C:\Windows\system32\DRIVERS\ql2300.sys - QLogic Corporation
[UnloadDriver] ql40xx.sys - C:\Windows\system32\DRIVERS\ql40xx.sys - QLogic Corporation
[UnloadDriver] sisraid4.sys - C:\Windows\system32\DRIVERS\sisraid4.sys - Silicon Integrated Systems
[UnloadDriver] ssudbus.sys - C:\Windows\system32\DRIVERS\ssudbus.sys - DEVGURU Co., LTD.(www.devguru.co.kr)
[UnloadDriver] ssudmdm.sys - C:\Windows\system32\DRIVERS\ssudmdm.sys - DEVGURU Co., LTD.(www.devguru.co.kr)
[UnloadDriver] stexstor.sys - C:\Windows\system32\DRIVERS\stexstor.sys - Promise Technology
[UnloadDriver] vsmraid.sys - C:\Windows\system32\DRIVERS\vsmraid.sys - VIA Technologies Inc.,Ltd
[UnloadDriver] HpSAMD.sys - C:\Windows\system32\drivers\HpSAMD.sys - Hewlett-Packard Company
[UnloadDriver] LGVirHid.sys - C:\Windows\system32\drivers\LGVirHid.sys - Logitech Inc.
[UnloadDriver] aliide.sys - C:\Windows\system32\drivers\aliide.sys - Acer Laboratories Inc.
[UnloadDriver] amdsata.sys - C:\Windows\system32\drivers\amdsata.sys - Advanced Micro Devices
[UnloadDriver] cmdide.sys - C:\Windows\system32\drivers\cmdide.sys - CMD Technology, Inc.
[UnloadDriver] hcw85cir.sys - C:\Windows\system32\drivers\hcw85cir.sys - Hauppauge Computer Works, Inc.
[UnloadDriver] iaStorV.sys - C:\Windows\system32\drivers\iaStorV.sys - Intel Corporation
[UnloadDriver] nvraid.sys - C:\Windows\system32\drivers\nvraid.sys - NVIDIA Corporation
[UnloadDriver] nvstor.sys - C:\Windows\system32\drivers\nvstor.sys - NVIDIA Corporation
[UnloadDriver] viaide.sys - C:\Windows\system32\drivers\viaide.sys - VIA Technologies, Inc.
Notify Routine
CreateProcess - 0xFFFFF88011081740 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
BugCheckReasonCallback - 0xFFFFF88011022DA0 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
PowerSettingCallback - 0xFFFFF88011025120 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
Filter
PnpManager - \Driver\LGBusEnum->\Driver\PnpManager - 0xFFFFFA800485E520[] - C:\Windows\system32\drivers\LGBusEnum.sys - Logitech Inc.
PnpManager - \Driver\LGJoyXlCore->\Driver\LGBusEnum - 0xFFFFFA800485E2F0[] - C:\Windows\system32\drivers\LGJoyXlCore.sys - Logitech Inc.
PnpManager - \Driver\ACPI_HAL->\Driver\PnpManager - 0xFFFFFA8003CEA960[] - -
DPC Timer
Worker Thread
Nothing
HalDispatchTable
Nothing
Nothing
Nothing
Nothing
WdfFunction
Nothing
MiniFilter
Nothing
File System
Nothing
Nothing
Nothing
Npfs Dispatch Fun
Nothing
Msfs Dispatch Fun
Nothing
Nothing
System Debug
Nothing
Object Hijack
Nothing
Direct IO
GDT
Nothing
SSDT
Int2e/Sysenter Hook, The Path[int2e/sysenter to ssdt] has been Hooked: 0xFFFFF800032CF800(C:\Windows\system32\ntoskrnl.exe)
Shadow SSDT
Nothing
FSD
Nothing
Keyboard
Nothing
I8042prt
Nothing
Mouclass
Nothing
Partmgr
Nothing
Classpnp
Nothing
Atapi
Nothing
Acpi
Nothing
Scsi
Nothing
Kernel Hook
Inline - len(4) ExFreePool[ntoskrnl.exe] - [0xFFFFF800033FD010]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF800032C2BE2]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF800032C2D4B]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF800032C2F02]->[-]
Inline - len(1) [ntoskrnl.exe] - [0xFFFFF800032C306D]->[-]
PTE HOOK
Nothing
Object Type
- PowerState(0xFFFFFA8003D8F700::0xFFFFFA800485E200) - Callback_Object - 0xFFFFF880049AE448 - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
- PowerState(0xFFFFFA8003D8F700::0xFFFFFA8005667820) - Callback_Object - 0xFFFFF88005683078 - C:\Windows\system32\drivers\RTKVHD64.sys - Realtek Semiconductor Corp.
- AMD_CALLBACK_OBJ_NAME__32335CF9-4817-4644-B367-(0xFFFFFA80045828E0::0xFFFFFA80045279C0) - Callback_Object - 0xFFFFF88011F17530 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
- AMD_CALLBACK_OBJ_NAME_FOR_PROXY_INIT(0xFFFFFA800459B9D0::0xFFFFFA800467D290) - Callback_Object - 0xFFFFF880110812F0 - C:\Windows\system32\DRIVERS\atikmdag.sys - Advanced Micro Devices, Inc.
IDT
Nothing
Message Hook
Nothing
Process Hook
Nothing
KernelCallbackTable
Nothing
Port
Tcp 0.0.0.0 : 135 - 0.0.0.0 : 0 - LISTENING - 824 - C:\Windows\System32\svchost.exe
Tcp 192.168.1.156 : 139 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 554 - 0.0.0.0 : 0 - LISTENING - 2480 - C:\Program Files\Windows Media Player\wmpnetwk.exe
Tcp 192.168.1.156 : 2869 - 192.168.1.1 : 44336 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 2869 - 192.168.1.1 : 44337 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 2869 - 192.168.1.1 : 44338 - TIME_WAIT - 0 -
Tcp 0.0.0.0 : 3390 - 0.0.0.0 : 0 - LISTENING - 1116 - C:\Windows\System32\svchost.exe
Tcp 127.0.0.1 : 5357 - 127.0.0.1 : 49608 - TIME_WAIT - 0 -
Tcp 127.0.0.1 : 5357 - 127.0.0.1 : 49623 - TIME_WAIT - 0 -
Tcp 0.0.0.0 : 49152 - 0.0.0.0 : 0 - LISTENING - 504 - C:\Windows\System32\wininit.exe
Tcp 0.0.0.0 : 49153 - 0.0.0.0 : 0 - LISTENING - 140 - C:\Windows\System32\svchost.exe
Tcp 0.0.0.0 : 49154 - 0.0.0.0 : 0 - LISTENING - 472 - C:\Windows\System32\svchost.exe
Tcp 0.0.0.0 : 49155 - 0.0.0.0 : 0 - LISTENING - 564 - C:\Windows\System32\services.exe
Tcp 0.0.0.0 : 49156 - 0.0.0.0 : 0 - LISTENING - 1336 - C:\Windows\System32\spoolsv.exe
Tcp 0.0.0.0 : 49171 - 0.0.0.0 : 0 - LISTENING - 592 - C:\Windows\System32\lsass.exe
Tcp 192.168.1.156 : 49282 - 173.194.205.188 : 5228 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49284 - 172.217.7.10 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49287 - 192.168.1.101 : 9098 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49308 - 208.111.135.64 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49316 - 104.16.222.128 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49320 - 152.195.33.132 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49329 - 172.217.12.202 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49338 - 192.229.211.228 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49340 - 172.217.10.99 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49363 - 192.229.211.229 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49390 - 208.111.135.64 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49391 - 208.111.135.64 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49392 - 208.111.135.64 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49393 - 208.111.135.64 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49394 - 208.111.135.64 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49408 - 93.184.216.135 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49427 - 52.9.143.243 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49428 - 13.33.74.13 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49444 - 23.111.151.154 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49451 - 104.16.46.23 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49452 - 104.16.47.55 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49453 - 104.16.147.241 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49459 - 104.16.46.23 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49464 - 109.71.161.200 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49466 - 185.13.88.201 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49470 - 192.229.163.85 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49479 - 93.93.51.195 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49480 - 13.33.74.82 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49482 - 13.33.74.101 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49510 - 207.178.0.72 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49554 - 52.9.143.243 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49555 - 50.17.115.180 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49556 - 104.27.47.60 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49569 - 104.131.19.175 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49570 - 34.235.192.165 : 80 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49571 - 104.131.87.71 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49583 - 172.217.12.173 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49584 - 172.217.3.110 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49587 - 151.139.245.22 : 443 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49588 - 172.217.12.170 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49589 - 108.161.189.121 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49590 - 23.111.9.64 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49591 - 172.217.12.131 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49592 - 172.217.9.234 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49593 - 23.111.9.64 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49594 - 108.161.189.121 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49595 - 172.217.12.136 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49598 - 54.231.131.99 : 443 - CLOSE_WAIT - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49602 - 172.217.6.206 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49603 - 173.194.205.154 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49604 - 172.217.10.100 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49605 - 172.217.7.14 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49606 - 172.217.11.46 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49609 - 151.139.245.22 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49610 - 72.21.91.43 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49611 - 172.217.10.110 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49613 - 54.175.188.194 : 443 - CLOSE_WAIT - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49614 - 172.217.10.38 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49615 - 172.217.12.130 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49616 - 172.217.12.182 : 443 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49618 - 192.168.1.101 : 9098 - ESTABLISHED - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49619 - 69.163.162.37 : 80 - CLOSE_WAIT - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Tcp 192.168.1.156 : 49620 - 192.168.1.1 : 38266 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49621 - 192.168.1.1 : 38266 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49622 - 192.168.1.1 : 38266 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49624 - 23.32.81.34 : 80 - ESTABLISHED - 2360 - C:\Program Files\AMD\CNext\CNext\RadeonSettings.exe
Tcp 192.168.1.156 : 49625 - 23.32.81.34 : 443 - ESTABLISHED - 2360 - C:\Program Files\AMD\CNext\CNext\RadeonSettings.exe
Tcp 192.168.1.156 : 49626 - 120.133.8.191 : 80 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49627 - 104.100.94.121 : 80 - TIME_WAIT - 0 -
Tcp 192.168.1.156 : 49629 - 23.50.75.27 : 80 - ESTABLISHED - 2360 - C:\Program Files\AMD\CNext\CNext\RadeonSettings.exe
Tcp 192.168.1.156 : 49630 - 192.168.1.1 : 38266 - TIME_WAIT - 0 -
Tcp 0.0.0.0 : 445 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 2869 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 5357 - 0.0.0.0 : 0 - LISTENING - 4 - System
Tcp 0.0.0.0 : 10243 - 0.0.0.0 : 0 - LISTENING - 4 - System
Udp 192.168.1.156 : 137 - * : * - 4 - System
Udp 192.168.1.156 : 138 - * : * - 4 - System
Udp 0.0.0.0 : 500 - * : * - 472 - C:\Windows\System32\svchost.exe
Udp 127.0.0.1 : 1900 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 192.168.1.156 : 1900 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 3702 - * : * - 376 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 3702 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 4500 - * : * - 472 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 5004 - * : * - 2480 - C:\Program Files\Windows Media Player\wmpnetwk.exe
Udp 0.0.0.0 : 5005 - * : * - 2480 - C:\Program Files\Windows Media Player\wmpnetwk.exe
Udp 0.0.0.0 : 5353 - * : * - 3688 - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Udp 0.0.0.0 : 5355 - * : * - 1116 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 49583 - * : * - 376 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 58629 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 62944 - * : * - 376 - C:\Windows\System32\svchost.exe
Udp 192.168.1.156 : 64003 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 127.0.0.1 : 64004 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 1900 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 49584 - * : * - 376 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 58630 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 62945 - * : * - 376 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 64001 - * : * - 1644 - C:\Windows\System32\svchost.exe
Udp 0.0.0.0 : 64002 - * : * - 1644 - C:\Windows\System32\svchost.exe
Tcpip
Nothing
Nsiproxy
Nothing
Tdx
Nothing
Ndis Handler
0xFFFFFA80059188D0 - NdisOpenBlock - 0xFFFFF880048DED68 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80059188D0 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80059188D0 - NdisOpenBlock - 0xFFFFF88005371D98 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
0xFFFFFA80059188D0 - NdisOpenBlock - 0xFFFFF8800537197C - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
0xFFFFFA80059188D0 - NdisOpenBlock - 0xFFFFF880048DED68 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80059188D0 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80059188D0 - NdisOpenBlock - 0xFFFFF8800537178C - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\rspndr.sys - Microsoft Corporation
0xFFFFFA80059188D0 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF8800535CAAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF8800535C368 - PnPEventHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF8800535BE54 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF8800535CB50 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF8800535C350 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF8800535C2F0 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF8800535C4FC - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF8800535C908 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA800569A720 - NdisProtocolBlock - 0xFFFFF880053629D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF8800147DEF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF8800535CAAC - StatusHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF880048DED68 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF8800535C908 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF8800535C4FC - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF880048DED68 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF880053629D0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\lltdio.sys - Microsoft Corporation
0xFFFFFA80058F9330 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CCB008 - OpenAdapterCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CCB030 - CloseAdapterCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBEF00 - (Wan)SendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBEF00 - (Wan)TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBDBBC - BindAdapterHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBE2A0 - UnbindAdapterHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CCB064 - PnPEventHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBEEA4 - UnloadHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBEF0C - CoStatusHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBEFA8 - CoReceivePacketHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DB900 - NdisProtocolBlock - 0xFFFFF88002CBE80C - CoAfRegisterNotifyHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002DE1954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F9010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002DE1954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CC6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CBD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F8840 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002DC1270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6840 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002DC1270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CBD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F6010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002DA5D0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2840 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002DA5D0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CBD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F2010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88004458AF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E6010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88004458AF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CC6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CBD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1840 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF8800151AEB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF8800151B570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88001495970 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF880049E55D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF880049D9B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBD750 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - CmDeactivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBDB3C - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88001495970 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF880049E55D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF8800151AEB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF880049D9AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA840 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF8800151AEB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF8800151B570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - TransferDataCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ReceiveCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CBE7F0 - RequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88001495970 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ResetCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - StatusCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF880049E55D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF880049D9B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoCreateVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CoDeleteVcHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CC6008 - CmActivateVcCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CBD5A0 - CoRequestCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88001495970 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF880049E55D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF8800151AEB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88002CBEF00 - ProtSendCompleteHandler - C:\Windows\System32\Drivers\NDProxy.SYS - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF880049D9AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DA010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DA8AC4 - OpenAdapterCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DA9050 - CloseAdapterCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DB7F28 - (Wan)SendCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DB8778 - (Wan)TransferDataCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DA8BA4 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DB8468 - (Wan)ReceiveHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DB8904 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DA911C - StatusHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DA8B98 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DB7FF0 - ReceivePacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DA8348 - BindAdapterHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DA8DE0 - UnbindAdapterHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DA91E8 - PnPEventHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800484A010 - NdisProtocolBlock - 0xFFFFF88002DB1550 - UnloadHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D9D820 - OpenAdapterCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D9DF70 - CloseAdapterCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D9AA00 - (Wan)SendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D7F620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D7BB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D9A7B0 - (Wan)ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D765A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D815D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D7E9D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D7B0E0 - BindAdapterHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D80BA0 - UnbindAdapterHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D7B980 - PnPEventHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D7F5A0 - UnloadHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D8C2C0 - CoSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D81220 - CoStatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D8B190 - CoReceivePacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004844520 - NdisProtocolBlock - 0xFFFFF88002D7AD80 - CoAfRegisterNotifyHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF8800151DA60 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88002D9A7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88002D765A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88002D7BB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88002D7F620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88002D815D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88002D7E9D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF880075246B4 - WSendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF8800151DA60 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88002D9AA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040EC8D0 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D9A7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D765A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D7BB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D7F620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D815D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D7E9D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002DE1954 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D79360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88002D9AA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053FA010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D9A7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D765A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D7BB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D7F620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D815D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D7E9D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002DC1270 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D79360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88002D9AA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F5010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D9A7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D765A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D7BB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D7F620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D815D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D7E9D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002DA5D0C - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D79360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88002D9AA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1840 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF8800151B920 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D9A7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D765A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D7BB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D7F620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D815D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D7E9D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88004458AF0 - MiniportCoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D79360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88002D9AA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E1010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF8800151AEB0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF8800151B570 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D9A7B0 - ReceiveHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D765A0 - ReceiveCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D7BB10 - RequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88001495970 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D7F620 - ResetCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D815D0 - StatusHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D7E9D0 - StatusCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF880049E55D0 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF880049D9B7C - MiniportCoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D7A0A0 - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D79360 - CoRequestCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF8800151B480 - ProtSendNetBufferListsComplete - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88001495970 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF880049E55D0 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF8800151AEB0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88002D9AA00 - ProtSendCompleteHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF880014E3170 - OidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF880049D9AEC - MiniportCoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88001523560 - CoOidRequestCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053DE380 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FB5E30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FC0A30 - PnPEventHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FB66B0 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FC1970 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FBF330 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FC18F0 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FB5010 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FB53A0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004557CE0 - NdisProtocolBlock - 0xFFFFF88003FB6AF0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF8800147DEF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF88003FB5E30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF88002D76AD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF88003FB53A0 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF88003FB5010 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF88003FB6AF0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053F1010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FB5E30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FC0A30 - PnPEventHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FB66B0 - BindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FC1970 - UnbindAdapterHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FBF330 - OpenAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FC18F0 - CloseAdapterCompleteHandlerEx - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FB5010 - ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FB53A0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004555CF0 - NdisProtocolBlock - 0xFFFFF88003FB6AF0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF8800147DEF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF88003FB5E30 - StatusHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF88002D76AD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF88003FB53A0 - ProtSendNetBufferListsComplete - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF88003FB5010 - ReceiveNetBufferLists - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF8800151AA60 - SavedSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF88003FB6AF0 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80053EE840 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF88001615990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF8800161CCC0 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF880016DEB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF880016DEA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF880016DEA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF880016DE9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF880016DE980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF8800161BB90 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF880016067F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF880016DE3B0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF88001606EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF88001656C20 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF8800165B960 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF8800168AB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045AE490 - NdisProtocolBlock - 0xFFFFF880016CECB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF88001519920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF8800147DEF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880015197E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF88001519710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF88001615990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DEB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DEA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DEA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DE9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DE980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DE600 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF88001733330 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016DE550 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF8800165B960 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF88001656C20 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF8800185B210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF8800168AB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF880016CECB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004865010 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001519920 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF8800147DEF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880015197E0 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001519710 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001615990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016DEB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016DEA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016DEA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016DE9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016DE980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016D8EF0 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016D8EF0 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016D8EF0 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016D8EF0 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001733330 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001716FE0 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF8800165B960 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001656C20 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF8800185B210 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF8800168AB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF880016CECB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800486A8D0 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF88001615990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF88001741210 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF880016DEB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF880016DEA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF880016DEA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF880016DE9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF880016DE980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF8800161BB90 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF880016067F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF880016DE3B0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF88001606EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF88001656C20 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF8800165B960 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF8800168AB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80045DC410 - NdisProtocolBlock - 0xFFFFF880016CECB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF88001615990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF88001741290 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF880016DEB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF880016DEA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF880016DEA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF880016DE9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF880016DE980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF8800161BB90 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF880016067F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF880016DE3B0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF88001606EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF88001656C20 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF8800165B960 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF8800168AB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA8004489890 - NdisProtocolBlock - 0xFFFFF880016CECB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF8800147DEF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF88001615990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880048DED68 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DEB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DEA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DEA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DE9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DE980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DE600 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF88001733330 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016DE550 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF8800165B960 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF88001656C20 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880048DED68 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF8800168AB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF880016CECB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052E68D0 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF88001615990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF88001741250 - PnPEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF880016DEB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF880016DEA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF880016DEA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF880016DE9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF880016DE980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF8800161BB90 - BindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF880016067F0 - UnbindAdapterHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF880016DE3B0 - OpenAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF88001606EE0 - CloseAdapterCompleteHandlerEx - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF88001656C20 - ReceiveNetBufferListsHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF8800165B960 - SendNetBufferListsCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF8800168AB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA800448A850 - NdisProtocolBlock - 0xFFFFF880016CECB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF8800151ACF0 - (Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF8800151A0A0 - TransferDataHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF8800147DEF0 - ReceiveCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF8800151D630 - ResetHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF88001517370 - RequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF88001615990 - StatusHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880048DED68 - CancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DEB30 - InitiateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DEA70 - TerminateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DEA20 - UpdateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DE9D0 - InvalidateOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DE980 - QueryOffloadCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadSendCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DE600 - TcpOffloadReceiveCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadDisconnectCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DE650 - TcpOffloadForwardCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF88001733330 - TcpOffloadEventHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016DE550 - TcpOffloadReceiveIndicateHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF88001516620 - OidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF8800165B960 - ProtSendNetBufferListsComplete - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF88001656C20 - ReceiveNetBufferLists - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880048DED68 - SavedCancelSendPacketsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF8800151ACF0 - Saved(Wan)SendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF8800168AB20 - OidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF880016CECB0 - DirectOidRequestCompleteHandler - C:\Windows\System32\drivers\tcpip.sys - Microsoft Corporation
