Can you try your GPU in the second slot, see how that goes? Try with one stick ram at a time if no dice on secondary PCI slot
I can try that tomorrow. My GPU wont fit while its still in the case. I've tried rotating individual sticks in A2 already and it persisted.Can you try your GPU in the second slot, see how that goes? Try with one stick ram at a time if no dice on secondary PCI slot
It still happens when I connect directly to integrated graphics. Along with info from RAM testing, it must be CPU or mobo right?Sounds good, off chance but could be a faulty slot...
I've also tried gsync and vsync. It reduces the tearing slightly, but doesnt remove the jitter effectHow to Set Up Nvidia G-Sync for Smooth, Tear-Free PC Gaming
By synchronizing your monitor's refresh rate to your graphics card, the monitor can draw a new frame whenever it's ready, without introducing stutters, screen tearing, or latency.www.pcmag.com
What exactly do you mean here? You turned gsync on and it improved or off and it improved?I've also tried gsync and vsync. It reduces the tearing slightly, but doesnt remove the jitter effect
I specifically tested Vsync and it improved the obvious tearing, but not completely. I've definitely tried with Gsync and it doesn't improve much. My monitor is a Samsung Odyssey G7. Its got FreeSync that can be toggled in the monitor settings. It's 240Hz. I'll take some slow motion videos of each behavior and add then to the Google Drive.What exactly do you mean here? You turned gsync on and it improved or off and it improved?
Are both Gsync and Vsync in the driver turned off or on? Result for each. Test with G/Vsync on and G/Vsync off and visa versa.
Is your monitor Gsync compatible? Is there a Gsync toggle within the monitor?
What is the refresh rate of the monitor? 60Hz?
https://drive.google.com/drive/folders/1Tbi8HphsnNvihrXvF_RsgTFxPN5tw0S-?usp=sharing Here are videos of each settingWhat exactly do you mean here? You turned gsync on and it improved or off and it improved?
I know it looks like it, but I don't think it is. It happened on this monitor, and another. with both GPU and iGPU. It happens outside of games as well. It also happens in Safe Mode.It definitely looks like refresh rate issues.
Turn all V/Gsync off in the driver, on the monitor, and in the game setting if applicable.
Then turn the driver G/Vsync on, test.
Turn driver G/Vsync off.
Turn Monitor G/Vsync on test.
Monitor G/Vsync off
Repeat in game settings on/off Matter of fact, check the in-game settings for other causation as well.
DELL S2721DGF (1440x2560@165Hz)
LC32G7xT (2560x1440@240Hz)
I've tried these steps as part of my testing already, but I just went ahead and tried them again in your order with a reboot. No luck. The other day, I disconnected all SATA drives and tried too. Same thing.Varying refresh rates is known to cause issues- try with just one monitor and if that doesn't work continue to my list below:
This is my laundry list, it's a good starting point for troubleshooting and should get you an idea what's going on, none of these should impact a warranty claim:
1. Try running the following programs, also try to keep at least 25-30% of your disks as free space.
Run Disk Cleanup (check all the boxes) this will delete things such as your recycling bin, so make sure you don't have any files you want to keep.
Run Defragment and Optimize Drives, run this on your drives.
These will free up some space, but you may need to relocate/delete files to reach the suggested free space.
2. Disable any overclocking or changes to power/performance settings
Undo any overclocking you may have done (if any)
Settings > System > Power and sleep > Additional power settings
Make sure your power plan is set to balanced, high performance/ultimate performance is only beneficial on gaming laptops where it needs that extra boost.
3. Check for Operating System Corruption
Right click on the Windows logo in the bottom left and select Windows Powershell (Admin)
Run these three commands separately:
sfc /scannow
Dism /Online /Cleanup-Image /CheckHealth
Dism /Online /Cleanup-Image /RestoreHealth
These will take a while to run, do not close out of Powershell while they are running, if one fails then move onto the next and then loop back around.
Note: It doesn't hurt to make a system backup before you make all these changes, save any important files of folders. While these changes shouldn't cause any issues, better to be safe than sorry.
4. Unplug unnecessary devices.
If you have a gamepad, extra monitor, external hard drive/flash drive, or anything that is not essential to using the computer plugged in, unplug it.
Once you have completed all of these tasks, restart it (using the restart option in the power menu) and re-test.
Thank you for your responses so far.There is a new BIOS version, while I doubt it to fix the issue it might be worth doing anyway.
Can you give me a bit more context on when the issue started? Has it been a problem since you got the computer?
Is this a custom build, if so when- if not who built it and when?
Was anything changed before the issue started, when did it start if not immediately?
Does it happen constantly or is there a time it is most common?
