Solved distributedcom 10016
does this look like a psu issue? do i need a new one?
or could my vid card have been damaged from the low power and all the crashes?
and is there a certain reason that diablo 4 would be the only game to cause the crash?
Looks like maybe the power supply was an issue, my pc is dead.
was storming last night so I shut it down to be safe, last week power went out twice and screwed the pc.
turned the pc on this morning just fine, took a shower and when I came out the pc was completely off, no lights on the keyboard\mouse or in the pc at all
Unplugged it and waited a bit and tried again, nothing lights up or starts
Looks like what happened when my other psu died like 7months ago
I'm really hoping it's just the psu and nothing else
If you had to get a top tier 1000w psu for a gaming pc what brand would you suggest?
I know 1000w is overkill for my current pc but I would want it for the next pc upgrade, the next pc will be a good one
I'm sorry if all the power supply questions seemed like i was doubting you guys or anything like that, I hope it didn't come across as unappreciative or disrespectful to you or phill
i can get the 850w version way faster, the 850 should be more than enough for my system right?
an EVGA G5 850w - it's a Tier B on Cultists, is 80+ Gold, 10yr warranty, has all the over and under protections.
and the RTX3050 card recommends 550w overall system power.
looks good. (y)
i went with the evga g6 850w, it was in the a tier list, hopefully i was reading it right
will be here thurs
really hope the vid card didnt get damaged during all this
thank you guys so much for the help
if you guys need to close it thats ok, nothing to do until i get the psu and see what happens
thanks again so much to you and peter and phill for all the help, i really appreciate it
Reactions: phillpower2
i woke up this morning and the pc was completely off, not sure if that kind of crash matters, usually when it crashes it will load back into windows, this time it was just off like it was shutdown.
i attached the mini tool box log to this message to see if there are any issues that might need the post to be reopened or if it was just random.
only changes made to the pc was i upgraded to windows 11 on thurs or fri
thanks for the help.
Sorry for the delay. The reopen request got missed at first.
A couple of errors.
Is everything running ok?
Nvida - GPU has errors.
And windows update.
Can you run windows update manually and see that it works.
sorry i didnt notice this got opened, never got an alert showing.
everything has been good since the crash, the power had gone out again so i dont think there was an actual issue. in the past five years the power might have gone out once and the past couple weeks it went out three times.
checked windows update and its fine
are the errors with the video card anything serious?
i can post another mtb if that will help
here is a mtb log from just now.
if there are still gpu errors does it look like something serious?
everything has been running perfect since the new power supply
thinking about trying d4 or another game soon so well see if that still crashes
all is good for now if you need to close this, thanks so much for all the help
Reactions: PeterOz