0xFFFFFA80052DA260 - NdisOpenBlock - 0xFFFFF88001466590 - DirectOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F66930 - SetOptionsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F70630 - SetFilterModuleOptionsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F6B8A0 - AttachHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F6B710 - DetachHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F776F0 - RestartHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F69190 - PauseHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F620C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F62010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F75AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F75AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800454ACB0 - NdisFilterDriverBlock - 0xFFFFF88003F6F540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88001516D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88001516260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88001462770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF880015168F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF8800147DEF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F70630 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F62170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F62140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F64A80 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F6B290 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F62170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F62140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F64A80 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F6B290 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F620C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F62010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F75AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F75AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88003F6F540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF8800146C900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF88001462650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053ECC80 - NdisFilterBlock - 0xFFFFF8800147EA00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88001516D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88001516260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88001462770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF880015168F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF8800147DEF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F70630 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F62170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F62140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F64A80 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F6B290 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F62170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F62140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F64A80 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F6B290 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F620C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F62010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F75AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F75AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88003F6F540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF8800146C900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF88001462650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053EB010 - NdisFilterBlock - 0xFFFFF8800147EA00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88001516D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88001516260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88001462770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF880015168F0 - NextReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF8800147DEF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F70630 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F62170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F62140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F64A80 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F6B290 - Characteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F62170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F62140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F64A80 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F6B290 - SavedCharacteristics.ReceiveNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F620C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F62010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F75AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F75AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88003F6F540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF8800146C900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF88001462650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80053E7C80 - NdisFilterBlock - 0xFFFFF8800147EA00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88001516440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88001516260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88001462770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF880048D9FD0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF880048DED68 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F70630 - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F62170 - Characteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F62140 - Characteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F64A80 - Characteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F62170 - SavedCharacteristics.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F62140 - SavedCharacteristics.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F64A80 - SavedCharacteristics.CancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F620C0 - OidRequestHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F62010 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F75AD0 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F75AB0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88003F6F540 - StatusHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF8800146C900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF88001462650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D6940 - NdisFilterBlock - 0xFFFFF8800147EA00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F59BDC - SetFilterModuleOptionsHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F59008 - AttachHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F59380 - DetachHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F592DC - RestartHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F59284 - PauseHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F595C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F59684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F597DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F597F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA8004546B70 - NdisFilterDriverBlock - 0xFFFFF88003F597C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88003F62170 - NextSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88001516260 - NextSendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88001462770 - NextIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF880048D9FD0 - NextReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88003F64A80 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88003F59BDC - SetFilterModuleOptionalHandlers - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88003F595C4 - OidRequestHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88003F59684 - OidRequestCompleteHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88003F597DC - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88003F597F0 - NetPnPEventHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88003F597C8 - StatusHandler - C:\Windows\system32\DRIVERS\wfplwf.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF8800146C900 - FilterSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF88001462650 - FilterIndicateReceiveNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80052D79C0 - NdisFilterBlock - 0xFFFFF8800147EA00 - FilterCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80058358D0 - NdisMiniDriverBlock - 0xFFFFF88007525E1C - HaltHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80058358D0 - NdisMiniDriverBlock - 0xFFFFF88007525E7C - InitializeHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80058358D0 - NdisMiniDriverBlock - 0xFFFFF8800752367C - QueryInformationHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80058358D0 - NdisMiniDriverBlock - 0xFFFFF88007526398 - ReconfigureHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80058358D0 - NdisMiniDriverBlock - 0xFFFFF880075263A4 - ResetHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80058358D0 - NdisMiniDriverBlock - 0xFFFFF880075246B4 - (Wan)SendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80058358D0 - NdisMiniDriverBlock - 0xFFFFF88007523924 - SetInformationHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DEC328 - UnloadHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DECBB0 - HaltHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DECF54 - InitializeHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DE12D4 - ResetHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DEE008 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DEE068 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DEE0B0 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DEE0F8 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DE1954 - CoRequestHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DEE068 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88002DEE0B0 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA8004856CD0 - NdisMiniDriverBlock - 0xFFFFF88001463EA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DD5400 - UnloadHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DC79E0 - HaltHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DD91B0 - InitializeHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DC3BF0 - ResetHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DCEDB0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DD53B0 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DD5360 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DCF2D0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DC1270 - CoRequestHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DD53B0 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88002DD5360 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800484A800 - NdisMiniDriverBlock - 0xFFFFF88001463EA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DB02B4 - UnloadHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DA54B4 - HaltHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DB0AB4 - InitializeHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DA5604 - ResetHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DB2008 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DB2150 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DB2198 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DB21E0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DA5D0C - CoRequestHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DB2150 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88002DB2198 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA8004761B10 - NdisMiniDriverBlock - 0xFFFFF88001463EA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D97B00 - UnloadHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D80DA0 - HaltHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D9D350 - InitializeHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F9A0 - ReconfigureHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F8D0 - ResetHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D766F0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D76AD0 - SendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F850 - CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F7D0 - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F750 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F6D0 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D81670 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D79760 - CoRequestHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F850 - MiniportCharacteristics.CoCreateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F7D0 - MiniportCharacteristics.CoDeleteVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F750 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88002D7F6D0 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA8004843CD0 - NdisMiniDriverBlock - 0xFFFFF88001463EA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF88004475120 - UnloadHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF88004475010 - HaltHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF88004473500 - InitializeHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF8800445B470 - ResetHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF880044643D0 - ReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF8800446F930 - CoActivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF8800446F930 - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF880044655A0 - CoSendPacketsHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF88004458AF0 - CoRequestHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF8800446F930 - MiniportCharacteristics.CoActivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF8800446F930 - MiniportCharacteristics.CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA8004790A40 - NdisMiniDriverBlock - 0xFFFFF88001463EA0 - CoOidRequestHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9B7C - CoCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9B7C - CoDeleteVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9B7C - CoActivateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9B7C - CoDeactivateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E5418 - CoSendNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9AEC - CoOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DA31C - CmCreateVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DA59C - CmDeleteVcHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9D18 - CmOpenAfHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9DA4 - CmCloseAfHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DA8A8 - CmRegisterSapHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DAA10 - CmDeregisterSapHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DAE7C - CmMakeCallHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DADDC - CmCloseCallHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E5650 - CmIncomingCallCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E583C - CmActivateVcCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E5A50 - CmDeactivateVcCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E5B38 - CmModifyCallQoSHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DB54C - CmOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DB598 - CmOidRequestCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DB598 - CmNotifyCloseAfCompleteHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E4138 - SetOptionsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E3C60 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D92D4 - HaltHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E3328 - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D94DC - PauseHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9550 - RestartHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E55D0 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E55DC - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E55D0 - CancelSendHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D958C - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049D9B70 - ResetHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049E4364 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DB598 - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800477C020 - NdisMiniDriverBlock - 0xFFFFF880049DB598 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D8270 - FilterResourceRequirementsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D81F8 - SetOptionsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D8314 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D99EC - HaltHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048DF62C - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D9560 - PauseHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D969C - RestartHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048E764C - OidRequestHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048DA1F4 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D9FD0 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048DED68 - CancelSendHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D99E0 - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048D9B68 - ResetHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048DF264 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048DC604 - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA80047357B0 - NdisMiniDriverBlock - 0xFFFFF880048F18A4 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF88001859F84 - InitializeHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185AD80 - HaltHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800186A7DC - MiniportDriverCharacteristics.UnloadHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185AED8 - PauseHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185B000 - RestartHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185ACCC - OidRequestHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185AD54 - SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185AD44 - ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185B210 - CancelSendHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185E7AC - CheckForHangHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800186A944 - DevicePnPEventNotifyHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185B0FC - ShutdownHandlerEx - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA8004518C60 - NdisMiniDriverBlock - 0xFFFFF8800185A7F8 - CancelOidRequestHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014A1020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF8800149B3F0 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014A1020 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014A1020 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880014A1020 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80040E71A0 - NdisMiniportBlock - 0xFFFFF880075246B4 - (Wan)SendHandler - C:\Windows\system32\DRIVERS\asyncmac.