WiFi Signal Strength Issues: Is it my Hardware?
  • Malnutrition
    PCHF Moderator
    • 7041
    #31
    I’ll have a look at these logs, just got home. Give me an hour or so, (y)
    • Malnutrition
      PCHF Moderator
      • 7041
      #32
      FRST Fix.
      Download attached fixlist.txt file and save it to the Desktop.
      NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work.
      Right Click Run FRST64 as admin; and press the Fix button just once and wait.
      If for some reason the tool needs a restart, please make sure you let the system restart normally.
      After that let the tool complete its run.
      When finished FRST will generate a log on the Desktop (Fixlog.txt).
      Please post it to your reply.
      There should also be a new .txt file on your desktop named:[COLOR=rgb(243, 121, 52)] Persistence_Sniper_Result.txt please attach that as well.
      ZHP Diag Scanner.
      Download ZHP Suite to your desktop.
      Right Click Run as admin.
      Hit the scanner button.
      Once it is complete a file name ZHPdiag.txt will be on your desktop.
      Attach it.
      Content of Fixlist.txt [MEDIA=pastebin]JUL2jbDg[/MEDIA][/COLOR]
      • Classy
        • Jan 2025
        • 17
        #33
        Originally posted by Malnutrition
        FRST Fix.
        ZHP Diag Scanner.
        Attach it.
        [/COLOR]
        Alrighty, it’ll be a moment before I can do this.
        Good news, got Ethernet and it’s super fast.. didn’t fix my original issue with WiFi performance but it fixes the base issue.
        Also.. this step is just getting needed files, or is it doing something?[/color]
        • Malnutrition
          PCHF Moderator
          • 7041
          #34
          It is cleaning up some redundant items, and performing a few task. So yes it is doing something, the fixlist.
          As far as ZHP diag scan it will list areas that FRST does not, and I will clean up trash files from that as well.
          • Malnutrition
            PCHF Moderator
            • 7041
            #35
            @Classy where are we at? Care to continue, and update would be appreciated.
            • Classy
              • Jan 2025
              • 17
              #36
              It may be a bit longer, currently working day in day out on a project I must hit deadline on.
              • Malnutrition
                PCHF Moderator
                • 7041
                #37
                Alright, that update is appreciated. (y)
                  #38
                  @Classy - do we have a rough timeline?
                    #39
                    Thread closed. If you need to re-open thread just contact a staff member,
