WiFi Signal Strength Issues: Is it my Hardware?
  • Classy
    • Jan 2025
    • 17
    #16
    Do you want me to pause it and test the speeds? Right now it’s working fine, so it’d be more of a.. pause it and see if it happens again.
    • Classy
      • Jan 2025
      • 17
      #17
      Originally posted by Malnutrition
      Yes, but that is fine, I need to work on this tool a bit.
      There should be a new .txt file named PCHF.txt if it works.
      Sorry, this is a tool i am working and i am working out bugs.,
      'll leave you with @PeterOz
      Last time if this does not work then use MiniToolbox.
      Please download MiniToolBox and save it to your desktop.
      Run the program by right clicking on it and selecting Run as administrator.
      When the program opens select the following boxes:
      Flush DNS
      Report IE Proxy Settings
      Reset IE Proxy Settings
      Report FF Proxy Settings
      Reset FF Proxy Settings
      List content of Hosts
      List IP Configuration
      List Winsock Entries
      List Installed Programs
      List Devices (Only Problems)
      Please post the log in your next reply
      • PeterOz
        PCHF Technical Response Team
        • Mar 2021
        • 4181
        #18
        Next time you notice a slow connection
        Pause onedrive
        test speed
        • Classy
          • Jan 2025
          • 17
          #19
          Pause onedrive
          test speed
          Alright, I also just posted the information asked for by Malnutrition. What do we do with that one?
          • Malnutrition
            PCHF Moderator
            • 7041
            #20
            [COLOR=rgb(243, 121, 52)]Percentage of memory in use: 80% that seems rather high, for 16 gigs of ram on windows 10 .
            [li]Opera: 2,148 MB[/li][li]Discord: 824 MB[/li][li]msedgewebview2: 312.21 MB[/li]Subtotal: 3,284.21 MB
            [/ul]
            System/Windows Processes:
            [li]explorer.exe: 200 MB[/li][li]dwm.exe: 71 MB[/li][li]svchost.exe: 600 MB[/li][li]MsMpEng.exe: 408 MB[/li][li]Other system processes: 100 MB[/li]Subtotal: 1,379 MB
            [/ul]
            Gaming/Streaming:
            [li]NVIDIA Broadcast: 243 MB[/li][li]Steam and steamwebhelper: 597 MB[/li][li]Gaming services: 33.68 MB[/li]Subtotal: 873.68 MB
            [/ul]
            Utilities:
            [li]Speedtest.exe: 187 MB[/li][li]SteelSeriesEngine: 73 MB[/li]Subtotal: 260 MB
            [/ul]
            Total Memory Usage: 5,796.89 MB (approximately 5.8 GB)
            We can check the machine for malware if you wish, when is that last time that was done?[/COLOR]
            • PeterOz
              • Mar 2021
              • 4181
              #21
              Just as an aside
              You are running low on disc space on drive c
              Partition 1
              Partition ID:
              Disk #1, Partition #1
              Disk Letter:
              C:
              File System:
              NTFS
              Volume Serial Number:
              F85F71D9
              Size:
              465 GB
              Used Space:
              403 GB (86%)
              Free Space:
              61 GB (14%)
              • Classy
                • Jan 2025
                • 17
                #22
                [/ul]
                [/ul]
                Gaming/Streaming:
                [/ul]
                Utilities:
                [/ul]
                Only checks I’ve ran recently were Windows Defender checks. That was 2 days ago
                • Malnutrition
                  PCHF Moderator
                  • 7041
                  #23
                  Care to check? That seems suspicious…
                  • Classy
                    • Jan 2025
                    • 17
                    #24
                    Just as an aside
                    Partition 1
                    Partition ID:
                    Disk Letter:
                    C:
                    File System:
                    NTFS
                    F85F71D9
                    Size:
                    465 GB
                    Used Space:
                    403 GB (86%)
                    Free Space:
                    61 GB (14%)
                    Yeah I typically free space if it ever hits red on the PC tab
                    • Malnutrition
                      PCHF Moderator
                      • 7041
                      #25
                      Please download FRST 64bit It is important FRST is downloaded to your desktop.
                      Once downloaded right click the FRST desktop icon and select “Run as administrator” from the menu
                      FRST will open with two dialogue boxes, accept the disclaimer.
                      [ol]
                      [li]Then select Scan[/li][li]Frst will take a few minutes to scan your computer, and when finished will produce two log files on your desktop, FRST.txt, and Addition.txt.[/li][li]They will display immediately on the desktop, attach those both in your next reply.[/li][/ol]
                      @Furtivex
                      • Classy
                        • Jan 2025
                        • 17
                        #26
                        If the resource usage shown also displays Palworld (which I have open in the background), and is still higher than should be.. wouldn’t hurt to check
                        • PeterOz
                          • Mar 2021
                          • 4181
                          #27
                          Your network card shows as this.
                          Which is normally a laptop card but can be used with a pc
                          • Malnutrition
                            PCHF Moderator
                            • 7041
                            #28
                            Yes, I will move this thread to the malware area, Run FRST, and post the logs. @Furtivex will assist further.
                            • Classy
                              • Jan 2025
                              • 17
                              #29
                              Is that bad?
                              • Classy
                                • Jan 2025
                                • 17
                                #30