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF8800151C730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88002DEE008 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88002DEE008 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\rassstp.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047581A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF8800151C730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88002DCEDB0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88002DCEDB0 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\raspptp.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475E1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF8800151C730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88002DB2008 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88002DB2008 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\raspppoe.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800475C1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001516AB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800151CB10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001520C30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880015220D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88002D76AD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001516AB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800145A3B0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800145A3B0 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88002D766F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800151E0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88003F64A80 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88003F62140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88003F6B290 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF88003F62170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047621A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001516AB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800151CB10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001520C30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880015220D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88002D76AD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001516AB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800145A3B0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800145A3B0 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88002D766F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800151E0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88003F64A80 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88003F62140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88003F6B290 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF88003F62170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047601A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001516AB0 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800151CB10 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001520C30 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880015220D0 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88002D76AD0 - WSendPacketsHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001516AB0 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800145A3B0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800145A3B0 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88002D766F0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\ndiswan.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800151E0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88003F64A80 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88003F62140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88003F6B290 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF88003F62170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA80047661A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF8800151AA60 - SendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF8800151C730 - DeferredSendHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001516E60 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880044643D0 - MiniportReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880044643D0 - SynchronousReturnPacketHandler - C:\Windows\system32\DRIVERS\rasl2tp.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001516D70 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880015168F0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80047641A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014A1020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001516440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001516440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014E7910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880049DB598 - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF8800151E0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880049E55D0 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880049E55DC - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001516440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880049E55D0 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880049E55DC - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\AgileVpn.sys - Microsoft Corporation
0xFFFFFA800476A1A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800145A3B0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800145A3B0 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880048DC604 - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800151E0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880048DED68 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880048D9FD0 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001516440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88003F64A80 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88003F62140 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF880048D9FD0 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\Rt64win7.sys - Realtek
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF88003F62170 - Next.SendNetBufferListsHandler - C:\Windows\system32\DRIVERS\pacer.sys - Microsoft Corporation
0xFFFFFA800477D1A0 - NdisMiniportBlock - 0xFFFFF8800151F010 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014A1020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880015167D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001516440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014E7910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800185B0FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800151E0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800185B210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800185AD44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001516440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800185B210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF8800185AD44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B41A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014A1020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800147DF90 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001516440 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001516440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014E7910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800185B0FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800151E0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800185B210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800185AD44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001516440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800185B210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF8800185AD44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B21A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014A1020 - PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001516FA0 - SendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014F23B0 - SendResourcesHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014F2C80 - ResetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001520650 - EthRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001521280 - TrRxIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001520570 - EthRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880015211F0 - TrRxCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014E1BB0 - StatusHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014E7BD0 - StatusCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800151B720 - TDCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014F25C0 - QueryCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014F24D0 - SetCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800151A3C0 - WanSendCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014EC8A0 - WanRcvHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014EC7D0 - WanRcvCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - SavedPacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800147DEF0 - NextCancelSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880015167D0 - NextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001516440 - SavedNextSendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014E7910 - IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880015161B0 - SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014E35B0 - SavedIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - NextSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014A0150 - FinalSendPacketsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800185B0FC - ShutdownHandler(Ex) - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014DF900 - TopIndicateLoopbackNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - Ndis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800151E0C0 - SynchronousReturnPacketHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800185B210 - NoFilter.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001516260 - NoFilter.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001462770 - NoFilter.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800185AD44 - NoFilter.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001516440 - NoFilter.SendNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800185B210 - Next.CancelSend(Packets)Handler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001516260 - Next.SendNetBufferListsCompleteHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.IndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF88001462770 - Next.SaveIndicateNetBufferListsHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF8800185AD44 - Next.ReturnNetBufferListsHandler - C:\Windows\system32\DRIVERS\tunnel.sys - Microsoft Corporation
0xFFFFFA80046B01A0 - NdisMiniportBlock - 0xFFFFF880014F5340 - TopNdis5PacketIndicateHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA8004556AB0 - NdisIfProviderBlock - 0xFFFFF88003FB54B0 - QueryObjectHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA8004556AB0 - NdisIfProviderBlock - 0xFFFFF88003FC16B0 - SetObjectHandler - C:\Windows\system32\DRIVERS\wanarp.sys - Microsoft Corporation
0xFFFFFA80043EBA60 - NdisIfProviderBlock - 0xFFFFF8800145FE30 - QueryObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80043EBA60 - NdisIfProviderBlock - 0xFFFFF88001483770 - SetObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80043E56B0 - NdisIfProviderBlock - 0xFFFFF8800145D020 - QueryObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
0xFFFFFA80043E56B0 - NdisIfProviderBlock - 0xFFFFF88001483770 - SetObjectHandler - C:\Windows\system32\drivers\ndis.sys - Microsoft Corporation
IE Plugin
Browser Helper Objects - - - - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408}
Browser Helper Objects(Wow64) - - - - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408}
Browser Helper Objects(Wow64) - Java(tm) Plug-In SSV Helper - C:\Program Files (x86)\Java\jre7\bin\ssv.dll - Oracle Corporation - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43}
Browser Helper Objects(Wow64) - Java(tm) Plug-In 2 SSV Helper - C:\Program Files (x86)\Java\jre7\bin\jp2ssv.dll - Oracle Corporation - {DBC80044-A445-435b-BC74-9C25C1C588A9}
Browser Extensions(Wow64) - @C:\Program Files (x86)\Windows Live\Writer\WindowsLiveWriterShortcuts.dll,-1004 - - - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600}
Browser Extensions(Wow64) - Send to OneNote - - - {2670000A-7350-4f3c-8081-5663EE0C6C49}
Browser Extensions(Wow64) - Research - - - {92780B25-18CC-41C8-B9BE-3C9C571A8263}
ActiveX - - - - {5852F5ED-8BF4-11D4-A245-0080C6F74284}
ActiveX - - - - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43}
ActiveX - - - - {9BE31822-FDAD-461B-AD51-BE1D1C159921}
ActiveX - Adobe PDF Reader - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroPDF64.dll - Adobe Systems, Inc. - {CA8A9780-280D-11CF-A24D-444553540000}
ActiveX - Shockwave Flash Object - C:\Windows\System32\Macromed\Flash\Flash64_28_0_0_161.ocx - Adobe Systems, Inc. - {D27CDB6E-AE6D-11CF-96B8-444553540000}
ActiveX - - - - {DBC80044-A445-435B-BC74-9C25C1C588A9}
ActiveX - Microsoft Silverlight - C:\Program Files\Microsoft Silverlight\5.1.50907.0\npctrl.dll - Microsoft Corporation - {DFEAF541-F3E1-4C24-ACAC-99C30715084A}
IE Shell
Nothing
Spi
Nothing
Hosts File
127.0.0.1 localhost
::1 localhost
Startup
DllDirectory32 - C:\Windows\system32\ - - [\Registry\Machine\SYSTEM\CurrentControlSet\Control\Session Manager\KnownDLLs DllDirectory32]
FAHDll.dll(FileAssociationHelper) - C:\Program Files\File Association Helper\FAHDll.dll - Nico Mak Computing - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers FileAssociationHelper]
RarExt.dll(WinRAR) - C:\Program Files\WinRAR\RarExt.dll - Alexander Roshal - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers WinRAR]
WZSHLS64.dll(WinZip) - C:\Program Files\WinZip\WZSHLS64.dll - WinZip Computing, S.L. - [\Registry\Machine\SOFTWARE\Classes\*\shellex\ContextMenuHandlers WinZip]
mbshlext.dll(MBAMShlExt) - C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll - Malwarebytes - [\Registry\Machine\SOFTWARE\Classes\AllFilesystemObjects\shellex\ContextMenuHandlers MBAMShlExt]
mbshlext.dll(MBAMShlExt) - C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll - Malwarebytes - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers MBAMShlExt]
RarExt.dll(WinRAR) - C:\Program Files\WinRAR\RarExt.dll - Alexander Roshal - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers WinRAR]
WZSHLS64.dll(WinZip) - C:\Program Files\WinZip\WZSHLS64.dll - WinZip Computing, S.L. - [\Registry\Machine\SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers WinZip]
Google Chrome({8A69D345-D564-463c-AFF1-A69D9E530F96}) - C:\Program Files (x86)\Google\Chrome\Application\64.0.3282.186\Installer\chrmstp.exe - Google Inc. - [\Registry\Machine\SOFTWARE\Microsoft\Active Setup\Installed Components {8A69D345-D564-463c-AFF1-A69D9E530F96}]
Google Chrome({8A69D345-D564-463c-AFF1-A69D9E530F96}) - C:\Program Files (x86)\Google\Chrome\Application\58.0.3029.81\Installer\chrmstp.exe - File not found - [\Registry\Machine\SOFTWARE\Wow6432Node\Microsoft\Active Setup\Installed Components {8A69D345-D564-463c-AFF1-A69D9E530F96}]
Service
AdobeARMservice - Started - Automatic - "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe" - Adobe Systems Incorporated - -
AdobeFlashPlayerUpdateSvc - Stopped - Disabled - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe - Adobe Systems Incorporated - -
AMD External Events Utility - Started - Automatic - C:\Windows\System32\atiesrxx.exe - AMD - -
DAUpdaterSvc - Stopped - Disabled - E:\Steam\steamapps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe - BioWare - -
gupdate - Stopped - Disabled - "C:\Program Files (x86)\Google\Update\GoogleUpdate.exe" /svc - Google Inc. - -
gupdatem - Stopped - Disabled - "C:\Program Files (x86)\Google\Update\GoogleUpdate.exe" /medsvc - Google Inc. - -
IEEtwCollectorService - Stopped - Manual - C:\Windows\syswow64\IEEtwCollector.exe /V - File not found - -
LogiRegistryService - Stopped - Disabled - "C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.exe" - Logitech Inc. - -
MBAMService - Stopped - Disabled - "C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe" - Malwarebytes - -
PAExec - Stopped - Manual - C:\Windows\PAExec.exe -service - Power Admin LLC - -
ss_conn_service - Stopped - Disabled - "C:\Program Files\SAMSUNG\USB Drivers\25_escape\conn\ss_conn_service.exe" - DEVGURU Co., LTD. - -
Steam Client Service - Stopped - Manual - "C:\Program Files (x86)\Common Files\Steam\SteamService.exe" /RunAsService - File not found - -
UMVPFSrv - Stopped - Disabled - C:\Program Files (x86)\Common Files\logishrd\LVMVFM\UMVPFSrv.exe - Logitech Inc. - -
Schedule Task
RunDAOD - \ASUS\RunDAOD - C:\Windows\DAODx.exe - - Enable -
AitAgent - \Microsoft\Windows\Application Experience\AitAgent - aitagent - Aggregates and uploads Application Telemetry information if opted-in to the Microsoft Customer Experience Improvement Program. - Enable -
GatherNetworkInfo - \Microsoft\Windows\NetTrace\GatherNetworkInfo - C:\Windows\System32\gatherNetworkInfo.vbs - Network information collector - Enable -
Adobe Acrobat Update Task - \Adobe Acrobat Update Task - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe - This task keeps your Adobe Reader and Acrobat applications up to date with the latest enhancements and security fixes - Enable - Adobe Systems Incorporated
Adobe Flash Player Updater - \Adobe Flash Player Updater - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe - This task keeps your Adobe Flash Player installation up to date with the latest enhancements and security fixes. If this task is disabled or removed, Adobe Flash Player will be unable to automatically secure your machine with the latest security fixes. - Enable - Adobe Systems Incorporated
GoogleUpdateTaskMachineCore - \GoogleUpdateTaskMachineCore - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe - Keeps your Google software up to date. If this task is disabled or stopped, your Google software will not be kept up to date, meaning security vulnerabilities that may arise cannot be fixed and features may not work. This task uninstalls itself when there is no Google software using it. - Enable - Google Inc.
GoogleUpdateTaskMachineUA - \GoogleUpdateTaskMachineUA - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe - Keeps your Google software up to date. If this task is disabled or stopped, your Google software will not be kept up to date, meaning security vulnerabilities that may arise cannot be fixed and features may not work. This task uninstalls itself when there is no Google software using it. - Enable - Google Inc.
StartCN - \StartCN - C:\Program Files\AMD\CNext\CNext\cncmd.exe - - Enable - Advanced Micro Devices, Inc.
StartDVR - \StartDVR - C:\Program Files\AMD\CNext\CNext\dvrcmd.exe - - Enable - Advanced Micro Devices, Inc.
