[COLOR=rgb(184, 49, 47)]Make sure and save the fix attached below to your desktop.
Download Runx save it to your desktop.
Drag and drop FRST onto the RunX program.
Then run the fix below.
If that fails
Download Power Run
Unzip it to your desktop.
Open the folder.
Run power run x64
Click file … Add file.
Under file location paste the following.
Do not include the word code!!
[ICODE]C:\Users\User\Desktop\FRST64.exe[/ICODE]
Then when FRST is open, click fix.
FRST Fix.
Download attached fixlist.txt file and save it to the Desktop. NOTE. It’s important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply.[/COLOR]
If that fails
Download Power Run
Open the folder.
Run power run x64
FRST Fix.
