Problem with speed. Ram? Motherboard?
  • system
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Hello. I’m not exactly sure where to start.
    I have a pretty solid build with NVIDIA Geforce 1070 and SSD NVMe and an HDD.
    So I’ve been rendering after effects videos at a good speed, but today after effects became very slow at rendering. 3x slower than normal. Rendering a near 2H video took 3-4 hours…now it’s 9-15. That’s not normal. I already did everything with after effects that I could but nothing. Attached is the footage of HDD squeaking occasionally WHILE saving the video which doesn’t usually happen. The sounds stopped after some time though. My PC has also been beeping twice after startup. 1 normal beep and a second lower pitch one. Says it might be the ram issue but I did change the ram already. I have a strong suspicion it’s the motherboard or specifically the RAM slots because the weird behavior began with PC not detecting the second ram stick. The double beeping began after the ram issue. Now I can’t render videos as fast. Not sure what’s going on anymore.
    Thanks in advance, I’m exhausted from brainstorming. I want to get the exact same new motherboard.
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    [HEADING=3]Can you Download and run and then post. Speccy - Free Download
    To publish a Speccy profile to the Web:[/HEADING]
    [HEADING=3]In Speccy, click File, and then click Publish Snapshot.[/HEADING]
    Speccy publishes the profile and displays a second Publish Snapshot dialog box. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.
    The last part of each URL is randomized, so only people you provide with the URL will be able to find your profile.
    The information given in Speccy cannot be used by anyone to hack your system
    Could you also include the power supply specs E.g Cooler Master 850W Gold V2 NOT E.g 850w
    • PCProbs
      • Jun 2023
      • 5
      Have you tested the memory, SSD, or HDD?
      An Extended test with Windows built-in memory diagnostic might be a good place to start.
      • system
        PCHF Owner
        • 7695
        • CachyOS
        Originally posted by PeterOz
        [HEADING=3]Can you Download and run and then post. Speccy - Free Download [/HEADING]
        [HEADING=3]To publish a Speccy profile to the Web:[/HEADING]
        Hello, Thanks for the reply.
        Here’s the link: http://speccy.piriform.com/results/i...goQJbcl6hO2QfD
        and Power supply: Amazon.ca
        • system
          PCHF Owner
          • 7695
          • CachyOS
          Heya, thanks for the reply.
          Memory diagnostic came out clean and so did everything else. I tested the performance of the whole system via UserBenchmark and it’s mostly up to standards with the exception of video card and something else.
          • PeterOz
            • Mar 2021
            • 4181
            I notice you are using mismatched ram - Ram will run at the lowest speed stick.
            For testing
            are you able to uninstall java - can be re installed later or is it needed for your program?
            If you have the serial key can you uninstall
            Kaspersky Total Security Antivirus
            Also can you change the power from High performance to balanced.
            Test
            • PeterOz
              • Mar 2021
              • 4181
              Your power supply might be a bit on the low side.
              Is this your GPU
              Minimum ps 500W
              • system
                PCHF Owner
                • 7695
                • CachyOS
                Is this your GPU
                Minimum ps 500W
                That’s the GPU, yes.
                • system
                  PCHF Owner
                  • 7695
                  • CachyOS
                  For testing
                  Test
                  Should I remove one of the RAM brands then?
                  I need Java.
                  Kaspersky has been uninstalled for a year.
                  Changed to balanced power.
                  By ‘Test’, you mean you want me to send the new Speccy link?
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #10
                    Speccy shows Kaspersky still on computer. Test means try a render
                    Windows Defender
                    Windows Defender:
                    Disabled
                    Firewall
                    Firewall:
                    Enabled
                    Display Name:
                    Antivirus
                    Windows Defender
                    Antivirus:
                    Disabled
                    • PeterOz
                      • Mar 2021
                      • 4181
                      #11
                      Overview of settings and features available in a Kaspersky application and guides on how to use them.
                      • system
                        PCHF Owner
                        • 7695
                        • CachyOS
                        #12
                        Removed Kaspersky with the app. Wasn’t sure which “Total Security” to pick but I think I’ve done it.
                        And I removed one of the RAM brands
                        • system
                          PCHF Owner
                          • 7695
                          • CachyOS
                          #13
                          Seems the render MIGHT be a bit faster but just in case, you got any more recommendations? Also, I switched back to high performance, unless it’s worse?
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #14
                            Does the render need java?
                            If not can you uninstall to test - you can reinstall later.
                            High performance in power is for laptops with a dedicated GPU.
                            It can cause stability issues with desktop computers.
                            Are you rending to the NVME or to the HDD.
                            If to the HDD can you render one to the NVME as a test.
                            Was all the original ram the same specs?
                            • system
                              PCHF Owner
                              • 7695
                              • CachyOS
                              #15
                              I need java only for Minecraft but ok. I uninstalled it.
                              Changed back to balanced power.
                              I’m saving the render to HDD usually.
                              The other ram that I removed has speed of 34000, the one I use has 36000. Both brands are 32GB. 64GB combined.
                              Tested render to SSD from NVMe (OS). The footage I’m using is saved on HDD since it’s for storage.
                              Render runs at same speed it seems.
                              (I do have one other issue which I’ll look for myself later.
                              Essentially when I got the NVMe, I used the Samsung Magician software to transfer my OS to NVMe from SSD. However I lost full control over SSD and cannot delete system files from it nor can I render to SSD)