File Association
hlpfile - %SystemRoot%\winhlp32.exe %1 - HKEY_CLASSES_ROOT\hlpfile\Shell\Open\Command
vbsfile - "%SystemRoot%\System32\WScript.exe" "%1" %* - HKEY_CLASSES_ROOT\vbsfile\Shell\Open\Command
jsfile - C:\Windows\System32\WScript.exe "%1" %* - HKEY_CLASSES_ROOT\jsfile\Shell\Open\Command
HKCU .bat Progid - "%1" %* - HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.bat\OpenWithProgids
IFEO
Nothing
IME/CTF
Nothing
Firewall Rule
NetPres-In-TCP-NoScope --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=6|Profile=Domain|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31761|Desc=@FirewallAPI.dll,-31764|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-Out-TCP-NoScope --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=6|Profile=Domain|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31765|Desc=@FirewallAPI.dll,-31768|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-WSD-In-UDP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=17|LPort=3702|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31753|Desc=@FirewallAPI.dll,-31756|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-WSD-Out-UDP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=17|RPort=3702|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31757|Desc=@FirewallAPI.dll,-31760|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-In-TCP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=In|Protocol=6|Profile=Private|Profile=Public|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31761|Desc=@FirewallAPI.dll,-31764|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
NetPres-Out-TCP --> C:\Windows\system32\netproj.exe - v2.10|Action=Allow|Active=FALSE|Dir=Out|Protocol=6|Profile=Private|Profile=Public|RA4=LocalSubnet|RA6=LocalSubnet|App=%SystemRoot%\system32\netproj.exe|Name=@FirewallAPI.dll,-31765|Desc=@FirewallAPI.dll,-31768|EmbedCtxt=@FirewallAPI.dll,-31752| - Enabled - File not found
{204523DB-ECE5-44DC-B20E-D3771411D969} --> C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{330531C7-7EB7-44DE-AD00-514D78DA6082} --> C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.2880\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{63685001-A660-4C55-8040-0928EA485E33} --> C:\Program Files (x86)\Battle.net\Battle.net.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Battle.net\Battle.net.exe|Name=Battle.net| - Enabled - File not found
{B7E226B4-6E16-418E-AC44-9B0AC8E8D4D4} --> C:\Program Files (x86)\Battle.net\Battle.net.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Battle.net\Battle.net.exe|Name=Battle.net| - Enabled - File not found
{38F8CFA0-49DB-406D-9694-1CBC18050ABB} --> C:\Program Files (x86)\Diablo III\Diablo III.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Diablo III\Diablo III.exe|Name=Diablo III| - Enabled - File not found
{80E28519-0F39-4094-9E80-3EE1B31AE91A} --> C:\Program Files (x86)\Diablo III\Diablo III.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Diablo III\Diablo III.exe|Name=Diablo III| - Enabled - File not found
{B63ADA1B-7A0A-4E61-8BDB-E9AA4F3D11AC} --> E:\Steam\Steam.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\Steam.exe|Name=Steam| - Enabled - Valve Corporation
{E496D788-C304-4BB0-9D66-6D47FB915919} --> E:\Steam\Steam.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\Steam.exe|Name=Steam| - Enabled - Valve Corporation
{24D88DBA-DAE1-403D-B1EE-05D1A475F557} --> E:\Steam\SteamApps\common\Contagion\contagion.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Contagion\contagion.exe|Name=Contagion| - Enabled -
{3DF5206E-E507-49B2-BE42-CAFE4FF0CDA3} --> E:\Steam\SteamApps\common\Contagion\contagion.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Contagion\contagion.exe|Name=Contagion| - Enabled -
{4EB98C22-831F-4E5B-ABE0-3CF831D15A7B} --> E:\Steam\SteamApps\common\Contagion\contagionds.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Contagion\contagionds.exe|Name=ContagionDSBeta| - Enabled -
{43488864-C1CA-45F0-92F0-897DB8C09F8E} --> E:\Steam\SteamApps\common\Contagion\contagionds.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Contagion\contagionds.exe|Name=ContagionDSBeta| - Enabled -
{0E00EAD6-01A4-4E93-AC69-F13B368C5EB6} --> E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe|Name=State of Decay| - Enabled -
{CC602AB4-6FD1-4C6D-AEAF-E6B009BCB548} --> E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\State of Decay\StateOfDecay.exe|Name=State of Decay| - Enabled -
{A6D6A61F-4A3C-4031-8A28-76EBD852ABC7} --> E:\Steam\SteamApps\common\Dawn of War 2\DOW2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dawn of War 2\DOW2.exe|Name=Warhammer® 40,000™: Dawn of War® II| - Enabled - Sega Corporation
{1DB121AE-6A08-445F-BF4E-08175FEA23B9} --> E:\Steam\SteamApps\common\Dawn of War 2\DOW2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dawn of War 2\DOW2.exe|Name=Warhammer® 40,000™: Dawn of War® II| - Enabled - Sega Corporation
{048A2BD0-B4C7-4E14-9A0C-DB373BAD1F41} --> E:\Steam\SteamApps\common\Dawn of War II - Retribution\DOW2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dawn of War II - Retribution\DOW2.exe|Name=Warhammer® 40,000™: Dawn of War® II – Retribution™| - Enabled - Sega Corporation
{C3636805-4BD1-4911-B77B-A2E56DAFA051} --> E:\Steam\SteamApps\common\Dawn of War II - Retribution\DOW2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dawn of War II - Retribution\DOW2.exe|Name=Warhammer® 40,000™: Dawn of War® II – Retribution™| - Enabled - Sega Corporation
{166DF566-73F7-4A12-9076-628C9B2A7892} --> E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe|Name=Command and Conquer: Red Alert 3| - Enabled -
{8B27EBE7-7A8B-4778-8FDB-5BF49FBE9713} --> E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Command and Conquer Red Alert 3\runme.exe|Name=Command and Conquer: Red Alert 3| - Enabled -
{1045CBC8-35FD-47D2-8E63-AF4B21CC76CA} --> E:\Steam\SteamApps\common\Tomb Raider\TombRaider.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Tomb Raider\TombRaider.exe|Name=Tomb Raider| - Enabled - Square Enix
{C6086797-A8C1-434E-A789-D89E5ACC2F4B} --> E:\Steam\SteamApps\common\Tomb Raider\TombRaider.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Tomb Raider\TombRaider.exe|Name=Tomb Raider| - Enabled - Square Enix
{78308042-0E31-4ED6-B88C-C09515035626} --> E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe|Name=MURDERED: SOUL SUSPECT™| - Enabled -
{7E3962FB-BFD4-47EE-834C-AA04D89B7F72} --> E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Murdered Soul Suspect\Binaries\Win64\Murdered.exe|Name=MURDERED: SOUL SUSPECT™| - Enabled -
{5C844D98-43BC-4089-9164-6E07CC7ABC33} --> E:\Steam\SteamApps\common\Skyrim\SkyrimLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Skyrim\SkyrimLauncher.exe|Name=The Elder Scrolls V: Skyrim| - Enabled - Bethesda Softworks
{164255EE-6193-44BD-BCCA-D96BC09F95CE} --> E:\Steam\SteamApps\common\Skyrim\SkyrimLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Skyrim\SkyrimLauncher.exe|Name=The Elder Scrolls V: Skyrim| - Enabled - Bethesda Softworks
{B9925F77-8800-4202-A56C-B7CAE9CEDC4F} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe|Name=Marvel Heroes 2015| - Enabled - File not found
{D274E088-584D-4780-9F2F-7E1D3C64B03D} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win32\MarvelHeroes2015.exe|Name=Marvel Heroes 2015| - Enabled - File not found
{08BE82A2-AA6B-4C05-B536-1F1AB306B4BF} --> E:\Steam\SteamApps\common\Space Hulk\game.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Space Hulk\game.exe|Name=Space Hulk| - Enabled -
{8B944443-1DA5-4843-8C70-BD83454D7982} --> E:\Steam\SteamApps\common\Space Hulk\game.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Space Hulk\game.exe|Name=Space Hulk| - Enabled -
{27271B2F-654F-454D-88EC-93BBA61961FF} --> E:\Steam\SteamApps\common\Gone Home\GoneHome.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Gone Home\GoneHome.exe|Name=Gone Home| - Enabled -
{C4719301-7D23-4C64-8C5C-67B214096824} --> E:\Steam\SteamApps\common\Gone Home\GoneHome.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Gone Home\GoneHome.exe|Name=Gone Home| - Enabled -
{BC19AAA4-BD6A-4287-AAEB-582E91BBBC24} --> E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe|Name=DuckTales Remastered| - Enabled -
{DF4C3EBF-B2FE-4B10-B6A7-B05A88FB1D78} --> E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\DuckTales Remastered\executable\DuckTales.exe|Name=DuckTales Remastered| - Enabled -
{D5DDBB79-FDAA-409B-9320-C5E81745EEBA} --> E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe|Name=The Stanley Parable| - Enabled -
{68EE5B9F-35D3-4991-B2C9-6C63B5B79271} --> E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Stanley Parable\stanley.exe|Name=The Stanley Parable| - Enabled -
{7BA5C408-A6B7-4A0D-B958-6909A370F7D5} --> E:\Steam\bin\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\bin\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - File not found
{1D7AEC08-A5E3-46AF-99F5-5E0AB2DFE371} --> E:\Steam\bin\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\bin\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - File not found
TCP Query User{10423A7B-48E4-4122-B9A5-83695CB09768}C:\programdata\battle.net\agent\agent.3286\agent.exe --> C:\programdata\battle.net\agent\agent.3286\agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\programdata\battle.net\agent\agent.3286\agent.exe|Name=Battle.net Update Agent|Desc=Battle.net Update Agent|Defer=User| - Enabled - File not found
UDP Query User{14DBE92F-6882-44C2-8991-27D4103C46E8}C:\programdata\battle.net\agent\agent.3286\agent.exe --> C:\programdata\battle.net\agent\agent.3286\agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\programdata\battle.net\agent\agent.3286\agent.exe|Name=Battle.net Update Agent|Desc=Battle.net Update Agent|Defer=User| - Enabled - File not found
{026C99E0-AEDE-4421-AF5D-D82CF1FD3F89} --> C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|App=C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe|Name=Windows Live Messenger|Edge=TRUE| - Enabled - File not found
{3CF6FE21-49E7-444B-8392-5474F180220C} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Diplomacy.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Diplomacy.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{1B698CC9-5E10-40D8-98F9-3D8B19ADD3E6} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Diplomacy.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Diplomacy.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{81078AF4-7B6F-4C0A-90A0-061A79D7B316} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Entrenchment.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Entrenchment.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{16FA5F60-ED6C-4D9B-A367-EEBEC5FE383E} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Entrenchment.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire Entrenchment.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{7B05C10F-1FBD-45E0-AE5D-ADAC5D38D9BA} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{D204FD5F-EB15-4C0B-BAFE-93327FD3AC38} --> E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sins of a Solar Empire Trinity\Sins of a Solar Empire.exe|Name=Sins of a Solar Empire®: Trinity| - Enabled - Ironclad Games
{255BEC1A-C06C-432E-ACB3-D3C72D6AD942} --> E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\witcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\witcher.exe|Name=The Witcher: Enhanced Edition| - Enabled - CD Projekt Red
{265E4297-7E60-47D4-9F9C-A8F5BB31F299} --> E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\witcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\witcher.exe|Name=The Witcher: Enhanced Edition| - Enabled - CD Projekt Red
{EA8DAB0F-62B2-4C4F-98A7-DD08B1C85DB7} --> E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\djinni!.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\djinni!.exe|Name=The Witcher: Enhanced Edition| - Enabled - CD Projekt Red
{62B5B36D-60DD-4BC8-B075-761B818F7671} --> E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\djinni!.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Witcher Enhanced Edition\System\djinni!.exe|Name=The Witcher: Enhanced Edition| - Enabled - CD Projekt Red
{FB534D17-ED3B-40D8-A761-B83BFABF9049} --> E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\DAOriginsLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\DAOriginsLauncher.exe|Name=Dragon Age: Origins - Ultimate Edition| - Enabled - BioWare
{211F2ABA-16F8-4D8C-8989-28A00ED1BEDE} --> E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\DAOriginsLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\DAOriginsLauncher.exe|Name=Dragon Age: Origins - Ultimate Edition| - Enabled - BioWare
{73AF861C-ECE4-4378-9923-1A41B1E95E86} --> E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe|Name=The Bureau: XCOM Declassified| - Enabled - 2K Marin, Inc.
{73B704C1-3302-409E-AE26-3B17C1125ED8} --> E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Bureau\Binaries\Win32\TheBureau.exe|Name=The Bureau: XCOM Declassified| - Enabled - 2K Marin, Inc.
{98413589-2324-4D4B-A50E-84170B3414E5} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe|Name=Nexus: The Jupiter Incident| - Enabled - File not found
{26CEFF01-D9CB-4A95-B7C4-E0E3F7568B7B} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\runme.exe|Name=Nexus: The Jupiter Incident| - Enabled - File not found
{14C0A219-D89E-4078-85DC-E1C116D8C145} --> E:\Steam\SteamApps\common\Outlast\OutlastLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Outlast\OutlastLauncher.exe|Name=Outlast| - Enabled - Red Barrels Inc.
{95048367-12BC-421B-AC20-5FD9ED9505C9} --> E:\Steam\SteamApps\common\Outlast\OutlastLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Outlast\OutlastLauncher.exe|Name=Outlast| - Enabled - Red Barrels Inc.
{0965A874-5235-4EA3-B5E6-7224962232FD} --> E:\Steam\SteamApps\common\Sid Meier's Civilization V\Launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sid Meier's Civilization V\Launcher.exe|Name=Sid Meier's Civilization V| - Enabled - Firaxis Games
{D0A83254-1BE4-4B20-B96B-5AD0E9CE47A5} --> E:\Steam\SteamApps\common\Sid Meier's Civilization V\Launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Sid Meier's Civilization V\Launcher.exe|Name=Sid Meier's Civilization V| - Enabled - Firaxis Games
{46CA8E78-4E57-435A-9F01-543CA6597655} --> E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|App=E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe|Name=Dragon Age Origins Updater| - Enabled - BioWare
{7BD57F5D-BE76-4A78-9E08-16ADBD8CCE63} --> E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|App=E:\Steam\SteamApps\common\Dragon Age Ultimate Edition\bin_ship\DAUpdaterSvc.Service.exe|Name=Dragon Age Origins Updater| - Enabled - BioWare
{01921918-583B-454B-9B53-626571D91F6A} --> E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe|Name=Dragon's Lair| - Enabled -
{057CBD5D-8121-4948-8EA8-F65C23D41C85} --> E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dragon's Lair\DragonsLair.exe|Name=Dragon's Lair| - Enabled -
{03CFE2B1-2F61-4DE0-8CF1-B5E197BBD818} --> C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{C20C8FCC-DA76-48B0-AE56-D465BFEA9B3D} --> C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3478\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{A2D38890-4450-4E81-911C-7B55B674F0F0} --> C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{AA898690-1D7D-453F-8600-571011E0BA10} --> C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3507\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{91019C81-FB01-47CD-8071-3E378E27004C} --> C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{63267EAA-A94A-46DE-A618-59616BA1200F} --> C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3526\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{3CED9BD6-5ABB-4C32-90B1-EA5E0BCF2E80} --> C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{51016FD8-C288-4F8B-9B17-B14349B2DC09} --> C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3632\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{AE09238B-E8AA-47B1-BD42-6E259B359250} --> C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{A3026DF8-AC67-4C99-8BA0-B5C9D89D95F6} --> C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3634\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{7957AA71-D52F-49C5-B66F-FE76025F8ECE} --> E:\Steam\SteamApps\common\War in the North\witn.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\War in the North\witn.exe|Name=The Lord of the Rings: War in the North| - Enabled - WB Games Inc.
{F2D21545-57C1-46B8-87C8-25786A475453} --> E:\Steam\SteamApps\common\War in the North\witn.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\War in the North\witn.exe|Name=The Lord of the Rings: War in the North| - Enabled - WB Games Inc.
{A34BE1AD-8AC9-4A26-8FB8-E7B7C98FE65A} --> C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{C26C8727-4F31-47B7-B5E8-3009CDF977FC} --> C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3688\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{119CAE3D-9CDB-4F91-9E20-640D9F4E8D0E} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe|Name=Marvel Heroes 2015| - Enabled - File not found
{6DCC1704-C9FB-4B54-80B5-9DAE36323672} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2015.exe|Name=Marvel Heroes 2015| - Enabled - File not found
{29243C02-9E73-4D45-9526-2DA5F92502F1} --> C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{62EB6B6B-5B43-466E-B0C7-E9089C496A21} --> C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\ProgramData\Battle.net\Agent\Agent.3689\Agent.exe|Name=Battle.net Update Agent| - Enabled - File not found
{B8134D53-C8EA-4034-88C2-A66F3E31862B} --> E:\Steam\SteamApps\common\XCom-Enemy-Unknown\Binaries\Win32\XComGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\XCom-Enemy-Unknown\Binaries\Win32\XComGame.exe|Name=XCOM: Enemy Unknown| - Enabled - Firaxis Games
{796F44F8-3786-4DB1-8352-D5B6B0DAFBDE} --> E:\Steam\SteamApps\common\XCom-Enemy-Unknown\Binaries\Win32\XComGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\XCom-Enemy-Unknown\Binaries\Win32\XComGame.exe|Name=XCOM: Enemy Unknown| - Enabled - Firaxis Games
{7F280529-461D-423F-B2E9-86BFCDED3EFF} --> E:\Steam\SteamApps\common\Saints Row the Third\game_launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\game_launcher.exe|Name=Saints Row: The Third| - Enabled - THQ Inc.
{AA3B4DF1-F8ED-4C08-B493-59F0FAB04AE0} --> E:\Steam\SteamApps\common\Saints Row the Third\game_launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\game_launcher.exe|Name=Saints Row: The Third| - Enabled - THQ Inc.
{27FB8D2E-6CBF-4DC6-BAC9-B448D3CC6A20} --> E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird.exe|Name=Saints Row: The Third| - Enabled - THQ Inc.
{C307F0F6-7267-497A-B7E4-6FAD00B4507E} --> E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird.exe|Name=Saints Row: The Third| - Enabled - THQ Inc.
