Solved distributedcom 10016
thanks again for reopening this. i hope i didnt jump the gun too early and have it opened for nothing.
everything was fine for the last week and then friday it crashed once. the only change that happened to the pc was i installed vlc media player earlier in the day.
its been a little over 24hrs since the crash and no further problems.
i will attach the mtb log
ETW Provider Security and has not granted enable permissions to the Event Log service identity
Try this fix for above error https://p0w3rsh3ll.wordpress.com/2017/03/20/etw-provider-security-fix-event-id-30/
Steam is also causing problems.
This could be a corrupted steam install or a corrupt windows install.
Step 1. Type cmd in the search box, and then right-click Command Prompt and select Run as administrator. Then click on Yes to access CMD with admin rights.
Step 2. Type the sfc /scannow command in the elevated command prompt and hit Enter. After that, the tool will scan and try to repair the corrupted system files automatically.
Step 3. If the SFC command was unable to repair corrupt system files, you can try running the following DISM commands:
  • DISM /Online /Cleanup-Image /CheckHealth
  • DISM /Online /Cleanup-Image /ScanHealth
  • DISM /Online /Cleanup-Image /RestoreHealth
Step 4 Run windows update.
Try the above steps first. From Here
should i wait to see if the pc crashes again before trying these?
if it was just like a one time random crash and its going fine now im kind of afraid im just going to cause more problems
how can windows keep getting so corrupt? i made a fresh install usb , no clue why all these things could be happening
thanks so much for the help, if it happens again ill try the steps you listed
if it does crash again do you need another mtb log or just do those fixes?
and do i try the etw fix first and then the scan stuff
or do i try the steps first from the last link you posted after run windows update
it says windows is activated with a digital license when i check
i have a legit key that i used during install
checked windows update and its up to date
Open a command prompt or PowerShell and type the following and post a screen shot of the results.
slmgr /xpr
Post a new speccy report.
Your ps does not have much wiggle room.
The gpu alone needs 550w and you only have 600.
If you uninstall steam and discord for testing how does it run.
wasnt that a typo on their site?
everything i look at says it takes like 130w for the rtx 3050
and the pc has always run perfectly, even now its fast and snappy, everything opens fast and runs great, its only diablo 4 that causes any problems
if my power supply was too low wouldnt that have caused problems on day 1 when i was playing games and watching streams at the same time and all that stuff?
i did install the latest graphics card driver last week when i reinstalled windows, i went with the latest one since i didnt plan on installing any games, and after you solved the problem last time the latest driver worked on everything except diablo 4. so the latest driver should be fine for streaming tv
the crash looks like it might have been just a one off, its been like 53 hours since it happened and no more issues
its just really so fishy
everything was perfect for 3 weeks, playing a bunch of different games using a few different game launchers, even the diablo 4 beta was perfect
then the full release of diablo 4 comes out and then all hell breaks loose on the pc.
then diablo 4 ran fine for a week then crashed again, just really weird why only diablo 4 is giving problems
for now everything seems to be ok so if you feel that this needs to be closed again then i think it might be time.
i feel bad for brining you guys back in and it was kind of for nothing.
i really appreciate your help again, im sure i will be back to haunt your dreams
No, things can appear to fine but while the hardware is not getting the required clean and stable power that it needs the hardware is being damaged and the GPU being the most power hungry tends to suffer first and the most, the brand of PSU also has a lot to do with it and Thermaltake are not a brand that I would ever use, the PSU in use here is only rated as – Tier C • Low-end something which this PC is not.
