Computer help
Yes, I think we were successful. still on Mac though. "library" folder taking FOREVER and I don't think it is stuff I need. Maybe cancel the transfer so I can try on my other computer? what is with this library folder?
operating files etc.
I have to go out for a couple of hours.
Let me know if you can read the data and i will post next steps.
You should only try and copy stuff you need
Docs Videos Pics etc
I think you did it! can we follow-up in a few days or this weekend? I have some lingering questions but I think you got the important thing done. I am mentally drained. talk soon, I owe you. will PM you
Hey guys! I no longer get email notification there is a message here. It did at the start and then stopped. That's why I did not know you were closing thread. Not sure why it stopped. but yes I got the files!
1) Peter OZ did you get my IM?
2) is there any reason, nostalgic reason, anything I would not know, why I should not just put Ubuntu on my Mac now since not supported for years? If I ever wanted to MacOs back, does that stuff live on forever in a download on the internet? Wouldn't I maximize useful life even more by putting Ubuntu on it?
3) is there a streamlined way to backup files on this New SSD so I don't keep saving duplicates or forget to save stuff? or just manually save stuff to computer and then always have this drive handy to put copy on? seems tedious
4) off topic, can I ask another question, on my new computer...it was supposed to have windows but I put Ubuntu on it. My new computer is supposed to have Bluetooth but in the Ubuntu OS I am not able to turn Bluetooth on like it doesn't exist? I will post link to my new computer. What do you think of the specs of my new computer? any good? doesn't all the stuff get made in the same factories? should I not have bought this cheaper brand?
I paid $349, looks like it is already lower price $319 (angry face won't save? )
Top right hand of the screen click on your name
Click on preferences
Check email settings under Content Options.
Automatically watch content you create…
and receive email notifications
Or you can turn on Push notifications. This will slide in a window to show you have a reply.
I have replied.
Ubuntu should run fine. Boot again with ubuntu and use the try again and give it a spin.
It might be a little bit slower as you are running it from a usb, but at least you can test that everything is running as you like and
everything works.
Not on the Apple store.
You could either fix the current install and install Ubuntu as a dual boot.
You could fix the current install and then clone the image or make a time machine image and use that to return to Mac.
If you purely return to Mac you can use Time Machine.
If you run Ubuntu it has a backup program
OR
You can just use a sync program.
Ubuntu may not have a driver for that computer.
You need to backup to more than 1 drive if your stuff is important to you.
Just thought of another idea if you want a fall back to mac after ubuntu.
Repair the current install so you can access the app store.
Then download High Sierra install dmg to a usb stick and keep it.
This stinks, I don't know what happened to my post the other day. I must not have uploaded it :(
It seems like I might want to fix the current Mac OS and sort of delete files and reset it. I never really understood what was wrong with it? It just kept forcing me to try to update it. I think last support for it was Circa 2018ish? so is there a way to freshen it up with the most up to date Mac OS it can handle?
Then it sounds like I can also run Ubuntu in a split fashion?
Is it true that with an old system like mine it might run more efficiently, or as good as it can be, with ubuntu over the MacOS?
Unless you have a need for Mac OS you are not going to get much use out of it.
It all depends on if you need OS or not. Is there anything you do that can only be done on a mac.
I am pretty sure that the last OS for you is High Sierra.
You will then need to start looking at 3rd party stuff as things like safari are not updated so web pages won't load properly.
It should run Ubuntu ok. Have you tried it from the usb?
The mac came with only 4gig of ram, have you added more?
You could also run Windows on it.
As mentioned before unless you need OS then you may as well just run Ubuntu or Windows.
I personally would not dual boot unless OS is needed.
Having said that there is no downfall to dual booting, but why do it if not needed.
Clear as mud?
Clear as mud?
I guess I was thinking just keep MacOs partly for nostalgia I suppose
It has always been my dream sort of to try to upgrade this Mac just to see if I can. I think mainly all I can do is the Ram? I am not sure there is much else? I still like this computer a lot. I think with a fresh start and more Ram I could still get lots of use on it.