{0953CD49-C8C1-480D-8748-8216D873B516} --> E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird_DX11.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird_DX11.exe|Name=Saints Row: The Third DX11| - Enabled - THQ Inc.
{D2E26BF6-EDDF-4007-BD99-2F5C4F255D36} --> E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird_DX11.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Saints Row the Third\SaintsRowTheThird_DX11.exe|Name=Saints Row: The Third DX11| - Enabled - THQ Inc.
{8AA555D4-C388-4AA4-88EB-44A5D4224E91} --> E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe|Name=Deus Ex: Game of the Year Edition| - Enabled -
{FE33F4D6-D576-4F5D-90D0-6B837F96C7BE} --> E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Deus Ex\System\DeusEx.exe|Name=Deus Ex: Game of the Year Edition| - Enabled -
{364C014F-2AA8-4E90-87EE-98C8620D8FA4} --> E:\Steam\SteamApps\common\Dead Island\DeadIslandGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dead Island\DeadIslandGame.exe|Name=Dead Island| - Enabled - Techland
{007B368A-F089-4BF2-ADA4-9F0C553BBEB1} --> E:\Steam\SteamApps\common\Dead Island\DeadIslandGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dead Island\DeadIslandGame.exe|Name=Dead Island| - Enabled - Techland
{3CF81BE6-3B1A-4686-B3D2-B99E2BC4D70E} --> E:\Steam\SteamApps\common\Deus Ex - Human Revolution\dxhr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Deus Ex - Human Revolution\dxhr.exe|Name=Deus Ex: Human Revolution| - Enabled - Square Enix Limited
{F2EC55AD-C1EC-436B-9DFB-975F07A9162E} --> E:\Steam\SteamApps\common\Deus Ex - Human Revolution\dxhr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Deus Ex - Human Revolution\dxhr.exe|Name=Deus Ex: Human Revolution| - Enabled - Square Enix Limited
{64B79135-159F-40E0-B975-19C99686403F} --> E:\Steam\SteamApps\common\DXHRML\dxhrml.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\DXHRML\dxhrml.exe|Name=Deus Ex: Human Revolution - The Missing Link| - Enabled - Square Enix Limited
{9A34A54E-665E-41B8-AAA6-AB84CFF5AA41} --> E:\Steam\SteamApps\common\DXHRML\dxhrml.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\DXHRML\dxhrml.exe|Name=Deus Ex: Human Revolution - The Missing Link| - Enabled - Square Enix Limited
TCP Query User{C9C2606F-F67B-404F-ADF9-ED9664973D59}E:\steam\steamapps\common\xcom-enemy-unknown\xew\binaries\win32\xcomew.exe --> E:\Steam\steamapps\common\xcom-enemy-unknown\XEW\Binaries\Win32\XComEW.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|Profile=Public|App=E:\steam\steamapps\common\xcom-enemy-unknown\xew\binaries\win32\xcomew.exe|Name=XCOM: Enemy Within|Desc=XCOM: Enemy Within|Defer=User| - Enabled - Firaxis Games
UDP Query User{4B43E231-EDAE-4528-8BC7-59EB671821D4}E:\steam\steamapps\common\xcom-enemy-unknown\xew\binaries\win32\xcomew.exe --> E:\Steam\steamapps\common\xcom-enemy-unknown\XEW\Binaries\Win32\XComEW.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|Profile=Public|App=E:\steam\steamapps\common\xcom-enemy-unknown\xew\binaries\win32\xcomew.exe|Name=XCOM: Enemy Within|Desc=XCOM: Enemy Within|Defer=User| - Enabled - Firaxis Games
{9D157DFB-B5FD-4D75-9778-FF47D1E3F2FD} --> E:\Steam\SteamApps\common\Skyrim\CreationKit.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Skyrim\CreationKit.exe|Name=Skyrim Creation Kit| - Enabled - Bethesda Softworks
{5EC0C182-7DA3-447C-8408-DB355C812D96} --> E:\Steam\SteamApps\common\Skyrim\CreationKit.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Skyrim\CreationKit.exe|Name=Skyrim Creation Kit| - Enabled - Bethesda Softworks
{D1606FA9-C2B8-4AAD-AD14-E1F85963FFDC} --> E:\Program Files (x86)\Origin Games\Command and Conquer Red Alert II\RA2Launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=E:\Program Files (x86)\Origin Games\Command and Conquer Red Alert II\RA2Launcher.exe|Name=Command & Conquer™ Red Alert 2 and Yuri’s Revenge| - Enabled - Kalloc Studios
{8BCFE501-6FF8-4C3C-9E42-7C51646768F1} --> E:\Program Files (x86)\Origin Games\Command and Conquer Red Alert II\RA2Launcher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=E:\Program Files (x86)\Origin Games\Command and Conquer Red Alert II\RA2Launcher.exe|Name=Command & Conquer™ Red Alert 2 and Yuri’s Revenge| - Enabled - Kalloc Studios
{A58B33D0-BC26-4F9A-B49B-A62BA65F28DC} --> C:\Program Files (x86)\Raptr\raptr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr\raptr.exe|Name=Raptr Desktop App| - Enabled - File not found
{5FBC2EAD-17E4-43A7-8F7D-8500F5312811} --> C:\Program Files (x86)\Raptr\raptr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr\raptr.exe|Name=Raptr Desktop App| - Enabled - File not found
{6F3E6FA2-07C8-4B80-9EE6-1AFCB424E090} --> C:\Program Files (x86)\Raptr\raptr_im.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr\raptr_im.exe|Name=Raptr IM| - Enabled - File not found
{F62EB103-89ED-44A6-89EC-213AFA4C97A7} --> C:\Program Files (x86)\Raptr\raptr_im.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr\raptr_im.exe|Name=Raptr IM| - Enabled - File not found
{5E7D5DD7-BBB2-4272-ABE0-A3E568382D62} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{C7E1F2F3-B957-45EE-8CF5-7D50BA0CA1FB} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{31F9FFF5-A9F4-40F0-A293-65D60FBC9588} --> E:\Steam\SteamApps\common\JurassicPark\JurassicPark100.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\JurassicPark\JurassicPark100.exe|Name=Jurassic Park: The Game| - Enabled - Telltale Games
{C700C7EC-CD04-4816-B379-A995B0263A74} --> E:\Steam\SteamApps\common\JurassicPark\JurassicPark100.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\JurassicPark\JurassicPark100.exe|Name=Jurassic Park: The Game| - Enabled - Telltale Games
{7635C5A1-2355-4BC2-BC2F-2AC35A81C8D2} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{58F44C40-4B7E-480C-8A6A-7D7C37F441D4} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\nexus_DX9.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{5347DEF1-74FA-4EC6-A7E6-17BDC2FC5FF6} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{000F2CCF-9014-4F19-A19C-76CC9F1DF342} --> E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Nexus The Jupiter Incident\mod_tools\mod_tools.exe|Name=Nexus: The Jupiter Incident| - Enabled - Nordic Games
{C1FCAE84-E209-47FB-BEF4-D2C2DFF576B2} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe|Name=Marvel Heroes 2016| - Enabled - File not found
{A271C9FB-E76F-4B5C-903C-E0FB304F9711} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroes2016.exe|Name=Marvel Heroes 2016| - Enabled - File not found
{0A8BAFE6-AFFD-405F-A03A-AC8A9BAE5DAC} --> C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe|Name=Raptr Desktop App| - Enabled - File not found
{6DCA5260-67C8-4CF6-BCF4-FCE9708263A2} --> C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\Raptr\raptr.exe|Name=Raptr Desktop App| - Enabled - File not found
{E50A44FE-6182-4951-BFA2-81547DAC95FB} --> C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe|Name=Raptr IM| - Enabled - File not found
{BB36AF9E-3A2D-4FA8-B9E2-8CDE4A028A51} --> C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\Raptr\raptr_im.exe|Name=Raptr IM| - Enabled - File not found
TCP Query User{B8D6574A-230E-46CA-A71C-A09A09CB16FF}E:\program files (x86)\diablo iii\diablo iii.exe --> E:\program files (x86)\diablo iii\diablo iii.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=E:\program files (x86)\diablo iii\diablo iii.exe|Name=Diablo III Retail|Desc=Diablo III Retail|Defer=User| - Enabled - Blizzard Entertainment
UDP Query User{781F11DA-E7E5-41F0-91D7-86106D98C2C9}E:\program files (x86)\diablo iii\diablo iii.exe --> E:\program files (x86)\diablo iii\diablo iii.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=E:\program files (x86)\diablo iii\diablo iii.exe|Name=Diablo III Retail|Desc=Diablo III Retail|Defer=User| - Enabled - Blizzard Entertainment
TCP Query User{B0BFEBD8-F610-49C8-A210-50C2B83F441C}C:\program files (x86)\counterpath\bria stretto\briastretto.exe --> C:\program files (x86)\counterpath\bria stretto\briastretto.exe - v2.10|Action=Block|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\program files (x86)\counterpath\bria stretto\briastretto.exe|Name=Bria Stretto|Desc=Bria Stretto| - Disable - File not found
UDP Query User{0E70B7F9-D2D7-436E-917F-BED0D00C5BC4}C:\program files (x86)\counterpath\bria stretto\briastretto.exe --> C:\program files (x86)\counterpath\bria stretto\briastretto.exe - v2.10|Action=Block|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\program files (x86)\counterpath\bria stretto\briastretto.exe|Name=Bria Stretto|Desc=Bria Stretto| - Disable - File not found
{64DE038F-4711-46BF-AB83-1154D7BE463B} --> C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe|Name=Plays.tv client| - Enabled - File not found
{CB6E88B3-9C3E-44A3-B272-A87AA4C64790} --> C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\Program Files (x86)\Raptr Inc\PlaysTV\playstv.exe|Name=Plays.tv client| - Enabled - File not found
{27F3FCB1-6835-42CC-9A4D-462BABBE00D7} --> E:\Steam\SteamApps\common\XCOM 2\Binaries\Win64\Launcher\ModLauncherWPF.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\XCOM 2\Binaries\Win64\Launcher\ModLauncherWPF.exe|Name=XCOM 2| - Enabled - Microsoft
{1717AF62-46C4-430E-B2E8-6A408B339499} --> E:\Steam\SteamApps\common\XCOM 2\Binaries\Win64\Launcher\ModLauncherWPF.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\XCOM 2\Binaries\Win64\Launcher\ModLauncherWPF.exe|Name=XCOM 2| - Enabled - Microsoft
TCP Query User{13163DF9-D2AA-421A-A545-1B044CA22736}E:\steam\steamapps\common\xcom 2\binaries\win64\xcom2.exe --> E:\Steam\steamapps\common\XCOM 2\Binaries\Win64\XCom2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|Profile=Public|App=E:\steam\steamapps\common\xcom 2\binaries\win64\xcom2.exe|Name=XCOM 2|Desc=XCOM 2|Defer=User| - Enabled - Firaxis Games
UDP Query User{5C2DADA8-E48D-44B9-8D36-2D369782A1A7}E:\steam\steamapps\common\xcom 2\binaries\win64\xcom2.exe --> E:\Steam\steamapps\common\XCOM 2\Binaries\Win64\XCom2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|Profile=Public|App=E:\steam\steamapps\common\xcom 2\binaries\win64\xcom2.exe|Name=XCOM 2|Desc=XCOM 2|Defer=User| - Enabled - Firaxis Games
{9CE7EE83-0607-4154-B0E4-6081BC2593D3} --> E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe|Name=Talisman: The Horus Heresy| - Enabled - Marmalade Technologies Ltd
{6167C9A7-0E89-41D1-8E93-589B845E6CEF} --> E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Talisman Horus Heresy\Horus.exe|Name=Talisman: The Horus Heresy| - Enabled - Marmalade Technologies Ltd
{A6E0B9D7-46DA-4BA3-9CB0-16C9B2270BD5} --> E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe|Name=Police Quest Collection| - Enabled - Vivendi Universal Games
