Originally posted by Malnutrition
BAse Filtering Engine Access Denied Error 5
[ATTACH type=“full”]9488[/ATTACH]Originally posted by Malnutrition[ATTACH type=“full” alt=“1649549203410.png”]9487[/ATTACH]
I’m sorry I have never used these programs so I may have a couple questions for each. But Is this dialogue box normal? Also absolutely EVERY box?Comment
It happens, no big deal.Originally posted by thiisnaccBut Is this dialogue box normal?
Just all the default items ticked under the option I sent to you in the screen shot.Originally posted by thiisnaccAlso absolutely EVERY box?Comment
Is there anything else I might need to check on or does that tool remove viruses/other vulnerabilities with the repair?Originally posted by MalnutritionIt happens, no big deal.
Just all the default items ticked under the option I sent to you in the screen shot.Comment
Your machine has no malware. I’ve seen that it does not with the logs we have ran thru. You can check the machine with the Kaspersky Virus Removal Tool if you wish.
Download KpRM
Save to Desktop
Check Delete Tools’
Delete Restore points
Create Restore point.
Then click run.
I’ll Mark this as solved for you.Comment
