Help
j_black215
43
I need this for school and I am out of options. I broke this computer down and meticulously cleaned the fans and vents, as well as changed the thermal paste. Still the fan begin to run crazy as if systems overheating and then just freezes and I have to power off and back on. Same thing everytime. I checked the CPU temp and they are good as well as RAM and HDD. So what is this, a bad board?
Thanx
You have checked the temps and the ram and hdd.
So does the computer start and log to windows?
If yes
Can you Download and run and then post. https://www.ccleaner.com/speccy/download
To publish a Speccy profile to the Web:​
In Speccy, click File, and then click Publish Snapshot.​
Speccy publishes the profile and displays a second Publish Snapshot dialog box. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.
The last part of each URL is randomized, so only people you provide with the URL will be able to find your profile.
The information given in Speccy cannot be used by anyone to hack your system
Could you also include the power supply specs E.g Cooler Master 850W Gold V2 NOT E.g 850w
If it does not boot to windows
Make and model of the Motherboard at least.