{26720516-0FB3-463D-BDAA-5733C2933D0D} --> E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Police Quest Collection\SierraLauncher.exe|Name=Police Quest Collection| - Enabled - Vivendi Universal Games
{0AC66CB7-4E98-4635-9C79-AE00F324DF60} --> E:\Steam\SteamApps\common\7 Days To Die\7dLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\7 Days To Die\7dLauncher.exe|Name=7 Days to Die| - Enabled -
{A53D4A40-4A89-43EF-AD68-FD68F914DAD7} --> E:\Steam\SteamApps\common\7 Days To Die\7dLauncher.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\7 Days To Die\7dLauncher.exe|Name=7 Days to Die| - Enabled -
{71B2AE31-321C-4CC8-A2C6-3709B180B7D0} --> E:\Steam\bin\cef\cef.win7\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\bin\cef\cef.win7\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - Valve Corporation
{A0AEB9E9-F9A5-4364-B499-2CC88A54D779} --> E:\Steam\bin\cef\cef.win7\steamwebhelper.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\bin\cef\cef.win7\steamwebhelper.exe|Name=Steam Web Helper| - Enabled - Valve Corporation
{6F279A62-3CEE-4CAD-A4C5-CADB9DD11C89} --> E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe|Name=Space Hulk: Deathwing| - Enabled -
{2A4C5138-1794-4E90-A5B1-A4C07FA5888F} --> E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Space Hulk Deathwing\SpaceHulkGame.exe|Name=Space Hulk: Deathwing| - Enabled -
{BFFAD919-52EE-4E03-85E7-22EB6DFE0899} --> E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe|Name=Friday the 13th: The Game BETA| - Enabled -
{94B611A9-8B99-4B9C-A6A5-4C2A605169E9} --> E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\F13Beta\SummerCamp.exe|Name=Friday the 13th: The Game BETA| - Enabled -
{F4036343-5049-4EF3-B40D-CE3E536CD910} --> E:\Steam\SteamApps\common\Dead State\ZRPG.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dead State\ZRPG.exe|Name=Dead State| - Enabled - DoubleBear Productions, Iron Tower Studio
{F17D2244-7DB6-4B8D-B298-084E4E6F24AE} --> E:\Steam\SteamApps\common\Dead State\ZRPG.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Dead State\ZRPG.exe|Name=Dead State| - Enabled - DoubleBear Productions, Iron Tower Studio
{85F311B7-E6CE-4BDB-B341-A7AFC9D75998} --> E:\Steam\SteamApps\common\TheRoom\TheRoom.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\TheRoom\TheRoom.exe|Name=The Room| - Enabled -
{DBDC55A0-7379-4A03-A92B-90509ABDB7D6} --> E:\Steam\SteamApps\common\TheRoom\TheRoom.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\TheRoom\TheRoom.exe|Name=The Room| - Enabled -
{B5A37BCD-94D4-4628-9CCA-DDE263B65E3C} --> E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe|Name=Warhammer 40,000: Regicide| - Enabled -
{EE680A25-86FB-4157-95B7-203F2C0A592D} --> E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Warhammer 40,000 Regicide\Warhammer 40K Regicide.exe|Name=Warhammer 40,000: Regicide| - Enabled -
TCP Query User{D5BA13C4-8EB3-42D4-B2CA-22A2A3BE7E2A}E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe --> E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|Profile=Public|App=E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe|Name=Heroes of the Storm|Desc=Heroes of the Storm|Defer=User| - Enabled - File not found
UDP Query User{41B28AE0-48B6-43CB-9F80-D48CBB086CD0}E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe --> E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|Profile=Public|App=E:\program files (x86)\heroes of the storm\versions\base50441\heroesofthestorm_x64.exe|Name=Heroes of the Storm|Desc=Heroes of the Storm|Defer=User| - Enabled - File not found
{C48A36A6-4A14-4FE4-A7FF-CB73E4875A37} --> E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe|Name=Plague Inc: Evolved| - Enabled -
{2FF4AB51-0353-47A0-A61D-68A2FA9D37BD} --> E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\PlagueInc\PlagueIncEvolved.exe|Name=Plague Inc: Evolved| - Enabled -
{E1D3ACF9-A910-4F53-BE2D-6005A77ECD5D} --> E:\Steam\SteamApps\common\Warhammer 40,000 - Eternal Crusade\EternalCrusadeClient.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Warhammer 40,000 - Eternal Crusade\EternalCrusadeClient.exe|Name=Warhammer 40,000: Eternal Crusade| - Enabled - EasyAntiCheat Ltd
{AF68201D-AB64-4E1E-B8AB-5FD9959F0FF6} --> E:\Steam\SteamApps\common\Warhammer 40,000 - Eternal Crusade\EternalCrusadeClient.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Warhammer 40,000 - Eternal Crusade\EternalCrusadeClient.exe|Name=Warhammer 40,000: Eternal Crusade| - Enabled - EasyAntiCheat Ltd
{B9718C95-EFD7-467B-A932-1739913F4A5F} --> E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE|Name=Killing Time| - Enabled - File not found
{DF60188E-22FC-49D7-AC10-8185B59A6E5E} --> E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Killing Time\KILLTIME.EXE|Name=Killing Time| - Enabled - File not found
{B3EAB2B3-0930-4FD9-8374-8E0C22DB0010} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe|Name=Marvel Heroes Omega| - Enabled - Gazillion, Inc.
{3B016CC3-F3CB-49B0-96E7-E6F035C1483E} --> E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Marvel Heroes\UnrealEngine3\Binaries\Win64\MarvelHeroesOmega.exe|Name=Marvel Heroes Omega| - Enabled - Gazillion, Inc.
{3DF33BBF-5A10-4282-AC43-0A4CE629AFA7} --> E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe|Name=Stranded Deep| - Enabled -
{DD950824-0E60-44D1-B0A2-F0754C156B84} --> E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Stranded Deep\Stranded_Deep_x64.exe|Name=Stranded Deep| - Enabled -
{503DAAC1-EDBD-4B77-A7F2-E91E6C69D5B7} --> E:\Steam\SteamApps\common\The Forest\TheForest.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Forest\TheForest.exe|Name=The Forest| - Enabled -
{6A76B832-9950-41BB-97ED-A4581D14E6BC} --> E:\Steam\SteamApps\common\The Forest\TheForest.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\The Forest\TheForest.exe|Name=The Forest| - Enabled -
{AD8DFFEA-1DC6-4D07-AA54-6D91ED2B2046} --> E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe|Name=Vampire: The Masquerade - Redemption| - Enabled -
{D2D3334E-F0B0-4A58-A151-0B64D6C34608} --> E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Vampire The Masquerade - Redemption\Vampire.exe|Name=Vampire: The Masquerade - Redemption| - Enabled -
{3F1B4BE2-16E1-401A-ABB0-C2DB65865152} --> E:\Steam\SteamApps\common\Firewatch\Firewatch.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Firewatch\Firewatch.exe|Name=Firewatch| - Enabled -
{CF807903-A7B7-4B6C-8D20-ADF4A496D9C9} --> E:\Steam\SteamApps\common\Firewatch\Firewatch.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Firewatch\Firewatch.exe|Name=Firewatch| - Enabled -
{5C0A5BC7-95F1-426A-AED9-7373B31E448E} --> E:\Steam\SteamApps\common\Total War SHOGUN 2\Shogun2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Total War SHOGUN 2\Shogun2.exe|Name=Total War: SHOGUN 2| - Enabled - The Creative Assembly Ltd
{22194631-5066-4FE9-9640-E00470260120} --> E:\Steam\SteamApps\common\Total War SHOGUN 2\Shogun2.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Domain|Profile=Private|Profile=Public|App=E:\Steam\SteamApps\common\Total War SHOGUN 2\Shogun2.exe|Name=Total War: SHOGUN 2| - Enabled - The Creative Assembly Ltd
{379F9EF1-959D-45B9-9175-A32EE4E39161} --> C:\Program Files (x86)\BlueStacks\HD-Plus-Service.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|App=C:\Program Files (x86)\BlueStacks\HD-Plus-Service.exe|Name=BlueStacks Service| - Enabled - File not found
TCP Query User{7347BDCE-E796-498D-85FA-62DDB80A9D72}C:\program files\logitech gaming software\lcore.exe --> C:\program files\logitech gaming software\LCore.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|Profile=Public|App=C:\program files\logitech gaming software\lcore.exe|Name=Logitech Gaming Framework|Desc=Logitech Gaming Framework|Defer=User| - Enabled - Logitech Inc.
UDP Query User{C4FEBBB9-D8C8-4D15-BCAB-86C67FEF2211}C:\program files\logitech gaming software\lcore.exe --> C:\program files\logitech gaming software\LCore.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|Profile=Public|App=C:\program files\logitech gaming software\lcore.exe|Name=Logitech Gaming Framework|Desc=Logitech Gaming Framework|Defer=User| - Enabled - Logitech Inc.
TCP Query User{2143CF31-74D4-46F8-88C3-EEA86AF676BC}E:\program files (x86)\diablo iii\x64\diablo iii64.exe --> E:\program files (x86)\diablo iii\x64\diablo iii64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=E:\program files (x86)\diablo iii\x64\diablo iii64.exe|Name=Diablo III Retail|Desc=Diablo III Retail|Defer=User| - Enabled - Blizzard Entertainment
UDP Query User{EE52F9F5-1344-49BA-A37F-11CB8B3A7606}E:\program files (x86)\diablo iii\x64\diablo iii64.exe --> E:\program files (x86)\diablo iii\x64\diablo iii64.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=E:\program files (x86)\diablo iii\x64\diablo iii64.exe|Name=Diablo III Retail|Desc=Diablo III Retail|Defer=User| - Enabled - Blizzard Entertainment
{E45E0E9B-ED52-4C49-A70F-75A27CD504DB} --> C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|App=C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe|Name=BitTorrent (TCP-In)|Desc=Allow BitTorrent network traffic with Edge Traversal|Edge=TRUE| - Enabled - File not found
{FF92BA05-DAFB-4969-84E0-7B1664C1F369} --> C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|App=C:\Users\Mike\AppData\Roaming\BitTorrent\BitTorrent.exe|Name=BitTorrent (UDP-In)|Desc=Allow BitTorrent network traffic with Edge Traversal|Edge=TRUE| - Enabled - File not found
{804AF3DF-2C29-452F-9612-A6C410EF0274} --> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|LPort=5353|App=C:\Program Files (x86)\Google\Chrome\Application\chrome.exe|Name=Google Chrome (mDNS-In)|Desc=Inbound rule for Google Chrome to allow mDNS traffic.|EmbedCtxt=Google Chrome| - Enabled - Google Inc.
TCP Query User{5DCDA691-17AF-46BE-910B-2AA2A2310F7F}C:\programdata\battle.net\agent\agent.6082\agent.exe --> C:\programdata\Battle.net\Agent\agent.6082\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\programdata\battle.net\agent\agent.6082\agent.exe|Name=Blizzard Update Agent|Desc=Blizzard Update Agent|Defer=User| - Enabled - Blizzard Entertainment
UDP Query User{A078B926-203A-4710-B33C-57EB3B622823}C:\programdata\battle.net\agent\agent.6082\agent.exe --> C:\programdata\Battle.net\Agent\agent.6082\Agent.exe - v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=17|Profile=Private|App=C:\programdata\battle.net\agent\agent.6082\agent.exe|Name=Blizzard Update Agent|Desc=Blizzard Update Agent|Defer=User| - Enabled - Blizzard Entertainment
System User Name
Nothing
Scan MBR Rootkit
MBR OK!
I notice BitTorrent still has system information here despite having been uninstalled a while ago. I may be an odd-man out here but I don't usually torrent. My wife does, but she assured me she's been doing so only on her laptop, which I now doubt.