I don't want to make them mad here. I guess they like to close threads? correct? Would you care if I just PM you as I have questions? I know I am going a bit slow as molasses here, but just to let you know, i had to take care of some job stuff this week and very specifically used files you helped me to recover!!! I really really appreciate. As I was sending files I was thinking about this forum in the back of my head!!! lol
Not allowed
You won't make anyone mad.
If we know you are coming back just ask and we will mark it pending.
Normally if there is no answer in 3-5 days we assume that the op has abandon the thread. It happens a lot.
You can upgrade the ram - super easy. I did have one with 20GB ram.
You can also update the hard drive to an SSD. Kind of easy.
I know of a video that shows how to do it BUT you have to really take your time and be really careful of the cables.
If you are happy with the normal boot time and how it runs then no need to go to SSD.
So do we all. We do understand.
Since you seem to have all your files do you want to try and get the Mac OS running?
If Safari gives problems with web pages you can always load Firefox as a browser.
If you want to go ahead with mac os let me know and we will check the hdd first and then try and get you going on High Sierra
Yes, I think I would like to get MacOS working again. I forget if High Sierra was the last I had? If that was the last most up to date one before support ended than I think I do have it.
I am thinking just RAM I looked up the max once, I thought it was about 8 or 12? Or 2 x 16? you would know more obviously
I am okay with boot times and a mechanical HD I think. What is the service life like on the mechanical HD? far beyond 10 years?
I always had Firefox, never really tried Safari.
I will try to find Ram and post link to see if correct one
I think there are 4 slots? But I feel like I am getting mixed messages on what I can get? I think 2 slots are filled with 4 in ea? Does this mean I buy 2 more 4's so I have a total of 16? Or do I get 4 x 8's and replace all for 32 total? I thought I looked into this yrs ago and I don't think it was capable of 32?
I found this, disregard above. This looks familiar to me:
Memory
4GB (two 2GB) of 1333MHz DDR3 memory Configurable to 16GB, only at the Apple Online Store.
From the first page of this thread, the serial number is A1312
I am confused with what came with it and what is max I can put in at this point!
I just found this:
Key points about A1312 Mac RAM:
  • Number of slots: 4
  • Maximum memory: 32GB
so it does look like 4 x 8's? does it have to be 1333 mhz or is 1600 mhz okay too?
Maximum RAM:
By default, 4 GB of RAM is installed as two 2 GB SO-DIMM modules. Two slots free.
*Officially, this model supports four 4 GB modules -- one in each slot for a maximum of 16 GB of memory. However, third-parties have discovered that it actually will support 32 GB of memory using four 8 GB modules.
In the US (and many other countries), site sponsor Other World Computing sells memory -- as well as other upgrades -- for this iMac.
Unless you are using photoshop or other intense programs 16GB should be enough.
You could try 2 x 8GB ram with the current 4GB giving you 20GB.
If it does not boot with the 20GB remove the 4GB and test.
Adding ram is simple.
I would not lay it on carpet
Insert ram
I suggest we check your disk first to make sure it is still good.
Remove the linux usb stick and start the mac holding
Command (⌘) and R.
Then follow this guide to check the disk.
https://support.apple.com/en-au/102611
If you get an ok about the drive.
Make sure you’re connected to the internet.
In the Recovery app, click Reinstall macOS , then click Continue.
Follow the on-screen instructions.
Important: When you’re asked to select a disk, select your current macOS disk (in most cases, it’s the only one available).
Reactions: mx_599
Insert ram
Command (⌘) and R.
I am kind of a hardcore internet surfer. Sometimes i have lots of tabs open and I don'[t like to close them!
I always thought you could sort of never have too much RAM? or that over abundance helps for less bottle necking
Shoot, Now I see a 1066 RAM. Then 1333 or the 1600. I will need to try to double check that before any ordering. It looked pretty easy to change RAM. I thought you had to like heat the glass edges and guitar pick it off or something major
anyway, I will do what you said about checking computer. I won't order RAM yet. I might not do it until weekend. It looked complicated.
