Solved distributedcom 10016
ok thanks, i will try the restore.
i will try it tomorrow thursday.
tonight storms came in and took out the power twice and the second time it was out for a couple hours, dont want to risk anything.
is there anything special i need to do for the restore or just run it?
it errored and crashed during the restore
wouldnt boot back into windows
its attempting an automatic repair right now
the automatic repair worked and i am back in windows.
havent tried anything yet
a few minutes into windows and the pc crashed
might be doing the random crashes again
just have the pc shutdown for now, dont want to risk it crashing and doing any damage
im not sure, if its something i had to do myself then no i dont have one.
at this point i dont even care about diablo anymore, or even other games right now
i feel bad like im just wasting your time
i just want to watch tv and movies without the random crashes
i dont mind having to reinstall windows again and do what i did before, it was good after that, no random crashes
not a problem.
at this point i dont even care about diablo anymore, or even other games right now i just want to watch tv and movies without the random crashes
Hopefully you can do tv and games.
List Installed Programs
List Devices (Only Problems)
Click on Go.
Post the resulting log in your next reply for us as an attachment
pc wont even load into windows
shows mobo screen then goes black with the loading wheel animation thing and then stays black
might need to reinstall windows
reinstalled windows
went with latest drivers from a couple days ago
not even going to bother downloading any games
lets see how this goes
thanks so much for your help.
i just need a break from being sick of the pc probs, even the last week while it was ok i was still just nervous waiting for it to crash every time i click something
been ok for 10 hrs now, well see how it goes tomorrow
i can easily go without a game but cant go without tv
since the prob started my pc has prob crashed 50 times, im afraid its going to break and then im royally screwed
i will download the mtb incase anything happens
thanks again, i really appreciate it
i will report back tomorrow either way so we can fix something or so you can close the thread
thanks again i really appreciate you guys
What you need to think about is either you re install windows when a problem happens - normally after a windows update
or a driver update.
So if you have an external drive you can make a system image of where you have it all working correctly.
Then with an issue you restore the system image.
Each time you add a new program you make a new image.
You can have more then 1 system image.
i might do that if problems persist
been a full day and so far so good
if you guys need to close the post its ok by me
hopefully i wont have to bother you guys for a while
does this problem still look like a driver or software problem? not sure why it would have crashed on the restore
thanks so much again i really appreciate your help
Reactions: xrobwx71
