Hi guys, I built my first custom PC back in August 2017 with the following specs:
Then I decided to upgrade my PC on Black Friday 2019 with the following changes:
Before the Black Friday upgrade my RAM was running at stock speed as I attempted to overclock using the built in XMP profile but couldn't get it to work so I let it go, I am since using the built in Game Boost and XMP settings and I believe my RAM is running at advertised speed (although I can't be sure as my task manager has decided to stop showing RAM speed, but some benchmark software has shown it at advertised speed).
Here's a benchmark I just ran https://www.userbenchmark.com/UserRun/24597283
Any help or suggestions would be appreciated and I'm willing to run any tests or give any extra info you need
- AMD Ryzen 5 1600 (14nm) 3.2 GHz 6-Core Processor
- Gigabyte GA-AB350-GAMING 3 ATX AM4 Motherboard
- Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
- PNY CS1311 120 GB 2.5" Solid State Drive
- Seagate Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
- Palit GeForce GTX 1070 8 GB GameRock Video Card
- Fractal Design Define R4 ATX Mid Tower Case
- Corsair CX 500 W 80+ Bronze Certified Semi-modular ATX Power Supply
- AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor for the Ryzen 5 1600
- MSI B450 TOMAHAWK MAX ATX AM4 Motherboard for the Gigabyte board
- MSI GeForce RTX 2070 SUPER 8 GB VENTUS OC Video Card for the 1070