SysNative
Thu 03/08/2018 15:01:16.20 Begin Logging
v4.6.0 compiled EXE
v4.6.0 compiled EXE
v4.6.0 compiled EXE
v4.6.0 compiled EXE
Thu 03/08/2018 15:01:16.21 Finished set commands - error level - 0
Thu 03/08/2018 15:01:16.21 Changed the title of the screen - error level - 0
Thu 03/08/2018 15:01:16.23 Did a PushD to HomeDrive:HomePath\Document- error level - 0
Thu 03/08/2018 15:01:16.23 Checked for existance of TSE Sub-Dir - error level - 0
Thu 03/08/2018 15:01:16.23 Created user Dir - error level - 0
Thu 03/08/2018 15:01:16.26 Copying mini-kernel dump files - error level - 0
Thu 03/08/2018 15:01:16.29 Copying mini-kernel dump files Done - error level - 1
* * * B S O D F I L E C O L L E C T I O N S C R I P T * * *
Authors:
jcgriff2 - J. C. Griffith, Microsoft MVP
TheOutcaste - Jerry Wines, Microsoft MVP
Patrick - Patrick Barker, Microsoft MVP
niemiro - Richard
Tekno Venus - Stephen
© http://www.sysnative.com/
© sysnative.com - MVP
© 2008 - 2014 sysnative.com
Last Update: July 2014
New Jersey, USA; Oregon, USA; New York, USA
ALL RIGHTS RESERVED
Thu 03/08/2018 15:01:11.62 ----- Actual Start execution time
B E G I N jcgriff2 B A T C H E X E C U T I O N
Thu 03/08/2018 15:01:16.31
Original home drive = C:
home path = \Users\Mike
current directory = C:\Users\Mike\Documents
Thu 03/08/2018 15:01:16.32 Running WHOAMI command - error level - 1
ALL user SIDs ------
USER INFORMATION
User Name SID
mike-pc\mike S-1-5-21-491581378-2402689455-2613464800-1000
GROUP INFORMATION
Group Name Type SID Attributes
Everyone Well-known group S-1-1-0 Mandatory group, Enabled by default, Enabled group
NT AUTHORITY\Local account and member of Administrators group Well-known group S-1-5-114 Mandatory group, Enabled by default, Enabled group
Mike-PC\HomeUsers Alias S-1-5-21-491581378-2402689455-2613464800-1001 Mandatory group, Enabled by default, Enabled group
BUILTIN\Administrators Alias S-1-5-32-544 Mandatory group, Enabled by default, Enabled group, Group owner
BUILTIN\Users Alias S-1-5-32-545 Mandatory group, Enabled by default, Enabled group
NT AUTHORITY\INTERACTIVE Well-known group S-1-5-4 Mandatory group, Enabled by default, Enabled group
CONSOLE LOGON Well-known group S-1-2-1 Mandatory group, Enabled by default, Enabled group
NT AUTHORITY\Authenticated Users Well-known group S-1-5-11 Mandatory group, Enabled by default, Enabled group
NT AUTHORITY\This Organization Well-known group S-1-5-15 Mandatory group, Enabled by default, Enabled group
NT AUTHORITY\Local account Well-known group S-1-5-113 Mandatory group, Enabled by default, Enabled group
LOCAL Well-known group S-1-2-0 Mandatory group, Enabled by default, Enabled group
NT AUTHORITY\NTLM Authentication Well-known group S-1-5-64-10 Mandatory group, Enabled by default, Enabled group
Mandatory Label\High Mandatory Level Label S-1-16-12288 Mandatory group, Enabled by default, Enabled group
PRIVILEGES INFORMATION
Privilege Name Description State
SeIncreaseQuotaPrivilege Adjust memory quotas for a process Disabled
SeSecurityPrivilege Manage auditing and security log Disabled
SeTakeOwnershipPrivilege Take ownership of files or other objects Disabled
SeLoadDriverPrivilege Load and unload device drivers Disabled
SeSystemProfilePrivilege Profile system performance Disabled
SeSystemtimePrivilege Change the system time Disabled
SeProfileSingleProcessPrivilege Profile single process Disabled
SeIncreaseBasePriorityPrivilege Increase scheduling priority Disabled
SeCreatePagefilePrivilege Create a pagefile Disabled
SeBackupPrivilege Back up files and directories Disabled
SeRestorePrivilege Restore files and directories Disabled
SeShutdownPrivilege Shut down the system Disabled
SeDebugPrivilege Debug programs Disabled
SeSystemEnvironmentPrivilege Modify firmware environment values Disabled
SeChangeNotifyPrivilege Bypass traverse checking Enabled
SeRemoteShutdownPrivilege Force shutdown from a remote system Disabled
SeUndockPrivilege Remove computer from docking station Disabled
SeManageVolumePrivilege Perform volume maintenance tasks Disabled
SeImpersonatePrivilege Impersonate a client after authentication Enabled
SeCreateGlobalPrivilege Create global objects Enabled
SeIncreaseWorkingSetPrivilege Increase a process working set Disabled
SeTimeZonePrivilege Change the time zone Disabled
SeCreateSymbolicLinkPrivilege Create symbolic links Disabled
Thu 03/08/2018 15:01:16.37 WHOAMI Command Done - error level - 1
Get basic system information . . .
Number of processors . . . . 8
PC Brand . . . . . . . . . .
Platform . . . . . . . . . .
Processor Architecture . . . AMD64
Processor Identifier . . . . AMD64 Family 21 Model 2 Stepping 0, AuthenticAMD
Processor Level. . . . . . . 21
Processor Revision . . . . . 0200
Operating system . . . . . . Windows_NT
Windows Dir. . . . . . . . . C:\Windows
User Profile Dir . . . . . . C:\Users\Mike
Thu 03/08/2018 15:01:16.38 Starting msinfo32 - save in NFO format
Thu 03/08/2018 15:01:16.40 msinfo32 Started - error level - 0
Thu 03/08/2018 15:01:16.42 Starting dxdiag
Thu 03/08/2018 15:01:16.42 dxdiag Started - error level - -
Thu 03/08/2018 15:01:16.43 Copy Hosts File
Thu 03/08/2018 15:01:16.43 Copy Hosts File Done - error level - 1
Thu 03/08/2018 15:01:16.45 Starting Driver Query #1
Thu 03/08/2018 15:01:16.46 Driver Query #1 Started - error level - 1
Thu 03/08/2018 15:01:16.48 Starting Driver Query #2
Thu 03/08/2018 15:01:16.48 Driver Query #2 Started - error level - 1
Thu 03/08/2018 15:01:16.49 Starting Driver Query #3
Thu 03/08/2018 15:01:16.51 Driver Query #3 Started - error level - 1
D R I V E R Q U E R Y E N D
Thu 03/08/2018 15:01:16.52 Starting Event Viewer log dump - apps
Thu 03/08/2018 15:01:16.54 Event Viewer log dump - apps - Started - error level - 1
Thu 03/08/2018 15:01:16.56 Starting Event Viewer log dump - System
Thu 03/08/2018 15:01:16.57 Event Viewer log dump - System - Started - error level - 1
Thu 03/08/2018 15:01:16.59 Starting TRACERT and IPCONFIG
Thu 03/08/2018 15:01:16.60 TRACERT Started - error level - 1
Thu 03/08/2018 15:01:16.71 Running IPCONFIG Done - error level - 0
Thu 03/08/2018 15:01:16.73 Starting SystemInfo
Thu 03/08/2018 15:01:16.75 SystemInfo Started - error level - 0
Thu 03/08/2018 15:01:16.75 Starting SysInfo e-mail removing vbs script
Thu 03/08/2018 15:01:16.78 Export current variables Done - error level - 0
Thu 03/08/2018 15:01:16.78 Starting WHERE *.sys Command
Thu 03/08/2018 15:01:17.18 NETSH Commands Done - error level - 1
Thu 03/08/2018 15:01:17.20 Running NETSTAT Command
Thu 03/08/2018 15:01:22.46 NETSTAT Command Done - error level - 0
Thu 03/08/2018 15:01:22.46 Obtaining Windows Error Reporting information
Thu 03/08/2018 15:01:22.69 Windows Error Reporting Done - error level - 0
Thu 03/08/2018 15:01:22.69 Running Windows Management Instrumentation
Thu 03/08/2018 15:01:23.82 Windows Management Instrumentation Done - error level - 0
Thu 03/08/2018 15:01:23.82 Listing running Tasks
Thu 03/08/2018 15:01:24.49 Running executing Tasks Listing . . . DONE
Issue cd cmd - Where are we? . . .
Thu 03/08/2018 15:01:24.51 cd command issued - error level - 0
Thu 03/08/2018 15:01:24.51 Downloading and executing autorunsc.exe. . .
Thu 03/08/2018 15:01:41.42 Downloading and executing autorunsc.exe. . . DONE
Thu 03/08/2018 15:01:41.42 Copy dumps - 2nd time
Thu 03/08/2018 15:01:41.43 Copy dumps - 2nd time . . . Done - error level - 0
Thu 03/08/2018 15:01:41.43 Begin registry dump - program un-install strings in case needed
Thu 03/08/2018 15:01:45.36 Regquery 1 . . . D O N E - error level - 0
Thu 03/08/2018 15:01:45.38 Regquery 2 . . . D O N E - error level - 0
Thu 03/08/2018 15:01:45.44 Regquery 3 . . . D O N E - error level - 0
Volume in drive C has no label.
Volume Serial Number is 7E36-2F37
Directory of C:\Users\Mike\Documents\SysnativeFileCollectionApp
03/08/2018 03:01 PM <DIR> .
03/08/2018 03:01 PM <DIR> ..
01/18/2018 02:18 AM 288,449 011818-18813-01.dmp
01/31/2018 08:37 AM 288,449 013118-15615-01.dmp
02/04/2018 02:02 AM 288,449 020418-11138-01.dmp
02/28/2018 10:38 PM 289,161 022818-18064-01.dmp
02/28/2018 06:25 PM 288,649 022818-21044-01.dmp
03/03/2018 12:46 AM 289,161 030318-18002-01.dmp
03/08/2018 03:01 PM 2 Autoruns.txt
03/08/2018 03:01 PM 36,583 DriverqFo.txt
03/08/2018 03:01 PM 13,367 DriverqSi.txt
03/08/2018 03:01 PM 62,710 DriverqV.txt
03/08/2018 03:01 PM 20,212 DxDiagx86.txt
03/08/2018 03:01 PM 9,780,788 EvtxAppDump.txt
03/08/2018 03:01 PM 12,146,964 EvtxSysDump.txt
03/08/2018 03:01 PM 738 HKCUSoftMSWinCVUninstall.txt
03/08/2018 03:01 PM 10,959 HKLMSoftMSA-SInstalledComponents.txt
03/08/2018 03:01 PM 56,073 HKLMSoftMSWinCVUninstall.txt
03/08/2018 03:01 PM 5,207 IPconfigAll.txt
03/08/2018 03:01 PM 10,925 Jcgriff2Log.txt
03/08/2018 03:01 PM 1,428 KernelDumpList.txt
03/08/2018 03:01 PM 4,256 NetSHLAN1.txt
03/08/2018 03:01 PM 19,795 NetstatJcgriff2
03/08/2018 03:01 PM 0 NetstatJcgriff2.StdErr
03/08/2018 03:01 PM 10,268 RAMInfo.html
03/08/2018 03:01 PM 3,590 SetEnvironmentVar.txt
03/08/2018 03:01 PM 101,388 SysList.txt
03/08/2018 03:01 PM 0 SystemInfo1.txt
03/08/2018 03:01 PM 141,372 TasklistSVCHOST.txt
03/08/2018 03:01 PM 480 Tracert.txt
03/08/2018 03:01 PM 85,350 WERALL.txt
03/08/2018 03:01 PM 5,452 WERLocalAppData
03/08/2018 03:01 PM 120,628 WERProgramData
03/08/2018 03:01 PM 1,340 WMICRecoveros.txt
32 File(s) 24,372,193 bytes
2 Dir(s) 38,606,733,312 bytes free
Thu 03/08/2018 15:01:45.44 Dir command . . . Done - error level - 0
Thu 03/08/2018 15:01:45.44 -- E O J - End of Job . . .
Thu 03/08/2018 15:01:45.45 -- E O J - End of Job . . .
Authors:
niemiro - Richard
ALL RIGHTS RESERVED
Thu 03/08/2018 15:01:45.49 -- E O J - End of Job . . .
Thu 03/08/2018 15:03:05.90 All
Sorry for the huge delay, life and stuff... I am having a look now.
